Текущее время: Вт, сен 29 2026, 02:28
Начать новую тему Ответить на тему  [ Сообщений: 20 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Чт, сен 06 2007, 10:12
Вт, авг 17 2004, 13:57
бросьте сюда подробное описание сообщения
...кожу рвёт мне вена на виске...
ERP 2005
СообщениеДобавлено: Чт, сен 06 2007, 10:27
Ср, сен 05 2007, 10:08
During settlement error message KD256 is output
"There are no accrued amounts; settlement is not possible".
The error message and the long text do not supply sufficient information on the causes for the error message.
Additional key words
CJ88, CJ8G, VA88, KO88, KO8G, CO88
Cause and prerequisites
Preconditions for message KD256 are:
1. The sender carries a results analysis key
and
2. it is
a) a sender with revenue
or
b) a production order with FUL rule to product which in the settlement period has neither the status DLV nor the status TECO
or
c) a WBS element which does not have the status TECO
or
d) an order, which in the settlement period has neither the status DLV nor the status TECO, and the indicator 'WIP on dependent orders' is in the results analysis version.
In these cases, only data from accrual calculation is settled. In the cases b) to d), no actual costs are settled to the receiver of the settlement rule.
The error message is now output
1. if no accrual calculation has been carried out,
or
2. the accrued data have already been settled
or
3. the flag 'Settlement to FI' has not been set in any of the results analysis versions
or
4. no posting rules have been defined for any of the results analysis categories.
Solution
1. Check for the cases b), c) and d) whether the sender already had the status GLV or TECO in the settlement period, that is, whether the delivery date or the date of the technical closure is prior to the posting date of the settlement. If this is not the case, the system continues to determine and settle in period WIP.
Note: Prior to Release 4.0, the system did not update the date of the technical closure with WBS elements. This is why the date of the technical closure was not checked in Release 3.0/3.1. This was an error in Release 3.0/3.1.
2. Check the settings in the Customizing of accrual calculation, that is, check the flags 'Settlement to FI' in the results analysis version and check the posting rules.
3. Check the previous settlements for the sender. For this use the function 'Extras -> Previous settlements' on the initial screen of the settlement.
4. If necessary, start accrual calculation for the sender again and start the settlement again afterwards.
СообщениеДобавлено: Чт, сен 06 2007, 10:36
Виды затрат для НЗП заведены (тип 31) ?Идентификаторы строк определены? Присвоения идентификаторов строк определено? Опрределение обновления данных задано?
Если есть IDES зайдите посмотрите там для БЕ 6000 и Завода 6000 если мне не изменяет память и настройте аналогично.
ERP 2005
СообщениеДобавлено: Чт, сен 06 2007, 11:07
да вроде все настроено...
есть вопрос поводу технического вида затрат для анализа результатов
при просмотре НЗП на тех. заказе Затраты->анализ->НЗП
на этом виде затрат 0, суммы есть на других видах затрат,
COP Первичные затраты и COS Вторичные затраты, кот заданны в настройке обновления анализа результатов
СообщениеДобавлено: Пн, сен 10 2007, 08:21
Вот такую информацию можно просмотреть если при расчете заказа включить журнал выполнения.... Что-то не нравиться системе моя категория НПOО
Распределение Версия/ВидЗатр/Операция: 0 3298000000 НПOО
Общее значение (сальдо) 14,61- USD
Значение периода 14,61- USD
Обработка разграниченных значений
Категория релевантна для результата -
Категория <> РГУБ Резервные отчисления на грозящие убытки
Категория <> РГУО РезервнОтчисления на ГрозящУбытки с учетом
Категория <> ЗОOО Затраты по обороту, оприходование обязател
Категория <> ЗОOВ Затраты по обороту, оприходование по выбор
Категория <> ЗОOН Затраты по обороту, oприходование невозмож
Категория <> РОСУ Убыток (РОС-метод)
Категория <> РОСР Реализованный убыток (РОС-метод, ДопАнализ
Категория <> ФВОР Оцененная ФактВыручка/ОтражНаРезультатах в
Правило проводки для FI сущест -
Распределение Версия/ВидЗатр/Операция: 0 3299000000 НПOО
Общее значение (сальдо) 11,41- USD
Значение периода 11,41- USD
