Текущее время: Пт, авг 07 2026, 14:44
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: SYSTEM_NO_MEMORY при апгрейде Solution Manager 7.1
СообщениеДобавлено: Чт, апр 17 2014, 11:49
Вт, окт 10 2006, 12:23
Добрый день, коллеги.
Выполняем апгрейд Solution Manager 7.1 SP4 до SP11 через SUM.
СУБД Oracle 11.2
ОС SLES11.
ОЗУ 72Гб.
Второй день крутим параметры, но безрезультатно. Дампы (SYSTEM_NO_MEMORY, SYSTEM_NO_ROLL, STACK_STATE_NO_ROLL_MEMORY).
На фазе PREP_EXTENSION/EHP_INCLUSION получаем дамп SYSTEM_NO_MEMORY.
Категория              Дефицит ресурсов
ДинамОшибка            SYSTEM_NO_MEMORY
Дата и время           17.04.2014 12:16:25
|Краткий текст        |
|    No memory available.        |
|Что произошло?        |
|    Each transaction requires some main memory space to process                                   |
|    application data. If the operating system cannot provide any more                             |
|    space, the transaction is terminated.                                                         |
|Что Вы можете сделать?        |
|    Try to find out (e.g. by targetted data selection) whether the                                |
|    transaction will run with less main memory.                                                   |
|    If there is a temporary bottleneck, execute the transaction again.                            |
|    If the error persists, ask your system administrator to check the                             |
|    following profile parameters:        |
|    o  ztta/roll_area            (1.000.000 - 15.000.000)                                         |
|           Classic roll area per user and internal mode                                           |
|           usual amount of roll area per user and internal mode                                   |
|    o  ztta/roll_extension       (10.000.000 - 500.000.000)                                       |
|           Amount of memory per user in extended memory (EM)                                      |
|    o  abap/heap_area_total      (100.000.000 - 1.500.000.000)                                    |
|           Amount of memory (malloc) for all users of an application                              |
|           server. If several background processes are running on                                 |
|           one server, temporary bottlenecks may occur.                                           |
|           Of course, the amount of memory (in bytes) must also be                                |
|           available on the machine (main memory or file system swap).                            |
|           Caution:        |
|           The operating system must be set up so that there is also                              |
|           enough memory for each process. Usually, the maximum address                           |
|           space is too small.        |
|           Ask your hardware manufacturer or your competence center                               |
|           about this.        |
|           In this case, consult your hardware vendor                                             |
|    abap/heap_area_dia:        (10.000.000 - 1.000.000.000)                                       |
|           Restriction of memory allocated to the heap with malloc                                |
|           for each dialog process.                                                               |
|    Parameters for background processes:                                                          |
|    abap/heap_area_nondia:        (10.000.000 - 1.000.000.000)                                    |
|           for each background process.                                                           |
|    Other memory-relevant parameters are:                                                         |
|    em/initial_size_MB:         (35-1200)                                                         |
|           Extended memory area from which all users of an                                        |
|           application server can satisfy their memory requirement.                               |
|    Note which actions and input led to the error.                                                |
|    For further help in handling the problem, contact your SAP administrator                      |
|    You can use the ABAP dump analysis transaction ST22 to view and manage                        |
|    termination messages, in particular for long term reference.                                  |
|Анализ ошибки        |
|    A new main memory area of size 65536 was requested. All available space                       |
|    is already in use however. Possible causes:                                                   |
|    - lots of (large) internal tables                                                             |
|    - lots of (large) programs active                                                             |
|    - deep nesting of subroutnines with large local data.                                         |
|Указания по устранению ошибки        |
|    Try to decide by analysis whether this request is                                             |
|    reasonable or whether there is a program error. You should pay                                |
|    particular attention to the internal table entries listed below.                              |
|    If the error occures in a non-modified SAP program, you may be able to                        |
|    find an interim solution in an SAP Note.                                                      |
|    If you have access to SAP Notes, carry out a search with the following                        |
|    keywords:        |
|    "SYSTEM_NO_MEMORY" " "        |
|    "SAPLOCS_CORE" or "LOCS_COREU01"                                                              |
|    "OCS_CREATE_LOGLINE"        |
|    If you cannot solve the problem yourself and want to send an error                            |
|    notification to SAP, include the following information:                                       |
|    1. The description of the current problem (short dump)                                        |
|       To save the description, choose "System->List->Save->Local File                            |
|    (Unconverted)".        |
|    2. Corresponding system log        |
|       Display the system log by calling transaction SM21.                                        |
|       Restrict the time interval to 10 minutes before and five minutes                           |
|    after the short dump. Then choose "System->List->Save->Local File                             |
|    (Unconverted)".        |
|    3. If the problem occurs in a problem of your own or a modified SAP                           |
|    program: The source code of the program                                                       |
|       In the editor, choose "Utilities->More                                                     |
|    Utilities->Upload/Download->Download".                                                        |
|    4. Details about the conditions under which the error occurred or which                       |
|Системная среда        |
|    SAP Release..... 702        |
|    SAP Basis Level. 0009        |
|    Application server... "cism4"        |
|    Network address...... "172.23.90.16"                                                          |
|    Operating system..... "Linux"        |
|    Release.............. "3.0.101-0.8-default"                                                   |
|    Hardware type........ "x86_64"        |
|    Character length.... 16 Bits        |
|    Pointer length....... 64 Bits        |
|    Work process number.. 2        |
|    Shortdump setting.... "full"        |
|    Database server... "sap-srv-01"                                                               |
|    Database type..... "ORACLE"        |
|    Database name..... "SM4"        |
|    Database user ID.. "SAPSR3"        |
|    Terminal.......... "localhost"        |
|    Char.set.... "C"        |
|    SAP kernel....... 720        |
|    created (date)... "Mar 8 2014 02:12:21"                                                       |
|    create on........ "Linux GNU SLES-11 x86_64 cc4.3.4 use-pr140213"                             |
|    Database version. "OCI_112, 11.2.0.3.0, V1, default"                                          |
|    Patch level. 600        |
|    Patch text.. " "        |
|    Database............. "ORACLE 10.1.0.*.*, ORACLE 10.2.0.*.*, ORACLE 11.2.*.*.*"               |
|    SAP database version. 720        |
|    Operating system..... "Linux 2.6, Linux 3"                                                    |
|    Memory consumption        |
|    Roll.... 6272416        |
|    EM...... 4001812992        |
|    Heap.... 4000298880        |
|    Page.... 172032        |
|    MM Used. 8001854824        |
|    MM Free. 456368        |
Параметры.
|Buffer Name                    Comment                                                       |
|Profile Parameter             Value      Unit  Comment                                       |
|Program buffer                 PXA                                                           |
|abap/buffersize               2000000    kB    Size of program buffer                        |
|abap/pxa                      shared           Program buffer mode                           |
|CUA buffer                     CUA                                                           |
|rsdb/cua/buffersize           15000      kB    Size of CUA buffer                            |
The number of max. buffered CUA objects is always: size / (2 kB)
|Screen buffer                  PRES                                                          |
|zcsa/presentation_buffer_area 30720000   Byte  Size of screen buffer                         |
|sap/bufdir_entries            10000            Max. number of buffered screens               |
|Generic key table buffer       TABL                                                          |
|zcsa/table_buffer_area        153600000  Byte  Size of generic key table buffer              |
|zcsa/db_max_buftab            30000            Max. number of buffered objects               |
|Single record table buffer     TABLP                                                         |
|rtbb/buffer_length            60000      kB    Size of single record table buffer            |
|rtbb/max_tables               5000             Max. number of buffered tables                |
|Export/import buffer           EIBUF                                                         |
|rsdb/obj/buffersize           32768      kB    Size of export/import buffer                  |
|rsdb/obj/max_objects          20000            Max. number of objects in the buffer          |
|rsdb/obj/large_object_size    512000     Bytes Estimation for the size of the largest object |
|rsdb/obj/mutex_n              0                Number of mutexes in Export/Import buffer     |
|OTR buffer                     OTR                                                           |
|rsdb/otr/buffersize_kb        4096       kB    Size of OTR buffer                            |
|rsdb/otr/max_objects          2000             Max. number of objects in the buffer          |
|rsdb/otr/mutex_n              0                Number of mutexes in OTR buffer               |
|Exp/Imp SHM buffer             ESM                                                           |
|rsdb/esm/buffersize_kb        4096       kB    Size of exp/imp SHM buffer                    |
|rsdb/esm/max_objects          2000             Max. number of objects in the buffer          |
|rsdb/esm/large_object_size    8192       Bytes Estimation for the size of the largest object |
|rsdb/esm/mutex_n              0                Number of mutexes in Exp/Imp SHM buffer       |
|Table definition buffer        TTAB                                                          |
|rsdb/ntab/entrycount          159969           Max. number of table definitions buffered     |
The size of the TTAB is nearly 100 bytes * rsdb/ntab/entrycount
|Field description buffer       FTAB                                                          |
|rsdb/ntab/ftabsize            140008     kB    Size of field description buffer              |
|rsdb/ntab/entrycount          159969           Max. number / 2 of table descriptions buffered|
FTAB needs about 700 bytes per used entry
|Initial record buffer          IRBD                                                          |
|rsdb/ntab/irbdsize            30002      kB    Size of initial record buffer                 |
|rsdb/ntab/entrycount          159969           Max. number / 2 of initial records buffered   |
IRBD needs about 300 bytes per used entry
|Short nametab (NTAB)           SNTAB                                                         |
|rsdb/ntab/sntabsize           10000      kB    Size of short nametab                         |
|rsdb/ntab/entrycount          159969           Max. number / 2 of entries buffered           |
SNTAB needs about 150 bytes per used entry
|Calendar buffer                CALE                                                          |
|zcsa/calendar_area            500000     Byte  Size of calendar buffer                       |
|zcsa/calendar_ids             200              Max. number of directory entries              |
|Roll, extended and heap memory EXTM                                                          |
|ztta/roll_area                6500352    Byte  Roll area per workprocess (total)             |
|ztta/roll_first               1024       Byte  First amount of roll area used in a dialog WP |
|ztta/short_area               3200000    Byte  Short area per workprocess                    |
|rdisp/ROLL_SHM                32768      8 kB  Part of roll file in shared memory            |
|rdisp/PG_SHM                  32768      8 kB  Part of paging file in shared memory          |
|rdisp/PG_LOCAL                150        8 kB  Paging buffer per workprocess                 |
|em/initial_size_MB            32768      MB    Initial size of extended memory               |
|em/blocksize_KB               4096       kB    Size of one extended memory block             |
|em/address_space_MB           4096       MB    Address space reserved for ext. mem. (NT only)|
|ztta/roll_extension           4000317440 Byte  Max. extended mem. per session (external mode)|
|abap/heap_area_dia            4000317440 Byte  Max. heap memory for dialog workprocesses     |
|abap/heap_area_nondia         4000317440 Byte  Max. heap memory for non-dialog workprocesses |
|abap/heap_area_total          4000317440 Byte  Max. usable heap memory                       |
|abap/heaplimit                40894464   Byte  Workprocess restart limit of heap memory      |
|abap/use_paging               0                Paging for flat tables used (1) or not (0)    |
|Statistic parameters        |
|rsdb/staton                   1                Statistic turned on (1) or off (0)            |
|rsdb/stattime                 0                Times for statistic turned on (1) or off (0)  |
 Заголовок сообщения: Re: SYSTEM_NO_MEMORY при апгрейде Solution Manager 7.1
СообщениеДобавлено: Чт, апр 17 2014, 11:58
на оси лимиты памяти на процесс корректные?
СообщениеДобавлено: Чт, апр 17 2014, 12:22
Вот такие:
/etc/sysctl.conf
# Disable response to broadcasts.
# You don't want yourself becoming a Smurf amplifier.
net.ipv4.icmp_echo_ignore_broadcasts = 1
# enable route verification on all interfaces
net.ipv4.conf.all.rp_filter = 1
# enable ipV6 forwarding
#net.ipv6.conf.all.forwarding = 1
# increase the number of possible inotify(7) watches
fs.inotify.max_user_watches = 65536
# avoid deleting secondary IPs on deleting the primary IP
net.ipv4.conf.default.promote_secondaries = 1
net.ipv4.conf.all.promote_secondaries = 1
# Added for SAP on 2013-12-19 07:49:36 UTC
kernel.shmmax = 9223372036854775807
kernel.sem = 1250 256000 100 8192
kernel.shmall = 1152921504606846720
vm.max_map_count = 2000000
/etc/security/limits.conf
* soft nproc 16384
* hard nproc 16384
* soft nofile 65536
* hard nofile 65536
* soft stack 10240
* hard stack 10240
СообщениеДобавлено: Чт, апр 17 2014, 12:24
Пн, фев 11 2008, 11:38
Что то я не заметил что вы там что то крутили параметры ))
Для начала поставьте в STMS в вашу систему SP_TRANS_SYNC=OFF , если еще не стоит.
А по параметрам :
Вы написали что у вас 72 гига памяти , ну допустим 35 отдали для оракла.
Увеличте ВРЕМЕННО все три параметра до 20 гиг к примеру и запустите заново.
СообщениеДобавлено: Пт, апр 18 2014, 08:24
А по параметрам :
Сделали. Дамп все равно выскакивает.
Увеличивали и до 40 - 60Гб.
В sm50 видно, что крутится один процесс SAPLOCS_CORE и отжирает всю память.
СообщениеДобавлено: Пт, апр 18 2014, 09:56
Вт, ноя 09 2010, 19:59
а кернел какой?
и я бы пошел по-шагово, сначала до 8 стэка с помощью SPAM/SAINT/JSPM, а потом уж до 11 через SUM
СообщениеДобавлено: Пт, апр 18 2014, 10:13
Да , интересная проблемка ... Попробуйте сам SPAM/SAINT обновите для начала на сколько можно.
SAPLOCS_CORE обычно с ним связана.
СообщениеДобавлено: Пт, апр 18 2014, 13:06
Kernel 721, уровень 201.
Перегенерили stack файл. Не помогло.
Решили обновлять Java и ABAP по отдельности. По старинке Java через JSMP, а ABAP через SAINT/SPAM.
СообщениеДобавлено: Пт, апр 18 2014, 13:07
SPAM версии KD70253, это последний на сегодняшний день.
СообщениеДобавлено: Пт, апр 18 2014, 15:25
Пт, окт 06 2006, 15:20
Я бы покрутил в первую очередь:
ztta/roll_area
ztta/roll_extension
rdisp/ROLL_SHM
rdisp/ROLL_MAXFS
Т.к это - только для апгрейда, думаю их можно существенно увеличить.
Хотя сообщение в ТП тоже можно было бы выставить..
СообщениеДобавлено: Пт, апр 18 2014, 15:32
bdmalex написал:
ztta/roll_area
ztta/roll_extension
rdisp/ROLL_SHM
rdisp/ROLL_MAXFS
Не имеет никакого отношения к проблеме 3 параметра. ztta/roll_extension можно , но то же самое что и heap крутить , только внутри extended.
Надо как то трейсить что происходит, st12 в помощ. Глюк какой то.
СообщениеДобавлено: Пт, апр 18 2014, 15:41
bdmalex написал:
ztta/roll_area
ztta/roll_extension
rdisp/ROLL_SHM
rdisp/ROLL_MAXFS
Сообщение выставили. SAP молчит пока ))
СообщениеДобавлено: Сб, апр 19 2014, 17:34
а какая версия ядра на линухе?
uname -a
СообщениеДобавлено: Пн, апр 21 2014, 08:11
шрам написал:
uname -a
Linux sapserver 3.0.101-0.8-default #1 SMP Fri Nov 1 12:51:09 UTC 2013 (2417eb9) x86_64 x86_64 x86_64 GNU/Linux
СообщениеДобавлено: Пн, апр 21 2014, 08:38
Ctrelok написал:
чистый 201? без заплаток поверху?
если чистый, но поверху положить нужно рассыпушку - у 201 кернела есть проблема с утечкой памяти...
