Текущее время: Пт, сен 25 2026, 01:54
 Заголовок сообщения: signal 11
СообщениеДобавлено: Пн, июн 27 2011, 13:10
Пн, июн 27 2011, 12:47
Всем привет,
постоянно получаем ошибку в транзакции VA01, с последующим завершением сеанса.
Вывод SM21
Часть дампа из ST22:
Краткий текст
Process terminated by signal 11.
Что произошло?
Error in the SAP kernel.
The current ABAP "SAPMSSY0" program had to be terminated because the
ABAP processor detected an internal system error.
Анализ ошибки
An R/3 System process was terminated by an operating system signal.
Possible reasons for this are:
1. Internal system error.
2. Process was terminated externally (by the system administrator).
Last error logged in SAP kernel
Component............ "Taskhandler"
Place................ "**"
Version.............. 1
Error code........... 11
Error text........... "ThSigHandler: signal"
Description.......... " "
System call.......... " "
Module............... "thxxhead.c"
Line................. 10852
The error reported by the operating system is:
Error number..... " "
Error text....... " "
Информация о месте прерывания
Termination occurred in the ABAP program "SAPMSSY0" - in "SYSTEM-EXIT".
The main program was "SAPMV45A ".
In the source code you have the termination point in line 0
of the (Include) program " ".
| Main memory destroyed |
The error occurred because of a main memory overwrite. There may
be an internal error in the R/3 System.
The amount of memory occupied at the time of the termination was:
> Roll area......................... 0 bytes
> Extended memory area (EM)......... 0 bytes
> Fixed area........................ 0 bytes
> Short area........................ " " bytes
In the work directory of the SAP system (e.g. /usr/sap/C11/D00/work ),
there may be files called 'mm.dump' and 'mm.info'.
Save these files under other names.
В ST22 еще есть дампы такого вида:
Termination occurred in the ABAP program "SAPLSPO2" - in "SYSTEM-EXIT".
> Extended memory area (EM)......... 9007336695791648 bytes
OS - HP-UX
db - ORACLE
Версия базиса - 700
В чем может быть проблема?
Спасибо.
 Заголовок сообщения: Re: signal 11
СообщениеДобавлено: Пн, июн 27 2011, 13:26
Вт, июл 24 2007, 14:52
попробуйте обновить клиент оракла
ORACLE Client V5 10.2.0.4
DVD 51039412
СообщениеДобавлено: Пн, июн 27 2011, 13:36
Вт, ноя 23 2004, 10:40
Для начала проверьте параметры ядра ОС, скорей всего проблема в этом.
Потом можно пошерстить параметры инстанции, посмотреть в сторону патча ядра.
СообщениеДобавлено: Пн, июн 27 2011, 13:42
судя по оформлению вопроса человек в курсе про базовые моменты - параметры и обновление кернела
у меня просто была один в один ошибка
в системе обновил ядро, на базу накатил последние патчи и пошли процессы валиться по сигналу 11
нигде не написано, но обновление клиента оракла решило все проблемы
СообщениеДобавлено: Ср, июн 29 2011, 10:16
Пт, сен 07 2007, 15:58
Extended memory area (EM)......... 9007336695791648 bytes :P
8192 ТБ что ли.
Сигнал 11 - это когда ОС останавливает процесс из-за исчерпания виртуальной памяти.
