Текущее время: Чт, сен 24 2026, 16:49
 Заголовок сообщения: GETWA_NOT_ASSIGNED при выгрузке в EXCEL
СообщениеДобавлено: Пт, янв 30 2009, 12:22
Вт, окт 10 2006, 12:23
Здравствуйте!
после установки следующих пакетов обновлений
SAPKGPAC20
SAPKGPDC20
SAPKGPGC20
SAPKGPFC20
SAPKGPHC51
SAPKGPHC52
SAPKGPHC53
SAPKGPHC54
SAPKGPHC55
SAPKGPIC18
SAPKGPPC20
SAPKGPRC20
SAPKIPZI6I
SAPKIPYJ6H
SAPKIPYL07
SAPKA64023
SAPKH50020
SAPKB64023
SAPKW35023
SAPKE50051
SAPKE50052
SAPKE50053
SAPKE50054
SAPKE50055
SAPKITLQH8
SAPK-10623INCCEE
SAPK-10624INCCEE
SAPK-10625INCCEE
при выгрузке в EXCEL возникает динамическая ошибка
Динамическая ошибка GETWA_NOT_ASSIGNED
КрТекст
Field symbol has not yet been assigned.
Что произошло?
Error in ABAP application program.
The current ABAP program "CL_SALV_BS_TT_RESULT_TABLE====CP" had to be
terminated because one of the
statements could not be executed.
This is probably due to an error in the ABAP program.
Что Вы можете сделать?
Print out the error message (using the "Print" function)
and make a note of the actions and input that caused the
error.
To resolve the problem, contact your SAP system administrator.
You can use transaction ST22 (ABAP Dump Analysis) to view and administer
termination messages, especially those beyond their normal deletion
date.
is especially useful if you want to keep a particular message.
Анализ ошибки
You attempted to access an unassigned field symbol
(data segment 32781).
This error may occur for any of the following reasons:
- You address a typed field symbol before it is set using ASSIGN
- You address a field symbol that points to a line in an internal table
that has been deleted
- You address a field symbol that had previously been reset using
UNASSIGN, or that pointed to a local field that no longer exists
- You address a global function interface parameter, even
though the relevant function module is not active,
that is it is not in the list of active calls. You can get the list
of active calls from the this short dump.
Указания по устранению ошибки
You may able to find an interim solution to the problem
in the SAP note system. If you have access to the note system yourself,
use the following search criteria:
"GETWA_NOT_ASSIGNED" C
"CL_SALV_BS_TT_RESULT_TABLE====CP" or "CL_SALV_BS_TT_RESULT_TABLE====CM00L"
"GET_CELL_VALUE"
Пару нот поставил по этой ошибке, но результата нет.
Может кто номера нот даст по этой ошибке?
 Заголовок сообщения: Re: GETWA_NOT_ASSIGNED при выгрузке в EXCEL
СообщениеДобавлено: Пт, янв 30 2009, 12:28
Ср, ноя 17 2004, 18:38
Установить Note 1256200 - Web Dynpro ABAP ALV: Short dump during export to Excel или установить следующий базисный SP SAPKB64024
з.ы. Обязательно обратить внимание на строчку "Before you do this, refer to Note 875986 for information about transaction SNOTE." и удостоверится что все удовлетворяет условиям описанным в Note 875986.
СообщениеДобавлено: Пт, янв 30 2009, 13:08
Эта нота уже установлена. при установке ноты система попросила скачать ещё ноты зависимые (1258458, 1261151, 1275534). их тоже скачал и поставил.
Note Assistant у меня версии 1.2. т.к. пакет SAPKB64013 установлен.
СообщениеДобавлено: Ср, фев 04 2009, 15:37
Написал в SAP об этой ошибке. Откорректировали ноту 1275534. Теперь всё ок)
