Текущее время: Пн, июн 22 2026, 13:04
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: для знающих. Проблемы с SDM
СообщениеДобавлено: Вт, июн 07 2005, 21:45
Чт, авг 19 2004, 14:31
При установке J2EE-AddIn есть такой момент как деплой пакетов через SDM, предпоследняя стадия. При старте инстанции в логах SDM вижу:
Jun 7, 2005 11:25:47 PM Info:
Jun 7, 2005 11:25:47 PM Info: ============================================
Jun 7, 2005 11:25:47 PM Info: = Starting to execute command 'server' =
Jun 7, 2005 11:25:47 PM Info: Starting SDM - Software Deployment Manager...
Jun 7, 2005 11:25:51 PM Info: tc/SL/SDM/SDM/sap.com/SAP AG/6.3003.00.0000.20031126161800.0000
Jun 7, 2005 11:25:54 PM Info: SDM operation mode successfully set to: Standalone
Jun 7, 2005 11:25:56 PM Info: JStartupFramework is requesting to start the SDM Server.
Jun 7, 2005 11:25:56 PM Info: SDM is currently detached from JStartupFramework. Forward this information to the JStartupFramekwork (disable SDM process).
Jun 7, 2005 11:25:57 PM Info: disabling SDM Process with JStartupFramework
Jun 7, 2005 11:25:57 PM Info: ====================================
Jun 7, 2005 11:25:57 PM Info: JControl is shutting SDM Server down
Jun 7, 2005 11:25:57 PM Info: disabled SDM Process with JStartupFramework
Jun 7, 2005 11:25:57 PM Error: Could not start SDM. Precondition not fulfilled. Return code: 8
При деплое (через sapinst или ручном) получаю вот что:
Jun 7, 2005 11:25:57 PM Info: Loading selected archives...
Jun 7, 2005 11:25:57 PM Info: Loading archive 'E:\Distrib\SAP\SAP Netweaver 04 WEB AS\J2EE1\J2EE-ENG\ONLINE\SAPJTECHS03_0.SCA'
Jun 7, 2005 11:26:34 PM Info: Selected archives successfully loaded.
Jun 7, 2005 11:26:39 PM Info: Error handling strategy: OnErrorStop
Jun 7, 2005 11:26:39 PM Info: Update strategy: UpdateLowerVersions
Jun 7, 2005 11:26:39 PM Info: Starting to execute deployment action (deploy) for "SQLTrace".
Jun 7, 2005 11:26:39 PM Info: SDA to be deployed: E:\usr\sap\C12\DVEBMGS00\SDM\root\origin\sap.com\SQLTrace\SAP AG\6.3003.00.0000.20031215150458.0000\SQLTrace.ear
Jun 7, 2005 11:26:39 PM Info: Software type of SDA: J2EE
Jun 7, 2005 11:26:56 PM Info: ***** Begin of SAP J2EE Engine Deployment (J2EE Application) *****
Jun 7, 2005 11:27:11 PM Info: Begin of log messages of the target system:
05/06/07 23:27:00 - ***********************************************************
05/06/07 23:27:05 - Start updating EAR file...
05/06/07 23:27:05 - EAR file updated successfully for 2563s.
05/06/07 23:27:05 - Start deploying ...
05/06/07 23:27:11 - ERROR : com.sap.engine.deploy.manager.DeployManagerException: ERROR: Cannot connect to Host: [virvit] with UserName: [J2EE_ADMIN]
Check your Login Info.
Exception is:
com.sap.engine.services.jndi.persistent.exceptions.NamingException: Exception during getInitialContext operation. No server is running [Root exception is javax.security.auth.login.LoginException: com.sap.engine.services.rmi_p4.P4IOException: Connection lost.]
at com.sap.engine.deploy.manager.DeployManagerImpl.setBroker(DeployManagerImpl.java:3490)
at com.sap.engine.deploy.manager.DeployManagerImpl.makeNewConnection(DeployManagerImpl.java:3457)
at com.sap.engine.deploy.manager.DeployManagerImpl.deployUpdateAction(DeployManagerImpl.java:586)
at com.sap.engine.deploy.manager.DeployManagerImpl.deploy(DeployManagerImpl.java:503)
at com.sap.sdm.serverext.servertype.inqmy.extern.EngineJ2EE620OnlineDeployerImpl.performDeployment(EngineJ2EE620OnlineDeployerImpl.java:355)
at com.sap.sdm.serverext.servertype.inqmy.extern.EngineDeployerImpl.deploy(EngineDeployerImpl.java:89)
at com.sap.sdm.serverext.servertype.inqmy.EngineProcessor.executeAction(EngineProcessor.java:216)
at com.sap.sdm.app.proc.deployment.impl.PhysicalDeploymentActionExecutor.execute(PhysicalDeploymentActionExecutor.java:58)
at com.sap.sdm.app.proc.deployment.impl.DeploymentActionImpl.execute(DeploymentActionImpl.java:181)
at com.sap.sdm.app.proc.deployment.controllers.internal.impl.DeploymentExecutorImpl.execute(DeploymentExecutorImpl.java:51)
at com.sap.sdm.app.proc.deployment.states.eventhandler.ExecuteDeploymentHandler.executeAction(ExecuteDeploymentHandler.java:84)
at com.sap.sdm.app.proc.deployment.states.eventhandler.ExecuteDeploymentHandler.handleEvent(ExecuteDeploymentHandler.java:61)
at com.sap.sdm.app.proc.deployment.states.StateBeforeNextDeployment.processEvent(StateBeforeNextDeployment.java:78)
at com.sap.sdm.app.proc.deployment.states.InstContext.processEventServerSide(InstContext.java:88)
at com.sap.sdm.app.proc.deployment.states.InstContext.processEvent(InstContext.java:74)
at com.sap.sdm.app.sequential.deployment.impl.DeployerImpl.doPhysicalDeployment(DeployerImpl.java:121)
at com.sap.sdm.app.sequential.deployment.impl.DeployerImpl.deploy(DeployerImpl.java:90)
at com.sap.sdm.control.command.cmds.Deploy.execute(Deploy.java:162)
at com.sap.sdm.control.command.decorator.AssureStandaloneMode.execute(AssureStandaloneMode.java:54)
at com.sap.sdm.control.command.decorator.AssureOneRunningSDMOnly.execute(AssureOneRunningSDMOnly.java:61)
at com.sap.sdm.control.command.decorator.SDMInitializer.execute(SDMInitializer.java:52)
at com.sap.sdm.control.command.decorator.GlobalParamEvaluator.execute(GlobalParamEvaluator.java:60)
at com.sap.sdm.control.command.decorator.AbstractLibDirSetter.execute(AbstractLibDirSetter.java:46)
at com.sap.sdm.control.command.decorator.ExitPostProcessor.execute(ExitPostProcessor.java:48)
at com.sap.sdm.control.command.decorator.CommandNameLogger.execute(CommandNameLogger.java:49)
at com.sap.sdm.control.command.decorator.AdditionalLogFileSetter.execute(AdditionalLogFileSetter.java:65)
at com.sap.sdm.control.command.decorator.AbstractLogDirSetter.execute(AbstractLogDirSetter.java:52)
at com.sap.sdm.control.command.Command.exec(Command.java:42)
at SDM.main(SDM.java:21)
05/06/07 23:27:11 - ***********************************************************
Jun 7, 2005 11:27:11 PM Info: End of log messages of the target system.
Jun 7, 2005 11:27:11 PM Info: ***** End of SAP J2EE Engine Deployment (J2EE Application) *****
Jun 7, 2005 11:27:11 PM Error: Execution of deployment action for "SQLTrace" aborted:
Caught exception during application deployment from SAP J2EE Engine's deploy API:
Exception is:
(message ID: com.sap.sdm.serverext.servertype.inqmy.extern.EngineJ2EE620OnlineDeployerImpl.performAction(DeploymentActionTypes).DMEXC)
Jun 7, 2005 11:27:12 PM Error: Deployment NOT successful for SQLTrace
Jun 7, 2005 11:27:12 PM Info: --------------- Deployment was successful -----------------
Jun 7, 2005 11:27:12 PM Info: Summarizing the deployment results:
Jun 7, 2005 11:27:12 PM Error: Admitted: E:\Distrib\SAP\SAP Netweaver 04 WEB AS\J2EE1\J2EE-ENG\ONLINE\SAPJTECHS03_0.SCA
Jun 7, 2005 11:27:12 PM Error: Processing error. Return code: 4
В результате третие сутки не могу поставить этого зверя :( В нотах ничего нет, в доках тоже.
virvit.ru
saphr.ru
СообщениеДобавлено: Вт, июн 07 2005, 23:09
Чт, ноя 04 2004, 20:42
Попробуй установить последнюю версию Web AS и продолжить инсталяцию. Еще как вариант, <я не знать русский языка> "вручную" запустить SDM установить sca архив. А для начала <я не знать русский языка> запустить администратор Web AS и залогиниться в нем пользователем j2ee_admin
СообщениеДобавлено: Ср, июн 08 2005, 06:06
1. Стоит Web AS 6.4, J2EE 6.3.
2. Вручную выходит с той же ошибкой (не могу достучаться до хоста, хотя он висит на 50004 порту)
3. Администратор Web AS - что есть? SDM, SecureStore нормально запускаются и логинятся. В самом Web AS (ABAP) J2EE_ADMIN нормально ходит во все манданты :)
virvit.ru
saphr.ru
СообщениеДобавлено: Ср, июн 08 2005, 10:02
Вт, мар 29 2005, 19:54
1) WAS ставишь как аддон на абап часть?
2) не менял ли пароль пользователя J2EE_ADMIN в абап части?
3) морда у сервера весит по порту 50000+100*IN, посмотри что у тебя тут болтается
4) на какой стадии ошибка, когда устанавливаешь WAS или какой-то аддон на него?
Не откладывай работу на субботу, а секс на старость
система без базисника должна лежать! (с) Skif
СообщениеДобавлено: Ср, июн 08 2005, 10:38
Сб, авг 21 2004, 14:24
попробуйте нотку 795142 - вдруг поможет
СообщениеДобавлено: Ср, июн 08 2005, 11:25
не помогло
virvit.ru
saphr.ru
СообщениеДобавлено: Ср, июн 08 2005, 11:28
1) Да, ставил как AddIn
2) пароль оно спрашивает при установке для SAPJSF, J2EE_ADMIN, J2EE_GUEST. Для всех пароли заданы в абапе.
3) морда висит (jlaunch), если запускать SDM ручками (сервер + морду), то все нормально коннектится
4) устанавливаю WAS J2EE AddIn for ABAP (Central Instance).
Все удовольствие находится на одной машинке (оракл, абап и ява).
тем более в логах написано, что не видит именно сервер, не может соединиться.
virvit.ru
saphr.ru
СообщениеДобавлено: Ср, июн 08 2005, 11:35
а если сервер ручками остановить? А потом стартовать и попробовать деплоить руками? В смысле SDM сервер конечно. А кстати что именно система не может деплоить? Callsdmviasapinst.log - что там?
СообщениеДобавлено: Ср, июн 08 2005, 11:42
пароль J2EE_ADMIN не менялся случайно в абап части?
СообщениеДобавлено: Ср, июн 08 2005, 11:44
посмотри ноту 699557
СообщениеДобавлено: Ср, июн 08 2005, 11:57
Господа, при всем уважении. Читайте внимательно посты.
Ручками деплоил, та же ошибка. Exception у меня другой выбрасывается, а не PermissionDenied.
virvit.ru
saphr.ru
СообщениеДобавлено: Ср, июн 08 2005, 11:59
VirVit написал:
а при деплоинге сервер на месте? никуда не вылетает в даун не уходит?
СообщениеДобавлено: Ср, июн 08 2005, 12:14
VirVit написал:
Exception is:
Exception is:
virvit.ru
saphr.ru
СообщениеДобавлено: Ср, июн 08 2005, 12:15
При самом деплое сервер на месте. Но при первом старте инстанции в логах сервера вот такое. Смущают эти самые preconditions.
virvit.ru
saphr.ru
