Текущее время: Вт, сен 15 2026, 03:36
 Заголовок сообщения: Переход на партионный учет
СообщениеДобавлено: Пт, дек 18 2009, 11:45
Вт, окт 10 2006, 16:37
Всем привет!
САП сделал report'ик (RVBCONVMAT2BM), c помощью которого можно переходить на партионный учет, не снося запас и т.п. Думаю, что многим будет полезно знать.
Краткое описание из того толмуда, что прислали:
Basically the conversion tool can only be used in a pure R/3 environment. If the R/3 system is linked to
an APO, please take into account the additional steps listed in chapter 2.4. Using the tool in combination
with other components or an industry solution is to be discussed separately. A complete list of all
prerequisites for the use of the conversion tool can be found in chapter 1.5 ‘Prerequisites for using the
conversion tool’.
Report RVBCONVMAT2BM activates Batch Management for a material ( = batch numbers are unique
per material or client) or a combination of material and plant ( = batch numbers are unique per plant).
Please note that the Tool is a special development by the Batch Development Team. We can only
guarantee a proper working of the tool and provide support for conversion-related issues for R/3-systems
that have been analysed by us concerning relevant master data and document data. Please contact
SAP, if the tool is to be used in a ‘new’ environment in order to clarify on whether a new analysis
concerning master data and document data has to be performed.
We recommend to schedule a sufficient timeframe for the testing. First you should carrying out test runs
in a test-system on a recent client copy of your production system (both in test mode and update mode).
Moreover when using the tool in your production system, please run the tool in test mode first before
starting it in update mode. Due to this procedure it is possible to identify and correct problems before the
update run starts.
Кто-нибудь пробовал использовать?
 Заголовок сообщения: Re: Переход на партионный учет
СообщениеДобавлено: Пт, дек 18 2009, 22:22
Круто! А я полгода назад сам мастерил создание копий ОЗМ и перенос на них запаса для перехода на партионный учет. А все, уже, оказывается придумано..
СообщениеДобавлено: Пн, дек 21 2009, 09:45
LKU написал:
Там хитрее, хотя замутить прожку, как у тебя, тоже хорошая идея.
Там активируется партионный учет для существующих материалов (без создания новых): без списания запасов (создается партия, куда все существующие запасы на уровне таблиц переносятся), учитываются серийные номера и т.п. И все это без лишних проводок.
СообщениеДобавлено: Пн, дек 21 2009, 10:03
Ну, понятно, что плодить двойников некрасиво. Но я ж не САП, чтобы переносить запасы на уровне таблиц в продуктиве :)
СообщениеДобавлено: Вт, фев 09 2010, 11:25
Вт, янв 24 2006, 15:07
Система ERP2005.
Что-то не могу найти такую прогу RVBCONVMAT2BM, или она приходит с каким-то пакетом?
СообщениеДобавлено: Вт, фев 09 2010, 11:38
Пт, янв 30 2009, 16:19
viewtopic.php?f=1&t=57366
Waverzzz: "С программкой есть прикол: САП не продает ее отдельно от своего консалта :)) "
СообщениеДобавлено: Ср, мар 16 2011, 11:48
Ср, мар 21 2007, 17:32
Подскажите, может SAP уже постарался для тех, кто хочет партионный учет начать вести на некоторых заводах, а не на всех?
Нужно перемещать материалы с завода непартионного на завод партионный, при этом уровень партии уже активирован на уровне материала :(
