Текущее время: Вс, май 31 2026, 15:03
 Заголовок сообщения: Dump CALL_FUNCTION_CONFLICT_LENG
СообщениеДобавлено: Пт, июл 10 2009, 11:53
Пн, сен 17 2007, 10:48
          Call Function 'BAPI_CHARACT_CREATE'
            Exporting
              charactdetail             = charactdetail
            Tables
              charactdescr              = charactdescr
              charactvaluesnum          = charactvaluesnum
              charactvalueschar         = charactvalueschar
              charactvaluescurr         = charactvaluescurr
              charactvaluesdescr        = charactvaluesdescr
              charactreferences         = charactreferences
              charactrestrictions       = charactrestrictions
              return                    = return.
          Append charactdetail To charactdetailnew.
          Call Function 'BAPI_CHARACT_CHANGE'
            Exporting
              charactname                  = charactdetail-charact_name
            Tables
              charactdetailnew             = charactdetailnew
              charactdescrnew              = charactvaluescurr
              charactvaluesnumnew          = charactvaluesnum
              charactvaluescharnew         = charactvalueschar
              charactvaluescurrnew         = charactvaluescurr
              charactvaluesdescrnew        = charactvaluesdescr
              charactreferencesnew         = charactreferences
              charactrestrictionsnew       = charactrestrictions
              return                       = return.
Помогите советом:?
С уважением, Сергей С.
 Заголовок сообщения: Re: Dump CALL_FUNCTION_CONFLICT_LENG
СообщениеДобавлено: Пт, июл 10 2009, 12:10
Пт, июн 16 2006, 00:43
Внимательно посмотрите на дамп.
СообщениеДобавлено: Пт, июл 10 2009, 15:14
An exception occurred that is explained in detail below.
The exception, which is assigned to class 'CX_SY_DYN_CALL_ILLEGAL_TYPE', was not caught in procedure "Z**_*****_****" "(FUNCTION)", nor was it propagated a RAISING clause.
Since the caller of the procedure could not have anticipated that the excepton would occure, the current program is terrminated.
The reason for the exeption is:
The call to the fuctional module "BAPI_CHARACT_CHANGE" is incorrect:
In the function module interface, you can specify only fields of specific type and length under "CHARACTDESCRNEW". Although the currently specified field " " is the correct type, its length is incorrect.
Возможно я что-то неверно интерпретирую. :?
СообщениеДобавлено: Пт, июл 10 2009, 15:25
Что конкретно непонятно в этом тексте:
СообщениеДобавлено: Пт, июл 10 2009, 15:53
Пономарев Артем написал:
В интерфейсе функционального модуля, вы можете специфицировать только поля определенного типа и длины под "CHARACTDESCRNEW". Даже если определенное поле " " правильного типа, его длина некорректна.
Все, до последнего слова, понятно. :?
            Exporting
            Tables
тип charactdetailnew и charactdetail один и тот же - bapicharactdetail.
Попробовал сгенерировать ALE интерфейс к этому BAPI.
Inconsistency found in segment:
E1BPCHARACTDETAIL <-> BAPICHARACTDETAIL
:shock:
СообщениеДобавлено: Пт, июл 10 2009, 16:33
Приведите код объявления переменных.
Посмотрите ноты.
СообщениеДобавлено: Пт, июл 10 2009, 16:40
  Data: charactname   Type bapicharactkey-charactname,
        charactdetail Type bapicharactdetail.
  Data: charactdetailnew   Like Table Of bapicharactdetail.
  Data: charactdescr        Type Table Of bapicharactdescr,
        charactvaluesnum    Type Table Of bapicharactvaluesnum ,
        charactvalueschar   Type Table Of bapicharactvalueschar ,
        charactvaluescurr   Type Table Of bapicharactvaluescurr ,
        charactvaluesdescr  Type Table Of bapicharactvaluesdescr ,
        charactreferences   Type Table Of bapicharactreferences ,
        charactrestrictions Type Table Of bapicharactrestrictions,
        return              Type Table Of bapiret2.
Нот, к сожалению, нет :( Это первое, что я смотрел.
Гугл говорит, что схожие дампом проблемы решались натягиванием очередного патча. Наш текущий SAP_APPL 15.
СообщениеДобавлено: Пн, июл 13 2009, 17:21
Вт, сен 07 2004, 17:47
east написал:
Надо внимательно читать код и текст дампа
СообщениеДобавлено: Вт, июл 14 2009, 07:48
Пардон :)
              Exporting
*               changenumber                 =
*               keydate                      = sy-datum
              Tables
*                charactdescrnew              = charactdescr
*                charactvaluesnumnew          = charactvaluesnum
*                charactvaluescharnew         = charactvalueschar
*                charactvaluescurrnew         = charactvaluescurr
*                charactvaluesdescrnew        = charactvaluesdescr
*                charactreferencesnew         = charactreferences
*                charactrestrictionsnew       = charactrestrictions
                return                       = return.
