Текущее время: Вт, авг 18 2026, 20:11
 Заголовок сообщения: Закрыть вопрос по поиску User-Exits
СообщениеДобавлено: Пт, окт 06 2006, 14:42
Пт, окт 06 2006, 14:17
Для поиска "пользовательских выходов" пользуйтесь плз. данным отчетиком , просто и надежно , и не надо каждый раз спрашивать :)
:D :D
REPORT Z_show_all_user_exits no standard page heading.
tables : tstc, tadir, modsapt, modact, trdir, tfdir, enlfdir.
tables : tstct.
data : jtab like tadir occurs 0 with header line.
data : field1(30).
data : v_devclass like tadir-devclass.
parameters : p_tcode like tstc-tcode obligatory.
select single * from tstc where tcode eq p_tcode.
if sy-subrc eq 0.
select single * from tadir where pgmid = 'R3TR'
and object = 'PROG'
and obj_name = tstc-pgmna.
move : tadir-devclass to v_devclass.
if sy-subrc ne 0.
select single * from trdir where name = tstc-pgmna.
if trdir-subc eq 'F'.
select single * from tfdir where pname = tstc-pgmna.
select single * from enlfdir where funcname =
tfdir-funcname.
and object = 'FUGR'
and obj_name eq enlfdir-area.
endif.
endif.
select * from tadir into table jtab
and object = 'SMOD'
and devclass = v_devclass.
select single * from tstct where sprsl eq sy-langu and
tcode eq p_tcode.
format color col_positive intensified off.
write:/(19) 'Transaction Code - ',
20(20) p_tcode,
45(50) tstct-ttext.
skip.
if not jtab[] is initial.
write:/(95) sy-uline.
format color col_heading intensified on.
write:/1 sy-vline,
2 'Nombre Exit',
21 sy-vline ,
22 'Descripcion',
95 sy-vline.
loop at jtab.
select single * from modsapt
where sprsl = sy-langu and
name = jtab-obj_name.
format color col_normal intensified off.
write:/1 sy-vline,
2 jtab-obj_name hotspot on,
21 sy-vline ,
22 modsapt-modtext,
95 sy-vline.
endloop.
describe table jtab.
skip.
format color col_total intensified on.
write:/ 'Nъmero de Exits:' , sy-tfill.
else.
format color col_negative intensified on.
write:/(95) 'No existe ninguna user exit'.
endif.
else.
write:/(95) 'El cуdigo de transacciуn no existe'.
endif.
at line-selection.
get cursor field field1.
check field1(4) eq 'JTAB'.
set parameter id 'MON' field sy-lisel+1(10).
call transaction 'SMOD' and skip first screen.
СообщениеДобавлено: Пт, окт 06 2006, 14:49
Ср, ноя 23 2005, 13:37
Ба-а-а-я-я-ян:
http://sapboard.ru/forum/viewtopic.php?t=1771
http://sapboard.ru/forum/viewtopic.php?t=6781
http://sapboard.ru/forum/viewtopic.php?t=14622
http://sapboard.ru/forum/viewtopic.php?t=15612
http://sapboard.ru/forum/viewtopic.php?t=18571
Лучшее из того, что я видел:
http://sapfans.com/forums/viewtopic.php?t=236062
(эта ссылка тоже здесь пробегала).
СообщениеДобавлено: Пт, окт 06 2006, 15:07
sibrin написал:
Согласен полностю :D :D :!:
СообщениеДобавлено: Пн, окт 09 2006, 13:50
Пн, окт 02 2006, 13:46
попробовал прогу из http://sapfans.com/forums/viewtopic.php?t=236062
и выпал дамп при P_TCODE = CJ01 :D
пока не разбирался в чем ошибка :P
а так нормальная прога, удобная 8)
