Текущее время: Вс, авг 16 2026, 22:50
 Заголовок сообщения: тип контировки и оценка в классе потребности
СообщениеДобавлено: Вт, июл 21 2009, 12:16
Вс, авг 24 2008, 20:35
скажите пжлст на что влияют "тип контировки" и "оценка" в настройке класса потребности
 Заголовок сообщения: Re: тип контировки и оценка в классе потребности
СообщениеДобавлено: Вт, июл 21 2009, 12:56
А кнопка F1 перестала работать?
Тип контировки позволяет указать из какого запаса (E,Q) должен отгружаться запас при товаре.
Оценка позволяет указать, как должен в системе оцениваться запас:
Оценка особого запаса
Determines whether sales order stock or project stock is managed on a valuated or nonvaluated basis.
Use
In sales-order-related production and engineer-to-order production, you can use valuated stocks or nonvaluated stocks.
If you use valuated sales order stock or valuated project stock, the quantity and value flow is the same as that of anonymous make-to-stock production.
If you use nonvaluated sales order stock or nonvaluated project stock, you must carry out a results analysis in the course of period closing if you want to determine the stock values of finished and unfinished products.
Enter M if you want to use valuated sales order stock or valuated project stock and it should be valuated separately from anonymous warehouse stock.
Enter A if you want to use valuated sales order stock and it should be valuated together with anonymous warehouse stock.
Leave the field blank if you want to use nonvaluated sales order stock or nonvaluated project stock.
Dependencies
If you want to use valuated sales order stock and manage it separately from anonymous warehouse stock (entry M), please note the field Val. strategy.
You can display valuated special stocks using report RM07MBWS.
If you want to use valuated sales order stock and manage it together with anonymous warehouse stock (entry A), the valuated sales order stock is always valuated in the same way as material produced for anonymous warehouse stock. For materials valuated at a standard price. valuation is generally based on the standard cost estimate for the material.
СообщениеДобавлено: Вт, июл 21 2009, 13:14
отгрузку из особого запаса (E,O...) определяет поле "Особый запас" в той же настройке класса потребности (определяется из типа контировки).
потому и спрашиваю, что это смежная с CO функциональность. Предположительно необходимо создать новый тип контировки.
Подскажите пжлст где настраивается тип контировки, используемый в настройках класса потребности?????
СообщениеДобавлено: Вт, июл 21 2009, 17:35
- Управление материальными потоками - Закупки - Контировка - Ведение типов контировки
- Контроллинг - Контроллинг затрат на продукт - Учёт по носителям затрат - Контроллинг заказов клиентов - Управление изготовлением/контроллингом по заказам клиента - Проверка типа контировки
Позвольте переформулировать вопрос:
в настройке типа контировки кроме параметров
- Код особого запаса ('E' - отгрузка из запаса заказа клиента, 'Q' - отгрузка из запаса проекта, ' ' - для отгрузки из запаса без кода особого запаса)
- Проводка расхода ('E' - затраты собираются на позицию заказа клиента, 'P' - расчёт через проект)
имеется ли что-то ещё, влияющее на обработку сбытового заказа?
