Текущее время: Вс, июн 07 2026, 11:33
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: disp+work.exe не запускается после перезагрузки сервера
СообщениеДобавлено: Вт, дек 06 2011, 12:56
Вт, дек 06 2011, 09:44
После перезагрузки сервера, перестал запускаться disp+work.exe.
Запускаю через графическую SAPMMC.
Что может быть???
В dev_disp:
trc file: "dev_disp", trc level: 1, release: "640"
Tue Dec 06 09:37:56 2011
kernel runs with dp version 137(ext=102) (@(#) DPLIB-INT-VERSION-137)
length of sys_adm_ext is 312 bytes
sysno      00
sid        BWP
systemid   562 (PC with Windows NT)
relno      6400
patchlevel 0
patchno    238
intno      20020600
make:      multithreaded, ASCII, 64 bit
pid        140
***LOG Q00=> DpSapEnvInit, DPStart (00 140) [dpxxdisp.c   1107]
   shared lib "dw_xml.dll" version 238 successfully loaded
   shared lib "dw_xtc.dll" version 238 successfully loaded
   shared lib "dw_stl.dll" version 238 successfully loaded
   shared lib "dw_gui.dll" version 238 successfully loaded
   shared lib "dw_mdm.dll" version 238 successfully loaded
Tue Dec 06 09:38:01 2011
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 5 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c  3881]
MtxInit: -2 0 0
DpSysAdmExtInit: ABAP is active
DpIPCInit2: start server >sapp_BWP_00                             <
DpShMCreate: sizeof(wp_adm)      19200   (960)
DpShMCreate: sizeof(tm_adm)      3021432   (15032)
DpShMCreate: sizeof(wp_ca_adm)      18000   (60)
DpShMCreate: sizeof(appc_ca_adm)   6000   (60)
DpShMCreate: sizeof(comm_adm)      212000   (424)
DpShMCreate: sizeof(vmc_adm)      0   (448)
DpShMCreate: sizeof(wall_adm)      (22440/36712/56/104)
DpShMCreate: SHM_DP_ADM_KEY      (addr: 000000000E100050, size: 3342144)
DpShMCreate: allocated sys_adm at 000000000E100050
DpShMCreate: allocated wp_adm at 000000000E101880
DpShMCreate: allocated tm_adm_list at 000000000E106380
DpShMCreate: allocated tm_adm at 000000000E1063A8
DpShMCreate: allocated wp_ca_adm at 000000000E3E7E20
DpShMCreate: allocated appc_ca_adm at 000000000E3EC470
DpShMCreate: allocated comm_adm_list at 000000000E3EDBE0
DpShMCreate: allocated comm_adm at 000000000E3EDBF8
DpShMCreate: allocated vmc_adm_list at 000000000E421818
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 000000000E421840
DpShMCreate: allocated wall_adm at 000000000E421848
MBUF state OFF
ThTaskStatus: rdisp/reset_online_during_debug 0
EmInit: MmSetImplementation( 2 ).
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 4096 kByte.
Using implementation flat
<EsNT> Memory Reset disabled as NT default
<ES> 1535 blocks reserved for free list.
ES initialized.
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG Q0K=> DpMsAttach, mscon ( sapp) [dpxxdisp.c   10181]
DpStartStopMsg: send start message (myname is >sapp_BWP_00                             <)
DpStartStopMsg: start msg sent
CCMS: AlInitGlobals : alert/use_sema_lock = TRUE.
CCMS: Initalizing shared memory of size 40000000 for monitoring segment.
CCMS: Checking Downtime Configuration of Monitoring Segment.
CCMS: start to initalize 3.X shared alert area (first segment).
Tue Dec 06 09:38:02 2011
DpMsgAdmin: Set release to 6400, patchlevel 0
MBUF state PREPARED
MBUF component UP
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c   1025]
DpMsgAdmin: Set patchno for this platform to 238
Release check o.K.
Tue Dec 06 09:38:41 2011
*** ERROR => W0 (pid 3036) died [dpxxdisp.c   12752]
*** ERROR => W1 (pid 3052) died [dpxxdisp.c   12752]
*** ERROR => W2 (pid 1596) died [dpxxdisp.c   12752]
*** ERROR => W3 (pid 1776) died [dpxxdisp.c   12752]
*** ERROR => W4 (pid 1720) died [dpxxdisp.c   12752]
*** ERROR => W5 (pid 1632) died [dpxxdisp.c   12752]
*** ERROR => W6 (pid 1740) died [dpxxdisp.c   12752]
*** ERROR => W7 (pid 1888) died [dpxxdisp.c   12752]
my types changed after wp death/restart 0xbf --> 0xbe
*** ERROR => W8 (pid 1928) died [dpxxdisp.c   12752]
*** ERROR => W9 (pid 420) died [dpxxdisp.c   12752]
*** ERROR => W10 (pid 2620) died [dpxxdisp.c   12752]
my types changed after wp death/restart 0xbe --> 0xbc
*** ERROR => W11 (pid 1144) died [dpxxdisp.c   12752]
my types changed after wp death/restart 0xbc --> 0xb8
*** ERROR => W12 (pid 3044) died [dpxxdisp.c   12752]
*** ERROR => W13 (pid 2488) died [dpxxdisp.c   12752]
*** ERROR => W14 (pid 2016) died [dpxxdisp.c   12752]
*** ERROR => W15 (pid 2040) died [dpxxdisp.c   12752]
*** ERROR => W16 (pid 1604) died [dpxxdisp.c   12752]
*** ERROR => W17 (pid 560) died [dpxxdisp.c   12752]
my types changed after wp death/restart 0xb8 --> 0xb0
*** ERROR => W18 (pid 1600) died [dpxxdisp.c   12752]
my types changed after wp death/restart 0xb0 --> 0xa0
*** ERROR => W19 (pid 2052) died [dpxxdisp.c   12752]
my types changed after wp death/restart 0xa0 --> 0x80
*** DP_FATAL_ERROR => DpWPCheck: no more work processes
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
killing W0-3036 (SIGUSR2)
*** ERROR => DpWpKill(3036, SIGUSR2) failed [dpxxtool.c   2508]
killing W1-3052 (SIGUSR2)
*** ERROR => DpWpKill(3052, SIGUSR2) failed [dpxxtool.c   2508]
killing W2-1596 (SIGUSR2)
*** ERROR => DpWpKill(1596, SIGUSR2) failed [dpxxtool.c   2508]
killing W3-1776 (SIGUSR2)
*** ERROR => DpWpKill(1776, SIGUSR2) failed [dpxxtool.c   2508]
killing W4-1720 (SIGUSR2)
*** ERROR => DpWpKill(1720, SIGUSR2) failed [dpxxtool.c   2508]
killing W5-1632 (SIGUSR2)
*** ERROR => DpWpKill(1632, SIGUSR2) failed [dpxxtool.c   2508]
killing W6-1740 (SIGUSR2)
*** ERROR => DpWpKill(1740, SIGUSR2) failed [dpxxtool.c   2508]
killing W7-1888 (SIGUSR2)
*** ERROR => DpWpKill(1888, SIGUSR2) failed [dpxxtool.c   2508]
killing W8-1928 (SIGUSR2)
*** ERROR => DpWpKill(1928, SIGUSR2) failed [dpxxtool.c   2508]
killing W9-420 (SIGUSR2)
*** ERROR => DpWpKill(420, SIGUSR2) failed [dpxxtool.c   2508]
killing W10-2620 (SIGUSR2)
*** ERROR => DpWpKill(2620, SIGUSR2) failed [dpxxtool.c   2508]
killing W11-1144 (SIGUSR2)
*** ERROR => DpWpKill(1144, SIGUSR2) failed [dpxxtool.c   2508]
killing W12-3044 (SIGUSR2)
*** ERROR => DpWpKill(3044, SIGUSR2) failed [dpxxtool.c   2508]
killing W13-2488 (SIGUSR2)
*** ERROR => DpWpKill(2488, SIGUSR2) failed [dpxxtool.c   2508]
killing W14-2016 (SIGUSR2)
*** ERROR => DpWpKill(2016, SIGUSR2) failed [dpxxtool.c   2508]
killing W15-2040 (SIGUSR2)
*** ERROR => DpWpKill(2040, SIGUSR2) failed [dpxxtool.c   2508]
killing W16-1604 (SIGUSR2)
*** ERROR => DpWpKill(1604, SIGUSR2) failed [dpxxtool.c   2508]
killing W17-560 (SIGUSR2)
*** ERROR => DpWpKill(560, SIGUSR2) failed [dpxxtool.c   2508]
killing W18-1600 (SIGUSR2)
*** ERROR => DpWpKill(1600, SIGUSR2) failed [dpxxtool.c   2508]
killing W19-2052 (SIGUSR2)
*** ERROR => DpWpKill(2052, SIGUSR2) failed [dpxxtool.c   2508]
NiWait: sleep (10000 msecs) ...
NiISelect: timeout 10000 ms
NiISelect: maximum fd=245
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Tue Dec 06 09:38:51 2011
NiISelect: TIMEOUT occured (10000 ms)
dump system status
Workprocess Table (long)         Tue Dec 06 03:38:51 2011
No Ty. Pid      Status  Cause Start Err Sem CPU    Time  Program  Cl  User         Action                    Table
0 DIA     3036 Ended         no      1   0             0
1 DIA     3052 Ended         no      1   0             0
2 DIA     1596 Ended         no      1   0             0
3 DIA     1776 Ended         no      1   0             0
4 DIA     1720 Ended         no      1   0             0
5 DIA     1632 Ended         no      1   0             0
6 DIA     1740 Ended         no      1   0             0
7 DIA     1888 Ended         no      1   0             0
8 UPD     1928 Ended         no      1   0             0
9 UPD      420 Ended         no      1   0             0
10 UPD     2620 Ended         no      1   0             0
11 ENQ     1144 Ended         no      1   0             0
12 BTC     3044 Ended         no      1   0             0
13 BTC     2488 Ended         no      1   0             0
14 BTC     2016 Ended         no      1   0             0
15 BTC     2040 Ended         no      1   0             0
16 BTC     1604 Ended         no      1   0             0
17 BTC      560 Ended         no      1   0             0
18 SPO     1600 Ended         no      1   0             0
19 UP2     2052 Ended         no      1   0             0
Dispatcher Queue Statistics         Tue Dec 06 03:38:51 2011
|  Typ |    now |   high |    max | writes |  reads |
| NOWP |      0 |      3 |   2000 |     10 |     10 |
|  DIA |      5 |      5 |   2000 |      5 |      0 |
|  UPD |      0 |      0 |   2000 |      0 |      0 |
|  ENQ |      0 |      0 |   2000 |      0 |      0 |
|  BTC |      0 |      0 |   2000 |      0 |      0 |
|  SPO |      0 |      0 |   2000 |      0 |      0 |
|  UP2 |      0 |      0 |   2000 |      0 |      0 |
max_rq_id      13
wake_evt_udp_now   0
wake events         total     9,  udp     8 ( 88%),  shm     1 ( 11%)
since last update   total     9,  udp     8 ( 88%),  shm     1 ( 11%)
Dump of tm_adm structure:         Tue Dec 06 03:38:51 2011
Term    uid  man user    term   lastop  mod wp  ta   a/i (modes)
Workprocess Comm. Area Blocks         Tue Dec 06 03:38:51 2011
Slots: 300, Used: 1, Max: 0
|   id | owner        |   pid    | eyecatcher  |
|    0 | DISPATCHER   |       -1 | *WPCAAD000* |
NiWait: sleep (5000 msecs) ...
NiISelect: timeout 5000 ms
Tue Dec 06 09:38:56 2011
NiISelect: TIMEOUT occured (5000 ms)
DpHalt: shutdown server >sapp_BWP_00                             < (normal)
DpJ2eeDisableRestart
DpModState: buffer in state MBUF_PREPARED
NiBufSend starting
NiIWrite: write 110, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 110 bytes
MsIModState: change state to SHUTDOWN
DpModState: change server state from STARTING to SHUTDOWN
Switch off Shared memory profiling
ShmProtect( 57, 3 )
ShmProtect(SHM_PROFILE, SHM_PROT_RW
ShmProtect( 57, 1 )
ShmProtect(SHM_PROFILE, SHM_PROT_RD
DpWakeUpWps: wake up all wp's
Stop work processes...
Stop gateway
killing process (3004) (SOFT_KILL)
Stop icman
killing process (3028) (SOFT_KILL)
Terminate gui connections
[DpProcDied] Process lives  (PID:3004  HANDLE:220)
waiting for termination of gateway
NiWait: sleep (1000 msecs) ...
NiISelect: timeout 1000 ms
Tue Dec 06 09:38:57 2011
NiISelect: TIMEOUT occured (1000 ms)
[DpProcDied] Process died  (PID:3004  HANDLE:220)
[DpProcDied] Process lives  (PID:3028  HANDLE:228)
waiting for termination of icman
Tue Dec 06 09:38:58 2011
Tue Dec 06 09:38:59 2011
Tue Dec 06 09:39:00 2011
Tue Dec 06 09:39:01 2011
Tue Dec 06 09:39:02 2011
Tue Dec 06 09:39:03 2011
Tue Dec 06 09:39:04 2011
Tue Dec 06 09:39:05 2011
Tue Dec 06 09:39:06 2011
Tue Dec 06 09:39:07 2011
[DpProcDied] Process died  (PID:3028  HANDLE:228)
DpHalt: cancel all lcom connections
MPI CancelAll 2 -> 0
MPI DeleteAll 2 -> 0
DpStartStopMsg: send stop message (myname is >sapp_BWP_00                             <)
NiIMyHostName: hostname = 'sapp'
AdGetSelfIdentRecord: >        <
AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0
DpConvertRequest: net size = 163 bytes
NiBufSend starting
NiIWrite: write 562, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 562 bytes
send msg (len 110+452) to name          -, type 4, key -
DpStartStopMsg: stop msg sent
NiIRead: read 229, 1 packs, MESG_IO, hdl 3, data complete
NiBufIn: NIBUF len=229
NiBufIn: Packet complete for hdl 3
NiBufReceive starting
MsINiRead: received 229 bytes
MSG received, len 110+119, flag 1, from MSG_SERVER, typ 0, key -
DpHalt: received 119 bytes from message server
NiPRead: WSAEWOULDBLOCK 1.time 4
NiIPeek: peek for hdl 3 / socket 132 timed out (r; 0)
DpHalt: no more messages from the message server
DpHalt: send keepalive to synchronize with the message server
NiBufSend starting
NiIWrite: write 114, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 114 bytes
send msg (len 110+4) to name MSG_SERVER, type 0, key -
MsSndName: MS_NOOP ok
Send 4 bytes to MSG_SERVER
NiIPeek: peek successful for hdl 3 / socket 132 (r)
NiIRead: read 114, 1 packs, MESG_IO, hdl 3, data complete
NiBufIn: NIBUF len=114
MsINiRead: received 114 bytes
MSG received, len 110+4, flag 3, from MSG_SERVER, typ 0, key -
Received 4 bytes from MSG_SERVER
Received opcode MS_NOOP from msg_server, reply MSOP_OK
MsOpReceive: ok
MsSendKeepalive : keepalive sent to message server
Tue Dec 06 09:39:08 2011
NiIPeek: peek for hdl 3 / socket 132 timed out (r; 1000)
DpHalt: sync with message server o.k.
detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c   10471]
NiBufSend starting
MsIDetach: send logout to msg_server
MsIDetach: call exit function
DpMsShutdownHook called
NiSelClear: removed hdl 3 from selectset
MBUF state OFF
AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
blks_in_queue/wp_ca_blk_no/wp_max_no = 1/300/20
LOCK WP ca_blk 1
make DISP owner of wp_ca_blk 1
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 19)
MBUF component DOWN
NiBufClose: clear extensions for hdl 3
NiBufSetStat: bufstat of hdl 3 changed from OK to OFF
NiICloseHandle: shutdown and close hdl 3 / socket 132
MsIDetach: detach MS-system
EsCleanup ....
***LOG Q05=> DpHalt, DPStop ( 140) [dpxxdisp.c   8811]
Good Bye .....
 Заголовок сообщения: Re: disp+work.exe не запускается после перезагрузки сервера
СообщениеДобавлено: Вт, дек 06 2011, 13:00
Пн, фев 11 2008, 11:38
Добрый день. Что в dev_w0 ?
СообщениеДобавлено: Вт, дек 06 2011, 13:11
в dev_w0:
trc file: "dev_w0", trc level: 1, release: "640"
*  ACTIVE TRACE LEVEL           1
*  ACTIVE TRACE COMPONENTS      all, M
B Tue Dec 06 09:38:01 2011
B  create_con (con_name=R/3)
B  Loading DB library 'I:\usr\sap\BWP\SYS\exe\run\dboraslib.dll' ...
B  Library 'I:\usr\sap\BWP\SYS\exe\run\dboraslib.dll' loaded
B  Version of 'I:\usr\sap\BWP\SYS\exe\run\dboraslib.dll' is "640.00", patchlevel (0.101)
B  New connection 0 created
M sysno      00
M sid        BWP
M systemid   562 (PC with Windows NT)
M relno      6400
M patchlevel 0
M patchno    238
M intno      20020600
M make:      multithreaded, ASCII, 64 bit
M pid        3036
M
M  ***LOG Q0Q=> tskh_init, WPStart (Workproc 0 3036) [dpxxdisp.c   1167]
I  MtxInit: -2 0 0
M  DpSysAdmExtCreate: ABAP is active
M  DpShMCreate: sizeof(wp_adm)      19200   (960)
M  DpShMCreate: sizeof(tm_adm)      3021432   (15032)
M  DpShMCreate: sizeof(wp_ca_adm)      18000   (60)
M  DpShMCreate: sizeof(appc_ca_adm)   6000   (60)
M  DpShMCreate: sizeof(comm_adm)      212000   (424)
M  DpShMCreate: sizeof(vmc_adm)      0   (448)
M  DpShMCreate: sizeof(wall_adm)      (22440/36712/56/104)
M  DpShMCreate: SHM_DP_ADM_KEY      (addr: 000000000E100050, size: 3342144)
M  DpShMCreate: allocated sys_adm at 000000000E100050
M  DpShMCreate: allocated wp_adm at 000000000E101880
M  DpShMCreate: allocated tm_adm_list at 000000000E106380
M  DpShMCreate: allocated tm_adm at 000000000E1063A8
M  DpShMCreate: allocated wp_ca_adm at 000000000E3E7E20
M  DpShMCreate: allocated appc_ca_adm at 000000000E3EC470
M  DpShMCreate: allocated comm_adm_list at 000000000E3EDBE0
M  DpShMCreate: allocated comm_adm at 000000000E3EDBF8
M  DpShMCreate: allocated vmc_adm_list at 000000000E421818
M  DpShMCreate: system runs without vmc_adm
M  DpShMCreate: allocated ca_info at 000000000E421840
M  DpShMCreate: allocated wall_adm at 000000000E421848
M  ThTaskStatus: rdisp/reset_online_during_debug 0
X  EmInit: MmSetImplementation( 2 ).
X  <ES> client 0 initializing ....
X  Using implementation flat
M  <EsNT> Memory Reset disabled as NT default
X  ES initialized.
M Tue Dec 06 09:38:03 2011
M  calling db_connect ...
C  Prepending C:\oracle\BWP\102 to Path.
C  got NLS_LANG='AMERICAN_AMERICA.WE8DEC' from environment
C  Client NLS settings: AMERICAN_AMERICA.WE8DEC
C  Logon as OPS$-user to get SAPBWP's password
C  Connecting as /@BWP on connection 0 (nls_hdl 0) ... (dbsl 640 310805)
C  Nls CharacterSet                 NationalCharSet              C      EnvHp      ErrHp ErrHpBatch
C    0 WE8DEC                                                    1 000000000F8150B0 0000000009EB0E20 0000000009EB3F68
C  Attaching to DB Server BWP (con_hdl=0,svchp=0000000009EB3E28,svrhp=000000000F825108)
C  Starting user session (con_hdl=0,svchp=0000000009EB3E28,srvhp=000000000F825108,usrhp=0000000009EB1638)
C  Now '/@BWP' is connected (con_hdl 0, nls_hdl 0).
C  Got SAPBWP's password from OPS$-user
C  Disconnecting from connection 0 ...
C  Closing user session (con_hdl=0,svchp=0000000009EB3E28,usrhp=0000000009EB1638)
C  Now I'm disconnected from ORACLE
C  Connecting as SAPBWP/<pwd>@BWP on connection 0 (nls_hdl 0) ... (dbsl 640 310805)
C Tue Dec 06 09:38:04 2011
C  Now 'SAPBWP/<pwd>@BWP' is connected (con_hdl 0, nls_hdl 0).
C  Database NLS settings: AMERICAN_AMERICA.WE8DEC
C  Database instance bwp is running on SAPP with ORACLE version 10.2.0.2.0 since 20111206
B  Connection 0 opened (DBSL handle 0)
B  Wp  Hdl ConName          ConId     ConState     TX  PRM RCT TIM MAX OPT Date     Time   DBHost
B  000 000 R/3              000000000 ACTIVE       NO  YES NO  000 255 255 20111206 093803 SAPP
C  *** ERROR => Error in stmt_fetch()
[dbsloci.c    12121]
C  *** ERROR => ORA-376 occurred when executing SQL statement (parse error offset=0)
[dbsloci.c    12122]
C  sc_p=0000000009E45420,no=0,idc_p=0000000000000000,con=0,act=1,slen=26,smax=256,#vars=0,stmt=0000000009EAD970,table=SVERS
C  SELECT VERSION FROM SVERS ;
C  prep=0,lit=0,nsql=0,lobret=0,#exec=1,dbcnt=0,upsh_p=0000000000000000,ocistmth_p=000000000F82EA48
C  IN : cols=0,rmax=0,xcnt=0,rpc=0,rowi=0,rtot=0,upto=-1,rsize=0,vmax=0,bound=0,iobuf_p=0000000000000000,vda_p=0000000000000000
C       lobs=0,lmax=0,lpcnt=0,larr=0000000000000000,lcurr_p=0000000000000000,rret=0
C  OUT: cols=1,rmax=1,xcnt=1,rpc=0,rowi=0,rtot=0,upto=-1,rsize=72,vmax=32,bound=1,iobuf_p=0000000006C2A760,vda_p=000000000F83B490
B  ***LOG BZA=> table SVERS      does not exist on database [dblink#3 @ 1280] [dblink  1280 ]
M  ***LOG R19=> tskh_init, db_connect ( DB-Connect 004096) [thxxhead.c   1282]
M  in_ThErrHandle: 1
M  *** ERROR => tskh_init: db_connect (step 1, th_errno 13, action 3, level 1) [thxxhead.c   9707]
M  Info for wp 0
M    stat = 4
M    reqtype = 1
M    act_reqtype = -1
M    rq_info = 0
M    tid = -1
M    mode = 255
M    len = -1
M    rq_id = 65535
M    rq_source = 255
M    last_tid = 0
M    last_mode = 0
M    int_checked_resource(RFC) = 0
M    ext_checked_resource(RFC) = 0
M    int_checked_resource(HTTP) = 0
M    ext_checked_resource(HTTP) = 0
M    report = >                                        <
M    action = 0
M    tab_name = >                              <
M  *****************************************************************************
M  *
M  *  LOCATION    SAP-Server sapp_BWP_00 on host sapp (wp 0)
M  *  ERROR       tskh_init: db_connect
M  *
M  *  TIME        Tue Dec 06 09:38:04 2011
M  *  RELEASE     640
M  *  COMPONENT   Taskhandler
M  *  VERSION     1
M  *  RC          13
M  *  MODULE      thxxhead.c
M  *  LINE        9892
M  *  COUNTER     1
M  *
M  PfStatDisconnect: disconnect statistics
M  Entering TH_CALLHOOKS
M  ThCallHooks: call hook >ThrSaveSPAFields< for event BEFORE_DUMP
M  *** ERROR => ThrSaveSPAFields: no valid thr_wpadm [thxxrun1.c   730]
M  *** ERROR => ThCallHooks: event handler ThrSaveSPAFields for event BEFORE_DUMP failed [thxxtool3.c  255]
M  Entering ThSetStatError
M  Entering ThReadDetachMode
M  call ThrShutDown (1)...
M  ***LOG Q02=> wp_halt, WPStop (Workproc 0 3036) [dpnttool.c   357]
СообщениеДобавлено: Вт, дек 06 2011, 14:31
Вт, июл 24 2007, 14:52
Note 530392 - SVERS doesn't exist - System no longer restarts
Note 534765 - db connect fails because of wrong db schema in environment
СообщениеДобавлено: Вт, дек 06 2011, 14:35
Что то не радостно как то ...
Вы под каким пользователем сейчас стартовать пытаетесь?
Зайдите под SIDADM и дайте R3trans -d
У пользователя SAPserviceSID всё в порядке с переменными ?
P.S. Я бы на вашем месте ещё Oracle alert log бы проверил ....
СообщениеДобавлено: Ср, дек 07 2011, 09:12
Ср, окт 04 2006, 15:30
помоему это Ваш случай
http://forums.sdn.sap.com/thread.jspa?threadID=1003996
СообщениеДобавлено: Чт, дек 08 2011, 07:15
Спасибо за помощь, все заработало. Использовал Note 328785.
