Текущее время: Вс, июл 26 2026, 19:04
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
Начать новую тему Ответить на тему  [ Сообщений: 163 ]  На страницу Пред.  1 ... 6, 7, 8, 9, 10, 11  След.
 Заголовок сообщения: Re: SAP GUI 7.20 (Compilation 1) - Доступен для скачивания , Апрель 2010.
СообщениеДобавлено: Ср, ноя 16 2011, 14:52
Чт, дек 20 2007, 21:53
Changelog:
9 2011/09/13 .SAP Shortcut with Wrong Connection String, note 1616779
2011/09/13 ABAP Editor - Replace in selection option missing, note 1610658
2011/09/13 ABAP editor: fixed search and replace by regex, note 1616664
2011/09/13 APOGrid:Horizontal scroll event triggered on mouse release, note 1610166
2011/09/13 BTF-Editor: Change of SAP GUI input mode, note 1621876
2011/09/13 Crash of ABAP Edit Control with multiple windows open, note 1619169
2011/09/13 EH&S WWI: Corrections in WWI SP27, note 1620753
2011/09/13 How to activate Desktop Office Integration trace, note 190981
2011/09/13 Incremental search in second source code, note 1610835
2011/09/13 Method SET_SELECTED_TEXT_AS_TABLE of ABAP Edit Control dumps, note 1628127
2011/09/13 Office 2010 crashes on using quick option SaveAs , Print , note 1611709
2011/09/13 SAP GUI 7.20 terminates during front end printing, note 1467317
2011/09/13 Selection in edit fields with intensified text color, note 1626552
2011/09/13 SAP GUI in NWBC: in RTL mode popup elements not mirrored, note 1621487
2011/09/13 SAP GUI: The focussed column in table controls disappears, note 1624819
2011/09/13 SAP Logon (Pad) 7.20: system status button not displayed, note 1494623
2011/09/13 SAP Logon edit functionality became disabled, note 1628723
2011/09/13 SAPGantt: SAP GUI freezes on quitting the print preview page, note 1610779
2011/09/13 SAPLogon 7.20: Keyboard keys gets intercepted, note 1616286
2011/09/13 SAPLogon Pad 7.20: Wrong More context menu, note 1623173
2011/09/13 SAPLogon Pad 7.20: context menu entry Status not shown, note 1619130
2011/09/13 Scripting blocked when security dialog opened, note 1615132
2011/09/13 Security Module does not recognize downloaded URLs, note 1618683
2011/09/13 Statistic Graphics: Exception in X/Y-Interval Dialogue, note 1629383
2011/09/13 Textedit:Issue with Focus/Animated focus in Textedit control, note 1607054
2011/09/13 Tree:Icons drawn inside a Button is not correct, note 1610438
2011/09/13 Abap editor: error in russian menue entry, note 1602414
2011/09/13 Rnd: Fixed escaping in string templates, note 1616514
2011/09/13 Saplogon 7.20: wrong tab chain in tree view, note 1622812
2011/09/14 Access: Current version for Release 4.6 or higher, note 169887
2011/09/14 Fixed ABAP Quick Info tool tip window size, note 1607121
2011/09/14 SAP Logon (Pad) 7.20: create/distribute server config. file, note 1426178
2011/09/14 SAP Logon / SAP Logon Pad: show system status, note 1087494
2011/09/14 SAPphone server: New default value for log directory, note 1610526
2011/09/15 SAP GUI for Windows: unnecessary scrollbars on popups, note 1617793
2011/09/19 ALVGrid:Dropdown list should be opened on mouse button click, note 1628133
2011/09/19 F4 :Scroll bar appearing on F4 popup, note 1622588
2011/09/19 F4: SAPGUI Session hangs on invoking search help, note 1615262
2011/09/19 Html:Content of Cache is not deleted at the end of session, note 1626000
2011/09/19 SAPShortcut: login popup has no focus if StartSaplogon=1, note 1632603
2011/09/19 GuiXT: Version 2011 Q3 2, note 809461
2011/09/21 Crash of SAP GUI 7.20 with SAPPDFPRINT, note 1633924
2011/09/22 Classic Design does not show application toolbar, note 1633970
2011/09/22 SAP GUI in NWBC: wrong focus change in toolbar, note 1633221
2011/09/22 Script Development Tool disabled from Windows 7, note 1633639
2011/09/27 Addition of SSO feature for SNC in Logon Control, note 1617641
2011/09/27 Error displayed when a login is done to newly added system, note 1617737
2011/09/27 Logon Screen does not recognize the SAP Logon Language, note 1619149
2011/09/27 BI Patch SP05_500 breaks SAP GUI History folder setting, note 1633253
2011/09/28 ABAP Editor: Inserted text not completely saved, note 1635333
2011/09/28 Bug fixes for DtsCOMFramework 0.1 to SAPGUI for Windows 7.20, note 1636457
2011/10/12 Incorrect R/3 system list is displayed in Logon Control, note 1636823
2011/10/18 OI:Focus issue when word document opened in modeless dialog, note 1636208
2011/10/24 SAP Logon 720: Cannot log on to correction system in CSS, note 1642920
2011/10/27 GuiXT: RFC error RFC_ERROR_SYSTEM_FAILURE, note 1645749
2011/10/28 SAP GUI: a wrong font is used for frames (group-boxes), note 1633247
СообщениеДобавлено: Ср, ноя 16 2011, 21:44
Пт, май 04 2007, 08:01
Скачать sap gui720_9-10007878
СообщениеДобавлено: Пн, ноя 21 2011, 11:13
Вт, окт 18 2011, 13:47
Здравствуйте!
Может быть у кого-то была или есть аналогичная проблема:
при инсталляции с IS (версия 720 sp9) если нет прав администратора на ПК выходит ошибка:
C:\Program Files\SAP\SAPsetup\Setup\Updater\NwSapSetupUserNotificationTool.exe
Код:0x80004005
Поиск в нотах ничего не дал :( .
Есть конечно нотка 1587566 (34 глюка), но как-то не помогло.
Версия NWSapSetup: 8.6.1.74
Спасибо
СообщениеДобавлено: Пн, ноя 21 2011, 11:19
zadmin написал(а):
Код:0x80004005
Можно сам скрин ошибки. Если ошибка тянется от ОС, то посмотрите информацию.
СообщениеДобавлено: Пн, ноя 21 2011, 11:36
Спасибо за совет!
Отключили McAfee.
Ошибка та же.
Принтскрин смысла нет вставлять, вот все что есть:
Action-Type State Error Source Destination Error-Code
Execute Install Not Available C:\Program Files\SAP\SAPsetup\Setup\Updater\NwSapSetupUserNotificationTool.exe 0x80004005
СообщениеДобавлено: Пн, ноя 21 2011, 11:40
Подобное бывает когда файл-установщик поврежден, но не могу утверждать что ваш случай. Хотя вот пишут.
СообщениеДобавлено: Пн, ноя 21 2011, 11:48
Почему тогда, если запускаем с правами админа, данная ошибка не выскакивает....
СообщениеДобавлено: Ср, ноя 23 2011, 13:19
Ср, июн 11 2008, 09:41
Потому, что у админа прав побольше. Не дают политики либо писать куда, либо запустить чего. Трудно так сказать наверняка.
SAP Basis, SAP Security Audit/Pentest, РФ, Москва
СообщениеДобавлено: Пн, ноя 28 2011, 16:50
Чт, окт 30 2008, 18:22
Добрый день,
Проблема такая - не всегда получается с первого раза зарегистрироваться в системе с помощью ярлыка соединения.
Система Win XP, гуй с 9 патчем.
Создал в SAP Logon 720 несколько соединений . Тут же в Logon-е для каждого соединения создал ярлыки, содержащие username, system id и т.д. При попытке коннекта с ярлыка и верного ввода пароля попадаю на экран входа в систему с сообщением об ошибке 'Неправильное имя или пароль (попытайтесь зарегистрироваться ещe раз)'. После этого на экране входа набираю пароль и вход в систему проходит без проблем.
Такая ерунда происходит в 80% случаях, независимо от коннектящейся системы. Вобщем проблема доставляет неудобства - привык логиниться с ярлыка.
Кто-нибудь сталкивался с такой проблемой?
Может sapshortcut.ini кривой или это безопасность гуи режет соединения.
СообщениеДобавлено: Пн, ноя 28 2011, 17:03
Сделайте скриншот настроек ярлыка. Я так понял вы их делали вручную, а не через кнопку Ярлык в самой системе, да?
Что у вас прописано в поле "Транзакция" в настройках ярлыка? Попробуйте - SESSION_MANAGER.
СообщениеДобавлено: Вт, ноя 29 2011, 06:04
Выложить скриншот сейчас возможности нет.
Ярлыки делал и вручную и стандартным способом - из системы с сохранением в SAP Logon. Результат одинаковый - регистрация не всегда проходит с первого раза.
А транзакция конечно же SESSION_MANAGER.
СообщениеДобавлено: Вт, дек 13 2011, 06:37
zadmin написал(а):
Здравствуйте!
Код:0x80004005
Спасибо
Всем привет!
А ошибку то SAP признал, правда убеждать в ней пришлось... :D
Патчик выпустил, нотку с траблами обновил за номером 1587566...
Правда там тоже неприятность есть: по пути предложенному SAP'ом ничего пока нет... но по крайней мере ссылку хоть кинули :)
СообщениеДобавлено: Сб, янв 14 2012, 07:32
SAP GUI for Windows 7.20 patchlevel 10 is now available for download
СообщениеДобавлено: Вт, янв 17 2012, 09:39
Changelog:
2011/11/16 ALVGrid:Cell background color is not drawn correctly, note 1641198
2011/11/16 Chart: Missing value labels of value axis, note 1636618
2011/11/16 SAP Logon: Modis werden falsch sortiert angezeigt, note 1648972
2011/11/16 SAP Logon: Tooltip for More button added., note 1640048
2011/11/16 SAP Logon: focus incorrectly reset after usage of options di, note 1638500
2011/11/16 SAPGUI.EXE hanging and waiting for a timeout, note 1640549
2011/11/16 Scripting: ShowKey property for ComboBox, note 1634178
2011/11/16 Scripting: new session properties for Progress Indicator, note 1634547
2011/11/16 Scripting: suppress backend popups is necessary, note 1636636
2011/11/16 Session not reacting after send Email via Acrobar Reader X, note 1650455
2011/11/16 Textedit:Issue with Focus/Animated focus in Textedit control, note 1607054
2011/11/16 Saplgdll Creates/Changes Directory on Load, note 1635219
2011/11/17 Fokus(Cursor): falsch gesetzt auf einer Liste in neuem Modus, note 1650293
2011/11/17 Icon display problem in GUI 720, note 1636722
2011/11/17 SAP Logon: wrong variable connection icon, note 1640961
2011/11/17 SAPShortcut: command with OKcode > 255 characters failed, note 1650890
2011/11/17 Tabchain: field next to radiobutton label can not be tabbed, note 1646811
2011/11/21 ABAP editor: fixed document name in code templates, note 1635544
2011/11/21 Access: Current version for Release 4.6 or higher, note 169887
2011/11/21 History: stops working after Adobe Reader, Irfan, ECL, etc, note 1650482
2011/11/21 Interactive Excel: Current version, note 169479
2011/11/21 OI: Excel prints all the sheets of the workbook, note 1624493
2011/11/21 Planung: Plantafelversion 7.6.9, note 1548334
2011/11/21 Probleme mit der Druckerauswahlbox bei Koppelart G, note 1650892
2011/11/21 SAP GUI crashes sporadically when using ABAP Editor, note 1599299
2011/11/23 Calendar:Focus shifts to day field when Mo\Yr is navigated., note 1625687
2011/11/23 GDI leak if Save As dialog in OS Theme and not SAP Theme, note 1655676
2011/11/23 Gridview Scripting: GetCellValue API returns garbled text, note 1654550
2011/11/23 Improper R3 systems displayed when environment variable set, note 1649104
2011/11/23 Macro enabled excel document cannot save the edited document, note 1634382
2011/11/23 OI: Word document contents with link fields cannot be saved, note 1634398
2011/11/23 Crash in SAP GUI in CSAPGUIFont::init, note 1654192
2011/11/29 Some SAP GUI texts are displayed in English in patchlevel 9, note 1657315
2011/12/01 GuiXT: Version 2011 Q4 3, note 809461
2011/12/08 GuiXT: Version 2011 Q4 3, note 809461
2011/12/12 A text could be incorrectly displayed with the ellipsis(...), note 1656860
2011/12/12 The upper border from Browser For Folder dialogbox missing, note 1662640
2011/12/26 Merge field data in header field gets disappeared on Print , note 1645315
2011/12/26 Office 2010 crashes on using quick option SaveAs , Print , note 1611709
СообщениеДобавлено: Пт, янв 20 2012, 15:12
Пт, янв 20 2012, 15:09
Залейте пожалуйста на файлообменник.
http://it.linkedin.com/pub/eugenio-pospelov/16/548/50
