Текущее время: Пт, авг 07 2026, 15:13
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Останавлвается disp+work.EXE
СообщениеДобавлено: Вс, май 26 2013, 17:36
Пн, мар 12 2012, 12:49
Здравствуйте, пытаюсь установить SAP ERP 6.0 EHP6 ORACLE на Widows 7, установка проходит нормально, но когда пытаюсь запускать сервер процесс disp+work.EXE сначала стартует, а потом останавливается, в Developer trace пишет
trc file: "dev_disp", trc level: 1, release: "720"
sysno      00
sid        PRO
systemid   562 (PC with Windows NT)
relno      7200
patchlevel 0
patchno    100
intno      20020600
make       multithreaded, Unicode, 64 bit, optimized
profile    \\ECC\sapmnt\PRO\SYS\profile\PRO_DVEBMGS00_ECC
pid        3084
kernel runs with dp version 131000(ext=118000) (@(#) DPLIB-INT-VERSION-131000-UC)
length of sys_adm_ext is 588 bytes
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (00 3084) [dpxxdisp.c   1287]
   shared lib "dw_xml.dll" version 100 successfully loaded
   shared lib "dw_xtc.dll" version 100 successfully loaded
   shared lib "dw_stl.dll" version 100 successfully loaded
   shared lib "dw_gui.dll" version 100 successfully loaded
   shared lib "dw_mdm.dll" version 100 successfully loaded
   shared lib "dw_rndrt.dll" version 100 successfully loaded
   shared lib "dw_abp.dll" version 100 successfully loaded
   shared lib "dw_sym.dll" version 100 successfully loaded
   shared lib "dw_aci.dll" version 100 successfully loaded
rdisp/softcancel_sequence :  -> 0,5,-1
use internal message server connection to port 3900
rdisp/dynamic_wp_check : 1
rdisp/calculateLoadAverage : 1
Sun May 26 17:50:30 2013
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 5 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c  6404]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: write dp-profile-values into sys_adm_ext
DpIPCInit2: start server >ECC_PRO_00                              <
DpShMCreate: sizeof(wp_adm)      43024   (2264)
DpShMCreate: sizeof(tm_adm)      5517056   (27448)
DpShMCreate: sizeof(wp_ca_adm)      64000   (64)
DpShMCreate: sizeof(appc_ca_adm)   64000   (64)
DpCommTableSize: max/headSize/ftSize/tableSize=500/16/584064/584080
DpShMCreate: sizeof(comm_adm)      584080   (1144)
DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
DpShMCreate: sizeof(slock_adm)      0   (104)
DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
DpShMCreate: sizeof(file_adm)      0   (80)
DpShMCreate: sizeof(vmc_adm)      0   (2152)
DpShMCreate: sizeof(wall_adm)      (41664/36752/64/192)
DpShMCreate: sizeof(gw_adm)   48
DpShMCreate: sizeof(j2ee_adm)   3952
DpShMCreate: SHM_DP_ADM_KEY      (addr: 00000000075A0050, size: 6368736)
DpShMCreate: allocated sys_adm at 00000000075A0060
DpShMCreate: allocated wp_adm_list at 00000000075A3040
DpShMCreate: allocated wp_adm at 00000000075A3230
DpShMCreate: allocated tm_adm_list at 00000000075ADA50
DpShMCreate: allocated tm_adm at 00000000075ADAA0
DpShMCreate: allocated wp_ca_adm at 0000000007AF09B0
DpShMCreate: allocated appc_ca_adm at 0000000007B003C0
DpShMCreate: allocated comm_adm at 0000000007B0FDD0
DpShMCreate: system runs without slock table
DpShMCreate: system runs without file table
DpShMCreate: allocated vmc_adm_list at 0000000007B9E770
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated gw_adm at 0000000007B9E820
DpShMCreate: allocated j2ee_adm at 0000000007B9E860
DpShMCreate: allocated ca_info at 0000000007B9F7E0
DpShMCreate: allocated wall_adm at 0000000007B9F870
DpCommAttachTable: attached comm table (header=0000000007B0FDD0/ft=0000000007B0FDE0)
DpSysAdmIntInit: initialize sys_adm
rdisp/test_roll : roll strategy is DP_NORMAL_ROLL
dia token check not active (10 token)
MBUF state OFF
DpCommInitTable: init table for 500 entries
Sun May 26 17:50:31 2013
DpRqQInit: keep protect_queue / slots_per_queue 0 / 2001 in sys_adm
rdisp/queue_size_check_value :  -> on,50,30,40,500,50,500,80
EmInit: MmSetImplementation( 2 ).
MM global diagnostic options set: 0
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 4096 kByte.
Using implementation view
<EsNT> Using memory model view.
<EsNT> Memory Reset disabled as NT default
<ES> 732 blocks reserved for free list.
ES initialized.
mm.dump: set maximum dump mem to 96 MB
DpVmcSetActive: set vmc state DP_VMC_NOT_ACTIVE
MPI: dynamic quotas disabled.
MPI init: pipes=4000 buffers=1279 reserved=383 quota=10%
Sun May 26 17:50:32 2013
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 4.0.1 4.0.1 5.1) [dpxxdisp.c   1673]
Sun May 26 17:50:41 2013
***LOG Q0K=> DpMsAttach, mscon ( ECC) [dpxxdisp.c   12339]
MBUF state LOADING
DpStartStopMsg: send start message (myname is >ECC_PRO_00                              <)
Sun May 26 17:50:42 2013
DpStartStopMsg: start msg sent
CCMS uses Shared Memory Key 73 for monitoring.
CCMS: SemInMgt: Semaphore Management initialized by AlAttachShm_Doublestack.
CCMS: SemInit: Semaphore 38 initialized by AlAttachShm_Doublestack.
Sun May 26 17:50:43 2013
CCMS: AlInitGlobals : alert/use_sema_lock = TRUE.
Sun May 26 17:50:45 2013
CCMS: start to initalize 3.X shared alert area (first segment).
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c   1296]
MBUF state ACTIVE
DpWpBlksLow: max wp blocks in queue is 800 (80 %)
MBUF component UP
DpMsgProcess: 1 server in MBUF
DpAppcBlksLow: max appc blocks in queue is 500 (50 %)
Sun May 26 17:51:22 2013
*** ERROR => DpHdlDeadWp: W0 (pid 3712) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W1 (pid 3228) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W2 (pid 3264) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W3 (pid 3220) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W4 (pid 3956) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W5 (pid 2752) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W6 (pid 3528) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W7 (pid 3952) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W8 (pid 2760) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W9 (pid 1800) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W10 (pid 3256) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W11 (pid 3772) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W12 (pid 120) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W13 (pid 904) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W14 (pid 3604) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W15 (pid 3148) died (severity=0, status=0) [dpxxwp.c     1522]
*** ERROR => DpHdlDeadWp: W16 (pid 3408) died (severity=0, status=0) [dpxxwp.c     1522]
*** DP_FATAL_ERROR => DpWPCheck: no more work processes
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
NiWait: sleep (10000ms) ...
NiISelect: timeout 10000ms
NiISelect: maximum fd=1105
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Sun May 26 17:51:32 2013
NiISelect: TIMEOUT occured (10000ms)
dump system status
Workprocess Table (long)         Sun May 26 13:51:32 2013
No Type  Pid    Status  Cause Start Rstr  Err Sem Time Program          Cl  User         Action                    Table
0 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
1 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
2 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
3 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
4 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
5 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
6 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
7 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
8 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
9 DIA       -1 Ended         no    no     1   0    0                                    NO_ACTION
10 UPD       -1 Ended         no    no     1   0    0                                    NO_ACTION
11 ENQ       -1 Ended         no    no     1   0    0                                    NO_ACTION
12 BTC       -1 Ended         no    no     1   0    0                                    NO_ACTION
13 BTC       -1 Ended         no    no     1   0    0                                    NO_ACTION
14 BTC       -1 Ended         no    no     1   0    0                                    NO_ACTION
15 SPO       -1 Ended         no    no     1   0    0                                    NO_ACTION
16 UP2       -1 Ended         no    no     1   0    0                                    NO_ACTION
Dispatcher Queue Statistics         Sun May 26 13:51:32 2013
|  Typ |    now |   high |    max | writes     |  reads     |
| NOWP |      0 |      3 |   2000 |          5 |          5 |
|  DIA |      3 |      3 |   2000 |          3 |          0 |
|  UPD |      0 |      0 |   2000 |          0 |          0 |
|  ENQ |      0 |      0 |   2000 |          0 |          0 |
|  BTC |      0 |      0 |   2000 |          0 |          0 |
|  SPO |      0 |      0 |   2000 |          0 |          0 |
|  UP2 |      0 |      0 |   2000 |          0 |          0 |
max_rq_id      8
wake_evt_udp_now   0
wake events         total     6,  udp     3 ( 50%),  shm     3 ( 50%)
since last update   total     6,  udp     3 ( 50%),  shm     3 ( 50%)
DpGetLoadAverage: la1[1] = 0.000000 / -1.000000 %
DpGetLoadAverage: la5[1] = 0.000000 / -1.000000 %
DpGetLoadAverage: la15[1] = 0.033333 / -1.000000 %
Dispatcher Load Statistics
|  Typ |     LA1 |     LA5 |    LA15 |
|  DIA |   0.000 |   0.000 |   0.033 |
DpGetLoadAverage: la1[2] = 0.000000 / -1.000000 %
DpGetLoadAverage: la5[2] = 0.000000 / -1.000000 %
DpGetLoadAverage: la15[2] = 0.000000 / -1.000000 %
|  UPD |   0.000 |   0.000 |   0.000 |
DpGetLoadAverage: la1[3] = 0.000000 / -1.000000 %
DpGetLoadAverage: la5[3] = 0.000000 / -1.000000 %
DpGetLoadAverage: la15[3] = 0.000000 / -1.000000 %
|  ENQ |   0.000 |   0.000 |   0.000 |
DpGetLoadAverage: la1[4] = 0.000000 / -1.000000 %
DpGetLoadAverage: la5[4] = 0.000000 / -1.000000 %
DpGetLoadAverage: la15[4] = 0.000000 / -1.000000 %
|  BTC |   0.000 |   0.000 |   0.000 |
DpGetLoadAverage: la1[5] = 0.000000 / -1.000000 %
DpGetLoadAverage: la5[5] = 0.000000 / -1.000000 %
DpGetLoadAverage: la15[5] = 0.000000 / -1.000000 %
|  SPO |   0.000 |   0.000 |   0.000 |
DpGetLoadAverage: la1[6] = 0.000000 / -1.000000 %
DpGetLoadAverage: la5[6] = 0.000000 / -1.000000 %
DpGetLoadAverage: la15[6] = 0.000000 / -1.000000 %
|  UP2 |   0.000 |   0.000 |   0.000 |
Dump of tm_adm structure:         Sun May 26 13:51:32 2013
Term    uid  man user    term   lastop  mod wp  ta   a/i (modes)
RM-T19, U20,                 , , 17:50:45, M0, W-1,     , 1/0
Workprocess Comm. Area Blocks         Sun May 26 13:51:32 2013
Slots: 1000, Used: 1, Max: 1
|   id | owner        |   pid    | eyecatcher  |
|    0 | DISPATCHER   |       -1 | 0xdeadbeef |
NiWait: sleep (5000ms) ...
NiISelect: timeout 5000ms
Sun May 26 17:51:37 2013
NiISelect: TIMEOUT occured (5000ms)
DpHalt: shutdown server >ECC_PRO_00                              < (normal)
DpJ2eeDisableRestart
DpMBufRead: read server list from MBUF (1 entries)
DpMBufMod: name [ECC_PRO_00                              ], types 191 state 3 (0x0 0x0 0x0 0x0)
DpMBufMod: call hooks for event MBUF_DPEVT_DSTATE (5->3)
AdGetSelfIdentRecord: >        <
AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
AdCallRegisteredCvtToExt: opcode 60
AdCallRegisteredCvtToExt: opcode 60 call 00000001408C7240
AdCallRegisteredCvtToExt: opcode 60 exit rc=SAP_O_K
AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
AdCallRegisteredCvtToExt: opcode 40
AdCallRegisteredCvtToExt: opcode 40 call 00000001408C7EE0
AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K
DpWpBlksLow: wp_blks_in_queue/limit/max = 1/800/1000
DpLockWpBlkEx: lock wp ca_blk 1
make DISP owner of wp_ca_blk 1
DpRqIPutIntoQ: put elem in queue DIA, elems=4
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 9)
MBUF server state SHUTDOWN
DpModState: change state STARTING -> SHUTDOWN
NiBufSend starting
NiIWrite: hdl 17 sent data (wrt=110,pac=1,MESG_IO)
MsINiWrite: sent 110 bytes
MsIModState: change state to SHUTDOWN
DpModState: change server state from STARTING to SHUTDOWN
DpHalt: switch off Shared memory profiling
ShmProtect( 57, 3 )
ShmProtect(SHM_PROFILE, SHM_PROT_RW
ShmProtect( 57, 1 )
ShmProtect(SHM_PROFILE, SHM_PROT_RD
DpWakeUpWps: wake up all wp's
DpHalt: stop work processes
DpHalt: stop gateway
killing process (2080) (SOFT_KILL)
DpHalt: stop icman
killing process (4012) (SOFT_KILL)
DpHalt: terminate gui connections
send SHUTDOWN to REM TM 19
DpWpBlksLow: wp_blks_in_queue/limit/max = 2/800/1000
DpLockWpBlkEx: lock wp ca_blk 2
return errno (-17) to T19
DpTmSend: errormsg without overhead: use mode 0
NiBufIAlloc: malloc NiBufadm, to 0 bytes
DpTmSend: try to send 14 bytes to T19/M0
NiBufSend starting
NiIWrite: hdl 25 sent data (wrt=14,pac=1,MESG_IO)
REL WP ca_blk 2
set status of T19 to TM_DISCONNECTED
NiBufISelUpdate: new MODE -- (r-) for hdl 25 in set0
SiSelNSet: set events of sock 1092 to: ---
NiBufISelRemove: remove hdl 25 from set0
SiSelNRemove: removed sock 1092 (pos=3)
NiSelIRemove: removed hdl 25
DpDelSocketInfo: del info for nihdl 25 (pos/type=3/3)
NiICloseHandle: shutdown and close hdl 25/sock 1092
NiBufIClose: clear extension for hdl 25
dp_tm_adm[19].stat = DP_SLOT_FREE
DpGetSchedule: next schedule 1369576302/223000
DpGetSchedule: no schedule found
DpITmSlotRelease: release slot 19
DpListRemove: remove elem 19 from tmadm_inuse_list
DpListRemove: 19 elems in tmadm_inuse_list
DpListInsert: insert elem 19 into tmadm_free_list (at begin)
DpListInsert: 182 elems in tmadm_free_list
DpHalt: wait for end of work processes
DpHalt: wait for end of gateway
[DpProcDied] Process lives  (PID:2080  HANDLE:980)
DpHalt: waiting for termination of gateway ...
NiWait: sleep (1000ms) ...
NiISelect: timeout 1000ms
Sun May 26 17:51:38 2013
NiISelect: TIMEOUT occured (1000ms)
*** ERROR => [DpProcDied] Process died  (PID:2080  HANDLE:980  rc:0x0) [dpnttool2.c  147]
DpHalt: wait for end of icman
[DpProcDied] Process lives  (PID:4012  HANDLE:988)
DpHalt: waiting for termination of icman ...
Sun May 26 17:51:39 2013
Sun May 26 17:51:40 2013
Sun May 26 17:51:41 2013
Sun May 26 17:51:42 2013
Sun May 26 17:51:43 2013
Sun May 26 17:51:44 2013
*** ERROR => [DpProcDied] Process died  (PID:4012  HANDLE:988  rc:0x0) [dpnttool2.c  147]
DpStartStopMsg: send stop message (myname is >ECC_PRO_00                              <)
DpStartStopMsg: Write AD_STARTSTOP message with type=  0, name=ECC_PRO_00          , sapsysnr= 0, hostname=ECC
AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0
AdCallRegisteredCvtToExt: opcode 4 call 00000001408C32D0
AdCallRegisteredCvtToExt: opcode 4 exit rc=SAP_O_K
DpConvertRequest: net size = 189 bytes
NiBufIAlloc: malloc MSLIB-BUF, to 32110 bytes
NiBufSend starting
NiIWrite: hdl 17 sent data (wrt=562,pac=1,MESG_IO)
MsINiWrite: sent 562 bytes
MsISnd2: send msg (ms hdr/msg 110/452 bytes) to name                    -, type 4, key -
DpStartStopMsg: stop msg sent
NiBufIAlloc: malloc NIBUF-IN, to 32110 bytes
NiIRead: hdl 17 received data (rcd=274,pac=1,MESG_IO)
NiBufIIn: NIBUF len=274
NiBufIIn: packet complete for hdl 17
NiBufReceive starting
MsINiRead: received 274 bytes
MsIReceive: received msg (ms hdr/msg 110/164 bytes), flag 1, from MSG_SERVER          , typ 0, key -
DpHalt: received 164 bytes from message server
NiIRead: hdl 17 recv would block (errno=EAGAIN)
NiIRead: read for hdl 17 timed out (0ms)
DpHalt: more messages from the message server
DpHalt: send keepalive to synchronize with the message server
NiBufSend starting
NiIWrite: hdl 17 sent data (wrt=114,pac=1,MESG_IO)
MsINiWrite: sent 114 bytes
MsISnd2: send msg (ms hdr/msg 110/4 bytes) to name           MSG_SERVER, type 0, key -
MsSndName: MS_NOOP ok
Send 4 bytes to MSG_SERVER
NiIPeek: peek successful for hdl 17 (r)
NiIRead: hdl 17 received data (rcd=114,pac=1,MESG_IO)
NiBufIIn: NIBUF len=114
MsINiRead: received 114 bytes
MsIReceive: received msg (ms hdr/msg 110/4 bytes), flag 3, from MSG_SERVER          , typ 0, key -
Received 4 bytes from MSG_SERVER
Received opcode MS_NOOP from msg_server, reply MSOP_OK
MsOpReceive: ok
MsISendKeepalive : keepalive sent to message server
Sun May 26 17:51:45 2013
NiIPeek: peek for hdl 17 timed out (r; 1000ms)
NiIRead: read for hdl 17 timed out (1000ms)
DpHalt: no more messages from the message server
DpHalt: sync with message server o.k.
DpHalt: detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c   12730]
NiBufSend starting
MsIDetach: send logout to msg_server (ECC / 3900)
MsIDetach: call exit function
DpMsShutdownHook called
NiBufISelUpdate: new MODE -- (r-) for hdl 17 in set0
SiSelNSet: set events of sock 976 to: ---
NiBufISelRemove: remove hdl 17 from set0
SiSelNRemove: removed sock 976 (pos=2)
NiSelIRemove: removed hdl 17
DpDelSocketInfo: del info for nihdl 17 (pos/type=2/4)
MBUF state OFF
make DISP owner of wp_ca_blk 2
DpRqIPutIntoQ: put elem in queue DIA, elems=5
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 12)
MBUF component DOWN
NiICloseHandle: shutdown and close hdl 17/sock 976
NiBufIClose: clear extension for hdl 17
MsIDetach: detach MS-system (ECC / 3900)
DpHalt: cleanup EM
EsCleanup( )
EsCleanup ....
EmCleanup() -> 0
Es2Cleanup: Cleanup ES2
***LOG Q05=> DpHalt, DPStop ( 3084) [dpxxdisp.c   11252]
DpHalt: Good Bye .....
помогите разобраться что там не так, вижу там строку
это что-то с джавой не так? Но вроде все переменные среды прописаны?
 Заголовок сообщения: Re: Останавлвается disp+work.EXE
СообщениеДобавлено: Пн, май 27 2013, 09:32
Диспетчер стартовал, запустил рабочие процессы.
Потом рабочие процессы померли.
Диспетчер вздохнул, и ушел.
Так что дальше смотрите логи рабочих процессов, почему они помирают.
СообщениеДобавлено: Пн, май 27 2013, 14:06
Ср, май 23 2012, 16:08
1. В самом начале лога есть информация по тому что disp не смог подключиться к Message Server. Собсвенно без него ничего не взлетит...
Вопросы следующие
1. Я так понимаю что центральная инстанция и AS инстанции на одной машине (всмысле одно неразнесенное целое), на каком порту прописан сервис msg server.
судя по логам он пытается прдключиться на 3900 проверьте, что там у вас (cat /etc/service |grep 3900)
2. Если все таки у вас центральная инстанция выделена в отдельный хост, то проверьте все ли хорошо у вас сеткой, DNS
это к JAVA инстанции никакого отношения не имеет. В данном случае это Virtual Memory Container - java машина внутри WP.
http://help.sap.com/saphelp_nw04s/helpdata/en/42/df8a715afb1631e10000000a1553f7/content.htm
СообщениеДобавлено: Пн, май 27 2013, 14:11
Господа гусары! Молчать! (c)
Очень хочется увидеть домашнюю распределенную систему под Windows 7. Просто на поржать :D
СообщениеДобавлено: Пн, май 27 2013, 16:34
avlag написал:
с утра даже поинтересовался у виндузятников - нет ли случайно win server 2007 :)
СообщениеДобавлено: Пн, май 27 2013, 17:40
avlag написал:
Home Basic :mrgreen:
СообщениеДобавлено: Вт, май 28 2013, 12:54
Вопросы следующие
Да, все на одной машине стоит, в etc/services ничего про 3900 не написано, но если через netstat посмотреть когда запускать сервер пытаюсь, то видно что как раз msg_server там и висит, диспетчер даже на какое-то время к нему подключается и горит зелененьким, но потом секунд через 30 останавливается
СообщениеДобавлено: Вт, май 28 2013, 13:32
Пн, фев 11 2008, 11:38
Вам же avlag чёрным по белому написал "смотрите логи рабочих процессов, почему они помирают." Обычно в dev_w0 вся инфа есть.
А вы как раз таки увидели бредовый коммент и почему то решили на него отреагировать.
СообщениеДобавлено: Вт, май 28 2013, 13:56
avlag написал:
Ой ладно вам юморить, я самой первой строчки про Win7 не заметил ( увы.
СообщениеДобавлено: Вт, май 28 2013, 14:21
Note 1786123 - Interpretation of DB and OS support in PAM
СообщениеДобавлено: Ср, май 29 2013, 10:26
Проблема решена, оказалось что это оракловский listener не запущен был.
Всем спасибо!
