Текущее время: Ср, сен 23 2026, 18:46
 Заголовок сообщения: MESSAGE_TYPE_X в CO01
СообщениеДобавлено: Пн, фев 13 2012, 11:57
Пн, фев 04 2008, 06:44
Помогите побороть дамп.
Динамическая ошибка MESSAGE_TYPE_X
Дата и время 13.02.2012 11:58:42
Краткий текст
The current application triggered a termination with a short dump.
Что произошло?
The current application program detected a situation which really
should not occur. Therefore, a termination with a short dump was
triggered on purpose by the key word MESSAGE (type X).
Что Вы можете сделать?
Note down which actions and inputs caused the error.
To process the problem further, contact you SAP system
administrator.
Using Transaction ST22 for ABAP Dump Analysis, you can look
at and manage termination messages, and you can also
keep them for a long time.
Анализ ошибки
Short text of error message:
Too many dummies on level / of BOM:: 1: /: 00020646
Long text of error message:
Technical information about the message:
Message class....... "CO"
Number.............. 889
Variable 1.......... "Too many dummies on level / of BOM:"
Variable 2.......... 1
Variable 3.......... "/"
Variable 4.......... 00020646
Указания по устранению ошибки
Probably the only way to eliminate the error is to correct the program.
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
"MESSAGE_TYPE_X" " "
"SAPLCOSD" or "LCOSDF44"
"STUFE_WEG_RENUMBER"
If you cannot solve the problem yourself and want to send an error
notification to SAP, include the following information:
1. The description of the current problem (short dump)
To save the description, choose "System->List->Save->Local File
(Unconverted)".
2. Corresponding system log
Display the system log by calling transaction SM21.
Restrict the time interval to 10 minutes before and five minutes
after the short dump. Then choose "System->List->Save->Local File
(Unconverted)".
3. If the problem occurs in a problem of your own or a modified SAP
program: The source code of the program
In the editor, choose "Utilities->More
Utilities->Upload/Download->Download".
4. Details about the conditions under which the error occurred or which
actions and input led to the error.
Системная среда
SAP-Release 700
Application server... "SAP-PRD"
Network address...... "192.168.10.3"
Operating system..... "Windows NT"
Release.............. "6.1"
Hardware type........ "8x AMD64 Level"
Character length.... 16 Bits
Pointer length....... 64 Bits
Work process number.. 0
Shortdump setting.... "full"
Database server... "SAP-PRD"
Database type..... "MSSQL"
Database name..... "TXP"
Database user ID.. "txp"
Char.set.... "C"
SAP kernel....... 700
created (date)... "Jul 10 2011 22:54:13"
create on........ "NT 5.2 3790 Service Pack 2 x86 MS VC++ 14.00"
Database version. "SQL_Server_8.00 "
Patch level. 310
Patch text.. " "
Database............. "MSSQL 9.00.2047 or higher"
SAP database version. 700
Operating system..... "Windows NT 5.0, Windows NT 5.1, Windows NT 5.2, Windows
NT 6.0, Windows NT 6.1"
Memory consumption
Roll.... 16192
EM...... 25139040
Heap.... 0
Page.... 40960
MM Used. 12677376
MM Free. 4078688
Пользователь, транзакция...
Client.............. 450
User................ "SHEN"
Language key........ "R"
Transaction......... "CO01 "
Transactions ID..... "B80756E161C4F1E2B8503C4A92E96118"
Program............. "SAPLCOSD"
Screen.............. "SAPLCOKO1 0115"
Screen line......... 62
Информация о месте прерывания
Termination occurred in the ABAP program "SAPLCOSD" - in "STUFE_WEG_RENUMBER".
The main program was "SAPLCOKO1 ".
In the source code you have the termination point in line 96
of the (Include) program "LCOSDF44".
Фрагмент исходного текста программы
Строк ИсхднТкст
66 * component => also adjust AUFST/AUFWG
67 ct_stb-astov = ls_stufe_weg-astov.
68 ct_stb-awgov = ls_stufe_weg-awgov.
69 IF ct_stb-astov <= l_stufe_max
70 AND ct_stb-awgov <= l_weg_max.
71 ct_stb-aufst = ct_stb-astov.
72 ct_stb-aufwg = ct_stb-awgov.
73 ELSE.
74 * we still have an overflow
75 CLEAR: ct_stb-aufst,
76 ct_stb-aufwg.
77 ENDIF.
78 ENDIF.
79 * now adjust BAUST/BAUWG
80 ct_stb-bstov = ls_stufe_weg-astov.
81 ct_stb-bwgov = ls_stufe_weg-awgov.
82 IF ct_stb-bstov <= l_stufe_max
83 AND ct_stb-bwgov <= l_weg_max.
84 ct_stb-baust = ct_stb-bstov.
85 ct_stb-bauwg = ct_stb-bwgov.
86 ELSE.
87 * we still have an overflow
88 CLEAR: ct_stb-baust,
89 ct_stb-bauwg.
90 ENDIF.
91 MODIFY ct_stb.
92 ENDIF.
93 IF ct_stb-aufst <> ct_stb-astov.
94 * still overflow in AUFST/AUFWG for dummies => dump because
95 * of too many dummies on one level (see note 431085)
>>>>> MESSAGE x889(co) "#EC NOTEXT
97 WITH 'Too many dummies on level / of BOM:'
98 ct_stb-astov '/' caufvd-stlnr.
99 ENDIF.
100 ENDLOOP.
101
102 ENDFORM. " stufe_weg_renumber
Содержимое системных полей
Имя Знач
SY-SUBRC 8
SY-INDEX 0
SY-TABIX 1
SY-DBCNT 1
SY-FDPOS 310
SY-LSIND 0
SY-PAGNO 0
SY-LINNO 1
SY-COLNO 1
SY-PFKEY HHKOPF
SY-UCOMM
SY-TITLE Производственный заказ создать: заголовок
SY-MSGTY X
SY-MSGID CO
SY-MSGNO 889
SY-MSGV1 Too many dummies on level / of BOM:
SY-MSGV2 1
SY-MSGV3 /
SY-MSGV4 00020646
SY-MODNO 2
SY-DATUM 20120213
SY-UZEIT 115841
SY-XPROG SAPCNVE
SY-XFORM CONVERSION_EXIT
 Заголовок сообщения: Re: MESSAGE_TYPE_X в CO01
СообщениеДобавлено: Пн, фев 13 2012, 12:24
А с чего бы базисники должны про это знать?
Там же в дампе все написано. Если Вы функционал, то Вам и знать лучше, что это такое.
99 ENDIF.
