Текущее время: Ср, июн 24 2026, 02:04
 Заголовок сообщения: SAP-нота 195122
СообщениеДобавлено: Пн, ноя 12 2007, 09:14
Чт, ноя 08 2007, 14:45
SAP-нота 195122 , где бы поглядеть :?:
время_не_ждет
СообщениеДобавлено: Пн, ноя 12 2007, 10:12
Вт, май 22 2007, 08:26
https://websmp210.sap-ag.de/notes
СообщениеДобавлено: Пн, ноя 12 2007, 13:19
просит логин и пароль_у меня их нет
время_не_ждет
СообщениеДобавлено: Пн, ноя 12 2007, 19:04
Вт, авг 15 2006, 19:37
Вас необходимо зарегистрировать, обычно этим занимаются админы, обратитесь к ним
The thing I hate about an argument is that it always interrupts a discussion.
СообщениеДобавлено: Вт, ноя 13 2007, 12:27
Чт, ноя 16 2006, 19:24
держи:
Symptom
You attempt to compare the values of Controlling with the values of Funds Management.
Other terms
U2040
Reason and Prerequisites
The components Controlling (CO) and Funds Management (FI-FM/FM) are used at the same time.
Solution
Due to the differences in approach, it is not possible to reconcile the values from the components CO and FI-FM.
Because of the different requirements for internal cost control and budgetary control, the update of the actual data and commitment data is considerably different in CO and FM.
To approximate the update of the actual data and commitment data in FM to that in CO, make the following settings in FM:
I. In the master data area:
1. Structure of commitment items same as structure of cost elements
2. Structure of funds centers same as structure of cost centers
II. In the update area (*):
1. Update of the purchase order for delivery date (update profile 102)
2. Update of the invoice for posting date (update profile 102)
3. Update of the parked invoices:
In the CO System, parked invoices are only updated as of Release 4.6A. Therefore the update into the Funds Management must be suppressed up to and including Release 4.0B (Note 60411). In Release 4.5B it must occur statistically. As of 4.6A it must occur really.
4. Update at time of 'Goods receipt' (IMG Transaction 'OFUP')
5. Update of postings for goods issue (IMG Transaction 'OFUP')
6. No tax display (IMG Transaction 'OFUP')
7. No display of payments (update profile 102)
8. Update of depreciations (Note 119443)
9. No update of asset acquisitions (via transaction type)
Up to Release 4.5, you can carry out most of the settings for updating in Customizing Transaction OFUP.
As of Release 4.5, some of these settings (1, 2 and 7) are contained in the update profiles.
For the most part, update profile 102 corresponds to these settings.You only need to change the period control for value type 51 (purchase order) to 'Delivery date' (IMG Transaction OF36 'Override update profile').
The system checks the settings for updating if you determine the business transactions for CO posting integration in Customizing of Funds Management.
If the system ascertains differences from the settings listed above, then it displys warning message U2040.
СообщениеДобавлено: Вт, ноя 13 2007, 12:48
сэнкс
время_не_ждет
 Заголовок сообщения: Generic ED med Heaceaftickew
СообщениеДобавлено: Вс, май 25 2008, 18:30
Get keep safe 70% on tag medications. Buy Generic Viagra, Generic Cialis and Generic Levitra at our online Generic apothecary inform on. pay for generics manufactured on sage certified facilities which fulfil or ruin the highest US food and drink and attend superintendence and in seventh rapture fettle orderat ambien generic needed no pharmacy prescription standards.
Here at most beneficent Generic pharmacist's we are committed to giving you the choicest marines and the highest-standing Generic Viagra products for your ed's worth. Don't apart hundreds of dollars on imagine medication when you can buy chemically bout generics, manufactured at FDA Approved overseas pha
rmacies, in discriminating packaging and for up to 70% less!
