Текущее время: Ср, сен 23 2026, 09:46
 Заголовок сообщения: Зависание на фазе Tabim_POST
СообщениеДобавлено: Ср, июн 13 2012, 17:49
Ср, ноя 30 2011, 07:26
Привет...
При Upgrade системы SAP R/3 4.7 до версии ECC 6.0 на этапе Downtime фазы Main_NewBas/Tabim_Post процедура апгрэйда зависла, Лог-апгрэйда выдает вот что:
Jun 13, 2012 11:54:20 AM [Info ]: Connected to host kdvbw on port 4240.
Jun 13, 2012 11:54:20 AM [Info ]: Waiting for tool to report unit status...
Jun 13, 2012 11:54:20 AM [Info ]: Tool reported version 2.0, using XML syntax for communication.
Jun 13, 2012 11:54:20 AM [Info ]: Handling configuration request from tool.
Jun 13, 2012 11:54:20 AM [Info ]: Feature "dialogue": Tool setting "unknown", server setting "enabled" level 2.
Jun 13, 2012 11:54:20 AM [Info ]: Feature "dialoghelp": Tool setting "unknown", server setting "enabled" level 1.
Jun 13, 2012 11:54:20 AM [Info ]: Feature "html": Tool setting "unknown", server setting "enabled" level 1.
Jun 13, 2012 11:54:20 AM [Warning]: Tool asked for unknown feature "console"!
Jun 13, 2012 11:54:20 AM [Info ]: Feature "console": Tool setting "unknown", server setting "unknown".
Jun 13, 2012 11:54:20 AM [Info ]: Feature "progress": Tool setting "unknown", server setting "enabled" level 2.
Jun 13, 2012 11:54:20 AM [Info ]: Feature "unitcontrol": Tool setting "unknown", server setting "enabled" level 3.
Jun 13, 2012 11:54:20 AM [Info ]: Feature "remotecontrol": Tool setting "unknown", server setting "enabled" level 1.
Jun 13, 2012 11:54:20 AM [Warning]: Tool asked for unknown feature "synchronization"!
Jun 13, 2012 11:54:20 AM [Info ]: Feature "synchronization": Tool setting "unknown", server setting "unknown".
Jun 13, 2012 11:54:20 AM [Info ]: Feature "mid": Tool setting "unknown", server setting "enabled" level 2.
Jun 13, 2012 11:54:20 AM [Warning]: Tool asked for unknown feature "evaluation"!
Jun 13, 2012 11:54:20 AM [Info ]: Feature "evaluation": Tool setting "unknown", server setting "unknown".
Jun 13, 2012 11:54:20 AM [Info ]: >> sapparam: sapargv(argc, argv) has not been called!
Jun 13, 2012 11:54:20 AM [Info ]: Received unit control request from tool.
Jun 13, 2012 11:54:20 AM [Info ]: Current unit is execute
Jun 13, 2012 11:54:20 AM [Info ]: Revokable status set to false.
Jun 13, 2012 11:54:20 AM [Info ]: Resettable status set to false.
Jun 13, 2012 11:54:20 AM [Info ]: Unit extract type PRP has status ok
Jun 13, 2012 11:54:20 AM [Info ]: Unit configure type PRP has status ok
Jun 13, 2012 11:54:20 AM [Info ]: Unit check type PRP has status ok
Jun 13, 2012 11:54:20 AM [Info ]: Unit pre-execute type UPG has status ignored
Jun 13, 2012 11:54:20 AM [Info ]: Unit execute type UPG has status failed
Jun 13, 2012 11:54:20 AM [Info ]: Unit post-execute type UPG has status initial
Jun 13, 2012 11:54:20 AM [Info ]: Reply to tool action next for unit execute.
Jun 13, 2012 11:54:20 AM [Info ]: Tool is already connected...
Jun 13, 2012 11:54:21 AM [Info ]: >> sapparam(1c): No Profile used.
Jun 13, 2012 11:54:21 AM [Info ]: >> sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline
Подскажите что можно сделать?
 Заголовок сообщения: Re: Зависание на фазе Tabim_POST
СообщениеДобавлено: Чт, июн 14 2012, 14:23
Еще раз всем привет!
Почитал ноты и выяснилось ошибка в RFC-connect, в STMS все статусы зеленые, единственное выдает окошко с авторизацией и после неудачной авторизации выдает сообщение об ошибке. Что за пользователь требуется?
СообщениеДобавлено: Ср, июн 27 2012, 09:29
Вс, янв 07 2007, 14:28
Привет, коллега,
Стандартные все перепробовали (sapinst и т.д.) ?
