Текущее время: Сб, авг 08 2026, 13:58
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: System Copy NW710 XI/PI
СообщениеДобавлено: Ср, мар 09 2011, 15:59
Ср, июн 16 2010, 14:16
Привет!
Выполняю System Copy NW710 XI/PI (гетерогенное) с целью получения тестовой системы.
Win2003 Enterprise SP2 x64 , Oracle 10.2.0.4
Зависло на стадии Import ABAP.
Import_monitor.log:
TRACE: 2011-03-09 14:52:11 com.sap.inst.migmon.LoadTask run
Loading of 'SAPDFACT' import package is started.
Loading of 'SAPDODS' import package is started.
TRACE: 2011-03-09 14:52:11 com.sap.inst.migmon.LoadTask processPackage
Loading of 'SAPDODS' import package into database:
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe -i SAPDODS.cmd -dbcodepage 4103 -k 1W1gf5M50Dh01eqte1It0a53 -l SAPDODS.log -stop_on_error -loadprocedure fast
Loading of 'SAPDFACT' import package into database:
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe -i SAPDFACT.cmd -dbcodepage 4103 -k 1W1gf5M50Dh01eqte1It0a53 -l SAPDFACT.log -stop_on_error -loadprocedure fast
ERROR: 2011-03-09 14:52:12 com.sap.inst.migmon.LoadTask run
Loading of 'SAPDFACT' import package is interrupted with R3load error.
Process 'D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe -i SAPDFACT.cmd -dbcodepage 4103 -k 1W1gf5M50Dh01eqte1It0a53 -l SAPDFACT.log -stop_on_error -loadprocedure fast' exited with return code 2.
For mode details see 'SAPDFACT.log' file.
Standard error output:
sapparam: sapargv(argc, argv) has not been called!
sapparam(1c): No Profile used.
sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline
Loading of 'SAPDODS' import package is interrupted with R3load error.
Process 'D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe -i SAPDODS.cmd -dbcodepage 4103 -k 1W1gf5M50Dh01eqte1It0a53 -l SAPDODS.log -stop_on_error -loadprocedure fast' exited with return code 2.
For mode details see 'SAPDODS.log' file.
WARNING: 2011-03-09 14:52:41
Cannot start import of packages with views because not all import packages with tables are loaded successfully.
2 error(s) during processing of packages.
import_monitor.java.log
Java(TM) 2 Runtime Environment, Standard Edition (build 5.1.015)
SAP Java 64-Bit Server VM (build 5.1.015, Nov  5 2007 23:34:18 - 01_REL - optU - windows amd64 - bas2:88748 (mixed mode))
Import Monitor jobs: running 1, waiting 2, completed 50, failed 0, total 53.
Import Monitor jobs: running 2, waiting 1, completed 50, failed 0, total 53.
Loading of 'SAPDFACT' import package: ERROR
Import Monitor jobs: running 1, waiting 1, completed 50, failed 1, total 53.
Loading of 'SAPDODS' import package: ERROR
Import Monitor jobs: running 0, waiting 1, completed 50, failed 2, total 53.
SAPDODS.log
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20110309145212
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe: sccsid @(#) $Id: //bas/710_REL/src/R3ld/R3load/R3ldmain.c#17 $ SAP
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe: version R7.10/V1.4 [UNICODE]
Compiled May 25 2009 23:51:25
DbSl Trace: ORA-1403 when accessing table SAPUSER
(DB) INFO: connected to DB
(DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8
(GSI) INFO: dbname   = "SID20110304110358        "
(GSI) INFO: vname    = "ORACLE                          "
(GSI) INFO: hostname = "xxxxxxxxxx                "
(GSI) INFO: sysname  = "Windows NT"
(GSI) INFO: nodename = "xxxxxxxxxx"
(GSI) INFO: release  = "5.2"
(GSI) INFO: version  = "3790 Service Pack 2"
(GSI) INFO: machine  = "2x AMD64 Level 6 (Mod 15 Step 8)"
(SQL) INFO: Trying to open H:\export_XP1\ABAP\DB/ORA/DODS.SQL
(SQL) INFO: H:\export_XP1\ABAP\DB/ORA/DODS.SQL opened
(DB) ERROR: DDL statement failed
(DROP TABLE "/BIC/B0000103000")
DbSlExecute: rc = 103
  (SQL error 942)
  error message returned by DbSl:
ORA-00942: table or view does not exist
(IMP) INFO: a failed DROP attempt is not necessarily a problem
DbSl Trace: Error 439 in exec_immediate() from oci_execute_stmt(), orpc=0
DbSl Trace: ORA-00439 occurred when executing SQL stmt (parse error offset=0)
(   CREATE TABLE "/BIC/B0000103000"       ("REQUEST" VARCHAR2 (000090)         DEFAULT ' ' NOT NULL,        "DATAPAKID" VARCHAR2 (000018)         DEFAULT '000000' NOT NULL,        "PARTNO" NUMBER (000010)         DEFAULT 0 NOT NULL,        "RECORD" NUMBER (000010)         DEFAULT 0 NOT NULL,        "RSPL_SUBPL" VARCHAR2 (000060)         DEFAULT ' ' NOT NULL,        "RSPL_PLSES" VARCHAR2 (000009)         DEFAULT '000' NOT NULL,        "RSPL_ORG" VARCHAR2 (000180)         DEFAULT ' ' NOT NULL,        "RSPL_AGNT" VARCHAR2 (000036)         DEFAULT ' ' NOT NULL,        "RSPL_CUSER" VARCHAR2 (000036)         DEFAULT ' ' NOT NULL,        "RSPL_TSTMP" VARCHAR2 (000042)         DEFAULT '00000000000000' NOT NULL,        "RECORDMODE" VARCHAR2 (000003)         DEFAULT ' ' NOT NULL)       PCTFREE 00       PCTUSED 00       INITRANS 001       TABLESPACE PSAPSR3       STORAGE (INITIAL     0000000016 K                NEXT        0000000016 K                MINEXTENTS  0000000001                MAXEXTENTS  2147483645                PCTINCREASE 0000                FREELISTS   001                FREELIST GROUPS 01)          PARTITION BY RANGE ("PARTNO")          (      PARTITION "/BIC/B00001030000000000002" VALUES LESS THAN      (0000000002)      TABLESPACE "PSAPSR3") )
DbSlExecute: rc = 99
  (SQL error 439)
ORA-00439: feature not enabled: Partitioning
(DB) INFO: disconnected from DB
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe: job finished with 1 error(s)
D:\usr\sap\SID\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20110309145212
SAPDFACT.log
(GSI) INFO: hostname = "xxxxxxxxxxxx                                                     "
(GSI) INFO: nodename = "xxxxxxxxxxx"
(SQL) INFO: Trying to open H:\export_XP1\ABAP\DB/ORA/DFACT.SQL
(SQL) INFO: H:\export_XP1\ABAP\DB/ORA/DFACT.SQL opened
(DROP INDEX "/BI0/E0PPM_VC1~020")
  (SQL error 1418)
ORA-01418: specified index does not exist
(   CREATE BITMAP            INDEX "/BI0/E0PPM_VC1~020" ON "/BI0/E0PPM_VC1"        ("KEY_0PPM_VC1T")        PCTFREE 10        INITRANS 002        TABLESPACE PSAPSR3        STORAGE (INITIAL     0000000016 K                 NEXT        0000000016 K                 MINEXTENTS  0000000001                 MAXEXTENTS  UNLIMITED                 PCTINCREASE 0000                 FREELISTS   001) )
  (SQL error 439)
ORA-00439: feature not enabled: Bit-mapped indexes
Помогите, плиз, пройти эти ошибки.
Заранее спасибо!
 Заголовок сообщения: Re: System Copy NW710 XI/PI
СообщениеДобавлено: Ср, мар 09 2011, 16:36
Ср, май 03 2006, 11:43
Посмотрите ноту Note 370819 - ORA-439: Feature not enabled: Partitioning там правда решение на 8-ку. Но указанный параметр можно проверить.
Еще metalink note 225688.1
Доступ на металинк в ноте 758563
СообщениеДобавлено: Ср, мар 09 2011, 16:53
Вт, июл 24 2007, 14:52
sapinst предоставляет response-файл для нужных опций при установке oracle
видимо устанавливали без него
СообщениеДобавлено: Ср, мар 09 2011, 16:55
Ludens написал:
на каком этапе?
DDL-statements я выгружал из source system на этапе экспорта.
СообщениеДобавлено: Ср, мар 09 2011, 17:00
на этапе когда sapinst тормозит и говорит "а теперь установите оракл"
СообщениеДобавлено: Ср, мар 09 2011, 17:01
Покажите актуальные параметры из init<SID>.ora
СообщениеДобавлено: Ср, мар 09 2011, 17:02
Ludens написал:
Я выполняю с галочкой "замена существующей системы"
СообщениеДобавлено: Ср, мар 09 2011, 17:13
figaro001 написал:
#  (c)Copyright SAP AG, Walldorf                          #
# @(#) $Id: //bc/710-1_REL/src/ins/SAPINST/impl/tpls/ora/ind/INITSIDBASE.ORA#2 $
# PART I, TUNING PARAMETERS                               #
#### SYSTEM GLOBAL AREA BUFFERS
# Total System Global Area = sum(bytes) of all caches
# Variable Size = shared_pool_size (approx.)
# Database Buffers = db_block_buffers * db_block_size
# Redo Buffers = log_buffer
# unit of shared_pool_size: bytes
# unit of db_block_buffers: number of cached blocks
# unit of log_buffer: bytes
shared_pool_size = 623955148
# 10% of shared_pool_size
shared_pool_reserved_size = 62395514
log_buffer = 1048576
#### MANAGING SORTS
# A small sort requires sort_area_retained_size in
# memory. Larger sorts are allocating segments in
# PSAPTEMP. They are using sort_area_size in memory.
sort_area_retained_size = 0
sort_area_size = 2097152
#sort_spacemap_size = 512
#### PGA-PARAMETERS
open_cursors = 800
#cursor_space_for_time =  true
#### LOCKS
# dml_locks = processes * 50
dml_locks = 4000
#enqueue_resources = 8000
#### CPU-PARAMETERS
#spin_count = 200
#_cpu_count = 4
#### TUNING ARCHIVING
#log_archive_buffer_size      127
#log_archive_buffers      4
#### USE VECTOR READ
#use_readv = true
#### OTHER TUNING PARAMETERS
#sequence_cache_entries = 100
#sequence_cache_hash_buckets = 89
# PART II, CHANGEABLE PARAMETERS                          #
#### CONTROL-FILES
# the controlfiles should be mirrored to every new
# database mount point @SAPDATA_HOME@/sapdata<#>
#control_files = @SAPDATA1@/cntrl/cntrlSID.dbf @SAPDATA2@/cntrl/cntrlSID.dbf @SAPDATA3@/cntrl/cntrlSID.dbf
#### AUTOMATICLY STARTED BACKGROUND PROCESSES
#### MANAGING LOG SWITCHES
# checkpoints occur only when switching logs, if
# log_checkpoint_interval * size of OS blocks > size of
# the actual redo log
log_checkpoint_interval = 0
#log_checkpoint_timeout = 0
#### PROCESS-PARAMETERS
# The number of allocated semaphores is equal to the
# number of processes
# sessions = 1.2 * processes
processes = 80
sessions  = 160
#### AUDITING AND STATISTICS
# sql_trace=TRUE
# audit_trail = true
# db_block_lru_extended_statistics = 1000
# db_block_lru_statistics = true
# PART III, STATIC PARAMETERS                             #
#### DB-NAME
db_name = SID
#### DB-BLOCKSIZE
db_block_size = 8192
#### DB-FILES
db_files = 254
#### OPTIMIZER MODE
#optimizer_mode = choose
#optimizer_search_limit = 3
#### PATHS / DESTINATIONS / TRACES
# H:\oracle\SID\saptrace\background: trace files of the background
# processes
# H:\oracle\SID\saptrace\usertrace:  trace files of the user processes
# log_archive_dest is a destination, not a path.
# The archivefiles get the name
# H:\oracle\SID\oraarch\SIDarch<thread#>_<log#>
background_dump_dest = H:\oracle\SID\saptrace\background
user_dump_dest       = H:\oracle\SID\saptrace\usertrace
core_dump_dest       = H:\oracle\SID\saptrace\background
log_archive_dest     = H:\oracle\SID\oraarch\SIDarch
#log_archive_format  = %t_%s
#### OTHER
# reduce_alarm only supported on HP
#reduce_alarm = TRUE
#### ORACLE OPS PARAMETER
remote_os_authent = true
# retention time for RMAN backup information in control file
control_file_record_keep_time = 30
#see SAP note 124361
#db_file_multiblock_read_count = 8
log_checkpoints_to_alert = true
#### OPTIMIZER MODE
#optimizer_index_cost_adj = 10
#timed_statistics = true
compatible = 10.2.0
optimizer_features_enable = 10.2.0.1
undo_retention = 43200
undo_tablespace = PSAPUNDO
undo_management = AUTO
pga_aggregate_target = 629145600
workarea_size_policy = AUTO
sga_max_size = 1247910297
db_cache_size = 623955148
statistics_level = typical
job_queue_processes = 1
remote_login_passwordfile = exclusive
recyclebin = off
event = "10191 trace name context forever, level 1"
_OPTIM_PEEK_USER_BINDS = FALSE
FILESYSTEMIO_OPTIONS = setall
control_files = (D:\oracle\SID\origlogA\cntrl\cntrlSID.dbf, D:\oracle\SID\origlogB\cntrl\cntrlSID.dbf, H:\oracle\SID\sapdata1\cntrl\cntrlSID.dbf)
СообщениеДобавлено: Ср, мар 09 2011, 17:25
Ок, с файлом все в порядке, только потом постинсталяционные шаги нужно обязательно сделать по Ораклу. После инсталляции патч накатывали?
Металинк смотрели?
СообщениеДобавлено: Ср, мар 09 2011, 17:42
Патч накатывал.
СообщениеДобавлено: Ср, мар 09 2011, 17:52
Start и Stop Базы проходит успешно?
СообщениеДобавлено: Ср, мар 09 2011, 17:57
Так точно:
SQL> shutdown;
Database closed.
Database dismounted.
ORACLE instance shut down.
SQL> startup;
ORACLE instance started.
Total System Global Area 1325400064 bytes
Fixed Size                  2065536 bytes
Variable Size             671091584 bytes
Database Buffers          637534208 bytes
Redo Buffers               14708736 bytes
Database mounted.
Database opened.
SQL>
СообщениеДобавлено: Ср, мар 09 2011, 18:01
SQL>select * from v$option where parameter = 'Partitioning';
СообщениеДобавлено: Ср, мар 09 2011, 18:02
SQL> select * from v$option where parameter = 'Partitioning';
PARAMETER
VALUE
Partitioning
FALSE
СообщениеДобавлено: Ср, мар 09 2011, 18:11
Надеюсь Вы делаете скриншоты всех действий. Меня интересует как вы инсталлировали Оракл? В пункте Available Product Compononents" там должна быть отмечена галочкой только опция "partitioning"
Если что, то можно не сносить всё, а запустить инсталлятор, Выбрать режим Custom и удалить (проинсталировать) нужные компоненты, потом накрыть патчем (в случае инсталяции).
