Текущее время: Пт, сен 25 2026, 21:16
 Заголовок сообщения: Logisti4eskie dannye v FI documentah
СообщениеДобавлено: Чт, янв 10 2008, 12:34
Вт, апр 18 2006, 14:52
Est' FI documenty WA, WE, WI, WL logisti4eskie polya (MATNR-material, EBELN-document zakupki, EBELP-nomer pos dok-ta zakuki, VBELN-torg documnt, POSN2-posiciya doc-ta zakupki) kotoryh ne zapolneny dannymi.
Naskl'ko ja ponimaju eti polja dolgna avtomati4 zapolnatsja is logistiki. Gde eto nastraivaetsja?
Sorry, net russkogo jazyka
Self is a bad counselor
СообщениеДобавлено: Вт, янв 15 2008, 21:42
Nigde ne nastraivaet'saya because tolko polya nuzhno otkryt', a potom ne propustit' momemt, when in MM-documet with certain movement type there's no purchase order and oohh, wonder, it is not filled in FI document
Sorry, ne mogu klafffku pereckluchit' and patch skachat' dlya russkoy klavvky ne razobralsya, net propiski
СообщениеДобавлено: Ср, янв 16 2008, 11:38
Where should these fields be opened? You ment that if in MM document were no purchase order, there isn't this data in FI? So, it can be customized in MM(SD) for purchase(sales) order?
СообщениеДобавлено: Ср, янв 16 2008, 16:15
Вт, ноя 29 2005, 22:07
Мне кажется, разумнее это будет спросить у логистиков...
СообщениеДобавлено: Ср, янв 16 2008, 16:18
СообщениеДобавлено: Ср, янв 16 2008, 20:21
OK, that's enough to open appropriate fields in OB41 transaction. Movement type are to have the same fields as FI-account opened. If fields in movement type and in FI-account have similar status, then MM data will be posted in FI-document. There are no transations supposed to make some specific customisations for filling MM data in FI
Could you give us any examples with acсount functions (stock account, GR/IR account and so on) where you're about to have MM data in FI and we'l try to give you any help or something
СообщениеДобавлено: Чт, янв 17 2008, 00:52
Пт, июл 08 2005, 13:07
[i]I am sorry for annoyance, but could you please read through p.1.6 here: http://www.sapboard.ru/forum/viewtopic.php?t=3710
Прошу прощения за занудство, но не могли бы Вы прочитать п.1.6 здесь: http://www.sapboard.ru/forum/viewtopic.php?t=3710
[/i]
СообщениеДобавлено: Пт, янв 18 2008, 10:48
These particular MM fields are opened in the field status group assigned to the account.
I'm not quite familiar with the topic of movement types, could you please explain where it can be customized?
I'm willing to see MM/SD data in Fi documents (goods receipt, goods issuue etc.). This data have to be previously saved in BSEG. And it is missing there
СообщениеДобавлено: Пт, янв 18 2008, 11:03
Извиняюсь,
прочитал пункт 1.6 правил
СообщениеДобавлено: Пт, янв 18 2008, 12:16
Чт, окт 20 2005, 08:45
Как же это я пропустил :(
to Интересующийся, Sergey@, darkduck: Предупреждение!
СообщениеДобавлено: Пн, янв 21 2008, 06:27
ОК, написано в правилах про мысли, но это было краткое изложение документации SAP. Будем по-русски писать. Понимаю, что это вне темы, но выходит, что все посты должны быть литературными без перехода на албанские диалекты или я не прав?
