Текущее время: Ср, сен 09 2026, 08:34
Начать новую тему Ответить на тему  [ Сообщений: 34 ]  На страницу 1, 2, 3  След.
 Заголовок сообщения: Не запускается java в solman
СообщениеДобавлено: Чт, фев 02 2012, 14:34
Пн, янв 23 2012, 14:13
Доброе время суток!
Коллеги, помогите пожалуйста.
В настоящий момент не стартует java под solman 7.1.
На одном сервере установлен SAP ERP 6.0 SR3 and solaman 7.1
java vm version : 1.4.2_21-b03
os win x64 server 2008
db oracle 11.2.0.2 for solman
dev_dispatcher:
[Thr 7704] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 7704] JLaunchRequestQueueInit: create pipe listener thread
[Thr 7088] JLaunchRequestFunc: Thread 7088 started as listener thread for np messages.
[Thr 8060] WaitSyncSemThread: Thread 8060 started as semaphore monitor thread.
[Thr 7704] *** ERROR => JsfOpenShm: ShmCreate(79, 4096, ATTACH) failed (rc = 3 SHM segment doesn't exist) [jsfxxshm.c 1751]
[Thr 7704] *** ERROR => JLaunchInitAdministration: Can't open static shared memory (rc = 4 object not found) [jlnchxx.c 1079]
[Thr 7704] *** ERROR => can't initialize JControl Administration [jlnchxx.c 470]
[Thr 7704] *** ERROR => JsfDetachDynShm: dynamic shared memory is not opened. [jsfxxshm.c 2642]
[Thr 7704] *** ERROR => JsfCloseShm: Static shared memory is not opened. [jsfxxshm.c 2117]
[Thr 7704] JLaunchCloseProgram: good bye (exitcode = -1)
std_server0.out:
stdout/stderr redirect
node name : server0
pid : 6852
system name : SSM
system nr. : 00
started at : Tue Jan 31 18:21:17 2012
[Thr 2976] MtxInit: 10001 0 2
Critical Error
Can't initialize JControl Administration
-> Internal program error (rc = -1)
defaultTrace.0.trc
[EXCEPTION]
{5}#6#0#<null>#Listener refused the connection with the following error:
ORA-12505, TNS:listener does not currently know of SID given in connect descriptor
The Connection descriptor used by the client was:
sapsrv:1527:SSM
#jdbc:oracle:thin:@sapsrv:1527:SSM#<null>#java.sql.SQLException: Listener refused the connection with the following error:
sapsrv:1527:SSM
Прочитал ноты, выполнил настройки по configtool.
Какие параметры необходимо проверить в configtool еще раз?
Спасибо.
Последний раз редактировалось vmois Чт, фев 02 2012, 17:23, всего редактировалось 2 раз(а).
 Заголовок сообщения: Re: Не запускается java в solman
СообщениеДобавлено: Чт, фев 02 2012, 14:40
ЭТУ ОШИБКУ ИСПРАВИЛ.
[EXCEPTION]
sapsrv:1527:SSM
СообщениеДобавлено: Чт, фев 02 2012, 15:46
Пн, фев 11 2008, 11:38
И теперь что пишет в dev_server0 , std_server0.out ,? Смотрели bootstrap логи ? Может там что есть интересного?
P.S. вы говорите что 2 сервера сразу ? ERP стартует? Посмотрите сколько у вас pagefile ?
СообщениеДобавлено: Чт, фев 02 2012, 17:17
Логи следующие:
erp dev_server0:
Used property files
-> files [00] : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\instance.properties
Instance properties
-> ms host : sapsrv
-> ms port : 3903
-> os libs : D:\usr\sap\GOL\DVEBMGS02\j2ee\os_libs
-> admin URL :
-> run mode : NORMAL
-> run action : NONE
-> enabled : yes
Bootstrap nodes
-> [00] bootstrap : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\instance.properties
-> [01] bootstrap_ID25277100 : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\instance.properties
-> [02] bootstrap_ID25277150 : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\instance.properties
Worker nodes
-> [00] ID25277100 : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\instance.properties
-> [01] ID25277150 : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\instance.properties
[Thr 6596] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 6596] JLaunchRequestQueueInit: create pipe listener thread
[Thr 6736] JLaunchRequestFunc: Thread 6736 started as listener thread for np messages.
[Thr 6744] WaitSyncSemThread: Thread 6744 started as semaphore monitor thread.
[Thr 6596] NiInit3: NI already initialized; param 'maxHandles' ignored (1;202)
[Thr 6596] CPIC (version=700.2009.02.11)
[Thr 6596] [Node: server0] java home is set by profile parameter
Java Home: C:\j2sdk\
[Thr 6596] Thu Feb 02 15:52:56 2012
[Thr 6596] JStartupICheckFrameworkPackage: can't find framework package D:\usr\sap\GOL\DVEBMGS02\exe\jvmx.jar
JStartupIReadSection: read node properties [ID25277150]
-> node name : server0
-> node type : server
-> node execute : yes
-> jlaunch parameters :
-> java path : C:\j2sdk\
-> java parameters : -Djco.jarm=1 -XX:MaxPermSize=256M -XX:PermSize=256M -XX:NewSize=171M -XX:MaxNewSize=171M -XX:+DisableExplicitGC -verbose:gc -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -Djava.awt.headless=true -Dsun.io.useCanonCaches=false -XX:SoftRefLRUPolicyMSPerMB=1 -XX:SurvivorRatio=2 -XX:TargetSurvivorRatio=90 -Djava.security.policy=./java.policy -Djava.security.egd=file:/dev/urandom -Dorg.omg.CORBA.ORBClass=com.sap.engine.system.ORBProxy -Dorg.omg.CORBA.ORBSingletonClass=com.sap.engine.system.ORBSingletonProxy -Djavax.rmi.CORBA.PortableRemoteObjectClass=com.sap.engine.system.PortableRemoteObjectProxy
-> java vm version : 1.4.2_21-b03
-> java vm vendor : Java HotSpot(TM) 64-Bit Server VM (Sun Microsystems Inc.)
-> java vm type : server
-> java vm cpu : amd64
-> heap size : 1024M
-> init heap size : 1024M
-> root path : D:\usr\sap\GOL\DVEBMGS02\j2ee\cluster\server0
-> class path : .\bin\boot\boot.jar;.\bin\boot\jaas.jar;.\bin\system\bytecode.jar;.
-> OS libs path : D:\usr\sap\GOL\DVEBMGS02\j2ee\os_libs
-> main class : com.sap.engine.boot.Start
-> framework class : com.sap.bc.proj.jstartup.JStartupFramework
-> registr. class : com.sap.bc.proj.jstartup.JStartupNatives
-> framework path : D:\usr\sap\GOL\DVEBMGS02\exe\jstartup.jar;D:\usr\sap\GOL\DVEBMGS02\exe\jvmx.jar
-> shutdown class : com.sap.engine.boot.Start
-> parameters :
-> debuggable : no
-> debug mode : no
-> debug port : 50221
-> shutdown timeout : 120000
[Thr 6596] JLaunchISetDebugMode: set debug mode [no]
[Thr 6420] JLaunchIStartFunc: Thread 6420 started as Java VM thread.
[Thr 6420] [JHVM_PrepareVMOptions] use java parameters set by profile parameter
Java Parameters: -Xss2m
JHVM_LoadJavaVM: VM Arguments of node [server0]
-> stack : 1048576 Bytes
-> arg[ 0]: exit
-> arg[ 1]: abort
-> arg[ 2]: vfprintf
-> arg[ 3]: -Djco.jarm=1
-> arg[ 4]: -XX:MaxPermSize=256M
-> arg[ 5]: -XX:PermSize=256M
-> arg[ 6]: -XX:NewSize=171M
-> arg[ 7]: -XX:MaxNewSize=171M
-> arg[ 8]: -XX:+DisableExplicitGC
-> arg[ 9]: -verbose:gc
-> arg[ 10]: -XX:+PrintGCDetails
-> arg[ 11]: -XX:+PrintGCTimeStamps
-> arg[ 12]: -Djava.awt.headless=true
-> arg[ 13]: -Dsun.io.useCanonCaches=false
-> arg[ 14]: -XX:SoftRefLRUPolicyMSPerMB=1
-> arg[ 15]: -XX:SurvivorRatio=2
-> arg[ 16]: -XX:TargetSurvivorRatio=90
-> arg[ 17]: -Djava.security.policy=./java.policy
-> arg[ 18]: -Djava.security.egd=file:/dev/urandom
-> arg[ 19]: -Dorg.omg.CORBA.ORBClass=com.sap.engine.system.ORBProxy
-> arg[ 20]: -Dorg.omg.CORBA.ORBSingletonClass=com.sap.engine.system.ORBSingletonProxy
-> arg[ 21]: -Djavax.rmi.CORBA.PortableRemoteObjectClass=com.sap.engine.system.PortableRemoteObjectProxy
-> arg[ 22]: -Dsys.global.dir=D:\usr\sap\GOL\SYS\global
-> arg[ 23]: -Dapplication.home=D:\usr\sap\GOL\DVEBMGS02\exe
-> arg[ 24]: -Djava.class.path=D:\usr\sap\GOL\DVEBMGS02\exe\jstartup.jar;D:\usr\sap\GOL\DVEBMGS02\exe\jvmx.jar;.\bin\boot\boot.jar;.\bin\boot\jaas.jar;.\bin\system\bytecode.jar;.
-> arg[ 25]: -Djava.library.path=C:\j2sdk\\jre\bin\server;C:\j2sdk\\jre\bin;C:\j2sdk\\bin;D:\usr\sap\GOL\DVEBMGS02\j2ee\os_libs;c:\oracle\GOL\102\bin;C:\oracle\SSM\11202\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\j2sdk\jre\bin;C:\j2sdk\jre\jre;;D:\usr\sap\GOL\SYS\exe\uc\NTAMD64
-> arg[ 26]: -Dmemory.manager=1024M
-> arg[ 27]: -Xmx1024M
-> arg[ 28]: -Xms1024M
-> arg[ 29]: -DLoadBalanceRestricted=no
-> arg[ 30]: -Djstartup.mode=JCONTROL
-> arg[ 31]: -Djstartup.ownProcessId=6792
-> arg[ 32]: -Djstartup.ownHardwareId=G0956960023
-> arg[ 33]: -Djstartup.whoami=server
-> arg[ 34]: -Djstartup.debuggable=no
-> arg[ 35]: -Xss2m
-> arg[ 36]: -DSAPINFO=GOL_02_server
-> arg[ 37]: -DSAPSTART=1
-> arg[ 38]: -DCONNECT_PORT=64996
-> arg[ 39]: -DSAPSYSTEM=02
-> arg[ 40]: -DSAPSYSTEMNAME=GOL
-> arg[ 41]: -DSAPMYNAME=sapsrv_GOL_02
-> arg[ 42]: -DSAPPROFILE=D:\usr\sap\GOL\SYS\profile\GOL_DVEBMGS02_sapsrv
-> arg[ 43]: -DFRFC_FALLBACK=ON
-> arg[ 44]: -DFRFC_FALLBACK_HOST=localhost
-> arg[ 45]: -DSAPSTARTUP=1
-> arg[ 46]: -DSAPSYSTEM=02
-> arg[ 47]: -DSAPSYSTEMNAME=GOL
-> arg[ 48]: -DSAPMYNAME=sapsrv_GOL_02
-> arg[ 49]: -DSAPDBHOST=sapsrv
-> arg[ 50]: -Dj2ee.dbhost=sapsrv
CompilerOracle: exclude com/sapportals/portal/pb/layout/taglib/ContainerTag addIviewResources
CompilerOracle: exclude com/sap/engine/services/keystore/impl/security/CodeBasedSecurityConnector getApplicationDomain
CompilerOracle: exclude com/sap/engine/services/rmi_p4/P4StubSkeletonGenerator generateStub
CompilerOracle: exclude com/sapportals/portal/prt/util/StringUtils escapeToJS
CompilerOracle: exclude com/sapportals/portal/prt/core/broker/PortalServiceItem startServices
CompilerOracle: exclude com/sap/engine/services/webservices/server/deploy/WSConfigurationHandler downloadFile
CompilerOracle: exclude com/sapportals/portal/prt/jndisupport/util/AbstractHierarchicalContext lookup
CompilerOracle: exclude com/sapportals/portal/navigation/cache/CacheNavigationNode getAttributeValue
CompilerOracle: exclude com/sapportals/portal/navigation/TopLevelNavigationiView PrintNode
CompilerOracle: exclude com/sapportals/wcm/service/ice/wcm/ICEPropertiesCoder encode
CompilerOracle: exclude com/sap/lcr/pers/delta/importing/ObjectLoader loadObjects
CompilerOracle: exclude com/sap/engine/services/webservices/jaxrpc/encoding/InstanceBuilder readElement
CompilerOracle: exclude com/sap/engine/services/webservices/jaxrpc/encoding/InstanceBuilder readSequence
CompilerOracle: exclude com/sap/engine/services/webservices/jaxrpc/encoding/TypeMappingImpl initializeRelations
CompilerOracle: exclude com/sap/engine/services/webservices/jaxrpc/encoding/GeneratedComplexType _loadInto
[Thr 6420] JHVM_LoadJavaVM: Java VM created OK.
JHVM_BuildArgumentList: main method arguments of node [server0]
[Thr 6476] Thu Feb 02 15:53:00 2012
[Thr 6476] JHVM_RegisterNatives: registering methods in com.sap.bc.krn.perf.PerfTimes
[Thr 6476] JHVM_RegisterNatives: registering methods in com.sap.bc.proj.jstartup.JStartupFramework
[Thr 6476] JLaunchISetClusterId: set cluster id 25277150
[Thr 6476] JLaunchISetState: change state from [Initial (0)] to [Waiting for start (1)]
[Thr 6476] JLaunchISetState: change state from [Waiting for start (1)] to [Starting (2)]
erp std_server0.out
node name : server0
pid : 4696
system name : GOL
system nr. : 02
started at : Thu Feb 02 15:52:55 2012
[Thr 6596] MtxInit: 10001 0 0
SAP J2EE Engine Version 7.00 PatchLevel 109886.44 is starting...
Loading: LogManager ... 1271 ms.
Loading: PoolManager ... 2 ms.
Loading: ApplicationThreadManager ... 57 ms.
Loading: ThreadManager ... 21 ms.
Loading: IpVerificationManager ... 9 ms.
Loading: ClassLoaderManager ... 10 ms.
Loading: ClusterManager ... 192 ms.
Loading: LockingManager ... 188 ms.
Loading: ConfigurationManager ... 2051 ms.
Loading: LicensingManager ... 20 ms.
Loading: CacheManager ... 116 ms.
Loading: ServiceManager ...
9.847: [GC 9.847: [DefNew: 87552K->6101K(131328K), 0.0410262 secs] 87552K->6101K(1004800K), 0.0411164 secs]
Loading services.:
Service memory started. (13 ms).
Service cross started. (25 ms).
Service runtimeinfo started. (11 ms).
Service timeout started. (12 ms).
Service trex.service started. (22 ms).
Service file started. (479 ms).
Service p4 started. (797 ms).
Service classpath_resolver started. (20 ms).
16.848: [GC 16.848: [DefNew: 93653K->10789K(131328K), 0.0575425 secs] 93653K->10789K(1004800K), 0.0576286 secs]
18.200: [GC 18.200: [DefNew: 98341K->10096K(131328K), 0.0276557 secs] 98341K->10096K(1004800K), 0.0277180 secs]
Service userstore started. (20 ms).
Service jmx_notification started. (26 ms).
21.067: [GC 21.067: [DefNew: 97648K->13198K(131328K), 0.0375735 secs] 97648K->13198K(1004800K), 0.0376375 secs]
22.834: [GC 22.834: [DefNew: 100750K->14989K(131328K), 0.0427356 secs] 100750K->14989K(1004800K), 0.0427985 secs]
Service log_configurator started. (8759 ms).
Service locking started. (2 ms).
Service naming started. (201 ms).
Service ts started. (29 ms).
Service failover started. (10 ms).
Service appclient started. (40 ms).
Service iiop started. (90 ms).
Service licensing started. (7 ms).
Service jmsconnector started. (29 ms).
Service javamail started. (102 ms).
Service connector started. (93 ms).
Service http started. (543 ms).
25.237: [GC 25.237: [DefNew: 102541K->18318K(131328K), 0.0535901 secs] 102541K->18318K(1004800K), 0.0536652 secs]
Service webservices started. (1884 ms).
Service deploy started. (7653 ms).
Service configuration started. (22 ms).
Service MigrationService started. (19 ms).
Service bi~mmr~deployer started. (5 ms).
27.896: [GC 27.896: [DefNew: 105870K->22320K(131328K), 0.0688878 secs] 105870K->22320K(1004800K), 0.0689613 secs]
Service dbpool started. (1190 ms).
Service UT started. (4 ms).
Service com.sap.security.core.ume.service started. (9272 ms).
Service security started. (823 ms).
Service classload started. (25 ms).
38.811: [GC 38.811: [DefNew: 109872K->30184K(131328K), 0.0946394 secs] 109872K->30184K(1004800K), 0.0947419 secs]
Service shell started. (146 ms).
Service tc~eCATTPing~service started. (17 ms).
Service applocking started. (164 ms).
Service telnet started. (15 ms).
Service keystore started. (211 ms).
Service ssl started. (38 ms).
Service servlet_jsp started. (483 ms).
Service dsr started. (200 ms).
Service caf~um~metadata~imp started. (288 ms).
Service tc~sec~securestorage~service started. (101 ms).
Service tc~di~sdic~srv started. (1312 ms).
Service webdynpro started. (355 ms).
Service ejb started. (399 ms).
Service tc~sec~certrevoc~service started. (138 ms).
Service jmx started. (369 ms).
Service caf~um~relgroups~imp started. (212 ms).
Service caf~runtime~connectivity~impl started. (15039 ms).
39.619: [GC 39.619: [DefNew: 117736K->42470K(131328K), 0.1204117 secs] 117736K->42470K(1004800K), 0.1205069 secs]
Service tc~sec~wssec~service started. (505 ms).
Service tc~lm~ctc~confs~service_sda started. (460 ms).
Service CUL started. (456 ms).
Service sld started. (599 ms).
Service com.adobe~DocumentServicesLicenseSupportService started. (331 ms).
Service com.adobe~DataManagerService started. (333 ms).
Service apptracing started. (78 ms).
Service com.adobe~DocumentServicesBinaries2 started. (435 ms).
Service tc~sec~destinations~service started. (668 ms).
Service basicadmin started. (595 ms).
Service rfcengine started. (41 ms).
Service pmi started. (31 ms).
Service com.adobe~LicenseService started. (99 ms).
Service adminadapter started. (108 ms).
Service com.adobe~DocumentServicesDestProtoService started. (75 ms).
Service tc~sec~vsi~service started. (177 ms).
Service com.adobe~DocumentServicesConfiguration started. (174 ms).
40.321: [GC 40.321: [DefNew: 130001K->43775K(131328K), 0.1191378 secs] 130001K->48342K(1004800K), 0.1192205 secs]
Service com.adobe~TrustManagerService started. (173 ms).
Service monitor started. (407 ms).
Service jms_provider started. (940 ms).
Service com.adobe~XMLFormService started. (1263 ms).
Service com.adobe~PDFManipulation started. (1546 ms).
41.658: [GC 41.658: [DefNew: 131327K->41142K(131328K), 0.0972286 secs] 135894K->50389K(1004800K), 0.0973006 secs]
Service tc.monitoring.logviewer started. (2966 ms).
Service com.adobe~FontManagerService started. (3595 ms).
ServiceManager started for 36568 ms.
Framework started for 40722 ms.
SAP J2EE Engine Version 7.00 PatchLevel 109886.44 is running!
PatchLevel 109886.44 November 17, 2007 10:27 GMT
Login :51.647: [GC 51.648: [DefNew: 128694K->41773K(131328K), 0.0948593 secs] 137941K->53495K(1004800K), 0.0949283 secs]
54.588: [GC 54.588: [DefNew: 129325K->41016K(131328K), 0.0899950 secs] 141047K->56316K(1004800K), 0.0900631 secs]
56.759: [GC 56.759: [DefNew: 128568K->38096K(131328K), 0.0874072 secs] 143868K->57906K(1004800K), 0.0874823 secs]
59.150: [GC 59.150: [DefNew: 125648K->40942K(131328K), 0.0801174 secs] 145458K->60752K(1004800K), 0.0801831 secs]
61.375: [GC 61.375: [DefNew: 128494K->36195K(131328K), 0.0764480 secs] 148304K->61382K(1004800K), 0.0765139 secs]
### Excluding compile: com.sap.engine.services.webservices.server.deploy.WSConfigurationHandler::downloadFile
63.155: [GC 63.155: [DefNew: 123747K->37124K(131328K), 0.0706386 secs] 148934K->62311K(1004800K), 0.0707054 secs]
### Excluding compile: com.sap.engine.services.webservices.jaxrpc.encoding.TypeMappingImpl::initializeRelations
65.272: [GC 65.272: [DefNew: 124676K->39251K(131328K), 0.0713873 secs] 149863K->64438K(1004800K), 0.0714532 secs]
66.985: [GC 66.986: [DefNew: 126803K->41030K(131328K), 0.0795855 secs] 151990K->66217K(1004800K), 0.0797543 secs]
### Excluding compile: com.sap.engine.services.webservices.jaxrpc.encoding.InstanceBuilder::readElement
### Excluding compile: com.sap.engine.services.webservices.jaxrpc.encoding.GeneratedComplexType::_loadInto
68.651: [GC 68.651: [DefNew: 128582K->28025K(131328K), 0.0819842 secs] 153769K->68068K(1004800K), 0.0820526 secs]
70.900: [GC 70.900: [DefNew: 115577K->31670K(131328K), 0.0776012 secs] 155620K->71713K(1004800K), 0.0776722 secs]
72.904: [GC 72.904: [DefNew: 119222K->33526K(131328K), 0.0783382 secs] 159265K->73569K(1004800K), 0.0784094 secs]
### Excluding compile: com.sap.engine.services.webservices.jaxrpc.encoding.InstanceBuilder::readSequence
74.592: [GC 74.592: [DefNew: 121078K->34339K(131328K), 0.0780602 secs] 161121K->74382K(1004800K), 0.0781205 secs]
75.848: [GC 75.848: [DefNew: 121891K->36523K(131328K), 0.0792028 secs] 161934K->76566K(1004800K), 0.0792690 secs]
77.180: [GC 77.180: [DefNew: 124075K->39118K(131328K), 0.0904014 secs] 164118K->79160K(1004800K), 0.0904760 secs]
78.788: [GC 78.788: [DefNew: 126670K->41576K(131328K), 0.0885747 secs] 166712K->81619K(1004800K), 0.0886423 secs]
80.438: [GC 80.438: [DefNew: 129128K->37386K(131328K), 0.1004214 secs] 169171K->83250K(1004800K), 0.1004871 secs]
82.540: [GC 82.540: [DefNew: 124938K->40184K(131328K), 0.0892672 secs] 170802K->86047K(1004800K), 0.0893396 secs]
84.217: [GC 84.217: [DefNew: 127736K->41002K(131328K), 0.0993263 secs] 173599K->88505K(1004800K), 0.0993936 secs]
85.760: [GC 85.760: [DefNew: 128554K->38345K(131328K), 0.0934250 secs] 176057K->90086K(1004800K), 0.0935985 secs]
87.432: [GC 87.432: [DefNew: 125897K->40508K(131328K), 0.0960538 secs] 177638K->92249K(1004800K), 0.0961234 secs]
88.878: [GC 88.878: [DefNew: 128060K->39730K(131328K), 0.0883168 secs] 179801K->93411K(1004800K), 0.0883816 secs]
341.117: [GC 341.117: [DefNew: 127282K->43775K(131328K), 0.1164483 secs] 180963K->100341K(1004800K), 0.1165341 secs]
382.631: [GC 382.631: [DefNew: 131327K->43776K(131328K), 0.1334024 secs] 187893K->109422K(1004800K), 0.1334834 secs]
solman dev_server0
trc file: "dev_server0", trc level: 1, release: "720"
node name : ID8916650
pid : 7948
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:06:12 2012
arguments :
arg[00] : D:\usr\sap\SSM\DVEBMGS00\exe\jlaunch.exe
arg[01] : pf=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
arg[02] : -DSAPINFO=SSM_00_server
arg[03] : pf=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
arg[04] : -DSAPSTART=1
arg[05] : -DCONNECT_PORT=64997
arg[06] : -DSAPSYSTEM=00
arg[07] : -DSAPSYSTEMNAME=SSM
arg[08] : -DSAPMYNAME=sapsrv_SSM_00
arg[09] : -DSAPPROFILE=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
arg[10] : -DFRFC_FALLBACK=ON
arg[11] : -DFRFC_FALLBACK_HOST=localhost
Used property files
-> files [00] : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
Bootstrap nodes
-> [00] bootstrap : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
-> [01] bootstrap_ID8916600 : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
-> [02] bootstrap_ID8916650 : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
Worker nodes
-> [00] ID8916600 : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
-> [01] ID8916650 : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
JStartupReadInstanceProperties: read instance properties [D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties]
solman std_server0.out
node name : server0
pid : 4636
system name : SSM
system nr. : 00
[Thr 6216] MtxInit: 10001 0 2
Critical Error
node name : server0
pid : 4636
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:06:17 2012
[Thr 6012] MtxInit: 10001 0 2
Critical Error
node name : server0
pid : 4636
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:06:23 2012
[Thr 5732] MtxInit: 10001 0 2
Critical Error
Bootstrap all ok на обоих инстанциях.
ERP стартует норм.
По файлам подкачки, сделал на 2 лог. диска (кроме системного), размер определяет система.
Места на дисках достаточно. Сейчас два файла подкачки по 24GB.
На серваке 24 GB RAM.
 Заголовок сообщения: Re: Не запускается java в solman  Тема решена
СообщениеДобавлено: Чт, фев 02 2012, 17:28
После того как page файл поставили перезагружались? Яву вы кстати не правильную говорите лог пишет про java vm version : 1.4.2_21-b03
Получается на старте диспетчера уже заваливается, ABAP часть без проблем? Это новая система или работало до этого ? Опишите как она появилась и как устанавливалась (были ли проблемы ?)
P.S. посмотрите профиль SOLMAN-а (профиль инстанции ABAP), сравните параметры относящиеся к JAVA части с тем же самым ERP ,вы ничего не меняли в профиле? Попробуйте подсунуть тот что был после установки , для теста, если меняли что либо.
Последний раз редактировалось SergoB Чт, фев 02 2012, 17:32, всего редактировалось 1 раз.
СообщениеДобавлено: Чт, фев 02 2012, 17:29
dev_jcontrol
этот лог покажите...
и dev_disp
во время инсталляции SAP JVM ставили?
вообще solman 7.1 оставил у меня крайне негативные впечатления...что в админской части (логи ворк-процессов на инсталяционном ядре пухли до 60 гиг за штуку), что в настройках...
может я его просто не привык готовить?
СообщениеДобавлено: Чт, фев 02 2012, 17:41
Перегружался. (я так понял, это любимый вопрос :))
Прошу прощения, что неправильно указал версию java, поправил.
Система ставится мной в первый раз, на чистую операционную систему win server 2008 R2.
Предназначение - тестовая, учебная система.
Необходимо установить erp, solman, enh, ideas (если хватит ресурсов у сервера), best practics.
Куплен контракт у SAP, все компоненты стянуты с маркетплейса и затачиваются через маны и ноты.
Сапорт тоже куплен, письма написаны.
Недавно победил SNC.
Дело дошло до настройки solman.
Проблемы были, решались исключительно по нотам и форумам.
СообщениеДобавлено: Чт, фев 02 2012, 17:44
кабы с такими хотелками СХД не померла...
многовато на одну шкурку... даже для тест/демо
и памяти негусто.... у дуал-стэка одна только жаба от гига кушает (и то только после воспитания)...а еще надо субд покормить и абап...
а вот enh эт что такое?
СообщениеДобавлено: Чт, фев 02 2012, 17:46
Перегружался. (я так понял, это любимый вопрос )
Ну к сожалению Windows так работает с shared что только повторение ошибки после перезагрузки указывает на существование ошибки (обычно всё что с shared memory связано после перезагрузки решается ) Вы не ответили были ли проблемы в ходе установки SOL MAN 7.1 ? Посмотрели параметры в профилях ?
СообщениеДобавлено: Чт, фев 02 2012, 17:52
шрам написал:
dev_jcontrol
и dev_disp
Мне сейчас, трудно сравнивать с чем-то. Идет первое знакомство с миром САП )
SAP JVM - установлен
Логи
dev_disp:
trc file: "dev_disp", trc level: 1, release: "720"
sysno 00
sid SSM
systemid 562 (PC with Windows NT)
relno 7200
patchlevel 0
patchno 120
intno 20020600
make multithreaded, Unicode, 64 bit, optimized
profile \\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
pid 6812
kernel runs with dp version 133000(ext=118000) (@(#) DPLIB-INT-VERSION-133000-UC)
length of sys_adm_ext is 588 bytes
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (00 6812) [dpxxdisp.c 1315]
shared lib "dw_xml.dll" version 120 successfully loaded
shared lib "dw_xtc.dll" version 120 successfully loaded
shared lib "dw_stl.dll" version 120 successfully loaded
shared lib "dw_gui.dll" version 120 successfully loaded
shared lib "dw_mdm.dll" version 120 successfully loaded
shared lib "dw_rndrt.dll" version 120 successfully loaded
shared lib "dw_abp.dll" version 120 successfully loaded
shared lib "dw_sym.dll" version 120 successfully loaded
shared lib "dw_aci.dll" version 120 successfully loaded
rdisp/softcancel_sequence : -> 0,5,-1
use internal message server connection to port 3900
rdisp/dynamic_wp_check : 1
rdisp/calculateLoadAverage : 1
Thu Feb 02 16:46:06 2012
*** WARNING => DpNetCheck: NiHostToAddr(www.doesnotexist0051.qqq.nxst) took 3 seconds
Thu Feb 02 16:46:10 2012
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 4 seconds
***LOG GZZ=> 2 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 6423]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: write dp-profile-values into sys_adm_ext
DpIPCInit2: start server >sapsrv_SSM_00 <
DpShMCreate: sizeof(wp_adm) 43024 (2264)
DpShMCreate: sizeof(tm_adm) 5517056 (27448)
DpShMCreate: sizeof(wp_ca_adm) 64000 (64)
DpShMCreate: sizeof(appc_ca_adm) 64000 (64)
DpCommTableSize: max/headSize/ftSize/tableSize=500/16/584064/584080
DpShMCreate: sizeof(comm_adm) 584080 (1144)
DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
DpShMCreate: sizeof(slock_adm) 0 (296)
DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
DpShMCreate: sizeof(file_adm) 0 (80)
DpShMCreate: sizeof(vmc_adm) 0 (2152)
DpShMCreate: sizeof(wall_adm) (41664/42896/64/192)
DpShMCreate: sizeof(gw_adm) 48
DpShMCreate: sizeof(j2ee_adm) 3952
DpShMCreate: SHM_DP_ADM_KEY (addr: 000000000A5D0050, size: 6374928)
DpShMCreate: allocated sys_adm at 000000000A5D0060
DpShMCreate: allocated wp_adm_list at 000000000A5D3070
DpShMCreate: allocated wp_adm at 000000000A5D3260
DpShMCreate: allocated tm_adm_list at 000000000A5DDA80
DpShMCreate: allocated tm_adm at 000000000A5DDAD0
DpShMCreate: allocated wp_ca_adm at 000000000AB209E0
DpShMCreate: allocated appc_ca_adm at 000000000AB303F0
DpShMCreate: allocated comm_adm at 000000000AB3FE00
DpShMCreate: system runs without slock table
DpShMCreate: system runs without file table
DpShMCreate: allocated vmc_adm_list at 000000000ABCE7A0
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated gw_adm at 000000000ABCE850
DpShMCreate: allocated j2ee_adm at 000000000ABCE890
DpShMCreate: allocated ca_info at 000000000ABCF810
DpShMCreate: allocated wall_adm at 000000000ABCF8A0
DpCommAttachTable: attached comm table (header=000000000AB3FE00/ft=000000000AB3FE10)
DpSysAdmIntInit: initialize sys_adm
rdisp/test_roll : roll strategy is DP_NORMAL_ROLL
dia token check not active (10 token)
MBUF state OFF
DpCommInitTable: init table for 500 entries
DpRqQInit: keep protect_queue / slots_per_queue 0 / 2001 in sys_adm
rdisp/queue_size_check_value : -> on,50,30,40,500,50,500,80
EmInit: MmSetImplementation( 2 ).
MM global diagnostic options set: 0
<ES> client 0 initializing ....
<ES> EsILock: use spinlock for locking
<ES> InitFreeList
<ES> block size is 4096 kByte.
<ES> Info: em/initial_size_MB( 24574MB) not multiple of em/blocksize_KB( 4096KB)
<ES> Info: em/initial_size_MB rounded up to 24576MB
Using implementation view
<EsNT> Using memory model view.
<EsNT> Memory Reset disabled as NT default
<ES> 6143 blocks reserved for free list.
ES initialized.
mm.dump: set maximum dump mem to 96 MB
DpVmcSetActive: set vmc state DP_VMC_NOT_ACTIVE
MPI: dynamic quotas disabled.
MPI init: pipes=4000 buffers=1279 reserved=383 quota=10%
J2EE server info
start = TRUE
state = STARTED
pid = 7108
argv[0] = D:\usr\sap\SSM\DVEBMGS00\exe\jcontrol.EXE
argv[1] = D:\usr\sap\SSM\DVEBMGS00\exe\jcontrol.EXE
argv[2] = pf=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
argv[3] = -DSAPSTART=1
argv[4] = -DCONNECT_PORT=64996
argv[5] = -DSAPSYSTEM=00
argv[6] = -DSAPSYSTEMNAME=SSM
argv[7] = -DSAPMYNAME=sapsrv_SSM_00
argv[8] = -DSAPPROFILE=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
argv[9] = -DFRFC_FALLBACK=ON
argv[10] = -DFRFC_FALLBACK_HOST=localhost
start_lazy = 0
start_control = SAP J2EE startup framework
DpJ2eeStart: j2ee state = STARTED
Thu Feb 02 16:46:11 2012
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 3.4 3.4 4.1) [dpxxdisp.c 1701]
***LOG Q0K=> DpMsAttach, mscon ( sapsrv) [dpxxdisp.c 12467]
MBUF state LOADING
DpStartStopMsg: send start message (myname is >sapsrv_SSM_00 <)
DpStartStopMsg: start msg sent
CCMS uses Shared Memory Key 73 for monitoring.
CCMS: Initalized shared memory of size 60000000 for monitoring segment.
CCMS: Checking Downtime Configuration of Monitoring Segment.
CCMS: AlMsUpload called by wp 1024.
Thu Feb 02 16:46:13 2012
CCMS: AlMsUpload successful for D:\usr\sap\SSM\DVEBMGS00\log\ALMTTREE.DAT (2327 MTEs).
Thu Feb 02 16:46:16 2012
CCMS: start to initalize 3.X shared alert area (first segment).
DpJ2eeLogin: j2ee state = CONNECTED
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1296]
MBUF state ACTIVE
DpWpBlksLow: max wp blocks in queue is 800 (80 %)
MBUF component UP
DpMsgProcess: 1 server in MBUF
DpAppcBlksLow: max appc blocks in queue is 500 (50 %)
Thu Feb 02 16:46:24 2012
DpModState: change server state from STARTING to ACTIVE
СообщениеДобавлено: Чт, фев 02 2012, 17:53
trc file: "D:\usr\sap\SSM\DVEBMGS00\work\dev_jcontrol", trc level: 1, release: "700"
node name : jcontrol
pid : 7108
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:46:12 2012
arguments :
arg[00] : D:\usr\sap\SSM\DVEBMGS00\exe\jcontrol.EXE
arg[02] : -DSAPSTART=1
arg[03] : -DCONNECT_PORT=64996
arg[04] : -DSAPSYSTEM=00
arg[05] : -DSAPSYSTEMNAME=SSM
arg[06] : -DSAPMYNAME=sapsrv_SSM_00
arg[07] : -DSAPPROFILE=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
arg[08] : -DFRFC_FALLBACK=ON
arg[09] : -DFRFC_FALLBACK_HOST=localhost
[Thr 7092] Thu Feb 02 16:46:12 2012
[Thr 7092] *** WARNING => INFO: Unknown property [instance.box.number=SSMDVEBMGS00sapsrv] [jstartxx.c 841]
[Thr 7092] *** WARNING => INFO: Unknown property [instance.en.host=sapsrv] [jstartxx.c 841]
[Thr 7092] *** WARNING => INFO: Unknown property [instance.en.port=3201] [jstartxx.c 841]
[Thr 7092] *** WARNING => INFO: Unknown property [instance.system.id=0] [jstartxx.c 841]
JStartupReadInstanceProperties: read instance properties [D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties;D:\usr\sap\SSM\DVEBMGS00\SDM\program\config\sdm_jstartup.properties]
-> ms host : sapsrv
-> ms port : 3901
-> OS libs : D:\usr\sap\SSM\DVEBMGS00\j2ee\os_libs
-> Admin URL :
-> enabled : yes
Used property files
-> files [01] : D:\usr\sap\SSM\DVEBMGS00\SDM\program\config\sdm_jstartup.properties
Instance properties
-> ms host : sapsrv
-> ms port : 3901
-> os libs : D:\usr\sap\SSM\DVEBMGS00\j2ee\os_libs
-> admin URL :
-> enabled : yes
Bootstrap nodes
Worker nodes
-> [02] sdm : D:\usr\sap\SSM\DVEBMGS00\SDM\program\config\sdm_jstartup.properties
[Thr 7092] JControlExecuteBootstrap: execute bootstrap process [bootstrap]
[Thr 7092] [Node: bootstrap] java home is set by profile parameter
Java Home: C:\j2sdk
[Thr 6892] JControlDPMessageProxy: Thread 6892 started as handler thread for R/3 dispatcher messages.
[Thr 7092] JStartupICheckFrameworkPackage: can't find framework package D:\usr\sap\SSM\DVEBMGS00\exe\jvmx.jar
JStartupIReadSection: read node properties [bootstrap]
-> node name : bootstrap
-> node type : bootstrap
-> java parameters : -Djco.jarm=1 -Djava.security.policy=./java.policy
-> heap size : 256M
-> root path : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster
-> class path : .\bootstrap\launcher.jar
-> OS libs path : D:\usr\sap\SSM\DVEBMGS00\j2ee\os_libs
-> main class : com.sap.engine.offline.OfflineToolStart
-> framework path : D:\usr\sap\SSM\DVEBMGS00\exe\jstartup.jar;D:\usr\sap\SSM\DVEBMGS00\exe\jvmx.jar
-> parameters : com.sap.engine.bootstrap.Bootstrap ./bootstrap ID0089166
-> debuggable : yes
-> debug mode : no
-> debug port : 60000
JControlStartJLaunch: program = D:\usr\sap\SSM\DVEBMGS00\exe\jlaunch.exe
-> arg[00] = D:\usr\sap\SSM\DVEBMGS00\exe\jlaunch.exe
-> arg[01] = pf=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
-> arg[02] = -DSAPINFO=SSM_00_bootstrap
-> arg[03] = -nodeId=-1
-> arg[04] = -file=D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\instance.properties
-> arg[05] = -syncSem=JSTARTUP_WAIT_ON_7108
-> arg[06] = -nodeName=bootstrap
-> arg[07] = -jvmOutFile=D:\usr\sap\SSM\DVEBMGS00\work\jvm_bootstrap.out
-> arg[08] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_bootstrap.out
-> arg[09] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_bootstrap
-> arg[10] = -mode=BOOTSTRAP
-> arg[11] = pf=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
-> arg[12] = -DSAPSTART=1
-> arg[13] = -DCONNECT_PORT=64995
-> arg[14] = -DSAPSYSTEM=00
-> arg[15] = -DSAPSYSTEMNAME=SSM
-> arg[16] = -DSAPMYNAME=sapsrv_SSM_00
-> arg[17] = -DSAPPROFILE=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
-> arg[18] = -DFRFC_FALLBACK=ON
-> arg[19] = -DFRFC_FALLBACK_HOST=localhost
-> lib path = PATH=C:\j2sdk\\jre\bin\server;C:\j2sdk\\jre\bin;D:\usr\sap\SSM\DVEBMGS00\exe;c:\oracle\GOL\102\bin;C:\oracle\SSM\11202\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\j2sdk\jre6\bin;C:\j2sdk\jre6\jre;;D:\usr\sap\SSM\SYS\exe\uc\NTAMD64
-> exe path = PATH=C:\j2sdk\\bin;D:\usr\sap\SSM\DVEBMGS00\j2ee\os_libs;D:\usr\sap\SSM\DVEBMGS00\exe;c:\oracle\GOL\102\bin;C:\oracle\SSM\11202\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\j2sdk\jre6\bin;C:\j2sdk\jre6\jre;;D:\usr\sap\SSM\SYS\exe\uc\NTAMD64
[Thr 7092] Thu Feb 02 16:46:19 2012
[Thr 7092] JControlExecuteBootstrap: read instance values after global bootstrap
-> ms host : sapsrv
-> ms port : 3901
-> Admin URL :
-> enabled : yes
[Thr 7092] JControlExecuteBootstrap: enumerate the nodes after global bootstrap
Used property files
Instance properties
-> ms host : sapsrv
-> ms port : 3901
-> admin URL :
-> enabled : yes
Bootstrap nodes
Worker nodes
[Thr 7092] JControlExecuteBootstrap: execute bootstrap process [bootstrap_ID8916600]
[Thr 7092] [Node: dispatcher bootstrap] java home is set by profile parameter
Java Home: C:\j2sdk
JStartupIReadSection: read node properties [bootstrap_ID8916600]
-> node name : dispatcher bootstrap
-> heap size : 256M
-> parameters : com.sap.engine.bootstrap.Bootstrap ./bootstrap ID008916600
-> debuggable : yes
-> debug mode : no
-> arg[06] = -nodeName=bootstrap_ID8916600
-> arg[07] = -jvmOutFile=D:\usr\sap\SSM\DVEBMGS00\work\jvm_bootstrap_ID8916600.out
-> arg[08] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_bootstrap_ID8916600.out
-> arg[09] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_bootstrap_ID8916600
-> lib path = PATH=C:\j2sdk\jre\bin\server;C:\j2sdk\jre\bin;D:\usr\sap\SSM\DVEBMGS00\exe;c:\oracle\GOL\102\bin;C:\oracle\SSM\11202\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\j2sdk\jre6\bin;C:\j2sdk\jre6\jre;;D:\usr\sap\SSM\SYS\exe\uc\NTAMD64
-> exe path = PATH=C:\j2sdk\bin;D:\usr\sap\SSM\DVEBMGS00\j2ee\os_libs;D:\usr\sap\SSM\DVEBMGS00\exe;c:\oracle\GOL\102\bin;C:\oracle\SSM\11202\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\j2sdk\jre6\bin;C:\j2sdk\jre6\jre;;D:\usr\sap\SSM\SYS\exe\uc\NTAMD64
[Thr 7092] Thu Feb 02 16:46:22 2012
[Thr 7092] JControlExecuteBootstrap: execute bootstrap process [bootstrap_ID8916650]
[Thr 7092] [Node: server0 bootstrap] java home is set by profile parameter
Java Home: C:\j2sdk
JStartupIReadSection: read node properties [bootstrap_ID8916650]
-> node name : server0 bootstrap
-> heap size : 256M
-> parameters : com.sap.engine.bootstrap.Bootstrap ./bootstrap ID008916650
-> debuggable : yes
-> debug mode : no
-> arg[06] = -nodeName=bootstrap_ID8916650
-> arg[07] = -jvmOutFile=D:\usr\sap\SSM\DVEBMGS00\work\jvm_bootstrap_ID8916650.out
-> arg[08] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_bootstrap_ID8916650.out
-> arg[09] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_bootstrap_ID8916650
[Thr 7092] Thu Feb 02 16:46:25 2012
[Thr 7092] JControlIBuildProcessList: Maximum error count is set to 4
[Thr 7896] JControlRequestFunc: Thread 7896 started as listener thread for np messages.
[Thr 7092] [Node: dispatcher] java home is set by profile parameter
Java Home: C:\j2sdk
JStartupIReadSection: read node properties [ID8916600]
-> node type : dispatcher
-> java parameters : -verbose:gc -Djava.security.policy=./java.policy
-> heap size : 200M
-> init heap size : 200M
-> stack size : 2M
-> root path : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\dispatcher
-> class path : .\bin\boot\boot.jar;.\bin\system\bytecode.jar;.
-> parameters :
-> debuggable : no
-> debug mode : no
[Thr 7092] [Node: server0] java home is set by profile parameter
Java Home: C:\j2sdk
JStartupIReadSection: read node properties [ID8916650]
-> java parameters : -XX:MaxNewSize=341M -XX:NewSize=341M -XX:MaxPermSize=512M -XX:PermSize=512M -XX:ReservedCodeCacheSize=64M -XX:CodeCacheMinimumFreeSpace=2M -XX:CompilerThreadStackSize=4096 -XX:SurvivorRatio=2 -XX:TargetSurvivorRatio=90 -XX:SoftRefLRUPolicyMSPerMB=1 -XX:+HandlePromotionFailure -XX:+UseParNewGC -XX:+DisableExplicitGC -XX:+UseTLAB -XX:+PrintGCTimeStamps -XX:+PrintGCDetails -verbose:gc -Dsun.io.useCanonCaches=false -Djava.awt.headless=true -Djco.jarm=1 -Dorg.omg.CORBA.ORBClass=com.sap.engine.system.ORBProxy -Dorg.omg.CORBA.ORBSingletonClass=com.sap.engine.system.ORBSingletonProxy -Dorg.omg.PortableInterceptor.ORBInitializerClass.com.sap.engine.services.ts.jts.ots.PortableInterceptor.JTSInitializer -Djavax.rmi.CORBA.PortableRemoteObjectClass=com.sap.engine.system.PortableRemoteObjectProxy -Djava.security.policy=./java.policy
-> heap size : 2048M
-> init heap size : 2048M
-> stack size : 2M
-> root path : D:\usr\sap\SSM\DVEBMGS00\j2ee\cluster\server0
-> parameters :
-> debuggable : no
-> debug mode : no
-> debug port : 50021
[Thr 7092] INFO: Invalid property value [Debbugable=yes]
[Thr 7092] [Node: SDM] java home is set by profile parameter
Java Home: C:\j2sdk
JStartupIReadSection: read node properties [sdm]
-> node name : SDM
-> node type : sdm
-> heap size : 512M
-> root path : D:\usr\sap\SSM\DVEBMGS00\SDM\program
-> class path : D:\usr\sap\SSM\DVEBMGS00\SDM\program\bin\SDM.jar
-> main class : SDMInternal
-> shutdown class : com.sap.sdm.jstartup.shutdown.InternalShutDown
-> parameters : server sdmhome=D:\usr\sap\SSM\DVEBMGS00\SDM\program
-> debuggable : yes
-> debug mode : no
[Thr 7092] JControlMSConnect: attached to message server (sapsrv/3901)
-> arg[02] = -DSAPINFO=SSM_00_dispatcher
-> arg[03] = -nodeId=0
-> arg[06] = -nodeName=ID8916600
-> arg[07] = -jvmOutFile=D:\usr\sap\SSM\DVEBMGS00\work\jvm_dispatcher.out
-> arg[08] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_dispatcher.out
-> arg[09] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_dispatcher
-> arg[10] = -mode=JCONTROL
-> arg[11] = [Thr 7904] JControlMSMessageFunc: Thread 7904 started as listener thread for ms messages.
[Thr 7092] JControlICheckProcessList: process dispatcher started (PID:7908)
-> arg[02] = -DSAPINFO=SSM_00_server
-> arg[03] = -nodeId=1
-> arg[06] = -nodeName=ID8916650
-> arg[07] = -jvmOutFile=D:\usr\sap\SSM\DVEBMGS00\work\jvm_server0.out
-> arg[08] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_server0.out
-> arg[09] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_server0
[Thr 7092] Thu Feb 02 16:46:26 2012
[Thr 7092] JControlICheckProcessList: process server0 started (PID:7924)
-> arg[02] = -DSAPINFO=SSM_00_sdm
-> arg[03] = -nodeId=2
-> arg[04] = -file=D:\usr\sap\SSM\DVEBMGS00\SDM\program\config\sdm_jstartup.properties
-> arg[06] = -nodeName=sdm
-> arg[07] = -jvmOutFile=D:\usr\sap\SSM\DVEBMGS00\work\jvm_sdm.out
-> arg[08] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_sdm.out
-> arg[09] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_sdm
[Thr 7092] JControlICheckProcessList: process SDM started (PID:7932)
[Thr 7092] JControlMSSendLogon: delete SDM logon information (rc=0)
[Thr 7092] Thu Feb 02 16:46:31 2012
[Thr 7092] JControlICheckProcessList: process dispatcher (pid:7908) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: reset process dispatcher
[Thr 7092] JControlIResetProcess: [dispatcher] not running -> increase error count (1)
[Thr 7092] JControlICheckProcessList: running flight recorder:
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916600 1328186785 -bz D:\usr\sap\SSM\SYS\global
-> arg[08] = -jvmOutMode=append
-> arg[09] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_dispatcher.out
-> arg[10] = -stdOutMode=append
-> arg[11] = -traceMode=append
-> arg[12] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_dispatcher
-> arg[13] = -mode=JCONTROL
-> arg[14] = pf=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
-> arg[15] = -DSAPSTART=1
-> arg[16] = -DCONNECT_PORT=64995
-> arg[17] = -DSAPSYSTEM=00
-> arg[18] = -DSAPSYSTEMNAME=SSM
-> arg[19] = -DSAPMYNAME=sapsrv_SSM_00
-> arg[20] = -DSAPPROFILE=\\sapsrv\sapmnt\SSM\SYS\profile\SSM_DVEBMGS00_sapsrv
-> arg[21] = -DFRFC_FALLBACK=ON
-> arg[22] = -DFRFC_FALLBACK_HOST=localhost
[Thr 7092] JControlICheckProcessList: process dispatcher started (PID:8088)
[Thr 7092] JControlICheckProcessList: process server0 (pid:7924) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: reset process server0
[Thr 7092] JControlIResetProcess: [server0] not running -> increase error count (1)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916650 1328186785 -bz D:\usr\sap\SSM\SYS\global
-> arg[09] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_server0.out
-> arg[12] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_server0
[Thr 7092] JControlICheckProcessList: process server0 started (PID:8160)
[Thr 7092] JControlICheckProcessList: process SDM (pid:7932) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: reset process SDM
[Thr 7092] JControlIResetProcess: [SDM] not running -> increase error count (1)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node sdm 1328186786 -bz D:\usr\sap\SSM\SYS\global
-> arg[09] = -stdOutFile=D:\usr\sap\SSM\DVEBMGS00\work\std_sdm.out
-> arg[12] = -locOutFile=D:\usr\sap\SSM\DVEBMGS00\work\dev_sdm
[Thr 7092] JControlICheckProcessList: process SDM started (PID:7340)
[Thr 7092] Thu Feb 02 16:46:36 2012
[Thr 7092] JControlICheckProcessList: process dispatcher (pid:8088) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [dispatcher] not running -> increase error count (2)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916600 1328186791 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process dispatcher started (PID:7524)
[Thr 7092] JControlICheckProcessList: process server0 (pid:8160) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [server0] not running -> increase error count (2)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916650 1328186791 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process server0 started (PID:7500)
[Thr 7092] JControlICheckProcessList: process SDM (pid:7340) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [SDM] not running -> increase error count (2)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node sdm 1328186791 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process SDM started (PID:7584)
[Thr 7092] Thu Feb 02 16:46:41 2012
[Thr 7092] JControlICheckProcessList: process dispatcher (pid:7524) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [dispatcher] not running -> increase error count (3)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916600 1328186796 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process dispatcher started (PID:7804)
[Thr 7092] JControlICheckProcessList: process server0 (pid:7500) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [server0] not running -> increase error count (3)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916650 1328186796 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] Thu Feb 02 16:46:42 2012
[Thr 7092] JControlICheckProcessList: process server0 started (PID:7692)
[Thr 7092] JControlICheckProcessList: process SDM (pid:7584) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [SDM] not running -> increase error count (3)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node sdm 1328186796 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process SDM started (PID:7972)
[Thr 7092] Thu Feb 02 16:46:47 2012
[Thr 7092] JControlICheckProcessList: process dispatcher (pid:7804) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [dispatcher] not running -> increase error count (4)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916600 1328186801 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process server0 (pid:7692) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [server0] not running -> increase error count (4)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID8916650 1328186802 -bz D:\usr\sap\SSM\SYS\global
[Thr 7092] JControlICheckProcessList: process SDM (pid:7972) died (RUN-FLAG)
[Thr 7092] JControlIResetProcess: [SDM] not running -> increase error count (4)
C:\j2sdk\bin\java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node sdm 1328186802 -bz D:\usr\sap\SSM\SYS\global
СообщениеДобавлено: Чт, фев 02 2012, 17:56
шрам написал:
Прошу прощения, EHP
СообщениеДобавлено: Чт, фев 02 2012, 18:05
ммм... а точно dev-server0 и std_server0.out полностью выложены?
собстно по последним двум логам диспетчер поднимается нормально... а вот SDM и server0 валятся.. причем в логах инстанции server явных ошибок я не вижу...
а на счет ehp... это пакеты обновлений..практически upgrade системы, и он потребует подъема инстанции равной а то и превосходящей по ресурсам ту, на которую ставится, так называемая shadow instance. чем меньше у нее ресурсов будет, тем дольше и геморройней будет идти процесс.
СообщениеДобавлено: Чт, фев 02 2012, 18:12
Можно попробовать удалить все логи , так как их что то много уже написалось , и запустить заново увеличив глубину трейса на 1 к примеру на диспетчере ява и ноде server0 , так же для начала я бы поставил PHYS_MEMSIZE в профиль к SM7.1 b ERP тоже примерно в 6 Гиг , ну и конечно ПЕРЕЗАГРУЗИТЬСЯ ))
СообщениеДобавлено: Чт, фев 02 2012, 18:14
шрам написал:
Про ehp понятно, для этого я так понимаю и ставится солман с секурной прикруткой к сапу.
Еще раз логи.
pid : 7924
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:46:26 2012
arguments :
arg[05] : -DCONNECT_PORT=64995
Used property files
Bootstrap nodes
Worker nodes
-> ms host : sapsrv
-> ms port : 3901
-> Admin URL :
-> enabled : yes
[Thr 7928] Thu Feb 02 16:46:26 2012
[Thr 7928] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 7928] JLaunchRequestQueueInit: create pipe listener thread
[Thr 7948] JLaunchRequestFunc: Thread 7948 started as listener thread for np messages.
[Thr 7956] WaitSyncSemThread: Thread 7956 started as semaphore monitor thread.
[Thr 7928] *** ERROR => JsfOpenShm: ShmCreate(79, 4096, ATTACH) failed (rc = 3 SHM segment doesn't exist) [jsfxxshm.c 1751]
[Thr 7928] *** ERROR => JLaunchInitAdministration: Can't open static shared memory (rc = 4 object not found) [jlnchxx.c 1079]
[Thr 7928] *** ERROR => can't initialize JControl Administration [jlnchxx.c 470]
[Thr 7928] *** ERROR => JsfDetachDynShm: dynamic shared memory is not opened. [jsfxxshm.c 2642]
[Thr 7928] *** ERROR => JsfCloseShm: Static shared memory is not opened. [jsfxxshm.c 2117]
[Thr 7928] JLaunchCloseProgram: good bye (exitcode = -1)
pid : 8160
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:46:31 2012
arguments :
Used property files
Bootstrap nodes
Worker nodes
-> ms host : sapsrv
-> ms port : 3901
-> Admin URL :
-> enabled : yes
[Thr 8164] Thu Feb 02 16:46:31 2012
[Thr 8164] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 8164] JLaunchRequestQueueInit: create pipe listener thread
[Thr 8184] JLaunchRequestFunc: Thread 8184 started as listener thread for np messages.
[Thr 8188] WaitSyncSemThread: Thread 8188 started as semaphore monitor thread.
[Thr 8164] *** ERROR => JsfOpenShm: ShmCreate(79, 4096, ATTACH) failed (rc = 3 SHM segment doesn't exist) [jsfxxshm.c 1751]
[Thr 8164] *** ERROR => JLaunchInitAdministration: Can't open static shared memory (rc = 4 object not found) [jlnchxx.c 1079]
[Thr 8164] *** ERROR => can't initialize JControl Administration [jlnchxx.c 470]
[Thr 8164] *** ERROR => JsfDetachDynShm: dynamic shared memory is not opened. [jsfxxshm.c 2642]
[Thr 8164] *** ERROR => JsfCloseShm: Static shared memory is not opened. [jsfxxshm.c 2117]
[Thr 8164] JLaunchCloseProgram: good bye (exitcode = -1)
pid : 7500
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:46:36 2012
arguments :
Used property files
Bootstrap nodes
Worker nodes
-> ms host : sapsrv
-> ms port : 3901
-> Admin URL :
-> enabled : yes
[Thr 7504] Thu Feb 02 16:46:36 2012
[Thr 7504] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 7504] JLaunchRequestQueueInit: create pipe listener thread
[Thr 7516] JLaunchRequestFunc: Thread 7516 started as listener thread for np messages.
[Thr 7556] WaitSyncSemThread: Thread 7556 started as semaphore monitor thread.
[Thr 7504] *** ERROR => JsfOpenShm: ShmCreate(79, 4096, ATTACH) failed (rc = 3 SHM segment doesn't exist) [jsfxxshm.c 1751]
[Thr 7504] *** ERROR => JLaunchInitAdministration: Can't open static shared memory (rc = 4 object not found) [jlnchxx.c 1079]
[Thr 7504] *** ERROR => can't initialize JControl Administration [jlnchxx.c 470]
[Thr 7504] *** ERROR => JsfDetachDynShm: dynamic shared memory is not opened. [jsfxxshm.c 2642]
[Thr 7504] *** ERROR => JsfCloseShm: Static shared memory is not opened. [jsfxxshm.c 2117]
[Thr 7504] JLaunchCloseProgram: good bye (exitcode = -1)
pid : 7692
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:46:42 2012
arguments :
Used property files
Bootstrap nodes
Worker nodes
-> ms host : sapsrv
-> ms port : 3901
-> Admin URL :
-> enabled : yes
[Thr 7880] Thu Feb 02 16:46:42 2012
[Thr 7880] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 7880] JLaunchRequestQueueInit: create pipe listener thread
[Thr 3152] JLaunchRequestFunc: Thread 3152 started as listener thread for np messages.
[Thr 7920] WaitSyncSemThread: Thread 7920 started as semaphore monitor thread.
[Thr 7880] *** ERROR => JsfOpenShm: ShmCreate(79, 4096, ATTACH) failed (rc = 3 SHM segment doesn't exist) [jsfxxshm.c 1751]
[Thr 7880] *** ERROR => JLaunchInitAdministration: Can't open static shared memory (rc = 4 object not found) [jlnchxx.c 1079]
[Thr 7880] *** ERROR => can't initialize JControl Administration [jlnchxx.c 470]
[Thr 7880] *** ERROR => JsfDetachDynShm: dynamic shared memory is not opened. [jsfxxshm.c 2642]
[Thr 7880] *** ERROR => JsfCloseShm: Static shared memory is not opened. [jsfxxshm.c 2117]
[Thr 7880] JLaunchCloseProgram: good bye (exitcode = -1)
node name : server0
pid : 4636
system name : SSM
system nr. : 00
Critical Error
node name : server0
pid : 4636
system name : SSM
system nr. : 00
Critical Error
node name : server0
pid : 4636
system name : SSM
system nr. : 00
Critical Error
node name : server0
pid : 4636
system name : SSM
system nr. : 00
started at : Thu Feb 02 16:06:28 2012
[Thr 7692] MtxInit: 10001 0 2
Critical Error
