Текущее время: Сб, авг 08 2026, 10:48
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Проблема с диалоговой инстанцией
СообщениеДобавлено: Чт, май 12 2011, 13:49
Чт, дек 23 2010, 10:54
Подскажите, пожалуйста, не понятно почему виснет диалоговая инстанция. Процессоры не загружены, ОЗУ свободно.
Система ERP 6.0, sap kernel x86_64 уровень 254
ОС SLES 11 sp1
Приведу кусок dev_disp
Fri May  6 11:38:26 2011
*** ERROR => DpWPCheck: W0 (pid 12026) died (severity=0, status=7) [dpxxdisp.c   15776]
child (pid=12026) killed with signal 7
*** ERROR => DpWPCheck: W10 (pid 12143) died (severity=0, status=7) [dpxxdisp.c   15776]
child (pid=12143) killed with signal 7
Fri May  6 11:38:29 2011
*** ERROR => DpWPCheck: W9 (pid 12035) died (severity=0, status=7) [dpxxdisp.c   15776]
child (pid=12035) killed with signal 7
Fri May  6 11:38:44 2011
*** ERROR => DpWPCheck: W10 (pid 12143) died (severity=0, status=0) [dpxxdisp.c   15776]
*** ERROR => DpWPCheck: W11 (pid 12037) died (severity=0, status=7) [dpxxdisp.c   15776]
child (pid=12037) killed with signal 7
Кусок лога dev_w0
M  -------------------------------------------------
M
M Fri May  6 11:38:25 2011
M  ***LOG Q0E=> SigIGenAction, signal ( 7) [sigux.c      1067]
M  in_ThErrHandle: 2
M  ***LOG R0H=> ThIErrHandle, Loop in ThErrHandle, restart wp () [thxxhead.c   10642]
M  ------------------ C-STACK ----------------------
(CTrcStack2+0x78)[0x6c6dd8]
(CTrcStack+0xb)[0x6c73db]
(ThIErrHandle+0xb77)[0x534e17]
(ThErrHandle+0x19)[0x536479]
(ThSigHandler+0x41)[0x59d691]
(SigIGenAction+0x318)[0x1916a88]
/lib64/libpthread.so.0[0x7f05a17585d0]
(MmxICheckList+0x492)[0x18085a2]
(MmxCheck+0x254)[0x1809294]
(EgCheck+0x13d)[0x17fb04d]
(ThIErrHandle+0x13f4)[0x535694]
/lib64/libc.so.6(memcpy+0x15b)[0x7f05a146cb8b]
(_Z13ab_ItabAppendtP4TABH4RUDIPK7AB_DATAPKvP7IT_ITER+0xc4)[0x92fe14]
(_Z8ab_jtappv+0x81a)[0x90a50a]
(_Z8ab_extriv+0x27b)[0x89ec7b]
(_Z9ab_xeventPKc+0x1c0)[0x9f18d0]
(_Z8ab_triggv+0x9c)[0x9f1f9c]
(ab_run+0x76)[0xbaaba6]
(N_ab_run+0x9)[0x72ce79]
(dynpmcal+0x6ad)[0x729f6d]
(dynppai0+0x8eb)[0x72b93b]
(dynprctl+0x3e7)[0x72a957]
(dynpen00+0x49a)[0x71e32a]
(Thdynpen00+0x366)[0x53ef76]
(TskhLoop+0xc29)[0x54ac59]
(ThStart+0x20f)[0x5585bf]
(DpMain+0x2fb)[0x4bbc8b]
(nlsui_main+0x9)[0x4905b9]
(main+0x9)[0x4905c9]
/lib64/libc.so.6(__libc_start_main+0xe6)[0x7f05a1409bc6]
M  ThSigHandler: signal (step 4, th_errno 11, action 4)
M
M  Info for wp 0
M
M    pid = 12026
M    severity = 0
M    status = 0
M    stat = WP_RUN
M    waiting_for = NO_WAITING
M    reqtype = DP_RQ_DIAWP
M    act_reqtype = DP_RQ_DIAWP
M    rq_info = 0
M    tid = 102
M    mode = 0
M    len = 8
M    rq_id = 36891
M    rq_source = FROM_WP_CA
M    last_tid = 102
M    last_mode = 0
M    semaphore = 0
M    act_cs_count = 1
M       cs[0] = semaphore
M    csTrack = 0
M    csTrackRwExcl = 0
M    csTrackRwShrd = 0
M    mode_cleaned_counter = 0
M    control_flag = 0
M    int_checked_resource(RFC) = 0
M    ext_checked_resource(RFC) = 0
M    int_checked_resource(HTTP) = 0
M    ext_checked_resource(HTTP) = 0
M    report = >Z_RIIFLO20                              <
M    action = 0
M    tab_name = >                              <
M    attachedVm = no VM
M
M  Modeinfo for User T102/M0
M
M    tm state = 2
M    uid = 154
M    term type = 0x4
M    display = 0x8
M    cpic_no = 0
M    cpic_idx = -1
M    usr = >ARM18_C033  <
M    terminal = >rzresapp            <
M    client = >015<
M    conversation_ID = >        <
M    appc_tm_conv_idx = -1
M    its_plugin = NO
M    allowCreateMode = YES
M    wp_ca block = 20
M    appc_ca block = 6
M    blockSoftCanel = NO
M    session_id = >4DC3BF92AFF92EFCE10000000A6F0208<
M    ext_session_id = >4DC3BF92AFF92EFCE10000000A6F0208<
M    imode = 1
M    mode state = 0x42
M    mode clean_state = 1
M    task_type = ZTTADIA
M    lastThFc = THFCTERM
M    lastAction = TH_IACT_NO_ACTION
M    th_errno = 11
M    rollout_reason = 1
M    last_rollout_level = 7
M    async_receives = 0
M    cpic_receive = 0
M    em handle = 90
M    roll state = 3
M    abap state = 3
M    em state = 2
M    eg state = 1
M    spa state = 3
M    enq state = 0
M    softcancel = 0
M    cancelInitiator = ?
M    clean_state = DP_DEFAULT_CLEANING
M    next hook = T-1/U-1/M255
M    master hook = T-1/U-1/M255
M    slave hook = T-1/U-1/M255
M    debug_tid = 255
M    debug_mode = 0
M    mode type = 0x1
M    debug = 0
M    msg_count = 0
M    tcode = >ZIH06               <
M    last_wp = 0
M    client conversation_ID = >        <
M    server conversation_ID = >        <
M    lock = 0
M    max enq infos = 0
M    act enq infos = 0
M    em_hyper_hdl = 0x7f05853d1b20
M    plugin_info = NULL
M    act_plugin_hdl = -1
M    act_plugin_no  = 0
M    max_plugin_no  = 0
M  PfStatDisconnect: disconnect statistics
M  Entering ThSetStatError
C  Received cancel request for current DB operation
C  Not in a DB Operation -> DBSL_ERR_ACCESS
B  db_sqlbreak() = 1
M  ThIErrHandle: don't try rollback again
M  ThIErrHandle: do not call ThrCoreInfo (no_core_info=0, in_dynp_env=1)
I  *** ERROR => SemRq: Inv. State detected. Units 1. Key=39 [semux.c      1770]
X  *** ERROR => EgIMmLock failed 2 [egxx.c       767]
X  WARNING: performing shared heap check despite lock error
 Заголовок сообщения: Re: Проблема с диалоговой инстанцией
СообщениеДобавлено: Чт, май 12 2011, 15:08
Вт, июл 24 2007, 14:52
похожая нота 1564966
но ваш уровень ядра выше..
а на центральной инстанции все ок?
СообщениеДобавлено: Чт, май 12 2011, 15:29
Да. На центральной все нормально. Правда там меньше пользователей.
СообщениеДобавлено: Чт, май 12 2011, 16:10
еще инфу давайте =)
например dev_disp с диалоговой, и dev_ms с центральной
СообщениеДобавлено: Чт, май 12 2011, 16:34
dev_disp с диалоговой инстанции
Wed May 11 10:30:02 2011
*** ERROR => DpWPCheck: W1 (pid 27466) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27466) killed with signal 7
*** ERROR => DpWPCheck: W8 (pid 27473) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27473) killed with signal 7
Wed May 11 10:30:04 2011
*** ERROR => DpWPCheck: W3 (pid 27468) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27468) killed with signal 7
Wed May 11 10:30:09 2011
*** ERROR => DpWPCheck: W9 (pid 27474) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27474) killed with signal 7
Wed May 11 10:30:17 2011
*** ERROR => DpWPCheck: W0 (pid 27465) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27465) killed with signal 7
Wed May 11 10:30:25 2011
*** ERROR => DpWPCheck: W15 (pid 27480) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27480) killed with signal 7
Wed May 11 10:30:33 2011
*** ERROR => DpWPCheck: W13 (pid 27478) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27478) killed with signal 7
Wed May 11 10:30:35 2011
*** ERROR => DpWPCheck: W17 (pid 27482) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=27482) killed with signal 7
Wed May 11 10:37:01 2011
*** ERROR => DpWPCheck: W2 (pid 28847) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=28847) killed with signal 7
Wed May 11 10:37:07 2011
*** ERROR => DpWPCheck: W19 (pid 28735) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=28735) killed with signal 7
Wed May 11 10:37:11 2011
SoftCancel request for T78 U183 M1 received from REMOTE_TERMINAL
*** ERROR => DpWPCheck: W2 (pid 28850) died (severity=0, status=7) [dpxxdisp.c   15841]
child (pid=28850) killed with signal 7
Wed May 11 10:37:17 2011
*** ERROR => DpWPCheck: W2 (pid 28850) died (severity=0, status=0) [dpxxdisp.c   15841]
DpHdlDeadWp: restart wp (pid=28792) automatically
Wed May 11 10:37:18 2011
*** ERROR => multiple send of tid 78 (ARM35       , M1) [dpxxdisp.c   12520]
***LOG Q0I=> NiIRead: recv (104: Connection reset by peer) [nixxi.cpp 4424]
*** ERROR => NiIRead: SiRecv failed for hdl 57 / sock 71
    (SI_ECONN_BROKEN/104; I4; ST; 10.111.28.231:1028) [nixxi.cpp    4424]
Network error of client T78, NiBufReceive (-6: NIECONN_BROKEN), dp_tm_status=3
Client address of T78 is 10.111.28.231(10.111.28.231)
***LOG Q04=> DpRTmPrep, NiBufReceive (183 ARM35 78 d0132028231 ) [dpxxdisp.c   12364]
RM-T78, U183, 015        ARM35, d0132028231, 10:36:08, M1, W6, IH08, 4/2
*** ERROR => DpRqCheck: mode 1 in status CANCEL [dpxxdisp.c   7485]
***LOG Q0G=> DpRqBadHandle, bad_req (NOWP) [dpxxdisp.c   5698]
*** ERROR => BAD REQUEST - Reason: DpRqCheck failed (line 3918): [dpxxdisp.c   5700]
-IN-- sender_id REMOTE_TERMINAL   tid  78    wp_ca_blk   39      wp_id -1
-IN-- action    SEND_TO_WP        uid  183   appc_ca_blk -1      type  NOWP
-IN-- new_stat  NO_CHANGE         mode 1     len         31      rq_id 36110
Wed May 11 10:37:27 2011
в это время инстанция повисла
стоплю и перегружаю
Wed May 11 10:38:05 2011
DpSigInt: caught signal 2
DpHalt: shutdown server >sapapp_CRP_07                           < (normal)
DpModState: change server state from ACTIVE to SHUTDOWN
Stop work processes
Wed May 11 10:38:06 2011
SoftCancel request for T60 U117 M0 received from DISPATCHER
SoftCancel request for T32 U656 M0 received from DISPATCHER
SoftCancel request for T3 U4 M0 received from DISPATCHER
SoftCancel request for T103 U649 M0 received from DISPATCHER
DpHdlSoftCancel: wp 4 inside critical section, do not interrupt now
SoftCancel request for T50 U658 M0 received from DISPATCHER
SoftCancel request for T7 U8 M0 received from DISPATCHER
SoftCancel request for T56 U644 M0 received from DISPATCHER
DpHdlSoftCancel: wp 8 inside critical section, do not interrupt now
SoftCancel request for T11 U12 M0 received from DISPATCHER
SoftCancel request for T116 U659 M0 received from DISPATCHER
SoftCancel request for T70 U642 M0 received from DISPATCHER
SoftCancel request for T14 U15 M0 received from DISPATCHER
SoftCancel request for T89 U614 M0 received from DISPATCHER
SoftCancel request for T16 U17 M0 received from DISPATCHER
SoftCancel request for T17 U18 M0 received from DISPATCHER
SoftCancel request for T18 U19 M0 received from DISPATCHER
SoftCancel request for T91 U657 M0 received from DISPATCHER
DpHdlSoftCancel: wp 19 inside critical section, do not interrupt now
SoftCancel request for T20 U21 M0 received from DISPATCHER
SoftCancel request for T21 U22 M0 received from DISPATCHER
SoftCancel request for T22 U23 M0 received from DISPATCHER
SoftCancel request for T25 U26 M0 received from DISPATCHER
Wed May 11 10:39:07 2011
Stop gateway
Stop icman
Terminate gui connections
HardCancel request for T27 U606 M0 received from DISPATCHER
HardCancel request for T39 U98 M0 received from DISPATCHER
HardCancel request for T87 U628 M0 received from DISPATCHER
HardCancel request for T123 U599 M1 received from DISPATCHER
DpHdlSoftCancel: previous cancel not yet handled, ignore
wait for end of work processes
waiting for termination of work processes ...
Wed May 11 10:39:08 2011
Wed May 11 10:39:09 2011
Wed May 11 10:39:10 2011
Wed May 11 10:39:11 2011
Wed May 11 10:39:12 2011
Wed May 11 10:39:13 2011
Wed May 11 10:39:14 2011
Wed May 11 10:39:15 2011
Wed May 11 10:39:16 2011
Wed May 11 10:39:17 2011
Wed May 11 10:39:18 2011
Wed May 11 10:39:19 2011
Wed May 11 10:39:20 2011
Wed May 11 10:40:07 2011
*** ERROR => DpHalt: W4 (pid 28795) still alive ... [dpxxdisp.c   10886]
*** ERROR => DpHalt: W8 (pid 28794) still alive ... [dpxxdisp.c   10886]
*** ERROR => DpHalt: W19 (pid 28851) still alive ... [dpxxdisp.c   10886]
Wed May 11 10:40:08 2011
wait for end of gateway
wait for end of icman
DpStartStopMsg: send stop message (myname is >sapapp_CRP_07                           <)
DpStartStopMsg: stop msg sent
Wed May 11 10:40:09 2011
DpHalt: sync with message server o.k.
detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c   13043]
MBUF state OFF
MBUF component DOWN
cleanup EM
cleanup event management
cleanup shared memory/semaphores
Profile configuration error detected, use temporary corrected setup
Shared Pool 40: ipc/shm_psize_40 = 112000000 (too small)
Shared Pool 40: (smaller than min requirement 233443096)
Shared Pool 40: (estimated size assumed 236000000)
*** INFO  Shm 42 in Pool 40    51750 KB estimated     35745 KB real (  -16005 KB    -31 %)
removing request queue
***LOG Q05=> DpHalt, DPStop ( 27457) [dpxxdisp.c   11514]
*** shutdown completed - server stopped ***
а в это время на центральной инстанции
кусок dev_ms
[Thr 47979650758144] Wed May 11 08:41:56 2011
[Thr 47979650758144] *** ERROR => MsSClientHandle: C1 (sapdb_CRP_00) send inv_name sapbip_CRP_56 [msxxserv_mt. 4666]
[Thr 47979650758144] ***LOG Q0U=> MsSClientHandle, inv_name (sapbip_CRP_56) [msxxserv_mt. 4675]
[Thr 47979650758144] *** ERROR => MsSClientHandle: C5 (sapapp1_CRP_08) send inv_name sapbip_CRP_56 [msxxserv_mt. 4666]
[Thr 47979650758144] *** ERROR => MsSClientHandle: C6 (sapapp_CRP_07) send inv_name sapbip_CRP_56 [msxxserv_mt. 4666]
[Thr 47979650758144] Wed May 11 08:42:06 2011
[Thr 47979650758144] Wed May 11 10:42:48 2011
[Thr 47979650758144] *** ERROR => MsSClientHandle: C5 (sapapp1_CRP_08) send inv_name sapapp_CRP_07 [msxxserv_mt. 4666]
[Thr 47979650758144] ***LOG Q0U=> MsSClientHandle, inv_name (sapapp_CRP_07) [msxxserv_mt. 4675]
[Thr 47979650758144] *** ERROR => MsSClientHandle: C1 (sapdb_CRP_00) send inv_name sapapp_CRP_07 [msxxserv_mt. 4666]
[Thr 47979650758144] Wed May 11 10:42:58 2011
СообщениеДобавлено: Чт, май 12 2011, 18:04
точно проблема знакомой показалась, такие же ошибки были у моего коллеги
диалоговая инстанция на линуксе теряла рабочие процессы при увеличении числа пользователей
конкретного решения не нашли, только несколько предположительных
завтра спрошу дало ли что-нибудь результат или нет
СообщениеДобавлено: Пт, май 13 2011, 08:10
Ср, окт 24 2007, 14:24
попробуйте с этими параметрами поиграться или вообще удалите из профиля
СообщениеДобавлено: Пт, май 13 2011, 08:21
tr0ublemaker написал:
Раньше стояло
ipc/shm_psize_40 = 236000000
проблема была таже.
СообщениеДобавлено: Пт, май 13 2011, 12:09
одно из предположений было
Note 157246 - DpRqCheck: T22 in stat TM_SLOT_FREE
Increase the roll areas by adjusting the parameter values of rdisp/ROLL_MAXFS and rdisp/PG_MAXFS.
кроме того, em/initial_size_MB сначала был выставлен размеру виртуальной памяти (RAM+SWAP),
его уменьшили с учетом потребления памяти рабочими процессами и для буферов (видно в ST02 - Detailed - Storage)
с тех пор зависаний не было, хотя пик отчетного периода прошел и возможно проблема повторится
СообщениеДобавлено: Пт, май 13 2011, 12:24
Ludens написал:
Буду пробовать
СообщениеДобавлено: Пт, май 13 2011, 13:00
Посмотрите нотку 941735. И не поленитесь проверьте, какой механизм работы с памятью используется. Иногда то, что д.б. "по-умолчанию" не соответствует действительности.
 Заголовок сообщения: Re: Проблема с диалоговой инстанцией  Тема решена
СообщениеДобавлено: Пт, май 13 2011, 14:28
Сб, авг 21 2004, 14:24
механизм работы с памятью для Linux по умолчанию устанавливается в map:) параметр es/implementation
что означает банально следующее - ваш extention растет по мере необходимости- может до размера физической памяти.
выставьте std режим - тогда будете работать в указанных пределах.
И почитайте нотку - как avlag указал - по всему похоже это ваша проблема.
Да чтобы определить - посмотрите статистику распределения extention - там видно.
СообщениеДобавлено: Чт, май 26 2011, 11:49
Всем спасибо.
Проблема решилась.
Просто в профиле был указан параметр em/initial_size_MB и он оказался больше, чем em/max_size_MB который SAP поставил сам.
СообщениеДобавлено: Чт, июн 30 2011, 11:40
Пн, фев 11 2008, 11:38
На Вашем SLES всё равно какое значение у "em/max_size_MB который SAP поставил сам".
Всё регулируется только em/initial_size_MB (не важно больше он или меньше чем em/max_size_MB)
Удачи.
