Текущее время: Сб, июл 25 2026, 13:53
 Заголовок сообщения: Kelly Services - FI,CO,PS,BW,PP,PM,АВАР,SD,ProjectManager,senior FI/CO,SD/MM,HR - 02.04.2007
СообщениеДобавлено: Ср, авг 09 2006, 11:28
Администратор
Администратор
Пн, авг 16 2004, 21:27
Работа во втором по величине в Европе Швейцарском банке UBS.
Вопросами оформления разрешения на работу занимается работодатель.
Компенсация и relocation package обсуждаемы в каждом случае отдельно.
Если Вы заинтересованы в какой-либо из этих вакансий - отправляйте,
пожалуйста, Ваше резюме на k.kuznetsov@kellyservices.ru
Application Manager
The team is responsible for the company and the further development of the
SAP Accounting solutions and appears towards the customer as a general
manager. As an Application Manager in SAP FI, CO & PS the following
activities belong to your responsibilities:
- 2nd level Support (ticket management)
- Care of operational interfaces
- intervene at performance issue
- Market observations (SAP, other suppliers, other users)
- Process and system consulting
- Prototyping
- Specifications to developing orders
- Process implementation incl. Customizing
- Test of new functionalities
- Education and training of the expert User and the final user
- Provide and administer the expiry descriptions and the training
documents Coordination of general requirements within the scope of the
different platforms Coordination the expert
- User Co-operation and management of projects
To do justice to the requirements of this place, bring the following
education, occupational experience and competence:
- Master's certificate (economic information scientist, business
management)
- Some years of experience in the analysis and conversion /
Customizing of business requirements
- Experience in the project guidance
- Several years of experience in SAP R/3 projects and
customizinexperience in SAP FI, CO and PS
- Business Warhouse knowledge is an advantage
- Readiness for occasional, project-conditioned foreign stays
- Very good English
Personally you distinguish yourselve by flexibility, dependability and
loading capacity and are used to work independently
Web Developer in SAP
Your area of responsibility encloses the developing of worldwide used
Inhouse web applications which are realised within the SAP Competence
centre . You work in different projects and to your urge of development
there are no boundaries set. You are not only responsible for the
development but also for the comprehensive process of development also the
analysis which contains consultation as well as the Support
To successfully fulfil the tasks mentioned on top, you are bringing with
you following education, occupational experiences and competences:
- Degree as an information scientist / economic information
scientist
- Deepend knowledge in ABAP/4, ABAP/-OO
- Experience with model View Controller
- Know-how over one or several SAP modules, in particular their
structures and extension possibilities
- Knowledge in application design
- Very good English written and spoken
Business Analysts
who dispose a profound and practically oriented knowledge of the
bankingbusiness and understand to compile suitable IT solutions together
with the developers.
As a business analyst you work independently bank-technical problems,
analyze available processes and functionalities, provide business
specifications and tune this with the default architecture. In the
conversion phase you narrowly co-operate with your team colleagues of the
application development.They judge the delivered solutions within the
scope of the Application-Testing. Because we accompany our solutions
during the whole life cycle, you become active also with production
problems for the bank-technical aspects and guarantee the suitable
Support.
To fulfil successfully the mentioned tasks, you bring the following
occupational experience and competence with you:
- Banking business education, economic information scientist or
equivalent education
- Some years of occupational experience in the bank sphere are an
advantage
- Understanding of connections in the data modelling
- Knowledge of Cognos products is an advantage
- Very Good English written and spoken
Data Warehouse Developer
your area of responsibility encloses:
- Data analysis and data quality investigations of source systems
- Analysis of the needs of information and consultation of the data
subscribers
- Design of the data transformation processes and loading processes
as well as the processing rules
- Development of measures to the increase of the data quality
- Assistance with the data modelling
- Implementation of the transformation processes, primarily under
the use of transformation tools and SQL
- Realisation of tests, partially together with business
representatives
- Documentation of the system components
- Production Support
To do justice to the steadily growing requirements, we use for these tasks
the most modern technologies for example, AIX on IBM RS6000 cluster and
use as a database DB2 / UDB. In addition, we work with standardised tools
as for example power centre in the maping area
- Hands on experience in UNIX, mainly AIX (Shell programming)
- DB2 UDB EEE, eventually also other relational database systems
- Deep hands on experience in SQL
- Experience in dealing with complex data models and big databases
- Experience in dealing with data transformation tools (Informatica
power centre / Powermart)
- Experience in Data Warehousing
- Banking business knowledge
Data Warhouse Data Application Engineer (ITLT)
In this function you are responsible for the design and the Implementation
of relational Data Marts in Oracle and on it of based universes in the
area WM&BB with the help of business Objects (BOBJ). From these Marts you
generate reports which are available to the end users through a web client
(InfoView). In addition analysis and Implementation of user requirement
specifications as well as the technical development in the database area
and the support of the professional place BOBJ (3rd level Support) belongs
to your tasks. You co-operate with other projects which are using BOBJ.
To meet our requirements for this position you bring following hands on
experiences and competences with you:
- Advanced technical college end or similar technical education
- Basic Knowledge in datawarehouse standards/ROLAP
- Good technical understanding in Oracle/SQL
Personally you distinguish yourselves by initiative, ability of getting
through, dependability as well as analytic and structured way of thinking.
If you work team-oriented and are communicative, we should absolutely
become acquainted.
Кирилл Кузнецов
Последний раз редактировалось Admin Ср, окт 04 2006, 14:59, всего редактировалось 1 раз.
СообщениеДобавлено: Ср, авг 16 2006, 10:57
Вт, мар 29 2005, 19:54
В крупной российской производственной компании открыта вакансия:
Консультант SAP по модулю PP (PP-MRP, PP-PPI, PP-SOP)
Требования к кандидату: опыт внедрения как минимум одного проекта от концептуального проектирования до продуктивного старта. Участие на проекте в роли консультанта PP. Длительность проекта не менее года. Знание функционала SAP PP (укрупненное планирование сбыта и производства, планирование потребности в материалах, производственные заказы, серийное производство), желательно сертификация SAP.
Обязанности: Выполнение полного цикла работ по внедрению функционала планирование и управление производством в SAP R/3.
Условия: оформление по ТК РФ, з/п белая: от 2500$ (после налогообложения), ежеквартальные премии, предоставление мобильной связи. Работа в офисе в центре Санкт-Петербурга. Командировки около 30% в Москву
Если Вы заинтересованы в этой вакансии - отправьте, пожалуйста, Ваше резюме на j.strelnikova@kellyservices.ru
Спасибо!
СообщениеДобавлено: Ср, окт 04 2006, 15:00
Администратор
Администратор
В крупной производственной российской компании в Санкт-Петербурге открыта позиция программиста АВАР.
Обязанности:
Участие в проекте внедрения и программировании ERP- системы SAP с нуля.
Требования:
Необходимый опыт работы в программировании АВАР от 1 года.
Условия:
Компания предлагает оформление по трудовому кодексу РФ,
"белую" заработную плату, квартальные бонусы.
Пожалуйста, присылайте Ваши резюме на j.strelnikova@kellyservices.ru
C Уважением,
Юлия Стрельникова
Консультант по подбору персонала
СообщениеДобавлено: Ср, янв 24 2007, 00:39
Ср, янв 12 2005, 13:39
закрыто
SAP FI специалист
Крупная международная компания приглашает SAP FI специалиста (внутренний проект в Москве).
Обязанности: поддержка, обучение пользователей; развитие (настройка и разработка), оптимизация SAP приложений по финансам; ведение технической и пользовательской документации.
Требования: в/о, практический опыт использования или внедрения SAP приложений по направлению финансы от 1-го года. Знания в функциональных областях SAP (FI ?; CO, MM, SD ? в части взаимодействия с FI). Знание основ АВАР-программирования, а также владение английским языком приветствуется.
Условия: белая з/п, 95 000 руб. + соц.пакет.
SAP Logistcs Specialist (SD&BW)
Крупная международная компания приглашает SAP SD and BW специалиста (внутренний проект в Москве).
Обязанности: поддержка, обучение пользователей; развитие (настройка и разработка), оптимизация SAP приложений по логистике; ведение технической и пользовательской документации.
Требования: в/о, практический опыт использования или внедрения SAP SD and BW от 2-х лет. Знание основ АВАР-программирования, а также владение английским языком приветствуется.
Менеджер проекта SAP R/3
Ведущая международная консалтинговая компания приглашает менеджера проекта по внедрению SAP R/3.
Обязанности: руководство проектом по внедрению SAP R/3 на всех этапах; согласование требований с заказчиком, управление ресурсами, сроками, бюджетом, рисками, оформление проектной документации.
Требования: в/о, участие как минимум в одном завершенном проекте внедрения SAP R/3 в качестве менеджера проекта, английский язык. Рассматриваются резюме специалистов из других городов.
Условия: белая з/п, высокая, оклад + бонус (по итогам собеседования), соц.пакет.
Senior Consultant SAP FI/CO
Ведущая международная консалтинговая компания приглашает ведущего консультанта по внедрению SAP FI/CO.
Обязанности: участие в проекте по внедрению SAP R/3 FI/CO. Согласование функциональных требований, обследование бизнес-процессов, постановка ТЗ, настройка модуля, обучение пользователей, оформление проектной документации, руководство группой консультантов.
Требования: в/о, участие как минимум в двух завершенных проектах внедрения SAP R/3 FI/CO, знание предметной области финансы, английский язык. Рассматриваются резюме специалистов из других городов.
Условия: белая з/п, оклад + бонус (по итогам собеседования), соц.пакет.
Consultant SAP MM/SD
Ведущая международная консалтинговая компания приглашает консультанта по внедрению SAP MM/SD.
Обязанности: участие в проекте по внедрению SAP R/3 MM/SD. Согласование функциональных требований, обследование бизнес-процессов, постановка ТЗ, настройка модуля, обучение пользователей, оформление проектной документации.
Требования: в/о, участие как минимум в одном завершенном проекте внедрения SAP R/3 MM/SD, знание предметной области логистика, английский язык. Рассматриваются резюме специалистов из других городов.
Ведущая международная консалтинговая компания приглашает консультанта по внедрению SAP FI/CO.
Обязанности: участие в проекте по внедрению SAP R/3 FI/CO. Согласование функциональных требований, обследование бизнес-процессов, постановка ТЗ, настройка модуля, обучение пользователей, оформление проектной документации.
Требования: в/о, участие как минимум в одном завершенном проекте внедрения SAP R/3 FI/CO, знание предметной области финансы, английский язык. Рассматриваются резюме специалистов из других городов.
Consultant SAP PP/PM
Ведущая международная консалтинговая компания приглашает консультанта по внедрению SAP PP/PM.
Обязанности: участие в проекте по внедрению SAP R/3 PP/PM. Согласование функциональных требований, постановка ТЗ, настройка модуля, обучение пользователей, оформление проектной документации.
Требования: в/о, участие как минимум в одном завершенном проекте внедрения SAP R/3 PP/PM, английский язык. Рассматриваются резюме специалистов из других городов.
Kind Regards,
Anthon Semenov
Staffing Assistant
Kelly Services IT / Telecom Resources
Phone: 961-14-07 ext. 2136
www.kellyservices.ru
