Текущее время: Сб, авг 15 2026, 00:29
 Заголовок сообщения: Что делают операции AMT=VA*, AMT+VA*
СообщениеДобавлено: Вт, окт 21 2008, 17:14
Ср, апр 25 2007, 12:15
Всем добрый вечер!
При расчете налогов в правилах: RU-2, RU-3
есть такие операции (пример): AMT=VA* или AMT+VA*
Что это за параметр VA?
Не подскажите, что происходит с AMT в таких случаях.
И где об этом можно прочитать.
Большое СПАСИБО!!!
СообщениеДобавлено: Ср, окт 22 2008, 06:34
Вт, авг 24 2004, 07:19
Операция AMT, NUM, RTE – при считывании таблиц – специфика России
Russian-Specific Operands: First Variant
Object: Additional Operation Documentation
Explanation: You use the operands below for wage types, but the syntax of the   operands follows that of the second variant.
OOOOOO
XYnnnn
     X: Table
     Y: Special algorithm
     nnnn: Table field or other code
In the position of X, you can use the following operands with the corresponding special algorithms, Y.
     X     Y     Note
     V           Processes table IT. The system reads the wage type
                 specified in the places nnnn from the table that is
                 specified in place X. The NUM, RTE, or AMT field of
                 the wage type in question contains the value of the
                 operand.
           I     Reads table IT with all splits, including field ABZNR.
           A     Reads all records in table IT that relate to the wage
                 type in question, without taking into account the
                 splits. This results in the sum of all values for the
                 requested field.
           S     Similar to I but in addition, provides full
                 support for all splits (V0 too). As such, I is
                 included in the S variant.
     S           Processes table ORT. The system reads the wage type
                 operand.
           L     Reads the wage types related to the employee's last
                 place of work.
           A     Reads the wage type splits for absences. Absences
                 from OAB ( old absences, or absences from previous
                 payroll run).
           B     Works in the same way as A above, except that
                 in ORT (old results table), the system processes
                 records that relate to the last part of an employee's
                 leave.
           S     Reads wage types from ORT that have the split V0 of
                 type R in table AB. Before reading table ORT            ,
                 the wage type is substituted with the value from field
                 VINFO in table OV0. The meaning of the wage type does
                 not change.
           Space Reads all defined splits. Before reading the
                 splits, V0 AL, and C1 are adjusted to the current
                 values of internal tables.
     X           Reads the wage types stored in table ORT. If there
                 are several entries in this table, this operand reads
                 the last of the entries.
     You can use the following operand with the operation AMT only.
     D           Reads the requested wage type as stored in table
                 DDNTK, along with the origin, V0 assignment, as well
                 as the Deduction Reduced indicator activated.
           Space Defines the origin of arrears (A).
           Other Defines the origin directly.
СообщениеДобавлено: Ср, окт 22 2008, 06:53
Пт, сен 07 2007, 07:53
2 OlegDm.
Можно спросить, откуда взято это описание? Прямо из САПа? Т.е., если, например, прямо в редакторе правил встать на AMT и нажать F1, то можно получить этот текст?
Я почему спрашиваю, у нас в системе отсутствует российско-специфичные описания. Приходится залезать в исходники и смотреть по коду. А оказывается такое описание в принципе существует.
Интересно, у нас базисники что-то не доставили? Вы случайно не знаете, как появляются такие описания?
СообщениеДобавлено: Ср, окт 22 2008, 10:53
1. F1 на AMT
2. Далее жмем на Operands for NUM, RTE, and AMT в окне справки
3. Далее жмем на 1st Variant: Wage Types в окне справки
4. Далее жмем на слово Russia (также в окне справки) и получаем вышевыложенный текст справки
ERP 2005 (ECC 6.0), HR_SAP 29 level
СообщениеДобавлено: Ср, окт 22 2008, 13:58
2 OlegDm.
Спасибо, так я и думал. Вот только у нас системе Russia в help-е не встречается. Например, в справке по AMT есть ссылка на Austrian Taxes . А Рашы нет :(.
Правда у нас пока ECC 5.0.
