Текущее время: Вс, авг 16 2026, 21:01
 Заголовок сообщения: Партнер-заказчик для материала с серийным номером
СообщениеДобавлено: Пт, авг 22 2008, 11:06
Ср, авг 18 2004, 11:47
Не знаю, к какой раздел отнести вопрос, решил сюда.
Есть материал с серийным номером. для материала указан партнер - заказчик. Делаю поступление материала с серийным номером с заказа ТОРО. После поступления значение в поле "заказчик" стирается. По этому поводу нашел ноту 734348:
Symptom
After an acquisition posting into the own warehouse, partners which have been maintained in the serial number / in the equipment before are deleted.
Other terms
MIGO, MB11, MB01, MB1B, PMS1
Reason and Prerequisites
The corresponding partner role is subject to the partner synchronization according to Customizing.
Solution
In general, the synchronization of the partner roles for  serial numbers primarily covers that you can derive by means of the partner data in which sphere of influence a serial number is after a delivery. Adhering to this concept the system deletes the synchronized partners again within the retour process as well as within any other goods receipt. If you want to connect other statements with the partner data as, for example, who the owner of the serial number is, you should use a partner role which is not subject to the synchronization with SD documents. These roles are neither changed with a goods receipts.
Also consider that the synchronization attributes depend on the partner scheme, thus that they can even be controlled differently for one and the same role in different contexts.
Как я понял, настроена синхронизация партнера с SD-документом. Вопроc, где настраивается эта синхронизация?
En Taro Tassadar
СообщениеДобавлено: Пт, авг 22 2008, 18:36
Пт, апр 28 2006, 22:39
Посмотрите SPRO -> Cross-Application Components -> Master Data Synchronization.
На мысль навела фраза из ноты 632477 - Partner in equipment/serial number deleted after goods issue:
If the synchronization for the partner of the master record is missing, the system initializes the partner for the goods movement.
B SD настройках что-то не припомню никакой синхронизации партнеров... На SDN находится только вот эта Master Data Synchronization и что-то с ALE/IDoc.
