Текущее время: Пн, сен 21 2026, 12:55
 Заголовок сообщения: Ошибка при апгрейде Netweaver: The command 'tp' from tool 'tp' could not be executed successf
СообщениеДобавлено: Ср, янв 27 2021, 06:36
Пн, май 15 2006, 07:01
Добрый день. Выполняю upgrade SAP Netweaver
XML файл сформирован Maintenance Planner
На фазе PREP_INPUT_CHECK/TOOLVERSXML_FEATURES_TP_EXTRACT идет проверка версий disp+work, R3trans и tp. Сейчас выдает ошибку
Last error code set:
Error: The command 'tp' from tool 'tp' could not be executed successfully
В файле TOOLCHECKXML.LOG:
2 ETQ399 TOOL-VERSION 'tp': sys:tp:version = '380.45.39'
2 ETQ399 TOOL-VERSION 'tp': sys:tp:release = '722'
2 ETQ399 TOOL-VERSION 'tp': sys:tp:patchlevel = '1000'
2 ETQ399 TOOL-VERSION 'tp': sys:tp:makevariant = '722_EXT_REL'
2 ETQ399 TOOL-VERSION 'tp': sys:tp:dbmsclient = ''
2 ETQ399 TOOL-VERSION 'tp': sys:tp:is_unicode = 'ON'
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:version = '6.24'
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:release = '722'
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:date = '15.01.20'
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:patchlevel = '1000'
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:makevariant = '722_EXT_REL'
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:dbmsclient = ''
2 ETQ399 TOOL-VERSION 'R3trans': sys:R3trans:is_unicode = 'ON'
2 ETQ399 TOOL-VERSION 'dbsl': sys:dbsl:release = '722'
2 ETQ399 TOOL-VERSION 'dbsl': sys:dbsl:patchlevel = '1000'
1 ETQ399 Consistency Check: Not requested for kernel type sys
2 ETQ399 TOOL-VERSION 'tp': exe:tp:version = '381.21.46'
2 ETQ399 TOOL-VERSION 'tp': exe:tp:release = '753'
2 ETQ399 TOOL-VERSION 'tp': exe:tp:patchlevel = '700'
2 ETQ399 TOOL-VERSION 'tp': exe:tp:makevariant = '753_REL'
2 ETQ399 TOOL-VERSION 'tp': exe:tp:dbmsclient = ''
2 ETQ399 TOOL-VERSION 'tp': exe:tp:is_unicode = 'ON'
2 ETQ399 TOOL-VERSION 'dbsl': exe:dbsl:release = '753'
2 ETQ399 TOOL-VERSION 'dbsl': exe:dbsl:patchlevel = '700'
1 ETQ399 Consistency Check: Not requested for kernel type exe
Файлы SAPEXE и SAPEXEDB именно те, которые MP сам положил в корзину
disp+work аналогичных версий и на них не ругается
ОС Windows
БД Sybase ASE 15.7
 Заголовок сообщения: Re: Ошибка при апгрейде Netweaver: The command 'tp' from tool 'tp' could not be executed successf
СообщениеДобавлено: Чт, янв 28 2021, 06:05
Вт, ноя 09 2010, 19:59
2435869 - Error: The command 'tp' from tool 'tp' could not be executed successfully with exit code 253 in TOOLVERSXML_FEATURES_R3LD_TP_EXTRACT phase
Cause
The tp file present in /usr/sap/<SID>/SUM/abap/exe directory may be corrupted.
Resolution
    Download the latest tp patch level from Software Downloads Center and save to directory location: /usr/sap/<SID>/SUM/abap/exe .
    Even if system contains the latest tp patch, please still download a new tp to replace the existing, potentially corrupted tp in your system.
    -> SUPPORT PACKAGES & PATCHES
    -> By Alphabetical Index (A-Z)
    -> K
    -> Choose your Kernel version
    -> In the left drop-down list, choose your Operating System
    -> In the right drop-down list, choose '#DATABASE INDPENDENT'
    -> Scroll down to find the "tp" SAR file to download
    Repeat the phase in SUM.
СообщениеДобавлено: Чт, янв 28 2021, 07:18
Я обновлял tp - все равно то же самое
Присмотревшись, увидел, что в каталоге log не появляется файл tp_exe.out
Directory of C:\usr\sap\BPD\SUM\abap\log
01/28/2021 08:49 AM 131,134 disp+work_sys.out
01/28/2021 08:49 AM 9,592 R3trans_sys.out
01/27/2021 03:38 PM 8,443 sapcontrol_sys.out
01/27/2021 03:38 PM 3,346 SSFS_sys.out
01/27/2021 03:38 PM 6,641 sybctrl_sys.out
01/28/2021 08:49 AM 8,313 tp_sys.out
01/28/2021 08:49 AM 132,703 disp+work_exe.out
01/28/2021 08:49 AM 9,465 R3trans_exe.out
01/28/2021 08:49 AM 9,627 sapcontrol_exe.out
01/28/2021 08:49 AM 4,146 SSFS_exe.out
01/28/2021 08:49 AM 9,413 sybctrl_exe.out
Однако файл tp_exe.sav появляется и показывает успешный вызов программы tp и информацию о версии
Пробовал создать сам вызвав exe/tp -V > log/tp_exe.out - файл появляется, но после нажатия кнопки Next - пропадает
Подозреваю ошибку в SUM
Есть у кого-нибудь SUM20SP09_<номер патча меньше 7>-80002458.SAR для Windows?
СообщениеДобавлено: Чт, янв 28 2021, 09:06
Для интереса попробовал поменять ядро на работающей системе
было
kernel release 722
kernel make variant 722_EXT_REL
Новое
kernel release 722
kernel make variant 722_EX2_REL
Целевое ядро, которое выбрал MP
kernel release 749
kernel make variant 749_REL
Первоначально хотел до 753 - с той же самой ошибкой столкнулся
СообщениеДобавлено: Чт, янв 28 2021, 09:36
ОС Windows
БД Sybase ASE 15.7
2337629 - Replacement of target release kernel for upgrade/EHPI
докиньте поверх 753 соответствующие файлики
tr R3load etc
СообщениеДобавлено: Чт, янв 28 2021, 11:02
Добавил все последние файлы - показывает их версии, но ошибка осталась
