Текущее время: Вт, сен 22 2026, 15:18
Начать новую тему Ответить на тему  [ Сообщений: 20 ]  На страницу 1, 2  След.
 Заголовок сообщения: sap host agent
СообщениеДобавлено: Пн, июн 01 2015, 11:58
Вт, фев 10 2015, 14:17
Доброго дня!
Обнаружилась проблема с sap host agent`ами, стоящими на HP-UX. Проблема следующего характера:
Агент не может обнаружить бд(ORACLE).
/usr/sap/hostctrl/work
файл sapstartsrv.log
[Thr 5386] Mon Jun 1 14:41:15 2015
[Thr 5386] *** ERROR => Webmethod ExecuteOperation ( versioninfo ) failed: Unauthorized: User authentication required [saphostcontr 1346]
[Thr 5388] Mon Jun 1 14:41:16 2015
[Thr 5388] Operation 38EAA752257C1ED582873EDFB5DE5801 finished! Remove from OperationManager
[Thr 5393] Mon Jun 1 14:43:32 2015
[Thr 5393] *** ERROR => Operation::ExecuteNextCommand(): Command GetDatabaseStatus terminated with errorcode 9 [Operation.cp 348]
[Thr 5393] *** ERROR => Operation [id=38EAA752257C1ED5828748FC6B309800]: Command execution failed [Operation.cp 449]
[Thr 5393] *** ERROR => Webmethod GetDatabaseStatus failed: Database not found [saphostcontr 1758]
[Thr 5394] Mon Jun 1 14:43:34 2015
[Thr 5394] *** ERROR => Operation::ExecuteNextCommand(): Command GetDatabaseStatus terminated with errorcode 9 [Operation.cp 348]
[Thr 5394] *** ERROR => Operation [id=38EAA752257C1ED58287491BC5E39804]: Command execution failed [Operation.cp 449]
[Thr 5394] *** ERROR => Webmethod GetDatabaseStatus failed: Database not found [saphostcontr 1758]
[Thr 5401] Mon Jun 1 14:49:36 2015
[Thr 5401] *** ERROR => Operation::ExecuteNextCommand(): Command GetDatabaseStatus terminated with errorcode 9 [Operation.cp 348]
[Thr 5401] *** ERROR => Operation [id=38EAA752257C1ED58287640E915A9800]: Command execution failed [Operation.cp 449]
[Thr 5401] *** ERROR => Webmethod GetDatabaseStatus failed: Database not found [saphostcontr 1758]
[Thr 5402] Mon Jun 1 14:49:37 2015
[Thr 5402] *** ERROR => Operation::ExecuteNextCommand(): Command GetDatabaseStatus terminated with errorcode 9 [Operation.cp 348]
[Thr 5402] *** ERROR => Operation [id=38EAA752257C1ED58287642E2F4B5807]: Command execution failed [Operation.cp 449]
[Thr 5402] *** ERROR => Webmethod GetDatabaseStatus failed: Database not found [saphostcontr 1758]
файл dev_sapdbctrl
[PID 21335] *** ERROR => Ambiguous ORACLE_SID: mismatch between instance name argument ('$DBMS_INSTANCE$ ') and ORACLE_SID ('QR1') in environment of user 'oraqr1' [dboractrlux.cpp 821]
[PID 21335] *** ERROR => Database not found [dboractrlux.cpp 822]
[PID 21335] *** ERROR => Database neither found in '/etc/oratab' nor in inventory and environment of 'ora<sid>' user. Giving up... [dboractrlux.cpp 611]
[PID 21335] *** ERROR => 'Get database status' failed: Database not found [sapdbctrl.cp 2999]
[PID 22074]
Mon Jun 1 14:49:34 2015
[PID 22074] *** WARNING => Failed to load SAP_DB_ListDatabaseSystems [sapdbctrl.cp 1300]
[PID 22074] *** WARNING => Failed to load SAP_DB_GetDatabaseSystemStatus [sapdbctrl.cp 1300]
[PID 22074]
[PID 22074] *** ERROR => Ambiguous ORACLE_SID: mismatch between instance name argument ('$DBMS_INSTANCE$ ') and ORACLE_SID ('DR1') in environment of user 'oradr1' [dboractrlux.cpp 821]
[PID 22074] *** ERROR => Database not found [dboractrlux.cpp 822]
[PID 22074] *** ERROR => Database neither found in '/etc/oratab' nor in inventory and environment of 'ora<sid>' user. Giving up... [dboractrlux.cpp 611]
[PID 22074] *** ERROR => 'Get database status' failed: Database not found [sapdbctrl.cp 2999]
[PID 22640]
[PID 22640] *** WARNING => Failed to load SAP_DB_ListDatabaseSystems [sapdbctrl.cp 1300]
[PID 22640] *** WARNING => Failed to load SAP_DB_GetDatabaseSystemStatus [sapdbctrl.cp 1300]
[PID 22640]
[PID 22640] *** ERROR => Ambiguous ORACLE_SID: mismatch between instance name argument ('$DBMS_INSTANCE$ ') and ORACLE_SID ('QR1') in environment of user 'oraqr1' [dboractrlux.cpp 821]
[PID 22640] *** ERROR => Database not found [dboractrlux.cpp 822]
[PID 22640] *** ERROR => Database neither found in '/etc/oratab' nor in inventory and environment of 'ora<sid>' user. Giving up... [dboractrlux.cpp 611]
[PID 22640] *** ERROR => 'Get database status' failed: Database not found [sapdbctrl.cp 2999]
Проблема одинаковая на всех серверах HP-UX. Установлены по 2 инстанции на хост. Был обновлен сап хост агент, результата не дало:
SAPHOSTAGENT information
kernel release 721
kernel make variant 721_REL
compiled on HP-UX B.11.23 U ia64 for hpia64
compiled for 64 BIT
compilation mode Non-Unicode
compile time May 9 2015 09:33:30
patch number 2
latest change number 1579353
supported environment
operating system
HP-UX B.11
В чем может быть проблема?
 Заголовок сообщения: Re: sap host agent
СообщениеДобавлено: Пн, июн 01 2015, 13:19
Вт, мар 06 2012, 09:25
Приветствую,
у меня аналогичная проблема, только привязки к HP-UX нету и суть в том, что на в двух ландшавтах на системах разработки агент работает нормально, а на тестовой и продуктивной системах логи забиты ошибками. Да и на самом Solman'e такая же проблема. Пытался и saphostagent+ Diagnostic Agent обновлять/переустанавливать, не помогает и Logical Ports обновлять, не помогает. Уже полностью шаги Basic Configuration/System Preparation выполнял, не помогает. Кучу нот перерыл ничего не помгло. В общем плюнул, выставил сообщение в SAP, жду ответа теперь. Для меня ключевая фраза была:
а вот почему не может авторизоваться агент, SAP пока молчит.
Такие ошибки посыпались после обновления до SP13
СообщениеДобавлено: Пн, июн 01 2015, 13:26
scazi написал:
Приветствую,
У меня тоже стоит SP13,
решается проблема путем рестарта сап хост агента на время, но потом опять появляется. в SMD Agent Administration в "SAP Host Agent" агент горит желтым треугольником и ошибки при чеке бывают разные:
Сейчас вот такая ошибка:
Cannot establish connection to SAP Host agent webservice. (Service call exception; nested exception is:
com.sap.engine.services.webservices.jaxrpc.exceptions.InvalidResponseCodeException: Invalid Response Code: (415) Unsupported Media Type. The requested URL was:"http://****:1128/SAPHostControl.cgi")
Еще бывают наподобие такой ошибки:
java.rmi.RemoteException:Service call exception; nested exception is:
java.io.IOException: Connection sync error ! Character [<] recieved ! > java.io.IOException:Connection sync error ! Character [<] recieved ! <HTTPSocket.java:587:isAlive()>
Причем если выполнять с хоста вручную метод, то он отрабатывает:
./saphostctrl -function ExecuteOperation -name versioninfo
Webmethod returned successfully
Я тоже выставил сообщение в САП. Подождем тогда, что ответят. Спасибо!
СообщениеДобавлено: Пн, июн 08 2015, 12:53
Всем доброго дня!
Проблема с :
Решилась установкой ноты 2156139. Плюс после этого необходимо в Sap Solution Manager Configuration->Technical monitoring->define scope->databases->выбрать базу, next, далее apply and activate all in background, next. После некоторого кол-ва времени информация о листенере, архивере и тд появиться в мониторинге.
Эту проблему:
нота не решила. Так же после какого то кол-ва времени в SMD Administration->Sap Host Agent агенты горят желтым треугольником и ошибка в логах таже.
СообщениеДобавлено: Пн, июн 15 2015, 14:55
mramil написал(а):
Всем доброго дня!
Эту проблему:
Вот эту ноту посмотрите 927637 - Web service authentication in sapstartsrv as of Release 7.00.
В моем понимание у них авторизация service/protectedwebmethods по этому методу кривовато работает или точнее не так как написано в документации, и приходится по крохам выгребать из разных нот как это должно работать.
На Solution Manager:
1 Проверяете параметр: service/protectedwebmethods (SDEFAULT), если не помогает, то выставить DEFAULT
2 Устанавливаете параметр: service/admin_users = daaadm
3 Далее, согласно ноты 1932225 - sapstartsrv RequestLogonFile extension for UNIX, sapuxuserchk для ядра не нужно(будет только использоваться версия инсталлирования совместо с saphostagent), то есть вроде как нужно удалить из DIR_EXECUTABLE и оставить только в /usr/sap/hostctrl/exe, необходимые полномочия устанавливаются автоматически.
4 Перезапускаете службу sapcontrol -nr <XX> -function RestartService
На клиенте проверяем sapcontrol -prot GSOAP_HTTP -nr <XX> -queryuser -function AccessCheck Stop
СообщениеДобавлено: Ср, июн 17 2015, 11:03
scazi написал:
mramil написал(а):
Всем доброго дня!
Эту проблему:
1) Пробовал и так и так в usr/sap/hostctrl/exe/host_profile и DEFAULT.PFL мониторируемых систем
2) в /usr/sap/hostctrl/exe/host_profile стоит, в DEFAULT.PFL мониторируемых систем стоит
3) sapuxuserchk стоял без s-бита изначально, поставил s-бит для проверки
4) службы перезапускал
Из под пользователя из под которого агент установлен выполняю:
sapcontrol -prot GSOAP_HTTP -nr 00 -user "" "" -function AccessCheck Stop
17.06.2015 13:54:30
RequestLogonFile
OK
17.06.2015 13:54:30
AccessCheck
OK
sapcontrol -prot GSOAP_HTTP -nr 01 -user "" "" -function AccessCheck Stop
17.06.2015 13:54:23
RequestLogonFile
OK
17.06.2015 13:54:23
AccessCheck
OK
sapcontrol -prot GSOAP_HTTP -nr 10 -user "" "" -function AccessCheck Stop
17.06.2015 13:54:54
RequestLogonFile
OK
17.06.2015 13:54:54
AccessCheck
OK
sapcontrol -prot GSOAP_HTTP -nr 11 -user "" "" -function AccessCheck Stop
17.06.2015 13:55:02
RequestLogonFile
OK
17.06.2015 13:55:02
AccessCheck
OK
Перезапустил агента, нажал в SMD Administration->Sap Host Agents Check all:
sapstartsrv.log
[Thr 09] Wed Jun 17 13:49:15 2015
[Thr 09] *** ERROR => Webmethod ExecuteOperation ( versioninfo ) failed: Unauthorized: User authentication required [saphostcontr 1346]
[Thr 17] Operation 38EAA752257C1EE58598AB3A14EA890C finished! Remove from OperationManager
[Thr 17] Wed Jun 17 13:54:09 2015
[Thr 17] Updating instance list: Wed Jun 17 13:54:09 2015
[Thr 17]
Причем на другой машине HP-UX, AccessCheck Stop не отрабатывает, тк ничего там не настраивал, но агент работает исправно.
СообщениеДобавлено: Чт, июн 18 2015, 14:44
Я примерное направление подсказал, возможно, что у вас именно по какой-то другой проверке авторизация не срабатывает.
Попробуйте sapcontrol -nr 00 -function GetVersionInfo, если не сработает, то попробуйте прописать
service/protectedwebmethods = SDEFAULT +GetVersionInfo или
service/protectedwebmethods = DEFAULT +GetVersionInfo
СообщениеДобавлено: Вс, янв 17 2016, 16:39
Вт, ноя 09 2010, 19:59
СообщениеДобавлено: Ср, фев 17 2016, 13:26
Всем привет! Сап наконец нашел причину.
SAP has asked Hewlett-Packard (HP) once more to assist in the
resolution effort for this message.
The current issue has been identified as due to an issue with the
HP-UX swlist command which causes it to hang.
This is a known issue with swlist. Please confirm the version of HP-UX
that you are running. Providing you are running HP-UX 11.31 you can
update the Software Distributor bundle (which includes swlist) to
version SD_B.11.31.1403.401.
Установили данный патч на ОС и все проблемы ушли.
СообщениеДобавлено: Чт, ноя 03 2016, 03:50
Ср, янв 16 2013, 04:04
не совсем по теме, но тем не менее.
обнаружил тут что saphostagent(7.21 sp17) спамит в логи (dev_sapdbctrl) каждые 15 мин.
Thu Nov  3 10:05:48 2016
[PID 4644] *** ERROR => readHanaSharedDir: Error! readlinkU of link /usr/sap//SYS/profile returns errno=2 (No such file or directory) [dbhdblibutil.cpp 157]
[PID 4644] *** ERROR => /usr/local/bin/db2ls: No such file or directory [dbdb6ctrlux.cpp 2461]
[PID 4644]
Thu Nov  3 10:05:51 2016
[PID 4644] *** ERROR => DlLoadLib()==DLENOACCESS - dlopen("libsapdbhdbctrl.so") FAILED
  "libSQLDBCHDB.so: cannot open shared object file: No such file or directory"  [dlux_mt.c    445]
[PID 4644] *** ERROR => Failed to load database control library 'libsapdbhdbctrl.so' for database type 'hdb'. Please check your installation. [sapdbctrl.cp 3265]
[PID 6466]
как бы ему помягче сказать, что ханы у меня нет?
СообщениеДобавлено: Чт, ноя 03 2016, 08:53
sap2me
это он Вам какбэ намекает :shumlol:
СообщениеДобавлено: Чт, ноя 03 2016, 10:00
Пн, янв 14 2013, 10:37
Да, это следствие политики SAP - всем на хану )
СообщениеДобавлено: Чт, ноя 03 2016, 10:23
Вт, мар 31 2015, 12:52
есть вот такая нотка, но она все же про инсталляцию с Ханой 2329981 - SAP Host Agent on SAP HANA: ATTACH fails after relocation to another server
Может где-то в конфигах прописано?
А по поводу первой ошибки, то в 18-м патче это исправлено
СообщениеДобавлено: Чт, ноя 03 2016, 10:53
чисто теоретически возможно, что агент не видит профили инстанции и поэтому не понимает тип БД.
Плюс стоит проверить корректность профиля хостагента, в том числе юзеров которые там прописаны.
СообщениеДобавлено: Пн, ноя 07 2016, 04:33
не, БД оракловые он видит и успешно по ним входит
