Текущее время: Сб, авг 08 2026, 23:27
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: ORA-3114 при формировании куба
СообщениеДобавлено: Ср, фев 11 2009, 14:29
Ср, авг 20 2008, 05:10
День добрый. Требуется помощь по решению проблемы, периодически возникающей при выгрузки данных из R3 в BW.
При возникновении проблемы формируется дамп :
Runtime Error          DBIF_DSQL2_SQL_ERROR
Exception              CX_SY_NATIVE_SQL_ERROR
       Occurred on     11.02.2009 at   04:04:37
SQL error 3114 occurred when executing EXEC SQL.
What happened?
The error occurred in the current database connection "R/3*".
Error analysis
An exception occurred. This exception is dealt with in more detail below
. The exception, which is assigned to the class 'CX_SY_NATIVE_SQL_ERROR', was
neither
caught nor passed along using a RAISING clause, in the procedure
"SID_RECORD_UPDATE" "(FORM)"
Since the caller of the procedure could not have expected this exception
to occur, the running program was terminated.
The reason for the exception is:
How to correct the error
The exception must either be prevented, caught within the procedure
"SID_RECORD_UPDATE"
"(FORM)", or declared in the procedure's RAISING clause.
To prevent the exception, note the following:
Database error text........: "ORA-03114: not connected to ORACLE"
Triggering SQL statement...: "UPDATE "/BI0/SREQUID" SET "DATAFL" = ? , "INCFL"
= ? WHERE "REQUID" = ? "
Internal call code.........: "[DBDS/NEW DSQL]"
Please check the entries in the system log (Transaction SM21).
You may able to find an interim solution to the problem
in the SAP note system. If you have access to the note system yourself,
use the following search criteria:
"DBIF_DSQL2_SQL_ERROR" CX_SY_NATIVE_SQL_ERRORC
"GP4DF48GB7N4FFLTLDLUGHMH8EA " or "GP4DF48GB7N4FFLTLDLUGHMH8EA "
"SID_RECORD_UPDATE"
В системном журнале BW слудующее
04:04:36 DIA 03 500 ALEREMOTE         BY2 Database error 3114 at EXE
04:04:36 DIA 03 500 ALEREMOTE         BY0 > ORA-03114: not connected to ORACLE
04:04:36 DIA 03 500 ALEREMOTE         R68 Perform rollback
04:04:36 DIA 03 500 ALEREMOTE         BYM SQL error 3114 . Work processes in reconnect status
04:04:36 DIA 03 500 ALEREMOTE         BYY Work process has left reconnect status
04:04:37 DIA 03 500 ALEREMOTE         AB0 Run-time error "DBIF_DSQL2_SQL_ERROR" occurred
04:04:38 DIA 03 500 ALEREMOTE         AB1 > Short dump "090211 040437 ornbw ALEREMOTE " generated
07:00:00 DIA 01 000 SAPSYS            EEA OPERATION MODES: Switch to operation mode DAY triggered
Кусочек алерта с продуктивной системы - никаких ошибок во время дампа:
Wed Feb 11 03:50:32 2009
/* BRCONNECT */ ALTER TABLESPACE "PSAPUSER1I" COALESCE
Completed: /* BRCONNECT */ ALTER TABLESPACE "PSAPUSER1I" COALESCE
/* BRCONNECT */ ALTER TABLESPACE "SYSTEM" COALESCE
Completed: /* BRCONNECT */ ALTER TABLESPACE "SYSTEM" COALESCE
Wed Feb 11 03:50:46 2009
Incremental checkpoint up to RBA [0x3650.9a6e.0], current log tail at RBA [0x3650.9b60.0]
Wed Feb 11 04:03:17 2009
Beginning log switch checkpoint up to RBA [0x3651.2.10], SCN: 938009152
Thread 1 advanced to log sequence 13905
  Current log# 13 seq# 13905 mem# 0: /oracle/ORN/origlogA/log_g13m1.dbf
  Current log# 13 seq# 13905 mem# 1: /oracle/ORN/mirrlogA/log_g13m2.dbf
Wed Feb 11 04:08:21 2009
Completed checkpoint up to RBA [0x3651.2.10], SCN: 938009152
Wed Feb 11 04:12:29 2009
Beginning log switch checkpoint up to RBA [0x3652.2.10], SCN: 938014202
Thread 1 advanced to log sequence 13906
  Current log# 15 seq# 13906 mem# 0: /oracle/ORN/origlogA/log_g15m1.dbf
  Current log# 15 seq# 13906 mem# 1: /oracle/ORN/mirrlogB/log_g15m2.dbf
Wed Feb 11 04:17:33 2009
Completed checkpoint up to RBA [0x3652.2.10], SCN: 938014202
Wed Feb 11 04:20:54 2009
Incremental checkpoint up to RBA [0x3652.24d0.0], current log tail at RBA [0x3652.5eb1.0]
Wed Feb 11 04:31:22 2009
Beginning log switch checkpoint up to RBA [0x3653.2.10], SCN: 938020635
Thread 1 advanced to log sequence 13907
  Current log# 11 seq# 13907 mem# 0: /oracle/ORN/origlogA/log_g11m1.dbf
  Current log# 11 seq# 13907 mem# 1: /oracle/ORN/mirrlogA/log_g11m2.dbf
Wed Feb 11 04:36:25 2009
Completed checkpoint up to RBA [0x3653.2.10], SCN: 938020635
Wed Feb 11 04:38:22 2009
Beginning log switch checkpoint up to RBA [0x3654.2.10], SCN: 938025532
Thread 1 advanced to log sequence 13908
  Current log# 12 seq# 13908 mem# 0: /oracle/ORN/origlogB/log_g12m1.dbf
  Current log# 12 seq# 13908 mem# 1: /oracle/ORN/mirrlogB/log_g12m2.dbf
Wed Feb 11 04:43:04 2009
Beginning log switch checkpoint up to RBA [0x3655.2.10], SCN: 938031075
Thread 1 advanced to log sequence 13909
  Current log# 14 seq# 13909 mem# 0: /oracle/ORN/origlogB/log_g14m1.dbf
  Current log# 14 seq# 13909 mem# 1: /oracle/ORN/mirrlogB/log_g14m2.dbf
Wed Feb 11 04:43:25 2009
а в BW тем более ничего криминального :
Wed Feb 11 03:52:34 2009
Completed checkpoint up to RBA [0x3810.2.10], SCN: 0x0000.7861d667
Wed Feb 11 04:01:01 2009
Beginning log switch checkpoint up to RBA [0x3811.2.10], SCN: 0x0000.786462da
Thread 1 advanced to log sequence 14353
  Current log# 4 seq# 14353 mem# 0: /oracle/OBW/origlogB/log_g14m1.dbf
  Current log# 4 seq# 14353 mem# 1: /oracle/OBW/mirrlogB/log_g14m2.dbf
ARC0: Evaluating archive   log 3 thread 1 sequence 14352
ARC0: Beginning to archive log 3 thread 1 sequence 14352
Creating archive destination LOG_ARCHIVE_DEST_1: '/oracle/OBW/oraarch/OBWarch1_14352.dbf'
ARC0: Completed archiving  log 3 thread 1 sequence 14352
Wed Feb 11 04:05:18 2009
Completed checkpoint up to RBA [0x3811.2.10], SCN: 0x0000.786462da
Wed Feb 11 04:06:45 2009
Beginning log switch checkpoint up to RBA [0x3812.2.10], SCN: 0x0000.78648832
Thread 1 advanced to log sequence 14354
  Current log# 1 seq# 14354 mem# 0: /oracle/OBW/origlogA/log_g11m1.dbf
  Current log# 1 seq# 14354 mem# 1: /oracle/OBW/mirrlogA/log_g11m2.dbf
ARC1: Evaluating archive   log 4 thread 1 sequence 14353
ARC1: Beginning to archive log 4 thread 1 sequence 14353
Creating archive destination LOG_ARCHIVE_DEST_1: '/oracle/OBW/oraarch/OBWarch1_14353.dbf'
ARC1: Completed archiving  log 4 thread 1 sequence 14353
Wed Feb 11 04:09:00 2009
Beginning log switch checkpoint up to RBA [0x3813.2.10], SCN: 0x0000.78648fda
Thread 1 advanced to log sequence 14355
  Current log# 2 seq# 14355 mem# 0: /oracle/OBW/origlogB/log_g12m1.dbf
ARC0: Evaluating archive   log 1 thread 1 sequence 14354
  Current log# 2 seq# 14355 mem# 1: /oracle/OBW/mirrlogB/log_g12m2.dbf
ARC0: Beginning to archive log 1 thread 1 sequence 14354
Creating archive destination LOG_ARCHIVE_DEST_1: '/oracle/OBW/oraarch/OBWarch1_14354.dbf'
Completed checkpoint up to RBA [0x3812.2.10], SCN: 0x0000.78648832
Wed Feb 11 04:09:02 2009
ARC0: Completed archiving  log 1 thread 1 sequence 14354
Wed Feb 11 04:09:34 2009
Completed checkpoint up to RBA [0x3813.2.10], SCN: 0x0000.78648fda
в логе процесса есть кое-что
C Tue Feb 10 23:50:42 2009
C  Starting user session (con_hdl=0,svchp=8000000102699c68,srvhp=8000000104226eb8,usrhp=800000010371bbe0)
C  *** ERROR => OCI-call 'OCISessionBegin' failed: rc = 1034
[dboci.c      3807]
C  Detaching from DB Server (con_hdl=0,svchp=8000000102699c68,srvhp=8000000104226eb8)
C  *** ERROR => CONNECT failed with sql error '1034'
[dbsloci.c    9650]
C
C Tue Feb 10 23:50:47 2009
C  Logon as OPS$-user to get SAPOBW's password
C  Connecting as /@OBW on connection 0 ...
C  Attaching to DB Server OBW (con_hdl=0,svchp=8000000102699c68,svrhp=8000000104226eb8)
C
C Tue Feb 10 23:50:48 2009
[dboci.c      3807]
[dbsloci.c    9650]
C  Try to connect with default password
C  Connecting as SAPOBW/<pwd>@OBW on connection 0 ...
[dboci.c      3807]
[dbsloci.c    9650]
C
C Tue Feb 10 23:50:53 2009
C
C Tue Feb 10 23:50:54 2009
[dboci.c      3807]
[dbsloci.c    9650]
R3 oracle 10.2.0.2, hp-ux 11.31
BW oracle 9.2.0.4, hp-ux 11.11
скриптик utlrp.sql запускал
 Заголовок сообщения: Re: ORA-3114 при формировании куба
СообщениеДобавлено: Ср, фев 11 2009, 16:31
Чт, фев 15 2007, 11:04
Глянь в директории bdump и udump на BW
СообщениеДобавлено: Чт, фев 12 2009, 06:16
В этих директориях уже 5 лет ничего не пишется :?
СообщениеДобавлено: Чт, фев 12 2009, 09:07
Параллельно с данной ошибкой возникает еще одна.
В логе процесса есть следующее:
C  *** ERROR => ORA-60 occured when executing SQL statement (parse error offset = 0)
[dbsloci.c    10964]
C  sc_p=800000010266d248,no=61,idc_p=8000000102682b90,con=0,act=1,slen=193,smax=2304,#vars=24,stmt=8000000103687d80,table=/BI0/F0IC_
C  prep=0,lit=0,nsql=0,lobret=0,#exec=29,dbcnt=0,upsh_p=0000000000000000,ocistmth_p=8000000103eb0790
C  IN : cols=24,rmax=2321,xcnt=2321,rpc=0,rowi=0,rtot=2321,upto=-9223372028264841217,rsize=232,vmax=32,bound=1,iobuf_p=8000000102735
C       lobs=0,lmax=0,lpcnt=0,larr=0000000000000000,lcurr_p=0000000000000000,rret=0
C  OUT: cols=4,rmax=7831,xcnt=0,rpc=0,rowi=0,rtot=0,upto=-9223372032559808512,rsize=75,vmax=64,bound=0,iobuf_p=0000000000000000,vda_
C  INSERT INTO "/BI0/F0IC_C03" VALUES( :A0 , :A1 , :A2 , :A3 , :A4 , :A5 , :A6 , :A7 , :A8 , :A9 , :A10\
C   , :A11 , :A12 , :A13 , :A14 , :A15 , :A16 , :A17 , :A18 , :A19 , :A20 , :A21 , :A22 , :A23 );
B  ***LOG BYO=> deadlock aborts transaction [dbsh#2 @ 893] [dbsh    0893 ]
B  SQL code: 60, SQL text: ORA-00060: deadlock detected while waiting for resource
B
B Thu Feb 12 07:17:56 2009
B  ***LOG BY4=> sql error 60     performing INS on table /BI0/F0IC_ [dbtran#13 @ 7275] [dbtran  7275 ]
B  ***LOG BY0=> ORA-00060: deadlock detected while waiting for resource [dbtran#13 @ 7275] [dbtran  7275 ]
B  dbtran ERROR LOG (hdl_dbsl_error): DbSl 'INS'
и сам дамп:
"WRITE_ICFACT"
Database error text........: "ORA-00060: deadlock detected while waiting fo
resource"
Internal call code.........: "[RSQL/INSR//BI0/F0IC_C03 ]"
Такая веще происходит периодически , но с разными кубами и с разными таблицами
СообщениеДобавлено: Чт, фев 12 2009, 14:01
Вт, авг 17 2004, 11:44
Ноты по "ORA-00060" не пробовали искать?
СообщениеДобавлено: Пт, фев 13 2009, 08:52
Да , искать пробовал. Много написано про параметры INI_TRANS,MAX_TRANS(значения 1 и 255 по умолчанию соответственно). При просмотре конкретно проблемной таблички обнаружилось отсутствие данных значений.НО, существует еще целая куча таких таблиц, где отсутствуют значения( я так понимаю, что они генерятся кубами). С индексами тоже все нормально.
Почему я вообще добавил это ошибку в топик с ошибкой ORA-003114: мне показалось , что ORA-000060 может стать следствием ORA-003114, так как сваливается какой-нибудь пакет(самое противное, что загрузка одна и та же , а пакеты сваливаются разные) и этот пакет удерживает ресурс. Если я ошибаюсь, то исправьте пожалуйста
СообщениеДобавлено: Вс, фев 15 2009, 08:20
Господа, вариантов больше ни у кого нет?
СообщениеДобавлено: Пт, фев 20 2009, 12:55
Ср, ноя 17 2004, 18:38
Вторичные индексы не пробовали удалять перед загрузкой ?
СообщениеДобавлено: Вт, фев 24 2009, 06:56
Вы знаете, господа. Я склонен предполагать, что эта проблема стала следствием рассинхронизации времени, так как когда убрали эту проблему , то пока ни разу не вывалилось подобной вещи
