Текущее время: Ср, сен 23 2026, 03:07
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: XI7.00 -> PI7.40 unchanged SLD tables
СообщениеДобавлено: Пн, ноя 17 2014, 09:14
Вт, ноя 09 2010, 19:59
всем доброго времени суток!
во время апгрейда на этапе Execution ява-инстанция не может стартовать по причине необновленной таблицы в SLD
  Service [tc~sec~destinations~service] start ================= ERROR =================
  CSN Component [BC-JAS-SEC], DC Name [sap.com/tc~sec~destinations~service]
com.sap.engine.frame.ServiceException: [com.sap.ASJ.dest.sv0159] An error occurred when trying to initialize the CIMOM service where the destinations are stored. The error was CIM_ERR_FAILED: The SQL statement "SELECT "APPL","NA_HASH","NA_KEY","TYP","ACTIVE","RANK","CL_START_ID","HOSTNAME","NAMESPACE" FROM "BC_SLD_NAMESP" WHERE "APPL" = ? AND "TYP" = ?" contains the semantics error[s]: - 1:31 - the column >>TYP<< is undefined in the current scope
- 1:36 - the column >>ACTIVE<< is undefined in the current scope
- 1:44 - the column >>RANK<< is undefined in the current scope
- 1:50 - the column >>CL_START_ID<< is undefined in the current scope
- 1:63 - the column >>HOSTNAME<< is undefined in the current scope
- 1:123 - the column >>TYP<< is undefined in the current scope
   at com.sap.security.core.server.destinations.service.DestinationServiceFrame.start(DestinationServiceFrame.java:249)
   at com.sap.engine.frame.ApplicationFrameAdaptor.start(ApplicationFrameAdaptor.java:31)
   at com.sap.engine.core.service630.container.ServiceRunner.startFrame(ServiceRunner.java:165)
   at com.sap.engine.core.service630.container.ServiceRunner.startService(ServiceRunner.java:118)
   at com.sap.engine.core.service630.container.ServiceRunner.run(ServiceRunner.java:65)
   at com.sap.engine.frame.core.thread.Task.run(Task.java:73)
   at com.sap.engine.core.thread.impl5.SingleThread.execute(SingleThread.java:178)
   at com.sap.engine.core.thread.impl5.SingleThread.run(SingleThread.java:316)
Caused by: com.sap.security.core.server.destinations.api.DestinationException: [com.sap.ASJ.dest.sv0159] An error occurred when trying to initialize the CIMOM service where the destinations are stored. The error was CIM_ERR_FAILED: The SQL statement "SELECT "APPL","NA_HASH","NA_KEY","TYP","ACTIVE","RANK","CL_START_ID","HOSTNAME","NAMESPACE" FROM "BC_SLD_NAMESP" WHERE "APPL" = ? AND "TYP" = ?" contains the semantics error[s]: - 1:31 - the column >>TYP<< is undefined in the current scope
кто-нибудь сталкивался?
 Заголовок сообщения: Re: XI7.00 -> PI7.40 unchanged SLD tables
СообщениеДобавлено: Пн, ноя 17 2014, 11:35
гугел вот такую ноту выдает
1311201 - Upgrade to 7.11 SP1: Error when starting CIM service
версия правда иная..но мож натолкнет на мысли
СообщениеДобавлено: Пн, ноя 17 2014, 11:51
шрам написал:
спасибо, но уже видел.
что ещё прикольнее - тупо скопировал правильную версию таблицы из теневой схемы. не помогло... та же ошибка.
ещё бы понять, в какую ява-инстанцию SUM пытается лезть... :(
по логике - в исходную, где ранее жили вместе ABAP и JAVA, потому как теневая ява-инстанция взлетает без проблем.
если в исходную, то понятно, что приконнектится к ней не может и отваливается.
бредятина какая-то...
СообщениеДобавлено: Пн, ноя 17 2014, 13:01
а вот вопрос, раз у нас зашел разговор про апгрейд до 7.4
я же правильно понимаю, что у Вас - DualStack система?
тогда интересно Ваше мнение на цитату из master guide по NW 7.4
Caution
Dual Stack Systems
No update or upgrade of optional dual-stack SAP NetWeaver systems is supported to SAP NetWeaver 7.4 and
higher (and already as of SAP NetWeaver 7.0 with SAP enhancement package 1, you can no longer install
optional dual-stack application systems)
. Also for earlier releases than SAP NetWeaver 7.4, SAP recommends
to avoid optional dual-stack deployments where possible.
By way of exception, dual-stack implementations can still exist in former SAP NetWeaver Process Integration
installations. However, note that a single-stack SAP Process Integration Java (Advanced Adapter Engine
Extended) exists that offers almost all of the features of classical dual-stack implementations.
Therefore, you should investigate if a Java-only implementation of SAP PI is a feasible approach for your use
cases. Due to the harmonized process orchestration stack (SAP PI and SAP BPM running on the same Java
instance), stateful system-centric processes can be developed using SAP Process Orchestration capabilities.
Processes that are created with ccBPM need to be redesigned and modeled with SAP BPM.
СообщениеДобавлено: Пн, ноя 17 2014, 13:54
шрам написал:
даже хуже - PI :lol:
во время апгрейда создаются 2 теневые инстанции - ABAP and JAVA
ABAP теневая инстанция переехала в итоге в результирующую систему под своим теневым номером
при этом из прежней совмещенной инстанции ABAP удален - осталась чистая ява-инстанция
она то и не взлетает... :(
не взлетает из-за SLD
есть подозрение, что я не совсем корректно ввел PI в MOPZ - Connect Managed Systems to SLD
вероятно нужно было так - SAP Netweaver PI Monitoring using Solution Manager- Configuration Guide
хотя в созданном стэке LMSLD08_0-20009952.SCA присутствует
нужно логи смотреть. ну не исключил же SUM SLD из списка устанавливаемых компонентов.
дак вот и решили "инвестигейтить"...
потому как согласно EHP7 for SAP ERP 6.0 SP Stacks - Release & Information Note
Be aware, that if you are currently using Enterprise Portal, Business Warehouse and/or Process Integration in conjunction with SAP Business Suite applications, you will have to upgrade those SAP NetWeaver Systems to 7.30 or higher before you can upgrade SAP ERP to SAP Enhancement Package 7 for SAP ERP 6.0
СообщениеДобавлено: Вт, ноя 18 2014, 11:21
хехе
опять таки цитата из мастер-гада
Caution
Although it should be technically possible to run an application system with a higher release than your PI
system in your system landscape, this is not supported by SAP
:mrgreen:
а по теме ошибки... видимо надо выставлять сообщение.. правда исходя из моих цитат, SAP может и распослать
jack_nsk написал:
и все тот-же пресловутый мастер
СообщениеДобавлено: Вт, ноя 18 2014, 14:32
шрам написал:
хехе
Caution
:mrgreen:
Upgrading from PI 7.1 to PO 7.4 - весьма любопытная ветка...
если не заморачиваться насчет PO, то можно и апгрейдом.
тем более, что задача стоит проапгрейдить ERP + BW, а PI тут как "неприятный довесок"... :)
и тут есть один момент, который не нужно упускать - начиная с NW740 SP08 OpenSQL практически становится SQL ANSI 92
теперь в OpenSQL можна даже делать сортировки и группировки - вот ломка то для абаперов... :D
поэтому 7.3Х не сильно хочется ставить.
 Заголовок сообщения: Re: XI7.00 -> PI7.40 unchanged SLD tables  Тема решена
СообщениеДобавлено: Ср, ноя 19 2014, 02:14
ситуация разрешилась при повторной попытке апгрейда.
проблема была в совпадении 2-х факторов - почему-то измененный пароль для DDIC в манданте UME
и банальный недостаток места на диске, что вылилось в невозможности записи части логов на диск.
при повторном прогоне "карты вскрылись".
с примерно десятого рестарта ява-инстанции в [safe] mode все пакеты deployed
