Текущее время: Чт, сен 24 2026, 06:08
 Заголовок сообщения: Oracle 12 invalid objects
СообщениеДобавлено: Вс, мар 13 2016, 18:47
Ср, фев 13 2013, 14:55
Коллеги,
После апгрейда Oracle 11 до Oracle 12 вылезли invalid objects в количестве 58 штук из них 28 SYS.
С многими решил не заморачиваться, а вот объекты SYS решил пересобрать.
Как я понял объекты SYS нужно пересобирать только скриптом utlrp.sql
Запускаю скрипт:
sqlplus sys as sysdba
password
SQL> @/oracle/KPR/121/rdbms/admin/utlrp.sql
TIMESTAMP
COMP_TIMESTAMP UTLRP_BGN  2016-03-13 20:05:50
DOC>   The following PL/SQL block invokes UTL_RECOMP to recompile invalid
DOC>   objects in the database. Recompilation time is proportional to the
DOC>   number of invalid objects in the database, so this command may take
DOC>   a long time to execute on a database with a large number of invalid
DOC>   objects.
DOC>
DOC>   Use the following queries to track recompilation progress:
DOC>
DOC>   1. Query returning the number of invalid objects remaining. This
DOC>     number should decrease with time.
DOC>        SELECT COUNT(*) FROM obj$ WHERE status IN (4, 5, 6);
DOC>
DOC>   2. Query returning the number of objects compiled so far. This number
DOC>     should increase with time.
DOC>        SELECT COUNT(*) FROM UTL_RECOMP_COMPILED;
DOC>
DOC>   This script automatically chooses serial or parallel recompilation
DOC>   based on the number of CPUs available (parameter cpu_count) multiplied
DOC>   by the number of threads per CPU (parameter parallel_threads_per_cpu).
DOC>   On RAC, this number is added across all RAC nodes.
DOC>
DOC>   UTL_RECOMP uses DBMS_SCHEDULER to create jobs for parallel
DOC>   recompilation. Jobs are created without instance affinity so that they
DOC>   can migrate across RAC nodes. Use the following queries to verify
DOC>   whether UTL_RECOMP jobs are being created and run correctly:
DOC>
DOC>   1. Query showing jobs created by UTL_RECOMP
DOC>        SELECT job_name FROM dba_scheduler_jobs
DOC>      WHERE job_name like 'UTL_RECOMP_SLAVE_%';
DOC>
DOC>   2. Query showing UTL_RECOMP jobs that are running
DOC>        SELECT job_name FROM dba_scheduler_running_jobs
DOC>#
PL/SQL procedure successfully completed.
TIMESTAMP
COMP_TIMESTAMP UTLRP_END  2016-03-13 20:06:20
DOC> The following query reports the number of objects that have compiled
DOC> with errors.
DOC>
DOC> If the number is higher than expected, please examine the error
DOC> messages reported with each object (using SHOW ERRORS) to see if they
DOC> point to system misconfiguration or resource constraints that must be
DOC> fixed before attempting to recompile these objects.
DOC>#
OBJECTS WITH ERRORS
        1
DOC> The following query reports the number of errors caught during
DOC> recompilation. If this number is non-zero, please query the error
DOC> messages in the table UTL_RECOMP_ERRORS to see if any of these errors
DOC> are due to misconfiguration or resource constraints that must be
DOC> fixed before objects can compile successfully.
DOC>#
ERRORS DURING RECOMPILATION
           1
Function created.
Function dropped.
В момент запуска скрипта в алерт логе такая тишина:
SERVER COMPONENT id=UTLRP_BGN: timestamp=2016-03-13 20:05:50
Sun Mar 13 20:06:20 2016
SERVER COMPONENT id=UTLRP_END: timestamp=2016-03-13 20:06:20
Sun Mar 13 20:06:39 2016
XDB installed.
XDB initialized.
XDB=VALID
CATALOG=VALID
CATPROC=VALID
SQL> ALTER VIEW SYS.S$DNFS_CHANNELS COMPILE;
Warning: View altered with compilation errors.
Надо ли обращать внимание на недействительные объекты?
У кого какой опыт?
Согласно ноте 648203 - Database objects with status INVALID SAP говорит не обращайте, но присмотритесь к SYS.
Вот список:
SYS          S$DNFS_CHANNELS                VIEW
SYS            S$DRM_HISTORY                VIEW
SYS      S$DRM_HISTORY_STATS      VIEW
SYS             S$KCLDELTAST                VIEW
SYS          S$KESWXMON                VIEW
SYS          S$KESWXMON_PLAN                VIEW
SYS         S$KEWMRMGMV        VIEW
SYS           S$KGSKCFT                VIEW
SYS           S$KGSKSCS                VIEW
SYS              S$KJBL                VIEW
SYS          S$KJDRMAFNSTATS                VIEW
SYS           S$KJDRMHVSTATS                VIEW
SYS          S$KJDRMREQ                VIEW
SYS             S$KMMDP                VIEW
SYS           S$KMPCMON                VIEW
SYS            S$KMPCSO                VIEW
SYS            S$KMPSRV                VIEW
SYS            S$KRASGA                VIEW
SYS             S$KRCFH                VIEW
SYS          S$KRSTDEST                VIEW
SYS           S$KRVXDTA                VIEW
SYS         S$KSFDSTBLK                VIEW
SYS             S$KSQEQ                VIEW
SYS             S$KSUPR                VIEW
SYS             S$KTSSO                VIEW
SYS           S$KTSTSSD                VIEW
SYS           S$RFAHIST                VIEW
SYS              S$RFMP                VIEW
 Заголовок сообщения: Re: Oracle 12 invalid objects  Тема решена
СообщениеДобавлено: Пн, мар 14 2016, 09:22
Ср, янв 16 2013, 04:04
2199300 - Invalid objects after upgrade to 12c
смотрели?
СообщениеДобавлено: Пн, мар 14 2016, 13:19
смотрели?
Спасибо за наводку! Не находил такую ноту. Скоро проверю.
СообщениеДобавлено: Ср, мар 16 2016, 17:24
Спасибо!
Проблема решена!
