Текущее время: Пн, авг 24 2026, 05:45
 Заголовок сообщения: Solution manager - В качестве разделителя используйте '_'
СообщениеДобавлено: Пт, фев 02 2007, 18:53
Чт, ноя 25 2004, 09:01
При настройке присвоения к логическим системам, выбираю:
SAP SRM EBP-SRM SERVER
В ответ вижу
А ведь выбор из SAP-овских названий. Я сам ничего не придумывал.
Это как-нибудь лечится ?
СообщениеДобавлено: Сб, фев 03 2007, 12:29
Вт, авг 17 2004, 11:44
Знакомые грабли.
There is a problem with the SAP logical component template name.
Please have a look at the following general information:
The logical components which are delivered by SAP are only a template,
please create your own logical components for the systems which you
want to configure.
How to create a logical component and how to add the logical component
to the solution landscape is described in the IMG of the Solution
Manager system (transaction SPRO).
It's recommended to create your own logical component for each
satellite system.
If you didn't do this, please create a new logical component for every
system which is defined in "SMSY>Landscape Components>Systems". You can
do this in "SMSY>System Groups and Logical Components>Logical Components" and create a new logical component for the related products with a
name syntax like "Z<PRODUCT/RELEASE>_SERRVER_<SID>", choose the
correct product version and add the logical system name (SID:CLIENT)
only to the 'Production System' field of the logical component. After
this add the new logical component to your Solution Landscape in "SMSY>
System Groups and Logical Components>Solution Landscapes - Operations"
If the "Leading role of the solution" for your Solution Landscape does
not correspond with the 'System' field which is used in the logical
component you can activate the system manually in the Solution Directory by select the system with your right mouse button and select "Put in
solution".
СообщениеДобавлено: Пн, фев 05 2007, 12:26
Спасибо.
То что надо.
