Текущее время: Чт, сен 24 2026, 08:42
 Заголовок сообщения: Ошибка: dipgntab.exe ERROR in initialization (can't get R/3-version)
СообщениеДобавлено: Пт, янв 20 2012, 11:05
Пн, фев 04 2008, 06:44
Помогите разобраться с ошибкой:
WARNING 2012-01-20 10:11:25
Execution of the command "C:\usr\sap\TXU\SYS\exe\nuc\NTI386\dipgntab.exe -rwr40 -srctt DDNTT -srctf DDNTF -dsttt DDNTT -dsttf DDNTF -ttonly TT" finished with return code -1. Output: ERROR in initialization (can't get R/3-version)ERROR in initialization (can't get R/3-version)
ERROR 2012-01-20 10:11:25
CJS-30023 Process call 'C:\usr\sap\TXU\SYS\exe\nuc\NTI386\dipgntab.exe -rwr40 -srctt DDNTT -srctf DDNTF -dsttt DDNTT -dsttf DDNTF -ttonly TT' exits with error code -1. For details see log file(s) dipgntab.log.
FCO-00011 The step adjustNametab with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|ind|ind|ind|10|0|NW_Postload|ind|ind|ind|ind|10|0|NW_Postload_MSS|ind|ind|ind|ind|2|0|adjustNametab was executed with status ERROR .
ЛОГ dipgntab.log
 Заголовок сообщения: Re: Помогите с ошибкой
СообщениеДобавлено: Пт, янв 20 2012, 11:21
Вт, июл 24 2007, 14:52
есть лог
еще нужно описание выполненных действий
СообщениеДобавлено: Пт, янв 20 2012, 11:28
http://forums.sdn.sap.com/thread.jspa?threadID=1955800&tstart=0#10272614
СообщениеДобавлено: Пт, янв 20 2012, 11:29
Пт, ноя 02 2007, 14:14
https://service.sap.com/sap/support/notes/162266
Typical causes for the errors are:
- The database is not running.
- Database users (OPS$-User) are not set up correctly. Check the DB connect with "r3trans -d".
- The version of DIPGNTAB.EXE does not fit the version of the database library DBSL (for example, DBORASLIB.DLL). This may happen if you have replaced the SAP kernel and the DBSL with a newer version during the installation (for example, 4.6D), but the DIPGNTAB.EXE however is still
in the original version (for example, 4.6C).
After the cause of the error has been eliminated, the installation must be continued by executing step DIPGNTAB_NT again.
И да, кроме ошибки, желательно знать, что же Вы делаете собственно, с какой системой, платформой и т.п.
P.S.Еще проверьте переменные среды/пользователя и результаты работы r3trans -d.
СообщениеДобавлено: Пт, янв 20 2012, 13:41
Вышла новая ошибка:
FCO-00011 The step dGetFreeSpace with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|ind|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW_MSS_DB|ind|ind|ind|ind|2|0|MssTempdb|ind|ind|ind|ind|4|0|dGetFreeSpace was executed with status ERROR .
СообщениеДобавлено: Пт, янв 20 2012, 13:45
Вышла новая ошибка:
можно было ограничиться и этой фразой.
суть информативности бы не изменилась..
хотите помощи - пишите подробно.
СообщениеДобавлено: Пт, янв 20 2012, 13:48
разобрался место в базе кончилось
