Текущее время: Вт, сен 29 2026, 01:32
 Заголовок сообщения: не получается расчет тарифов
СообщениеДобавлено: Ср, май 16 2007, 16:25
Чт, янв 18 2007, 10:30
Уважаемые гуру!
При расчете тарифов KSII выдается сообщение "Входящее соотношение работ в частичной итерации".
Diagnosis
In iterative activity price calculation, an activity relationship was determined between cost center 1002, activity type 102 and cost center 1001, activity type 101. Cost center 1002 is not included in the partial quantity to be iterated. The iterative network is therefore not complete, which can lead to calculated activity prices which do not agree with those resulting from an overall iteration.
System Response
The activity relationship is transfered, but it is not complete.
Procedure
Check the activity relationship. If a manually-set activity price existsfor cost center 1002, activity type 102, the relationship is correct. If an iterative activity price exists, you should check whether iterative relationships were used. If in doubt, run activity price calculation for the entire controlling area.
Кто-нибудь сталкивался с такой проблемой? Что нам делать? SOS :?
