Текущее время: Пт, июл 03 2026, 09:52
 Заголовок сообщения: Динамическая ошибка при двойном клике АЛВ ячейке.
СообщениеДобавлено: Пт, окт 06 2006, 09:05
Ср, окт 04 2006, 16:07
<я не знать русский языка>.
Пишу так:
DATA: gt_outtab type table of ZPLANS .
  IF g_custom_container IS INITIAL.
    CREATE OBJECT g_custom_container
           EXPORTING container_name = g_container.
    CREATE OBJECT g_grid
           EXPORTING i_parent = g_custom_container.
*Ї1.Set status of all cells to editable using the layout structure.
    gs_layout-edit = 'X'.
*    select * from ZPLANS
*    into table temp_plans up to g_max rows.
PERFORM OptionFilds changing gt_fieldcat_lvc.
**set handler lcl_event_receiver=>handle_toolbar for g_grid.
*set handler lcl_event_receiver=>HANDLE_USER_COMMAND for g_grid.
    CALL METHOD g_grid->set_table_for_first_display
         EXPORTING i_structure_name = 'ZPLANS'
                   is_layout        = gs_layout
         CHANGING
                   it_outtab        = gt_outtab
                   it_fieldcatalog      = gt_fieldcat_lvc.
*Ї2.Use SET_READY_FOR_INPUT to allow editing initially.
*   (state "editable and ready for input").
    CALL METHOD g_grid->set_ready_for_input
          EXPORTING i_ready_for_input = 1.
  ENDIF.
FORM OptionFilds  changing pt_fieldcat type lvc_t_fcat.
data ls_alv type lvc_s_fcat.
  CALL FUNCTION 'LVC_FIELDCATALOG_MERGE'
    CHANGING
      ct_fieldcat      = pt_fieldcat.
  clear ls_alv.
   ls_alv-tabname = 'ZPLANS'.
   ls_alv-fieldname = 'POSICION'.
   ls_alv-coltext = ls_alv-seltext = 'Позиция'.
   ls_alv-style  = cl_gui_alv_grid=>mc_style_enabled.
   ls_alv-key = 'X'.
  INSERT ls_alv INTO pt_fieldcat index 1.
Все было нормально. Но при добавленнии блока:
  clear ls_alv.
   ls_alv-key = 'X'.
При двойном клике по любой ячейке падает в дамп:
Пишет:
Field symbol has not yet been assigned.
Что произошло?
Error in ABAP application program.
The current ABAP program "CL_GUI_ALV_GRID===============CP " had to be
terminated because one of the
statements could not be executed.
This is probably due to an error in the ABAP program.
002110 * If field has not DDIC referencen
002120 if ls_fieldcat-ref_table is initial.
002130 * Formal field check without DDIC reference
> call method me->formal_field_check_no_ddic
002150 exporting
002160 i_currency = <l_currency>
002170 i_value = ls_cells-value
002180 i_row_id = ls_cells-row_id
002190 i_tabix = l_tabix
002200 is_fieldcat = ls_fieldcat
002210 importing
002220 eflg_invalid = eflg_invalid
002230 changing
002240 c_field = <l_field>
002250 ct_good_cells = et_good_cells
002260 ct_mod_cells = et_mod_cells.
002270 else.
Я понимаю что неправильно добавил поле в АЛВ, но как будет правильно? :?
СообщениеДобавлено: Пт, окт 06 2006, 09:17
Ср, май 04 2005, 16:29
    CHANGING
  clear ls_alv.
   ls_alv-key = 'X'.
то есть теперь у вас в каталоге два поля с именем POSICION?
Может вы хотели не вставить а изменить поле?
СообщениеДобавлено: Пт, окт 06 2006, 09:24
Ну вот, Sibrin удалил пост..
А ведь может речь как раз о вставке нового поля :)
СообщениеДобавлено: Пт, окт 06 2006, 09:28
Я <я не знать русский языка>:
clear ls_alv.
   ls_alv-tabname = '1'.
   ls_alv-key = 'X'.
Поля POSICION в таблице ZPLANS нету. Я просто хочю добавить свое поле (вспомогательное) в АЛВ к полям ZPLANS.
Или нужно определять переменную POSICION + ZPLANS-<поля> и соответственно вызать АЛВ.
Последний раз редактировалось osmus Пт, окт 06 2006, 09:30, всего редактировалось 1 раз.
Ср, ноя 23 2005, 13:37
T написал:
Я внимательно прочитал вопрос и решил, что тогда бы ALV ругнулся сразу, а не при двойном клике...
Был не прав.
Для полной страховки можно заполнять так:
    DESCRIBE TABLE t_fieldcatalog LINES i.
    i = i + 1.
    fieldcat-fieldname = 'POSICION'.
    fieldcat-inttype = 'C'.
    fieldcat-intlen = '4'.
    fieldcat-outputlen = '4'.
    fieldcat-coltext = 'Позиция'.
    fieldcat-seltext = 'Позиция'.
    fieldcat-tooltip = 'Позиция'.
    fieldcat-row_pos = '1'.
    fieldcat-col_pos = i.
    fieldcat-col_id = i.
    fieldcat-tech_col = i.
    APPEND fieldcat TO t_fieldcatalog.
или использовать DATATYPE, DOMNAME.
Но ссылаться на таблицу не надо: ls_alv-tabname = ''.
СообщениеДобавлено: Пт, окт 06 2006, 09:50
sibrin написал:
Был не прав.
Да работает. По двойном клику ошибки нет.
Но оно его добавляет в конец :cry: .
А мне нужно чтоб оно добавило его в начало.
СообщениеДобавлено: Пт, окт 06 2006, 09:52
Да именно мне нужно вставить новое поле.
СообщениеДобавлено: Пт, окт 06 2006, 10:02
Так я для того подробно и написал:
Переномируйте по порядку и будет Вам счастье.
СообщениеДобавлено: Пт, окт 06 2006, 10:39
А при назначении этих параметров к примнру.
   ls_alv-row_pos = '0'.
    ls_alv-col_pos = '1'.
    ls_alv-col_id = '0'.
    ls_alv-tech_col = '0'.
Нужно здвигать значения всей таблицы на +1?
СообщениеДобавлено: Пт, окт 06 2006, 10:51
Да.
Поиграйтесь с параметрами.
Добавление столбца col_pos = '0' без сдвига всей таблицы тоже работает, но есть сомнения, что не всегда и не везде.
