Текущее время: Пн, авг 24 2026, 13:33
 Заголовок сообщения: Ошибка при установке sapinst
СообщениеДобавлено: Вс, мар 22 2015, 18:12
Вс, мар 22 2015, 17:39
Добрый день! При установке minisap файл sapinst.exe вылетает такая ошибка, подскажите, пожалуйста, в чем может быть дело? loopback адаптер установлен, в host-файл записи внесены.
Заранее спасибо.
Running msiexec failed with return code 1620: This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package.
Commandline was msiexec.exe /norestart /L ._vcredist_x86.log /i ._vcredist_x86.msi /qn
If you want the installer to retry, choose Yes. If you want the installer to abort the installation, choose No.
log-файл:
Program is starting... Please wait!
Starting GUIServer using:
SAPinst port : 21200
GUIServer port: 21212
HTTP port : 4239
GUI autostart : on
GUI mode : normal
command : "C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/sapinst_exe.1632.1427034315/jre/bin\java.exe" -cp "C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/sapinst_exe.1632.1427034315\jar\instgui.jar" -Xmx256M -Dsun.java2d.noddraw=true -Dsap.env.var.javahome=SAPINST_JRE_HOME SDTGui sapinst host=localhost port=21200 -nolock
load resource pool C:\Documents and Settings\Administrator\Desktop\SAPNWABAP701SR1_TRIAL\SAP_NetWeaver701SR1_2008_Installation_Master\IM_WINDOWS_I386\resourcepool.xml
guiengine: No GUI server connected; waiting for a connection on host Netweaver, port 21200 to continue with the installation
Mar 22, 2015 6:25:53 PM [Info]: *************************
Mar 22, 2015 6:25:53 PM [Info]: Starting Server
Mar 22, 2015 6:25:53 PM [Info]: Reading server configuration.
Mar 22, 2015 6:25:55 PM [Info]: Reading service configuration SAPinstService.
Mar 22, 2015 6:25:55 PM [Info]: Configuring LogManager ...
Mar 22, 2015 6:25:55 PM [Info]: *************************************************
Mar 22, 2015 6:25:55 PM [Info]: Starting SL Controller ...
Mar 22, 2015 6:25:55 PM [Info]: StorageService switched off.
Mar 22, 2015 6:25:55 PM [Info]: Initializing SecurityManager ...
Mar 22, 2015 6:25:55 PM [Info]: Key Store management switched off.
Mar 22, 2015 6:25:56 PM [Info]: Configuring HTTPManager ...
Mar 22, 2015 6:25:56 PM [Info]: WebstartService switched off.
Mar 22, 2015 6:25:56 PM [Info]: RoleService switched off.
Mar 22, 2015 6:25:56 PM [Info]: AlertService switched off.
Mar 22, 2015 6:25:56 PM [Info]: NotesService switched off.
Mar 22, 2015 6:25:56 PM [Info]: ProcessService switched off.
Mar 22, 2015 6:25:56 PM [Info]: Starting MIDService ...
Mar 22, 2015 6:25:57 PM [Info]: Starting FileService ...
Mar 22, 2015 6:25:57 PM [Info]: LogService switched off.
Mar 22, 2015 6:25:57 PM [Info]: MailService switched off.
Mar 22, 2015 6:25:57 PM [Info]: Starting services ...
Mar 22, 2015 6:25:57 PM [Info]: Starting service "SAPinstService" ...
Mar 22, 2015 6:25:58 PM [Info]: Service "SAPinstService" started
Mar 22, 2015 6:25:58 PM [Info]: Services started.
Mar 22, 2015 6:25:58 PM [Info]: Starting HTTP server listening on port 4239 ...
Mar 22, 2015 6:25:58 PM [Info]: HTTP server started.
Mar 22, 2015 6:25:58 PM [Info]: SL Controller started.
Mar 22, 2015 6:25:58 PM [Info]: Starting GUI ...
guiengine: 2015-03-22 18:26:14 Login in progress
guiengine: 2015-03-22 18:26:15 Login successful
Mar 22, 2015 6:26:20 PM [Info]: GUI started.
INFO 2015-03-22 18:25:44.703 [synxcpath.cpp:776]
CSyPath::createFile()
Creating file C:\Program Files\sapinst_instdir\x.
INFO 2015-03-22 18:25:44.703 [synxcfile.cpp:177]
CSyFileImpl::remove()
Removing file C:\Program Files\sapinst_instdir\x.
INFO 2015-03-22 18:26:32.484 [synxcpath.cpp:776]
Creating file C:\Program Files\sapinst_instdir\NW701\AS-ABAP\ADA\CENTRAL\x.
INFO 2015-03-22 18:26:32.484 [synxcfile.cpp:177]
Removing file C:\Program Files\sapinst_instdir\NW701\AS-ABAP\ADA\CENTRAL\x.
INFO 2015-03-22 18:27:22.109 [synxcpath.cpp:776]
INFO 2015-03-22 18:27:22.109 [synxcfile.cpp:177]
INFO 2015-03-22 18:27:38.750 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.6.xml, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.xml' to 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.6.xml'.
INFO 2015-03-22 18:27:39.890 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.7.xml, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.xml' to 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.7.xml'.
WARNING 2015-03-22 18:27:42.750 [synxcpath.cpp:912]
CSyPath::getOSNodeType(bool )
Unable to get information about path \\LABEL.ASC\ using GetVolumeInformation. Operating system error message: The filename, directory name, or volume label syntax is incorrect.
INFO 2015-03-22 18:27:49.937 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/inifile.4.xml, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/inifile.xml' to 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/inifile.4.xml'.
INFO 2015-03-22 18:27:49.984 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/inifile.5.xml, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/inifile.xml' to 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/inifile.5.xml'.
INFO 2015-03-22 18:27:51.390 [sixxcstepexecute.cpp:388]
Execute step
Component W2K_ServicePack_Check|ind|ind|ind|ind
Preprocess of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|W2K_ServicePack_Check|ind|ind|ind|ind|2|0
INFO 2015-03-22 18:28:08.703 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/keydb.3.xml, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/keydb.xml' to 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/keydb.3.xml'.
INFO 2015-03-22 18:28:08.796 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.8.xml, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.xml' to 'C:/Program Files/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/statistic.8.xml'.
INFO 2015-03-22 18:28:08.843 [sixxcstepexecute.cpp:790]
Execute step adminCheck of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|W2K_ServicePack_Check|ind|ind|ind|ind|2|0
INFO 2015-03-22 18:28:09.265 [sixxcstepexecute.cpp:790]
Execute step W2KSPCheck of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|W2K_ServicePack_Check|ind|ind|ind|ind|2|0
INFO 2015-03-22 18:28:09.531 [sixxcstepexecute.cpp:790]
Execute step XPSPCheck of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|W2K_ServicePack_Check|ind|ind|ind|ind|2|0
INFO 2015-03-22 18:28:09.828 [sixxcstepexecute.cpp:790]
Execute step DNSCheck of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0
INFO 2015-03-22 18:28:10.125
CJSlibModule::writeInfo_impl()
DNS is configured correctly.
INFO 2015-03-22 18:28:10.328 [sixxcstepexecute.cpp:790]
Execute step done of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0
INFO 2015-03-22 18:28:10.703 [sixxcstepexecute.cpp:790]
Execute step ntpatch of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|NW_Update_DLLs|ind|ind|ind|ind|3|0
INFO 2015-03-22 18:28:11.281
Node C:\WINDOWS\system32 already exists.
INFO 2015-03-22 18:28:11.359 [synxcfile.cpp:493]
CSyFileImpl::copy(const CSyPath & ._vcredist_x86.msi, ISyNode::CopyMoveMode_t 0x3, ISyProgressObserver*) const
Copied file 'C:/Documents and Settings/Administrator/Desktop/SAPNWABAP701SR1_TRIAL/SAP_NetWeaver701SR1_2008_Installation_Master/IM_WINDOWS_I386/NTPATCH/._vcredist_x86.msi' to '._vcredist_x86.msi'.
INFO 2015-03-22 18:28:11.390 [synxcpath.cpp:776]
Creating file C:\Program Files\sapinst_instdir\NW701\AS-ABAP\ADA\CENTRAL\msiexec.log.
INFO 2015-03-22 18:28:11.515
Output of msiexec.exe /norestart /L ._vcredist_x86.log /i ._vcredist_x86.msi /qn is written to the logfile msiexec.log.
WARNING 2015-03-22 18:28:12.437
CJSlibModule::writeWarning_impl()
Execution of the command "msiexec.exe /norestart /L ._vcredist_x86.log /i ._vcredist_x86.msi /qn" finished with return code 1620. Output:
T
INFO 2015-03-22 19:11:39.031 [synxcpath.cpp:776]
INFO 2015-03-22 19:11:40.484
WARNING 2015-03-22 19:11:45.281
T
ERROR 2015-03-22 19:19:44.546
CJSlibModule::writeError_impl()
MOS-01257 Running 'msiexec' failed with return code 1620: This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package.
. Commandline was: <msiexec.exe /norestart /L ._vcredist_x86.log /i ._vcredist_x86.msi /qn>
ERROR 2015-03-22 19:19:46.781 [sixxcstepexecute.cpp:950]
FCO-00011 The step ntpatch with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|NW_Update_DLLs|ind|ind|ind|ind|3|0|ntpatch was executed with status ERROR ( Last error reported by the step :Running 'msiexec' failed with return code 1620: This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package.
. Commandline was: <msiexec.exe /norestart /L ._vcredist_x86.log /i ._vcredist_x86.msi /qn>).
INFO 2015-03-22 19:20:34.906 [sixxcstepexecute.cpp:995]
An error occured and the user decided to retry the current step: "|NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|1|0|NW_Update_DLLs|ind|ind|ind|ind|3|0|ntpatch".
INFO 2015-03-22 19:20:40.828
INFO 2015-03-22 19:20:40.937 [synxcfile.cpp:493]
INFO 2015-03-22 19:20:41.140 [synxcpath.cpp:776]
INFO 2015-03-22 19:20:41.250
WARNING 2015-03-22 19:20:41.765
T
ERROR 2015-03-22 19:20:45.593
Mar 22, 2015 7:21:06 PM [Info]: Stopping services ...
Mar 22, 2015 7:21:06 PM [Info]: Stopping service "SAPinstService" ...
Mar 22, 2015 7:21:06 PM [Info]: Service "SAPinstService" stopped.
Mar 22, 2015 7:21:06 PM [Info]: Services stopped.
Mar 22, 2015 7:21:06 PM [Info]: Server shutdown by SAPinstService
Exit status of child: -1073741819
