Текущее время: Пт, июн 12 2026, 15:53
 Заголовок сообщения: SQ-Team - различные вакансии - 14.05.2012
СообщениеДобавлено: Чт, дек 08 2011, 15:24
Администратор
Администратор
Пн, авг 16 2004, 21:27
SAP Business Analyst in a leading HI TECH company, Москва
Крупнейшая западная компания сектора Hi Tech проводит конкурс на должность.
Модули: ММ, SD, WM, FI. Знание хотя бы одного- двух является обязательным (на уровне описания БП и бизнес- анализа хотя бы. Опыт настроек не является обязательным).
Обязанности:
· first line support for end users
· incidence solving
· test, analyse test results and repair applications
· interface monitoring and providing solution\testing of all interface issues
· escalating the problems to 2nd or 3rd line support centres, and following the status when local solution is not possible
· testing the solutions related to the problem reports
· pre-analysis of change requests from end-users, raise change requests (CRs), to related competence centres when appropriate
· if the CR has been applied, control the testing
- сonsult and provide IT expertise of business projects and business development initiatives. Consolidate business demand within project scope. Analyse IT solutions of corporate competence centres and adjust them to local requirements.
- тo execute other tasks assigned by Line Manager required by business needs.
Требования:
· еnglish – fluent
· еducation: B.Sc. degree in Industrial Engineering, Computer Science, Informatics or any other related field.
· рarticipation in business projects, basic knowledge of project management.
· аt least 2 years of experience of supporting of SAP or experience as an advanced SD key user
· еxperience with company automation through supporting\implementing ERP systems, in a part of logistics or material management
· кnowledge of sales and logistics business processes, reporting and forms
Условия:
- З/п до 130 т.р.
- Работа в штате.
- Офис А класса в центре Москвы,
- В соцпакет входит бесплатное питание, фитнес, мед. страховка для сотрудника и родственников, ежегодные бонусы и др .
- Компания активно проводит внутренние и внешние тренинги.
Компания предлагает отличные перспективы роста, т.к. открывает новые направления.
Резюме присылайте пожалуйста по контактам ниже. Ответим всем.
Описание вакансии не слишком информативно, так что звоните и пишите в почту, отвечу на вопросы о компании.
Maria Kochanova
Recruiter, IT Practice
SQ-Team, IT Recruitment Intelligence
Тел.: +7 (495) 258 3159, +7 (495) 287 3637
Моб.: +7 (905) 778 8743
m.kochanova@sqteam.ru
СообщениеДобавлено: Чт, янв 19 2012, 17:34
Администратор
Администратор
Крупнейшая производственная компания набирает опытных консультантов на вакансии:
Ст. консультант SAP BI/BW (аналитическая отчетность)
Требования:
- Высшее техническое образование
- Опыт работы в должности консультанта по внедрению/поддержке системы SAP BW от 2-х лет
- Знание принципов построения архитектуры хранилищ данных SAP BW.
- Опыт проектирования модели хранилища и настройки потоков данных (разработка/расширение экстракции данных из SAP/не-SAP, настройка источников данных, трансформаций, процессов переноса данных, создание хранилищ данных).
- Опыт разработки отчетов в BeX.
- Прикладные знания функциональности модулей SAP ERP, систем SAP CRM, SAP APO. Опыт разработки хранилища и построения отчетности минимум для 2-х из перечисленных компонентов: SAP ERP (SD, MM, PS, PP, PM, QM),.SAP CRM, SAP APO.
- Опыт проведения мероприятий по оптимизации хранилищ и улучшению производительности системы SAP BW.
- Знания по настройке серверной части Business Objects, разработка отчетности с помощью инструментов Business Objects – является преимуществом.
- Знания по работе с SAP EP – является преимуществом.
- Готовность к командировкам (до 20% времени при необходимости).
Обязанности:
- Настройка хранилища, разработка отчетов в SAP BW для прикладных областей: Взаимоотношения с клиентами, Логистика, Производство, Ремонты, Добыча, Планирование Спроса/Производства.
- Обработка инцидентов, выполнение запросов на изменение для SAP BW.
- Подготовка технической документации для SAP BW.
- Подготовка документации для обучения пользователей для SAP BW.
- Проведения обучения пользователей SAP BW.
Ст. консультант SAP SD
Требования:
Обязательно:
- Опыт осуществления настроек компонента SD не менее 2 лет;
- Знание логистических процессов (планирование, закупка, продажа, расчет цены, отгрузка, транспортировка, фактурирование);
- Знание интеграции между SD и смежными компонентами(MM,FI,CO, PP, WF);
- Знание основ работы с ABAP на уровне отладчика и поиска ошибок;
- Знание основных способов расширения стандартной функциональности SD;
- Знание порядка разработки и оформления проектной документации, постановок задач, технических заданий и иной документации;
Желательно:
- Опыт создания и настройки IDOC;
- Опыт настройки компонентов MM, CRM;
- Знание ABAP на высоком уровне;
- Знание процессов и методологии материального и бухгалтерского учета.
- Готовность к командировкам (20-30% времени)
Должностные обязанности:
· Отвечает за настройку продуктивной системы; контролирует риски, выполняя точечные корректировки;
· Отвечает за тестирование функциональности системы в рамках своего модуля;
· Обеспечивает документированность выполненных настроек, разработанных программ/отчетов в системе «SAP Solution Manager» (спецификации, протокол настроек, протокол тестирования);
· Отвечает за создание, корректировку инструкций для пользователя системы SAP, вносит изменения в систему «SAP Solution Manager»;
· Качественно и своевременно выполняет настройки, согласованные с пользователями системы;
· Совместно с программистом в части дополнительно разработанных АВАР отчетов или программ отвечает за корректное, своевременное написание технического задания и качественное тестирование;
· Разделяет ответственность с другими менеджерами направления за совместно настраиваемые бизнес процессы;
· Содействует улучшению качества решения, проводя обучение и консультирование коллег и пользователей;
· Содействует в выполнение командной цели по KPI;
· Соблюдает в своей деятельности требования регламентирующих документов;
Ст. Консультант SAP HR
Требования:
· Обязательно: наличие опыта осуществления настроек в SAP (модуль PA и OM и\или PT и PY) не менее 2 лет
· Знание основ трудового законодательства
Желательно:
· Знания АВАР-языка хотя бы на уровне работы с отладчиком
· Знания основ бух.учета в части расчетов с персоналом
Условия работы:
- Место работы г. Москва.
- Мы предлагаем конкурентоспособный компенсационный пакет: заработная плата; компенсацию мобильной связи; ДМС, страхование от несчастных случаев.
- Возможность профессионального и карьерного роста.
Резюме и вопросы по вакансии присылайте, пожалуйста, по контактам ниже. Ответим незамедлительно.
Maria Kochanova
СообщениеДобавлено: Чт, мар 22 2012, 17:29
Администратор
Администратор
Руководитель направления SAP "Производство", "Управление качеством"
Требования:
- Высшее техническое образование.
- Обязательно:
- Наличие опыта осуществления настроек в SAP (Производство, Управление качеством) не менее 2 лет или 2 полных внедрения,
- Знание APO,QM, MII, Abap,
- Опыт управления командой,
- Общее понимание лучших мировых практик в горнодобывающей, металлургической промышленности,
- Наличие успешных проектов в области создания и развития корпоративных информационных систем (ERP); хорошее общее функциональное и техническое понимание SAP.
- Готовность к командировкам (50% времени).
Обязанности:
- Руководство функциональным направлением Центра компетенции.
- Выполнение всех административных функций, связанных с эффективной работой функционального направления в целом и его отдельных сотрудников.
- Контроль исполнения SLA.
- Решение или содействие в решении вопросов, которые могут возникать в связи с процессами, разработанными и внедренными в рамках проекта «Бизнес-стандарт».
- Решение или содействие в решении интеграционных вопросов, возникающих внутри центра компетенции и других проектах с ним связанных.
- Анализ всех критичных и высоко затратных запросов на изменения по функциональному направлению.
- Уточнение, совместно с бизнесом, ценности таких запросов на изменение для Компании.
- Приоритезация, утверждение их исполнения и крайних сроков.
- Определение потребности в развитии и обучении сотрудников функционального направления.
- Участие в создании единого информационного пространства Компании на основании единой технической политики и современного уровня информационных технологий.
Условия: возможности профессионального развития, участие в проекте развития системы SAP, привлекательная компенсация, оформление по ТК РФ, компенсация мобильной связи, ДМС.
Maria Kochanova
 Заголовок сообщения: Re: SQ-Team - SD/WM/MM/FI, BW/BI, SD, HR, рук-ль направления APO/PP/QM - 22.03.2012
СообщениеДобавлено: Пн, май 14 2012, 17:04
Администратор
Администратор
Менеджер внедрения SAP MM.
Профессиональные знания/навыки:
· Осуществление настроек SAP, в т.ч. закупки; управление запасами; контроль счетов; оценка материалов; планирование потребностей в материалах; оперативная логистика; управление сбытом; классификация; управлениями партиями; информационная система логистики; управление производством (основные данные, производственные заказы); система управления документами; расширения системы (customer exits, BADI)
· Опыт осуществления настроек в SAP MM не менее 3 лет (по крайней мере 2 полных внедрения) , опыт внедренияSAP на металлургических предприятиях
· Навыки коммуникации, умение работать в команде
· Технический английский язык
· Ориентация на результат, способность правильно расставить приоритеты (80/20)
· Открытость для новых подходов и решений, способность предлагать собственные решения
Основные обязанности:
· Внедрение и тиражирование системы на предприятиях холдинга
· Обследование и изменение бизнес-процессов по функциональности
· Обеспечение интеграции проектируемых процессов в Закупках с процессами по др. функциональным направлениям
· Коммуникация с бизнес-экспертами, потенциальными пользователями, аналитиками
· Разработка процессов “MM”, в т.ч.:
o Участвует в подготовке схем процессов;
o Участвует в сверке подготовленных процессов с ключевыми пользователями / представителями бизнеса и бизнес-экспертами;
o Участвует в разработке проектных решений (реализация процессов в SAP);
o Участвует в настройке системы
o Участвует в определении количества пользователей системы по заданным процессам, их роли и необходимых полномочия в системе;
o Участвует в тестировании по функциям и интеграционном тестировании
o Определяет модель основных данных материала, услуг, классификаций материалов и партий, поставщиков ТМЦ и услуг с точки зрения управления закупками, запасами и складского учёта, участвует в определении форматов для подготовки основных данных
o Готовит функциональные требования по обязательной отчетности, выходным формам
o Готовит и актуализирует инструкции пользователей
o Участвует в обучении ключевых и конечных пользователей
o Поддерживает и дорабатывает систему на этапе сопровождения
Условия:
· Оформление по ТК РФ, бессрочный трудовой договор.
· «Белая» заработная плата + бонусы
· ДМС, компенсация мобильной связи, тренинги
· Командировки в размере 20-30%
Менеджер SAP SD
· Разработка процессов “SD”, в т.ч.:
Требования:
- Обязательно:
o Опыт осуществления настроек компонента SD не менее 2 лет;
o Знание логистических процессов (планирование, закупка, продажа, расчет цены, отгрузка, транспортировка, фактурирование);
o Знание интеграции между SD и смежными компонентами(MM,FI,CO, PP, WF);
o Знание основ работы с ABAP на уровне отладчика и поиска ошибок;
o Знание основных способов расширения стандартной функциональности SD;
o Знание порядка разработки и оформления проектной документации, постановок задач, технических заданий и иной документации;
- Желательно:
o Опыт создания и настройки IDOC;
o Опыт настройки компонентов MM, CRM;
o Знание ABAP на высоком уровне;
o Знание процессов и методологии материального и бухгалтерского учета.
Условия:
o Оформление по ТК РФ
o "Белая" заработная плата + бонусы
o Компенсация мобильной связи, ДМС, страхование жизни и здоровья
Консультант SAP FI-TR в Центр компетенций.
Требования:
· Высшее техническое образование
· Обязательно:
o Наличие опыта осуществления настроек в SAP (модуль "Казначейство") не менее 2 лет или 3 года полных внедрения;
o Наличие опыта участия в проектах с интеграцией между FI-GL, CO, SD, ММ, PS
o Знание настроек и наличие опыта программы платежей (в том числе настройка форматных деревьев);
o Знание модуля управление финансовыми сделками, учет ценных бумаг, хеджирование, учет векселей, стандартное решение по прогнозу ликвидности;
o Знание ABAP на уровне поиска ошибок;
o Знание и умение писать проверки и замещения Open FI.
· Желательно:
o Знание FI-GL новой главной книги;
o Наличие сертификатов: по бухгалтерскому учету, МСФО; сертификат по SAP; -хорошие презентационные навыки, коммуникабельность.
o Готовность к командировкам (20-30% времени)
Условия:
· "Белая" заработная плата + бонусы
· Компенсация мобильной связи, ДМС, страхование жизни и здоровья
Консультант FI GL
Требования:
o Высшее образование
o Обязательно:
o Наличие опыта осуществления настроек в SAP (модуль "Финансы, главная книга") не менее 2 лет или 3 года полных внедрения; Наличие опыта участия в проектах с интеграцией между FI-GL, CO, SD, ММ, PS;
o Знание методологии РСБУ, МСФО, IFRS 12, желательно знание НУ 25 глава, ПБУ 18;
o Загрузка данных в SAP (пакетный ввод, LSMW и т.д.);
o Настройка проверок/замещений;
o Хорошее знание таблиц, уверенная постановка ТЗ для программистов;
o Знание типового решения SAP по РСБУ и МСФО;
o Знание принципов параллельного учета в SAP, опыт настройки модуля FI-GL, опыт работы с гибкой главной книгой;
o Знание ABAP (желательно), распознавание ошибок через отладчик;
o Знание английского на уровне intermediate.
o Желательно:
o Сертификаты: по бухгалтерскому учету, МСФО; сертификат по SAP;
o Хорошие презентационные навыки, коммуникабельность;
o Готовность к командировкам (20-30% времени).
Условия:
Менеджер SAP HR (OM, PA, PY, PT) в Центр компетенций.
Требования:
· Высшее образование
· Обязательно:
o Наличие опыта осуществления настроек в SAP (модуль PA и OM и\или PT и PY) не менее 1 года
o Знание основ трудового законодательства
· Желательно:
o Знания АВАР-языка хотя бы на уровне работы с отладчиком
o Знания основ бух.учета в части расчетов с персоналом
o Стрессоустойчивость
o Желание интенсивно учиться и развиваться
Условия:
· "Белая" Заработная плата + бонусы
Менеджер SAP BCS в Центр компетенций.
Требования:
· Высшее техническое образование,
· Опыт работы в SAP SEM BCS (настройка или поддержка функционирующей системы) от 2 лет,
· Базовые знания в области интеграции и работы модулей транзакционной системы SAP ERP (FI, CO) в части увязки с системой консолидации,
· Базовые знания BW (построение запросов/отчетов Bex, мэппинги),
· Опыт работы в области консолидации отчетности, что выражается в знании методологии учета и консолидации в соответствии с МСФО,
· Английский язык (разговорный/письменный),
· Готовность к командировкам (до 20% времени при необходимости).
Обязанности:
· Обработка инцидентов, выполнение запросов на изменение для SAP BCS,
· Поддержка формата загрузки данных DEF_BCS (техническая сторона),
· Участие в обновлениях модуля SAP BCS, установки нот, поиск технических причин сбоев в работоспособности SAPBCS,
· Поддержка технической реализации mapping-ов для потока данных в КПС+,
· Участие в технической реализации KPIs,
· Поддержка ролей пользователей в системе Консолидации SAP BCS,
· Подготовка технической документации для SAP BCS,
· Подготовка документации для обучения пользователей для SAP BCS,
· Проведения обучения пользователей SAP BCS,
· Разработка отчетов над кубами SAP BCS,
· Оказание методологических консультаций ключевым пользователям модуля SAP BCS.
Условия:
· Оформление по ТК РФ.
· "Белая" заработная плата + бонусы.
· Компенсация мобильной связи, ДМС, страхование жизни и здоровья.
Maria Kochanova
