Текущее время: Вт, сен 22 2026, 13:41
 Заголовок сообщения: Error in phase: XPRA_EXECUT : SPAM SP SAPKIBIFP2
СообщениеДобавлено: Чт, июл 28 2005, 16:15
Всем привет!
Система SCM 4.1. Вот инсталирую в SPAM Support Packages для BI-Content 3.53, SAP 6.40. Возникла следующая ошибка:For SAPKIBIFP2 I have follow Error Message :
________________________________________________
Te import was stopped, since an error occurred during the phase XPRA_EXECUTION, which the Support Package Manager is unable to resolve without your input. After you have corrected the cause of the error, continue with the Import by choosing Support Package -> Import queue from the initial screen of the Support Package Manager.
The following details help you to analyze the problem:
- Error in phase:XPRA_EXECUTION
- Reason for error: TP_STEP_FAILURE
- Return code: 0012
- Error message: OCS Package SAPKIBIFP2, tp step R, return code 0012
otes on phase XPRA_EXECUTION he XPRAs and after-import methods are executed in this phase. This phase can terminate due to the following reasons: TP_INTERFACE_FAILURE: The system was unable to call the tp interface.
TP_FAILURE: The system was unable to execute the tp program. For
more information, see the SLOG or ALOG log file. TP_STEP_FAILURE: The system was unable to execute the XPRA_EXECUTION
tp step. To see the cause of the error in the method execution log,
choose Goto -> Log -> Queue.
JOBLOG
Program terminated job: RDDEXECL
Step 001 started (program RDDEXECL, variant , user ID DDIC)
All DB buffers of application server sbsapo were synchronized
ABAP/4 processor: GETWA_NOT_ASSIGNED
Job cancelled
Кто-нибудь сталкивался с подобной проблемой ?
Спасибо.
СообщениеДобавлено: Чт, июл 28 2005, 16:36
Вт, авг 17 2004, 08:17
Смотри дамп GETWA_NOT_ASSIGNED в ST22.
СообщениеДобавлено: Чт, июл 28 2005, 17:29
Я уже изучала этот DUMP и искала по ключевым словам в OSS, без результата.
Вот как он выглядит :
Runtime Errors GETWA_NOT_ASSIGNED
Date and Time 28.07.2005 13:59:13
ShrtText Field symbol has not yet been assigned.
What happened? Error in ABAP application program.
The current ABAP program "SAPLRSDG_IOBJ_DB_READ" had to be terminated because one of the statements could not be executed. This is probably due to an error in the ABAP program.
use the following search criteria:
"GETWA_NOT_ASSIGNED" C
"SAPLRSDG_IOBJ_DB_READ" or "LRSDG_IOBJ_DB_READF10"
"ATR_NAV_FILTER_BCT_COMP"
СообщениеДобавлено: Чт, июл 28 2005, 17:42
Уже обсуждалось вот тут http://sapboard.ru/forum/viewtopic.php?t=6003
нота 844007 - правда в ней correction instruction указан для bw 30. Однако, это решение подходит и для 35. Пробовал - все получилось. :)
СообщениеДобавлено: Чт, июл 28 2005, 17:48
Кстати сейчас уже, похоже, можно обойтись без этой ноты, если предврительно накатить 13-й пак для BW. Во всяком случае сегодня у меня на новой системе все прошло чистенько.
Ну т.е. после чистой установки последовательно поднимаем BASIS до 13-го, ABA тоже, PI_BASIS до 10-го, BW до 13-го и BI_CONT до 5-го.
СообщениеДобавлено: Чт, июл 28 2005, 17:55
СПАСИБО. Завтра попытаюсь выполнить инструкции из 844007. А на счет 13-го SP уже не получится, SPAM уже заблокирован и его проинсталировать невозможно. Или кто-нибудь знает трюк как мне сделатй на этой фазе инсталяции SP.
СообщениеДобавлено: Пт, июл 29 2005, 11:24
Можно разблокировать, только последствия могут быть неприятные ))
Если интересно - пишите в почту, расскажу.
Лучше сделать по ноте.
СообщениеДобавлено: Пт, июл 29 2005, 16:10
Bнимательно прочитала 844007 и 0783254, но что то подходящего решения не могу найти. С чего начать? На что обратить внимание?
Спасибо,
Erika
СообщениеДобавлено: Пт, июл 29 2005, 16:22
В ноте есть раздел correction instruction и меняем соответсвующий объект по этой инструкции :)
СообщениеДобавлено: Пн, авг 01 2005, 10:23
В Note 844007 нет Correction Instruction. Kакая Note актуальна для меня, 783254, я что-то уже здесь запуталась... а в ней ссылка на кучу других...
Спасибо
СообщениеДобавлено: Пн, авг 01 2005, 10:42
Спасибо
Актуальна 844007. Вот смотрю на нее, есть Correction Instruction...
REPS LRSDG_IOBJ_DB_READF10
FORM ATR_NAV_FILTER_BCT_COMP
Delta 001
Context Block
CALL FUNCTION 'RSD_IOBJ_GET'
i_iobjnm = <l_s_atr_nav>-attrinm
i_objvers = rs_c_objvers-delivery
EXCEPTIONS
iobj_not_found = 0
bct_comp_invalid = 1.
IF sy-subrc <> 0.
DELETE c_t_atr_nav.
Delete Block
ENDIF.
Insert Block
CONTINUE.
ENDIF.
СообщениеДобавлено: Пн, авг 01 2005, 11:48
Ну вот какая же я слепая курица. Все 844007 ипроинсталлировала, теперь буду пробовать заново инсталлировать!
:P
СообщениеДобавлено: Пн, авг 01 2005, 11:50
Support Packages. Все от перепутала уже ! :shock:
СообщениеДобавлено: Пн, авг 01 2005, 11:56
УРРРРРРРРРРРРРРРРРРААААААААААА ! ВСЕ ОК! Всем громадное СПАСИБО!
Проблема РЕШЕНА! SP' s BI- Content 3.53 проинсталлированы!
:D :) :D
СообщениеДобавлено: Пн, авг 01 2005, 12:11
Чт, май 12 2005, 14:34
Да, а мне пришлось всю систему сносить :lol:
и заного с 13 патчами, ибо прова девелопера не имею :roll:
