Текущее время: Вт, сен 22 2026, 22:23
 Заголовок сообщения: При установки HANA вылетает ошибка запуска sapstartsrv
СообщениеДобавлено: Пн, мар 02 2015, 15:12
Сб, ноя 05 2011, 13:41
При установке SAP HANA возникла ошибка запуска сервиса sapstartsrv
Net::HTTP: Bad hostname 'linux-pvbk:50113'
15:04:34.854 - INFO: sapstartsrv is not running: Net::HTTP: Bad hostname 'linux-pvbk:50113'
15:04:35.857 - ERR: Waiting for sapstartsrv failed: timeout reached (120)
15:04:35.857 - INFO: Looking for error messages in sapstartsrv trace file
15:04:35.858 - ERR: Cannot start sapstartsrv
15:04:35.859 - INFO: Cannot create Instance
15:04:35.859 - ERR: error installing
15:04:35.859 - INFO: Installation failed
15:04:36.023 - ERR: Summary of critical errors
15:04:35.857 - INFO: Waiting for sapstartsrv failed: timeout reached (120)
В ЛОГАХ sapstartsrv СЛЕДУЮЩИЕ ОШИБКИ
trc file: "sapstartsrv.log", trc level: 1, release: "720"
pid 4319
[Thr 140131500152704] Fri Feb 27 17:12:24 2015
[Thr 140131500152704] MtxInit: -2 0 0
No halib defined => HA support disabled
CCMS agent initialization for instance type HOST: return code 0.
[Thr 140131500152704] CCMS: Initialized monitoring segment of size 40000000.
[Thr 140131500152704] CCMS: Initialized CCMS Headers in the shared monitoring segment.
[Thr 140131500152704] CCMS: Checking Downtime Configuration of Monitoring Segment.
[Thr 140131500152704] *** ERROR => SemRel: Inv. Operation. Units 1. Key=1004 [semux0_mt.c 1393]
[Thr 140131500152704] CCMS: AlMsUpload called by wp 1998.
[Thr 140131500152704] CCMS: AlMsUpload failed for /usr/sap/hostctrl/work/ALMTTREE.
CCMS agent start: return code 0.
Initializing SAPHostControl Webservice
[Thr 140131500152704] *** ERROR => Unable to open /usr/sap/hostctrl/exe/descriptors.d
(2: No such file or directory) [HTTPHandlerM 487]
[Thr 140131500152704] =================================================
[Thr 140131500152704] = SSL Initialization platform tag=(linuxx86_64_gcc41)
[Thr 140131500152704] = (720_REL,Nov 22 2014,mt,ascii,SAP_UC/size_t/void* = 8/64/64)
[Thr 140131500152704] profile param "ssl/ssl_lib" = "/usr/sap/hostctrl/exe/libsapcrypto.so"
[Thr 140131500152704] resulting Filename = "/usr/sap/hostctrl/exe/libsapcrypto.so"
[Thr 140131449669376] CCMS: Initialized monitoring segment of size 40000000.
[Thr 140131449669376] CCMS: Initialized CCMS Headers in the shared monitoring segment.
[Thr 140131449669376] CCMS: Checking Downtime Configuration of Monitoring Segment.
[Thr 140131500152704] = found CommonCryptoLib (SAPCRYPTOLIB) Version 8.4.32 pl40 (Nov 14 2014) MT-safe
[Thr 140131500152704] = current UserID: "sapadm", env-var USER="sapadm"
[Thr 140131500152704] = using SECUDIR=/usr/sap/hostctrl/exe/sec
[Thr 140131500152704] *** ERROR => secudessl_Create_SSL_CTX(): PSE "/usr/sap/hostctrl/exe/sec/SAPSSLS.pse": File not found! [ssslsecu_mt. 1793]
[Thr 140131500152704] secudessl_Create_SSL_CTX: SSL_CTX_set_default_pse_by_name() failed --
[Thr 140131500152704] secude_error 4129 (0x00001021) = "SAPCRYPTO API error"
[Thr 140131500152704] >> ---------- Begin of Secude-SSL Errorstack ---------- >>
[Thr 140131500152704] 0x00001021 | SAPCRYPTOLIB | SSL_CTX_set_default_pse_by_name
[Thr 140131500152704] SAPCRYPTO API error
[Thr 140131500152704] The PSE file does not exist.
[Thr 140131500152704] 0xa1d50108 | TOKEN_PSE | sec_SSL_CTX_set_asc
[Thr 140131500152704] Token application not existing
[Thr 140131500152704] << ---------- End of Secude-SSL Errorstack ----------
[Thr 140131500152704] *** ERROR => SapISSLAddCredential(): Error SSSLERR_PSE_ERROR trying to create SERVER Credential
for "/usr/sap/hostctrl/exe/sec/SAPSSLS.pse" [ssslxxi_mt.c 2422]
[Thr 140131500152704] *** ERROR => Initialization of SSL library failed -- NO SSL available!
[Thr 140131500152704] <<- ERROR: SapSSLInit(read_profile=1)==SSSLERR_PSE_ERROR
SapSSLInit failed => https support disabled
Starting WebService thread
Webservice thread started, listening on port 1128
[Thr 140131447039744] ***LOG Q0I=> NiPGetHostByName: 'susesrv' not found: getaddrinfo [niuxi.c 1759]
Trusted http connect via Unix domain socket '/tmp/.sapstream1128' enabled.
[Thr 140131449669376] *** ERROR => SemRel: Inv. Operation. Units 1. Key=1004 [semux0_mt.c 1393]
[Thr 140131449669376] CCMS: AlMsUpload called by wp 1998.
[Thr 140131449669376] CCMS: AlMsUpload failed for /usr/sap/hostctrl/work/ALMTTREE.
[Thr 140131447568128] Fri Feb 27 17:15:45 2015
[Thr 140131447568128] *** ERROR => Received a corrupt CommunicationHeader [Communicatio 175]
[Thr 140131447568128] *** ERROR => Header could not be read [Communicatio 154]
[Thr 140131447568128] *** ERROR => ProcessWatcher::Loop: More that 100 messages corrupt. Exit from ProcessWatcher::Loop [ProcessWatch 253]
[Thr 140131445982976] Fri Feb 27 17:15:46 2015
[Thr 140131445982976] *** ERROR => Failed to delete SLPServicePersistence (ThrMtxDelete ret = 8) [Synchronizat 50]
МОЖЕТ БЫТЬ КТО ЗНАЕТ ПРИЧИНУ ОШИБКИ
СПАСИБО ВСЕМ ЗА ОТВЕТЫ
 Заголовок сообщения: Re: При установки HANA вылетает ошибка запуска sapstartsrv
СообщениеДобавлено: Вт, мар 03 2015, 12:58
Тему можно закрыть!
Разобрался.
