Текущее время: Вс, сен 20 2026, 17:28
 Заголовок сообщения: Îøèáêà ïðè èíñòàëëÿöèè CRM 5.0 íà Solaris 9 !
СообщениеДобавлено: Пт, апр 20 2007, 10:17
Ср, янв 31 2007, 13:21
Ïðîáëåìà íà ýòàïå Start Java Engine. Ïðîñìîòðåë ëîãè è â dev_server0, à òàêæå â dev_sdm èìååòñÿ îäíà è òà æå îøèáêà
JStartupICheckFrameworkPackage: can't find framework package /usr/sap/CRI/DVEBMGS24/exe/jvmx.jar
 ñâÿçè ñ òåì, ÷òî ýòî ìîÿ ïåðâàÿ èíñòàëëÿöèÿ ñàìîñòîÿòåëüíî ðàçîáðàòüñÿ íå ìîãó. Ïî íîòàì ïîèñêàë åñòü ðàçëè÷íûå âàðèàíòû, îò óñòàíîâêè ïàðàìåòðà
jstartup/vm/home = <jdk home directory>
è óñòàíîâêè SHARED_POOL_SIZE=400000000
Ñìîæåò ëè êòî îáúÿñíèòü áåñòîëêîâîìó, ÷òî ìíå íàäî äåëàòü?
Äëÿ óäîáñòâà ñâÿçè ìîæíî èñïîëüçîâàòü ICQ 7241995 èëè Skype - RolandUlm
Çàðàíåå áëàãîäàðåí
 Заголовок сообщения: LOG ÈÇ DEV_JCONTROL
СообщениеДобавлено: Пт, апр 20 2007, 10:38
trc file: "/usr/sap/CRI/DVEBMGS24/work/dev_jcontrol", trc level: 1, release: "700"
node name : jcontrol
pid : 19879
system name : CRI
system nr. : 24
started at : Thu Apr 19 15:16:15 2007
arguments :
arg[00] : jcontrol
arg[01] : pf=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
arg[02] : -DSAPSTART=1
arg[03] : -DCONNECT_PORT=63082
arg[04] : -DSAPSYSTEM=24
arg[05] : -DSAPSYSTEMNAME=CRI
arg[06] : -DSAPMYNAME=sun450_CRI_24
arg[07] : -DSAPPROFILE=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
arg[08] : -DFRFC_FALLBACK=ON
arg[09] : -DFRFC_FALLBACK_HOST=localhost
[Thr 1] Thu Apr 19 15:16:15 2007
[Thr 1] *** WARNING => INFO: Unknown property [instance.en.host=sun450] [jstartxx_mt. 841]
[Thr 1] *** WARNING => INFO: Unknown property [instance.box.number=CRIDVEBMGS24sun450] [jstartxx_mt. 841]
[Thr 1] *** WARNING => INFO: Unknown property [instance.en.port=3225] [jstartxx_mt. 841]
[Thr 1] *** WARNING => INFO: Unknown property [instance.system.id=24] [jstartxx_mt. 841]
JStartupReadInstanceProperties: read instance properties [/usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties:/usr/sap/CRI/DVEBMGS24/SDM/program/config/sdm_jstartup.properties]
-> ms host : sun450
-> ms port : 3925
-> OS libs : /usr/sap/CRI/DVEBMGS24/j2ee/os_libs
-> Admin URL :
-> run mode : NORMAL
-> run action : NONE
-> enabled : yes
Used property files
-> files [00] : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
-> files [01] : /usr/sap/CRI/DVEBMGS24/SDM/program/config/sdm_jstartup.properties
Instance properties
-> ms host : sun450
-> ms port : 3925
-> os libs : /usr/sap/CRI/DVEBMGS24/j2ee/os_libs
-> admin URL :
-> enabled : yes
Bootstrap nodes
-> [00] bootstrap : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
Worker nodes
-> [00] sdm : /usr/sap/CRI/DVEBMGS24/SDM/program/config/sdm_jstartup.properties
[Thr 1] [Node: bootstrap] java home is set by profile parameter
Java Home: /usr/java
[Thr 1] Thu Apr 19 15:16:23 2007
[Thr 1] JStartupICheckFrameworkPackage: can't find framework package /usr/sap/CRI/SYS/exe/run/jvmx.jar
JStartupIReadSection: read node properties [bootstrap]
-> node name : bootstrap
-> node type : bootstrap
-> node execute : yes
-> java path : /usr/java
-> java parameters : -Djco.jarm=1
-> java vm version : 1.4.2_11-b06
-> java vm vendor : Java HotSpot(TM) 64-Bit Server VM (Sun Microsystems Inc.)
-> java vm type : server
-> java vm cpu : sparcv9
-> heap size : 512M
-> root path : /usr/sap/CRI/DVEBMGS24/j2ee/cluster
-> class path : ./bootstrap/launcher.jar
-> OS libs path : /usr/sap/CRI/DVEBMGS24/j2ee/os_libs
-> main class : com.sap.engine.offline.OfflineToolStart
-> framework class : com.sap.bc.proj.jstartup.JStartupFramework
-> registr. class : com.sap.bc.proj.jstartup.JStartupNatives
-> framework path : /usr/sap/CRI/SYS/exe/run/jstartup.jar:/usr/sap/CRI/SYS/exe/run/jvmx.jar
-> parameters : com.sap.engine.bootstrap.Bootstrap ./bootstrap ID2442741
-> debuggable : yes
-> debug mode : no
-> debug port : 60000
-> shutdown timeout : 120000
[Thr 1] SigISetDefaultAction : default handling for signal 18
[Thr 2] JControlDPMessageFunc: Thread 2 started as handler thread for R/3 dispatcher messages.
[Thr 1] JControlExecuteBootstrap: execute bootstrap process [bootstrap]
-> heap size : 512M
-> debuggable : yes
-> debug mode : no
JControlStartJLaunch: program = /usr/sap/CRI/DVEBMGS24/exe/jlaunch
-> arg[00] = /usr/sap/CRI/DVEBMGS24/exe/jlaunch
-> arg[01] = pf=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
-> arg[02] = -DSAPINFO=CRI_24_bootstrap
-> arg[03] = -nodeId=-1
-> arg[04] = -file=/usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
-> arg[05] = -syncSem=81
-> arg[06] = -nodeName=bootstrap
-> arg[07] = -jvmOutFile=/usr/sap/CRI/DVEBMGS24/work/jvm_bootstrap.out
-> arg[08] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_bootstrap.out
-> arg[09] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_bootstrap
-> arg[10] = -mode=BOOTSTRAP
-> arg[11] = pf=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
-> arg[12] = -DSAPSTART=1
-> arg[13] = -DCONNECT_PORT=63084
-> arg[14] = -DSAPSYSTEM=24
-> arg[15] = -DSAPSYSTEMNAME=CRI
-> arg[16] = -DSAPMYNAME=sun450_CRI_24
-> arg[17] = -DSAPPROFILE=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
-> arg[18] = -DFRFC_FALLBACK=ON
-> arg[19] = -DFRFC_FALLBACK_HOST=localhost
-> lib path = LD_LIBRARY_PATH=/usr/j2sdk1.4.2_11/jre/lib/sparcv9/server:/usr/j2sdk1.4.2_11/jre/lib/sparcv9:/usr/j2sdk1.4.2_11/jre/../lib/sparcv9:/usr/sap/CRI/DVEBMGS24/exe:/usr/sap/CRI/DVEBMGS24/exe:/usr/sap/CRI/DVEBMGS24/exe:/tmp/sapinst_exe.12781.1176975182:/usr/sap/CRI/SYS/exe/run:/oracle/client/10x_64/instantclient:/usr/lib:/usr/sap/CRI/DVEBMGS24/j2ee/os_libs:/usr/sap/CRI/DVEBMGS24/exe:/usr/sap/CRI/DVEBMGS24/exe:/usr/sap/CRI/DVEBMGS24/exe:/tmp/sapinst_exe.12781.1176975182:/usr/sap/CRI/SYS/exe/run:/oracle/client/10x_64/instantclient
-> exe path = PATH=/usr/java/bin:/usr/sap/CRI/DVEBMGS24/j2ee/os_libs:/oracle/CRI/102_64/bin:/usr/java/bin:.:/home/criadm:/usr/sap/CRI/SYS/exe/run:/usr/sbin:/usr/bin:/usr/dt/bin:/usr/openwin/bin:/bin:/usr/ucb:/usr/ccs/bin
[Thr 1] JStartupICreateProcess: fork process (pid 19884)
[Thr 1] Thu Apr 19 15:18:27 2007
[Thr 1] JControlExecuteBootstrap: read instance values after global bootstrap
-> ms host : sun450
-> ms port : 3925
-> Admin URL :
-> enabled : yes
[Thr 1] JControlExecuteBootstrap: enumerate the nodes after global bootstrap
Used property files
Instance properties
-> ms host : sun450
-> ms port : 3925
-> admin URL :
-> enabled : yes
Bootstrap nodes
-> [01] bootstrap_ID24427410 : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
-> [02] bootstrap_ID24427415 : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
Worker nodes
-> [00] ID244274100 : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
-> [01] ID244274150 : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/instance.properties
-> [02] sdm : /usr/sap/CRI/DVEBMGS24/SDM/program/config/sdm_jstartup.properties
[Thr 1] JControlExecuteBootstrap: execute bootstrap process [bootstrap_ID244274100]
[Thr 1] [Node: dispatcher bootstrap] java home is set by profile parameter
[Thr 1] Thu Apr 19 15:18:32 2007
JStartupIReadSection: read node properties [bootstrap_ID244274100]
-> node name : dispatcher bootstrap
-> jlaunch parameters :
-> heap size : 170M
-> parameters : com.sap.engine.bootstrap.Bootstrap ./bootstrap ID244274100
-> debuggable : yes
-> debug mode : no
-> arg[06] = -nodeName=bootstrap_ID244274100
-> arg[07] = -jvmOutFile=/usr/sap/CRI/DVEBMGS24/work/jvm_bootstrap_ID244274100.out
-> arg[08] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_bootstrap_ID244274100.out
-> arg[09] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_bootstrap_ID244274100
[Thr 1] JStartupICreateProcess: fork process (pid 19903)
[Thr 1] Thu Apr 19 15:19:12 2007
[Thr 1] JControlExecuteBootstrap: execute bootstrap process [bootstrap_ID244274150]
[Thr 1] [Node: server0 bootstrap] java home is set by profile parameter
[Thr 1] Thu Apr 19 15:19:17 2007
JStartupIReadSection: read node properties [bootstrap_ID244274150]
-> node name : server0 bootstrap
-> heap size : 1024M
-> parameters : com.sap.engine.bootstrap.Bootstrap ./bootstrap ID244274150
-> debuggable : yes
-> debug mode : no
-> arg[06] = -nodeName=bootstrap_ID244274150
-> arg[07] = -jvmOutFile=/usr/sap/CRI/DVEBMGS24/work/jvm_bootstrap_ID244274150.out
-> arg[08] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_bootstrap_ID244274150.out
-> arg[09] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_bootstrap_ID244274150
[Thr 1] JStartupICreateProcess: fork process (pid 19913)
[Thr 1] Thu Apr 19 15:20:55 2007
[Thr 1] JControlIBuildProcessList: Maximum error count is set to 4
[Thr 3] JControlRequestFunc: Thread 3 started as listener thread for np messages.
[Thr 1] *** WARNING => Maximum Java heap size specified twice (through maxHeapSize and in javaParameters) - using -Xmx170m [jstartxx_mt. 2604]
[Thr 1] [Node: dispatcher] java home is set by profile parameter
[Thr 1] Thu Apr 19 15:21:01 2007
JStartupIReadSection: read node properties [ID244274100]
-> node type : dispatcher
-> java parameters : -Djava.security.policy=./java.policy -Djava.security.egd=file:/dev/urandom -Djco.jarm=1 -Drdbms.driverLocation=/oracle/client/10x_64/instantclient/ojdbc14.jar
-> heap size : 170M
-> init heap size : 170M
-> root path : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/dispatcher
-> class path : ./bin/boot/boot.jar:./bin/system/bytecode.jar:.
-> main class : com.sap.engine.boot.Start
-> parameters :
-> debuggable : no
-> debug mode : no
[Thr 1] *** WARNING => Maximum Java heap size specified twice (through maxHeapSize and in javaParameters) - using -Xmx1024m [jstartxx_mt. 2604]
[Thr 1] [Node: server0] java home is set by profile parameter
[Thr 1] Thu Apr 19 15:21:04 2007
JStartupIReadSection: read node properties [ID244274150]
-> node type : server
-> java parameters : -Djava.security.policy=./java.policy -Djava.security.egd=file:/dev/urandom -Dorg.omg.CORBA.ORBClass=com.sap.engine.system.ORBProxy -Dorg.omg.CORBA.ORBSingletonClass=com.sap.engine.system.ORBSingletonProxy -Djavax.rmi.CORBA.PortableRemoteObjectClass=com.sap.engine.system.PortableRemoteObjectProxy -Dorg.xml.sax.driver=com.sap.engine.lib.xml.parser.SAXParser -verbose:gc -Djco.jarm=1 -XX:PermSize=256m -XX:MaxPermSize=256m -XX:NewSize=160m -XX:MaxNewSize=160m -XX:SurvivorRatio=2 -XX:TargetSurvivorRatio=90 -XX:+PrintGCTimeStamps -XX:+UseTLAB -XX:SoftRefLRUPolicyMSPerMB=1 -Dsun.io.useCanonCaches=false -Djava.awt.headless=true -XX:+UseParNewGC -Drdbms.driverLocation=/oracle/client/10x_64/instantclient/ojdbc14.jar
-> init heap size : 1024M
-> root path : /usr/sap/CRI/DVEBMGS24/j2ee/cluster/server0
-> class path : ./bin/boot/boot.jar:./bin/boot/jaas.jar:./bin/system/bytecode.jar:.
-> parameters :
-> debuggable : no
-> debug mode : no
-> debug port : 52421
[Thr 1] INFO: Invalid property value [Debbugable=yes]
[Thr 1] [Node: SDM] java home is set by profile parameter
[Thr 1] Thu Apr 19 15:21:07 2007
JStartupIReadSection: read node properties [sdm]
-> node name : SDM
-> node type : sdm
-> heap size : 256M
-> root path : /usr/sap/CRI/DVEBMGS24/SDM/program
-> class path : /usr/sap/CRI/DVEBMGS24/SDM/program/bin/SDM.jar
-> main class : SDMInternal
-> shutdown class : com.sap.sdm.jstartup.shutdown.InternalShutDown
-> parameters : server sdmhome=/usr/sap/CRI/DVEBMGS24/SDM/program
-> debuggable : yes
-> debug mode : no
[Thr 1] JControlMSConnect: attached to message server (sun450/3925)
[Thr 4] JControlMSMessageFunc: Thread 4 started as listener thread for ms messages.
-> arg[02] = -DSAPINFO=CRI_24_dispatcher
-> arg[03] = -nodeId=0
-> arg[06] = -nodeName=ID244274100
-> arg[07] = -jvmOutFile=/usr/sap/CRI/DVEBMGS24/work/jvm_dispatcher.out
-> arg[08] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_dispatcher.out
-> arg[09] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_dispatcher
-> arg[10] = -mode=JCONTROL
[Thr 1] JStartupICreateProcess: fork process (pid 19931)
[Thr 1] JControlICheckProcessList: process dispatcher started (PID:19931)
-> arg[02] = -DSAPINFO=CRI_24_server
-> arg[03] = -nodeId=1
-> arg[06] = -nodeName=ID244274150
-> arg[07] = -jvmOutFile=/usr/sap/CRI/DVEBMGS24/work/jvm_server0.out
-> arg[08] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_server0.out
-> arg[09] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_server0
[Thr 1] JStartupICreateProcess: fork process (pid 19932)
[Thr 1] JControlICheckProcessList: process server0 started (PID:19932)
-> arg[02] = -DSAPINFO=CRI_24_sdm
-> arg[03] = -nodeId=2
-> arg[04] = -file=/usr/sap/CRI/DVEBMGS24/SDM/program/config/sdm_jstartup.properties
-> arg[06] = -nodeName=sdm
-> arg[07] = -jvmOutFile=/usr/sap/CRI/DVEBMGS24/work/jvm_sdm.out
-> arg[08] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_sdm.out
-> arg[09] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_sdm
[Thr 1] JStartupICreateProcess: fork process (pid 19933)
[Thr 1] JControlICheckProcessList: process SDM started (PID:19933)
[Thr 1] JControlMSSendLogon: delete SDM logon information (rc=0)
[Thr 1] Thu Apr 19 15:21:12 2007
[Thr 1] JControlICheckProcessList: process server0 (pid:19932) died (RUN-FLAG)
[Thr 1] JControlIResetProcess: reset process server0
[Thr 1] JControlIResetProcess: [server0] not running -> increase error count (1)
[Thr 1] JControlICheckProcessList: running flight recorder:
/usr/java/bin/java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID244274150 1177003267 -bz /usr/sap/CRI/SYS/global
-> arg[08] = -jvmOutMode=append
-> arg[09] = -stdOutFile=/usr/sap/CRI/DVEBMGS24/work/std_server0.out
-> arg[10] = -stdOutMode=append
-> arg[11] = -traceMode=append
-> arg[12] = -locOutFile=/usr/sap/CRI/DVEBMGS24/work/dev_server0
-> arg[13] = -mode=JCONTROL
-> arg[14] = pf=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
-> arg[15] = -DSAPSTART=1
-> arg[16] = -DCONNECT_PORT=63084
-> arg[17] = -DSAPSYSTEM=24
-> arg[18] = -DSAPSYSTEMNAME=CRI
-> arg[19] = -DSAPMYNAME=sun450_CRI_24
-> arg[20] = -DSAPPROFILE=/usr/sap/CRI/SYS/profile/CRI_DVEBMGS24_sun450
-> arg[21] = -DFRFC_FALLBACK=ON
-> arg[22] = -DFRFC_FALLBACK_HOST=localhost
[Thr 1] Thu Apr 19 15:21:14 2007
[Thr 1] JStartupICreateProcess: fork process (pid 19942)
[Thr 1] JControlICheckProcessList: process server0 started (PID:19942)
[Thr 1] Thu Apr 19 15:21:19 2007
[Thr 1] JControlICheckProcessList: process server0 (pid:19942) died (RUN-FLAG)
[Thr 1] JControlIResetProcess: [server0] not running -> increase error count (2)
/usr/java/bin/java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID244274150 1177003274 -bz /usr/sap/CRI/SYS/global
[Thr 1] Thu Apr 19 15:21:20 2007
[Thr 1] JStartupICreateProcess: fork process (pid 19947)
[Thr 1] JControlICheckProcessList: process server0 started (PID:19947)
[Thr 1] Thu Apr 19 15:21:25 2007
[Thr 1] JControlICheckProcessList: process server0 (pid:19947) died (RUN-FLAG)
[Thr 1] JControlIResetProcess: [server0] not running -> increase error count (3)
/usr/java/bin/java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID244274150 1177003280 -bz /usr/sap/CRI/SYS/global
[Thr 1] Thu Apr 19 15:21:26 2007
[Thr 1] JStartupICreateProcess: fork process (pid 19953)
[Thr 1] JControlICheckProcessList: process server0 started (PID:19953)
[Thr 1] Thu Apr 19 15:21:31 2007
[Thr 1] JControlICheckProcessList: process server0 (pid:19953) died (RUN-FLAG)
[Thr 1] JControlIResetProcess: [server0] not running -> increase error count (4)
/usr/java/bin/java -classpath ../j2ee/cluster/bootstrap/sap.com~tc~bl~offline_launcher~impl.jar com.sap.engine.offline.OfflineToolStart com.sap.engine.flightrecorder.core.Collector ../j2ee/cluster/bootstrap -node ID244274150 1177003286 -bz /usr/sap/CRI/SYS/global
[Thr 1] Thu Apr 19 15:21:53 2007
[Thr 1] JControlMSSendLogon: insert SDM logon information (port=52418; rc=0)
СообщениеДобавлено: Пн, ноя 24 2008, 13:24
Чт, ноя 04 2004, 20:42
Столкнулся с такой же ошибкой, но на другой платформе. Удалось решить ?
СообщениеДобавлено: Пн, ноя 24 2008, 17:13
Проблему решили, но уже не я этим занимался. Так что, к сожалению, помочь ничем не могу. Но там какие-то косяки были с версиями Java.
