Текущее время: Пт, сен 25 2026, 03:10
 Заголовок сообщения: Заполнение ALV Tree
СообщениеДобавлено: Чт, ноя 29 2007, 17:56
Чт, дек 07 2006, 16:32
Вроде все по науке... а не выходит.
*& Report  Z_TREE                                                      *
REPORT  Z_TREE.
INCLUDE <ICON>.
TYPES:  BEGIN OF ALV_TREE_TAB,
                 field01(10),
                 field02(10),
                 field03(10),
        END OF ALV_TREE_TAB.
DATA:
      ALV_TREE_TAB        TYPE STANDARD TABLE OF ALV_TREE_TAB,
      ALV_TREE_TAB_line   LIKE LINE OF ALV_TREE_TAB,
      ALV_FC              TYPE LVC_T_FCAT,
      ALV_FC_line         LIKE LINE OF ALV_FC,
      ALV_HIERARCHY_HEAD  TYPE TREEV_HHDR,
      ALV_LYOUT_NODE      TYPE LVC_S_LAYN,
      ALV_last_key          TYPE LVC_NKEY,
      ALV_TREE            TYPE REF TO CL_GUI_ALV_TREE,
      CUSTOM_CONTAINER    TYPE REF TO CL_GUI_CUSTOM_CONTAINER.
SET SCREEN 0001.
*&      Form  ALV_FILL_TREE_TAB
*       text
FORM ALV_FILL_TREE_TAB.
  CLEAR ALV_TREE_TAB[].
  CLEAR ALV_TREE_TAB_line.
  ALV_TREE_TAB_line-field01 = '1.1'.
  ALV_TREE_TAB_line-field02 = '1.2'.
  ALV_TREE_TAB_line-field03 = '1.3'.
  APPEND ALV_TREE_TAB_line TO ALV_TREE_TAB.
  ALV_TREE_TAB_line-field01 = '2.1'.
  ALV_TREE_TAB_line-field02 = '2.2'.
  ALV_TREE_TAB_line-field03 = '2.3'.
  ALV_TREE_TAB_line-field01 = '3.1'.
  ALV_TREE_TAB_line-field02 = '3.2'.
  ALV_TREE_TAB_line-field03 = '3.3'.
  ALV_TREE_TAB_line-field01 = '4.1'.
  ALV_TREE_TAB_line-field02 = '4.2'.
  ALV_TREE_TAB_line-field03 = '4.3'.
ENDFORM.                    "ALV_FILL_TREE_TAB
*&      Form  ALV_BUILD_FC
*       text
FORM ALV_BUILD_FC.
  CLEAR ALV_FC[].
  CLEAR ALV_FC_line.
  ALV_FC_line-fieldname   = 'FIELD01'.
  ALV_FC_line-outputlen   = 8.
  ALV_FC_line-scrtext_s   = 'Поле1'.
  APPEND ALV_FC_line TO ALV_FC.
  CLEAR ALV_FC_line.
  ALV_FC_line-fieldname   = 'FIELD02'.
  ALV_FC_line-scrtext_s   = 'Поле2'.
  CLEAR ALV_FC_line.
  ALV_FC_line-fieldname   = 'FIELD03'.
  ALV_FC_line-scrtext_s   = 'Поле3'.
ENDFORM.                    "ALV_BUILD_FC
*&      Form  ALV_ADD_NODE
*       text
FORM ALV_ADD_NODE USING
                        TAB_line    TYPE ALV_TREE_TAB
                        p_relat_key TYPE lvc_nkey
                  CHANGING
                        p_node_key  TYPE lvc_nkey.
  CALL METHOD ALV_TREE->ADD_NODE
      i_relat_node_key = p_relat_key
      i_relationship   = CL_GUI_COLUMN_TREE=>RELAT_LAST_CHILD
      is_outtab_line   = TAB_line
      i_node_text      = 'asadasd'
    IMPORTING
      e_new_node_key   = p_node_key.
ENDFORM.                    "ALV_ADD_NODE
*&      Module  PBO_0001  OUTPUT
*       text
MODULE PBO_0001 OUTPUT.
  SET PF-STATUS '0001'.
  IF CUSTOM_CONTAINER IS INITIAL.
    CREATE OBJECT CUSTOM_CONTAINER
        container_name = 'CUSTOM_CONTAINER'.
    CREATE OBJECT ALV_TREE
        parent              = CUSTOM_CONTAINER
        node_selection_mode = CL_GUI_COLUMN_TREE=>NODE_SEL_MODE_SINGLE
        item_selection      = 'X'
        no_html_header      = 'X'
        no_toolbar          = 'X'.
    PERFORM ALV_BUILD_FC.
    ALV_HIERARCHY_HEAD-heading = 'Ключевой столбец'(300).
    ALV_HIERARCHY_HEAD-tooltip = ''.
    ALV_HIERARCHY_HEAD-width = 35.
    ALV_HIERARCHY_HEAD-width_pix = ''.
    CALL METHOD ALV_TREE->SET_TABLE_FOR_FIRST_DISPLAY
        is_hierarchy_header = ALV_HIERARCHY_HEAD
      CHANGING
        it_fieldcatalog     = ALV_FC
        it_outtab           = ALV_TREE_TAB.
    PERFORM ALV_FILL_TREE_TAB.
ВОТ ИЗ ЭТОГО ЦИКЛА ПРОГРАММА НЕ ВЫХОДИТ, А ЗАВИСАЕТ НАВЕЧНО! ДАЖЕ В ДАМП НЕ СВАЛИВАЕТСЯ.... Почему?
    LOOP AT ALV_TREE_TAB INTO ALV_TREE_TAB_line.
      PERFORM ALV_ADD_NODE USING
                                ALV_TREE_TAB_line
                                ALV_last_key
                           CHANGING
                                ALV_last_key.
    ENDLOOP.
    CALL METHOD ALV_TREE->FRONTEND_UPDATE.
  ENDIF.
ENDMODULE.                 " PBO_0001  OUTPUT
*&      Module  PAI_USER_COMMAND_0001  INPUT
*       text
MODULE PAI_USER_COMMAND_0001 INPUT.
  DATA pai_ucomm_0001 LIKE SY-ucomm.
  pai_ucomm_0001 = SY-ucomm.
  CASE pai_ucomm_0001.
    WHEN 'CANCEL'.
      CALL METHOD CUSTOM_CONTAINER->FREE.
      LEAVE PROGRAM.
  ENDCASE.
ENDMODULE.                 " PAI_USER_COMMAND_0001  INPUT
я в пути и нет у меня никаких тревог и забот. одинокая лодка моя рассекая волну плывет...
СообщениеДобавлено: Чт, ноя 29 2007, 19:40
Ср, ноя 23 2005, 13:37
ALV_TREE->ADD_NODE добавляет строчку в ALV_TREE_TAB. Но просходит это в цикле по ALV_TREE_TAB. В дебаггере это должно быть хорошо видно.
Например, в программе BCALV_TREE_02 "по науке" — это две разные внутренние таблицы. И комментарий, решающий Вашу проблему, написан перед set_table_for_first_display:
* IMPORTANT: Table 'gt_sflight' must be empty. Do not change this table
* (even after this method call). You can change data of your table
* by calling methods of CL_GUI_ALV_TREE.
* Furthermore, the output table 'gt_outtab' must be global and can
* only be used for one ALV Tree Control.
СообщениеДобавлено: Пт, ноя 30 2007, 00:24
Ср, ноя 03 2004, 14:51
Не поверите... В BCALV_TREE_01 таже фигня написана :)
Пора собираться и писать ФАК.
СообщениеДобавлено: Пт, ноя 30 2007, 09:03
не... ну могла прога хоть бы в дамп свалиться ради приличия :D. Тупонул. Всем спасибо! :oops:
