Текущее время: Вс, май 31 2026, 23:29
 Заголовок сообщения: Где посмотреть инфу по Этапам обновлений?
СообщениеДобавлено: Чт, июл 14 2005, 15:09
Чт, май 12 2005, 14:34
Где можно почитать о этапах обновлений? Какой что делает.
Например DD Activation, Main Import и так далее....
СообщениеДобавлено: Чт, июл 14 2005, 19:58
Пн, фев 21 2005, 12:57
Ты о чем говоришь? Об upgrade?
Тогда сходи на http://service.sap.com/upgrade, там можно найти upgrade roadmap и в ней ссылки на разные необходимые шаги и документацию по этим шагам.
Это для начала.
СообщениеДобавлено: Чт, июл 14 2005, 21:38
Чт, ноя 04 2004, 20:42
The steps in the import process are as follows:
DDIC I: ABAP Dictionary import
In an import with R3trans, all ABAP Dictionary structural data is
imported inactively, thus enabling you to import into an active SAP
ACTIV: ABAP Dictionary activation
Runtime descriptions (nametabs) are written inactively.
ACTIV: ABAP Dictionary distribution
After activation and running logical checks for the new dictionary
structures, the distribution program decides what actions are required to
bring the new objects into the running system.
Structure conversion
If necessary, changes are made to table structures.
ACTIV: Move nametabs
The new ABAP runtime objects are put into the active runtime
environment, database structures are adjusted if necessary.
MAIN I: Main import
All data is imported.
MCACT: Activation and conversion of enqueue objects
Enqueue objects such as matchcodes that were not previously activated
are activated in this separate step after the main import. They are used
immediately in the running system.
ADO I: application-defined objects import
Import of application-defined objects (ADOs): These objects include
forms, styles, and printer definitions.
VERSF: Versioning
Versions of repository objects are only created if transport parameter
vers_at_impotrt is activ. However, the import process does modify
the object.s version counter, which is incremented for all repository
objects during import.
XPRA: Execution of user-defined activities
XPRAs are objects that can be used to start reports in the target system.
GENERA: Generation of ABAP programs and screens
During this step, you can resume normal business activities in the
system.
