Текущее время: Вт, янв 13 2026, 20:18
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: проблемы с sapinst
СообщениеДобавлено: Вс, дек 02 2012, 23:17
Ср, авг 08 2012, 10:12
Проблема при запуске sapinst
ставлю NW7.3. ОС Suse 11 SP1
Подскажите, что может быть не так.
при запуске -
sapddt:/sapmnt/distr/SWPM10SP00_4-20009701_x86_64 # ./sapinst
[==============================] - extracting... done!
SAPinst build information:
abi version : 722
make variant: 720_REL
build : 1370395
compile time: Oct 29 2012 16:18:49
Starting GUIServer using:
SAPinst port : pipe:5:8
GUIServer port : 21212
HTTP port : 4239
GUIServer user : no user switch
GUI autostart : on
GUI mode : normal
command : /tmp/sapinst_exe.6792.1354478462/jre/bin/java -Xmx256M -Dsap.env.var.javahome=SAPINST_JRE_HOME -cp /tmp/sapinst_exe.6792.1354478462/JAR/instgui.jar SDTServer rootdir=/root/.sdtgui config=jar:sdtserver.xml guiport=21212 httpport=4239 -nolock -srvarg=/SAPinstService/host=127.0.0.1 -srvarg=/SAPinstService/port=pipe:5:8
protecting fds 5 and 8.
load resource pool /sapmnt/distr/SWPM10SP00_4-20009701_x86_64/resourcepool.xml
Dec 3, 2012 12:01:07 AM [Info]: *************************
Dec 3, 2012 12:01:07 AM [Info]: Starting Server
guiengine: No GUI server connected; waiting for a connection on <unknown> to continue with the installation
Dec 3, 2012 12:01:07 AM [Error]: java.net.UnknownHostException: sapddt: sapddt
Dec 3, 2012 12:01:07 AM [Error]: Error during configuration - see preceding messages.
Dec 3, 2012 12:01:07 AM [Fatal]: Error during controller startup.
Dec 3, 2012 12:01:07 AM [Fatal]: SL Controller exiting.
The process that should run the SAPinst GUI could not be started. Please make sure that a JDK is installed on this host and that SAPINST_JRE_HOME points to the root directory of your Java installation. As an alternative you may start the GUI on another host (for details please consult the installation guide).
Java has been started with the following command line:
Java установил, прописал переменную SAPINST_JRE_HOME="/sapmnt/distr/j2sdk1.4.2_38"
 Заголовок сообщения: Re: проблемы с sapinst
СообщениеДобавлено: Пн, дек 03 2012, 07:54
Пн, фев 11 2008, 11:38
А зачем ковычки ? SAPINST_JRE_HOME=/sapmnt/distr/j2sdk1.4.2_38 так лучше.
P.S. неужели NW 7.3 использует 1.4.2 все еще? Ну как минимум встроенный SAPJVM должен быть.
Почитайте ноты , не уверен я про 1.4.2
СообщениеДобавлено: Пн, дек 03 2012, 08:25
Читал. Говорится что есть SAPJVM, но можно использовать и 1.4.2
Если использовать SAPJVM, то я так понимаю ничего отдельно перед установкой устанавливать не нужно? И старую джаву удалить?
На линукс еще не ставил, а NW 7.3 вообще никуда не ставил
СообщениеДобавлено: Пн, дек 03 2012, 08:37
Где говорится что можно 1.4.2 для 7.3 ? Зачем старую джаву удалять , она кому мешает.
СообщениеДобавлено: Пн, дек 03 2012, 10:03
Ср, июн 11 2008, 09:41
Да вроде без проблем все ставится на суси, ставил 4 системы, не помню плясок. В хостах система прописана?
SAP Basis, SAP Security Audit/Pentest, РФ, Москва
СообщениеДобавлено: Пн, дек 03 2012, 10:32
"В хостах система прописана?"- подскажите куда и как прописать:)
все делал по гайду, назначил переменные окружения DISPLAY и SAPINST_JRE_HOME и прочие параметры.
Не пойму что такое?
СообщениеДобавлено: Пн, дек 03 2012, 10:40
Вт, ноя 23 2004, 10:40
Если делал все по гайду, тогда все уже д.б. сделано.
Проблемы иногда возникают, если активирован SELinux, кроме этого желательно использовать самый свежий SWPM.
Сама джава особо ни на что не влияет, оно там использует свою JRE.
Хотя для порядку заливал JRE 1.4 от SAP, и делал все ссылки по умолчанию на него.
СообщениеДобавлено: Пн, дек 03 2012, 10:45
"Проблемы иногда возникают, если активирован SELinux" - систему не активировал
SWPM- самый свежий
СообщениеДобавлено: Пн, дек 03 2012, 10:51
содержимое /etc/hosts ?
СообщениеДобавлено: Пн, дек 03 2012, 10:59
Ср, окт 24 2007, 14:24
вот прям так в /sapmnt/distr установил?
если не ошибаюсь, по умолчанию, джава в /opt ставится
СообщениеДобавлено: Пн, дек 03 2012, 11:38
попробуйте еще сапинст запустить на другом порту, ну а для начала можно посмотреть на результат нетстата
СообщениеДобавлено: Пн, дек 03 2012, 12:00
Ср, июл 25 2012, 22:24
Поддерживаю, проблема в hosts.
Покажите вывод:
cat /etc/hosts
и
hostname -f
:mrgreen:
СообщениеДобавлено: Пн, дек 03 2012, 13:36
sapddt:~ # cat /etc/hosts
# hosts This file describes a number of hostname-to-address
# mappings for the TCP/IP subsystem. It is mostly
# used at boot time, when no name servers are running.
# On small systems, this file can be used instead of a
# "named" name server.
# Syntax:
# IP-Address Full-Qualified-Hostname Short-Hostname
127.0.0.1 localhost
# special IPv6 addresses
::1 localhost ipv6-localhost ipv6-loopback
fe00::0 ipv6-localnet
ff00::0 ipv6-mcastprefix
ff02::1 ipv6-allnodes
ff02::2 ipv6-allrouters
ff02::3 ipv6-allhosts
sapddt:~ # hostname -f
hostname: Unknown host
СообщениеДобавлено: Пн, дек 03 2012, 13:38
Подскажите, что туда нужно прописать?
В Гайде ничего нет
СообщениеДобавлено: Пн, дек 03 2012, 14:07
Гайд по подготовке Suse 11, там указано что надо настроить имя хоста Note 1310037 - SUSE LINUX Enterprise Server 11: Installation notes
Задать имя хоста:
YaST > Network devices > Network Configuration and then the Hostname/DNS
И прописать его в /etc/hosts
echo "<ВашИп> <Заданное имя хоста>" >> /etc/hosts
:mrgreen:
