Текущее время: Пн, авг 24 2026, 20:41
 Заголовок сообщения: Перевод в сапе.
СообщениеДобавлено: Вт, дек 17 2013, 19:44
Вт, июл 29 2008, 10:51
Нашел новую ноту - 1953331 - Correction of translation of 'Automatic Account Determination'
Symptom
Wrong translation
Other Terms
SE63,
Solution
Translation of objects using transaction SE63 (see further below) / Delivery with Support Package
Transport Object(s):
PgID Object Name
R3TR TRAN J3RKKRS
Package: J3RK
Software Component: SAP_APPL
Application Component: FI-LOC-FI-RU
English Text: Automatic Account Determination
Wrong Target Text: Автомотическое определение счета
Correct Target Text: Автоматическое определение счета
The correction(s) will be delivered with support package:
Planned delivery:
SP25 for SAP_APPL 600 (SAPKH60025)
SP15 for SAP_APPL 602 (SAPKH60215)
SP14 for SAP_APPL 603 (SAPKH60314)
SP15 for SAP_APPL 604 (SAPKH60415)
SP12 for SAP_APPL 605 (SAPKH60512)
SP11 for SAP_APPL 606 (SAPKH60611)
SP06 for SAP_APPL 616 (SAPKH61606)
SP04 for SAP_APPL 617 (SAPKH61704)
Please refer to the SAP Support Package Stacks page in the SAP Service
Market Place: http://service.sap.com/sp-stacks
Alternatively the error can be corrected in translation object:
Object type (shortcut): TRAN
Object name: J3RKKRS
(Please check if the texts fit to your Support Package level!)
Please use transaction SE63 to translate the text(s).
Enter /oSE63 in the command field (transaction field) and press Enter
Enter Object type (see above) in the command field and press Enter
Enter Object name (see above) in the field Object Name
If required change Source and/or Target language
Press Edit
Enter or correct the translation in the text field below the source text
Choose Save to save your translation(s)
Choose Back (F3) to leave the translation editor
Please refer to the following notes:
585116 Translation after installation of WebAS SP25
110910 Deleting the language load
Note:
Translations performed in a customer system may be overwritten in the following instances:
If the object happens to be part of a future support package
Upgrade to a new release
Import of new language CDs from Support Releases
Transport of translations between customer systems:
Please transport the corrected translation object(s) to all relevant
systems (Transport of Copies):
PgID Object Name
LANG TRAN J3RKKRS
Or refer to one of the following notes:
669505 (for customers on Basis 620 or 640)
980626 (for customers on Basis 700 and higher)
Прецедент ? -)
 Заголовок сообщения: Re: Перевод в сапе.
СообщениеДобавлено: Чт, дек 19 2013, 07:47
Ср, ноя 07 2007, 11:36
а САП всё еще Логрус локализует?
СообщениеДобавлено: Чт, янв 02 2014, 23:15
Администратор
Администратор
Пн, авг 16 2004, 21:27
Мне кажется, что "импортировать щапрос" там будет до второго пришествия :)
Admin
e-mail: admin @ sapforum.ru
СообщениеДобавлено: Вт, янв 07 2014, 00:37
Пт, апр 28 2006, 22:39
Да они даже английский перевод не могут сделать нормально. Кнопка сохранения enhancement называется Sichern. :)
СообщениеДобавлено: Вт, янв 07 2014, 12:15
Пт, сен 28 2012, 13:20
Jelena написала:
Ну пропустил один "коллега" из ... (Индии) бывает, случается.
Он ведь со словом "тщательнее" не знаком :lol: :lol: .
