Текущее время: Пт, сен 25 2026, 00:55
 Заголовок сообщения: Помогите плзз с установкой IDES 2005
СообщениеДобавлено: Чт, июн 11 2009, 21:13
Вт, дек 18 2007, 13:09
Решил поставить домой IDES на этапе Import ABAP возникает ошибка при импорте sapview. Вот логи
import.monitor.log
CONFIG: 2009-06-11 23:53:03
Application options:
dbCodepage=4103
dbType=ORA
extFiles=yes
importDirs=C:\sapinst2\EXP1;C:\sapinst4\EXP2;C:\sapinst5\EXP3;C:\sapinst6\EXP4;C:\sapinst3\EXP5;C:\sapinst3\EXP6;C:\sapinst3\EXP7;C:\sapinst3\EXP8;C:\sapinst3\EXP9;C:\sapinst3\EXP10;C:\sapinst3\EXP11
installDir=C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS
jobNum=3
loadArgs= -stop_on_error
monitorTimeout=30
orderBy=
r3loadExe=C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe
sapinst=
trace=all
tskFiles=yes
List of packages with table structure: 'SAP0000'.
List of packages with views: 'SAPVIEW'.
TRACE: 2009-06-11 23:53:03 com.sap.inst.migmon.imp.ImportStandardTask preCreate
Parse of 'C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL' template file is started.
INFO: 2009-06-11 23:53:03 com.sap.inst.migmon.imp.ImportStandardTask preCreate
Parse of 'C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL' template file is successfully completed.
Primary key creation: after load.
Index creation: after load.
INFO: 2009-06-11 23:53:04
Data codepage 4103 is determined using TOC file 'C:\sapinst2\EXP1\DATA\AGR_HIERT.TOC' for package 'AGR_HIERT'.
TRACE: 2009-06-11 23:53:04 com.sap.inst.migmon.LoadTask run
Loading of 'SAPVIEW' import package is started.
TRACE: 2009-06-11 23:53:04 com.sap.inst.migmon.LoadTask processPackage
Loading of 'SAPVIEW' import package into database:
C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe -i SAPVIEW.cmd -dbcodepage 4103 -l SAPVIEW.log -stop_on_error
ERROR: 2009-06-11 23:53:05 com.sap.inst.migmon.LoadTask run
Loading of 'SAPVIEW' import package is interrupted with R3load error.
Process 'C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe -i SAPVIEW.cmd -dbcodepage 4103 -l SAPVIEW.log -stop_on_error' exited with return code 2.
For mode details see 'SAPVIEW.log' file.
Standard error output:
sapparam: sapargv( argc, argv) has not been called.
sapparam(1c): No Profile used.
sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline
INFO: 2009-06-11 23:53:33
All import packages are processed.
WARNING: 2009-06-11 23:53:33
1 error(s) during processing of packages.
Import Monitor is stopped.
вот sapview.log
C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20090611233309
C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe: sccsid @(#) $Id: //bas/700_REL/src/R3ld/R3load/R3ldmain.c#6 $ SAP
C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe: version R7.00/V1.4 [UNICODE]
Compiled Apr  3 2006 00:41:09
DbSl Trace: ORA-1403 when accessing table SAPUSER
(DB) INFO: connected to DB
(DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8
(DB) ERROR: DDL statement failed
(DROP VIEW "/1SAP1/CNV_A0026")
DbSlExecute: rc = 103
  (SQL error 942)
  error message returned by DbSl:
ORA-00942: table or view does not exist
(IMP) INFO: a failed DROP attempt is not necessarily a problem
(CREATE VIEW "/1SAP1/CNV_A0026" ( "MANDT" , "BUKRS" , "J_1AARVKEY" , "J_1AABASEA"  ) AS SELECT T0001."MANDT", T0001."BUKRS", T0001."J_1AARVKEY", T0001."J_1AABASEA" FROM "J_1AAA2" T0001)
  (SQL error 942)
(DB) INFO: disconnected from DB
C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe: job finished with 1 error(s)
C:\usr\sap\DVL\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20090611233311
Гуру помогите абаперу :)
ЗЫ ставлю на Windows2003 R2 + Oracle 10.2.0.2
Скакал Иван-царевич 3 дня и 3 ночи.. и дальше бы скакал, только скакалку отобрали..
 Заголовок сообщения: Re: Помогите плзз с установкой IDES 2005
СообщениеДобавлено: Чт, июн 11 2009, 21:36
Сб, авг 21 2004, 14:24
(SQL error 942)
первая мысль, которая приходит в голову - импорт прошел не полностью. Ошибок не было случайно при импорте? Посмотрите все логи импорта.
СообщениеДобавлено: Чт, июн 11 2009, 22:39
Ср, июн 10 2009, 21:16
View создаются на самом последнем этапе импорта. Ищите резон отсутствия соответствующих таблиц БД. Скорее всего вы смонтировали не все DVD c исходными данными и не все пакеты типа SAPAPPL0, SAPAPPL1, SAPAPPL2, SAPSDIC, SAPCLUST, SAPUSER, SAPLSEXC, SAPPOOL, SAPSLOAD, SAPDDIM, SAPSPROT, SAPDFACT etc. были импортированы. Вернитесь в SAPINST и проверьте на все ли исходники вы правильно указали. САП нота 124584 может быть полезна.
Есть еще такая САП нота: 584613, но скорее всего она из другой оперы.
Последний раз редактировалось scherbina Сб, июн 13 2009, 00:30, всего редактировалось 2 раз(а).
СообщениеДобавлено: Чт, июн 11 2009, 22:57
найдите отличия - между моим ответом и Вашим?:)))))))))))))))))))
и я и Вы говорим, что скорее всего не прошел импорт...
ээээээээ или только с ссылками на страницу руководства Вы читаете ответы?:)
СообщениеДобавлено: Чт, июн 11 2009, 23:16
Этот затык произошел на Import ABAP (остальные пакеты установлены нормально 71 штука).
как я понял нота 124584 - применяется на уже установленной системе.
нашел ноту 709389 - в ней говориться про UTF кодировку STR файлов, но она неподходит (там вроде все тексты написаны корректно).
Единственное что хотел попробовать это вручную запустить R3Load для пакета sapview но незнаю как это сделать.( файл sapview.cmd вроде выполняемый но в запускаться не хочет) может его нада как-то по особому запускать?
СообщениеДобавлено: Чт, июн 11 2009, 23:20
Таблица J_1AAA2 в базе данных есть? Создается вьюха - на основе несуществующей судя по сообщениям оракла таблицы.
вот этот SQL не проходит. Надо искать где она импортируется в базу. МОжно нотку попытаться по имени таблицы поискать попытаться. Логи импорта точно все с нулевым кодом возврата?
СообщениеДобавлено: Сб, июн 13 2009, 10:22
Пн, фев 11 2008, 11:38
Так общие вопросы сначала : файл подкачки какого размера? версия J2SE (JRE,JDK) какая ? Oracle bundle патч ставили?(но и без него по идее должно установитсья). Кстати вы ноту то правильную нашли сами : 709389. Там что то про Important for IDES installations в конце
может это ваш случай, посмотрите что там интересного в readme file?
p.s > Если честно совсем не понял что вы имели в виду под :
Вы повнимательнее почитайте ноту ... там несколько причин возникновения таких ошибок , вам нужно точно определить STR файл.
СообщениеДобавлено: Пн, июн 15 2009, 13:14
файл подкачки 4096М
JDK - 1.4.2_17 x64
JRE - 1.5
Oracle bundle патч ставили - незнаю :(. поставил что было (oracle 10.0.2 потом поставил патч 10.0.2.0.2)
возможно повлияло каким-то образом то что установку прерывали 2 раза. Но с другой стороны при продолжении ошибок не было...
СообщениеДобавлено: Пн, июн 15 2009, 13:22
Ну файл подкачки конечно маленький, сделайте 20 ГБ. JDK 17 нормальный, значит остаётся читать ноту (читать read-me как они просят) а так же смотреть STR файлы.
Там как раз про прерывание что то написано в 4 пункте -->
for R3load version >= 6.10 only: because of some reason the load process of SAPXXX.STR has been hard terminated (Ctrl-C, power failure, OS or hardware crash, etc.). If so there should be SAPXXX.TSK.bck file written in the installation directory.
СообщениеДобавлено: Пн, июн 15 2009, 14:28
Пт, ноя 02 2007, 14:14
Доброго дня.
Небольшая ремарка по поводу J2SDK, у меня при использовании версий 1.4.2_13 - 1.4.2_17 возникали МНОГОЧИСЛЕННЫЕ проблемы как раз на этапе установки, так что рекомендую использовать версию 12 или последнюю доступную - 21, что рекомендовано нотой https://service.sap.com/sap/support/notes/716604
СообщениеДобавлено: Пн, июн 15 2009, 14:38
1.4.2_13 наиболее боевая версия из всех для X86_64, с ней и по Kerberos не было проблем, а с 17 b06 возможна проблема только с Kerberos, но никак не на этапе установки,а ихние рекомендации
на счёт 1.4.2_19, далее 20,21. меняются в последнее время часто, что не свидетельствует об их работоспособности , больше похоже что они тестируют. Лично ставил на 1.4.2_13 и 1.4.2_17 b06
x86_64 Windows, без проблем.
Да а версия 1.4.2_17 какая в вашем случае b -- чего там? Посмотрите java -version в командной строке, b07 не и выше не прокатит.
