Текущее время: Вт, сен 22 2026, 12:38
 Заголовок сообщения: Перенос базы SQL 2005 на другой сервер версии 2012
СообщениеДобавлено: Ср, сен 28 2016, 07:51
Чт, май 21 2015, 07:23
Добрый день ! провожу тестовый перенос базы на 2012 SQL c 2005 SQL
Во время проверки связи выдает ошибку, не могу понять что не так, подскажите пожалуйста если кто знает
лог прилогаю
4 ETW000 R3trans version 6.24 (release 721 - 01.02.16 - 13:15:00).
4 ETW000 ===============================================
4 ETW000
4 ETW000 date&time : 26.09.2016 - 17:55:20
4 ETW000 control file: <no ctrlfile>
4 ETW000 R3trans was called as follows: R3trans -d -v -w c:\tmp\r3trans.log
4 ETW000 trace at level 1 opened for a given file pointer
4 ETW000 [ dev trc,00000] Mon Sep 26 17:55:21 2016
4 ETW000 [ dev trc,00000] Loading DB library 'dbmssslib.dll' ...
4 ETW000 [ dev trc,00000] Library 'dbmssslib.dll' loaded
4 ETW000 [ dev trc,00000] Version of 'dbmssslib.dll' is "721.02", patchlevel (0.621)
4 ETW000 [ dev trc,00000] Thread ID:6976
4 ETW000 [ dev trc,00000] Thank You for using the SLODBC-interface
4 ETW000 [ dev trc,00000] Using dynamic link library 'c:\usr\sap\RMP\SYS\exe\nuc\NTAMD64\dbmssslib.dll'
4 ETW000 [ dev trc,00000] 7210 dbmssslib.dll patch info
4 ETW000 [ dev trc,00000] SAP patchlevel 0
4 ETW000 [ dev trc,00000] SAP patchno 621
4 ETW000 [ dev trc,00000] Last MSSQL DBSL patchlevel 0
4 ETW000 [ dev trc,00000] Last MSSQL DBSL patchno 621
4 ETW000 [ dev trc,00000] Last MSSQL DBSL patchcomment Formatting error in FOR ALL ENTRIES statements in ST05 (2272340)
4 ETW000 [ dev trc,00000] ODBC Driver chosen: SQL Server Native Client 11.0 native
4 ETW000 [ dev trc,00000] Network connection used from sigma to MEGA using tcp:MEGA
4 ETW000 [ dev trc,00000] Driver: sqlncli11.dll Driver release: 11.00.6020
4 ETW000 [ dev trc,00000] ERROR: -1 in function ExecuteAndFlush (SQLExecDirect) [line 7543]
4 ETW000 [ dev trc,00000] (916) [08004] [Microsoft][SQL Server Native Client 11.0][SQL Server]Серверу-участнику "rmp" не удалось обратиться к базе данных "RMP" в текущем контексте безопасности.
4 ETW000 [ dev trc,00000] <if user_name() != 'rmp' execute as login = suser_sname(suser_sid('rmp')) with no revert> failed -- connect terminated
4 ETW000 [ dblink ,00000] ***LOG BY2=>sql error 916 performing CON
4 ETW000 [ dblink ,00000] ***LOG BY0=>Серверу-участнику "rmp" не удалось обратиться к базе данных "RMP" в текущем контексте безопасности.
2EETW169 no connect possible: "DBMS = MSSQL --- SERVER = 'MEGA' DBNAME = 'RMP'"
 Заголовок сообщения: Re: Перенос базы SQL 2005 на другой сервер версии 2012  Тема решена
СообщениеДобавлено: Чт, сен 29 2016, 11:35
Все проблему решил, сделал восстановление схему базы SQL
