Текущее время: Пт, авг 14 2026, 23:45
 Заголовок сообщения: Расчет надбавок
СообщениеДобавлено: Ср, авг 04 2010, 12:21
Ср, май 19 2010, 12:37
Возникла динамическая ошибка помогите ее решить
ДинамОшибка GETWA_NOT_ASSIGNED
Дата и время 04.08.2010 10:42:51
Краткий текст
Field symbol has not yet been assigned.
Что произошло?
Error in the ABAP Application Program
The current ABAP program "SAPLKASC" had to be terminated because it has
come across a statement that unfortunately cannot be executed.
Что Вы можете сделать?
Note down which actions and inputs caused the error.
To process the problem further, contact you SAP system
administrator.
Using Transaction ST22 for ABAP Dump Analysis, you can look
at and manage termination messages, and you can also
keep them for a long time.
Анализ ошибки
You attempted to access an unassigned field symbol
(data segment 32774).
This error may occur if
- You address a typed field symbol before it has been set with
ASSIGN
- You address a field symbol that pointed to the line of an
internal table that was deleted
- You address a field symbol that was previously reset using
UNASSIGN or that pointed to a local field that no
longer exists
- You address a global function interface, although the
respective function module is not active - that is, is
not in the list of active calls. The list of active calls
can be taken from this short dump.
Указания по устранению ошибки
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
"GETWA_NOT_ASSIGNED" " "
"SAPLKASC" or "LKASCF13"
"CREDIT_SEGMENTS_ADD"
Информация о месте прерывания
Termination occurred in the ABAP program "SAPLKASC" - in "CREDIT_SEGMENTS_ADD".
The main program was "SAPLKAZB ".
In the source code you have the termination point in line 134
of the (Include) program "LKASCF13".
127 * determine object data
128 read table xcoiob assigning <f_coiob>
129 with key objnr = ld_objnr
130 datbi = id_budat
131 binary search.
132 if sy-subrc <> 0.
133 read table xcoiob assigning <f_coiob> index sy-tabix.
>>> if <f_coiob>-objnr = ld_objnr
135 and <f_coiob>-datbi ge id_budat.
136 * right item found
137 else.
При анализе проблеммы проверены на корректность схемы калькуляции , кредитования, базы исчисления, надбавки, основные данные по заказам.
Помогите пожалуйста , сроки "поджимают".
 Заголовок сообщения: Re: Расчет надбавок
СообщениеДобавлено: Ср, авг 04 2010, 13:21
Пт, апр 10 2009, 11:13
Ну так поставьте точку прерывания на 133 строке и посмотрите чего он пытается считать и чего не находит...
А еще можно проверить:
1. не активированы ли какие экзиты для расчета надбавок
2. все ли корректно настроено для объекта в части FM
СообщениеДобавлено: Чт, авг 05 2010, 09:35
Подскажите какие настройки FM могут быть связаны с модулем СО в данном случае (чтобы можно проверить), так как в нашем проекте FM больше связан с ММ и FI , а настроек с модумем СО нет.
