Текущее время: Пт, авг 14 2026, 10:44
 Заголовок сообщения: Вопрос по налоговой схеме  Тема решена
СообщениеДобавлено: Ср, сен 16 2015, 07:06
Вт, июл 02 2013, 09:06
Подскажите, пожалуйста, каким образом используется ДопКлюч в T7RUP0.
РПрс ПодраздП ДопКл НС
RU10 1010 FOREG 67
С уважением, Данагуль
 Заголовок сообщения: Re: Вопрос по налоговой схеме
СообщениеДобавлено: Ср, сен 16 2015, 10:09
Чт, окт 13 2011, 22:45
Посмотрите документацию к признаку 33TXS, и сам признак
СообщениеДобавлено: Ср, сен 16 2015, 10:15
Можете скинуть док-ию, у нас ее нет(
СообщениеДобавлено: Ср, сен 16 2015, 10:20
Вт, май 30 2006, 08:34
33TXS Determine Additional Key for Tax Schema Assignment
Object
Feature
Task
This feature determines which tax schema the system reads for an
employee.
Use
The system uses this feature to determine the correct tax schema based
on an employee’s status in the following categories:
o Social insurance residence
For more information, see social insurance resident.
o Tax residence
This status determines whether an employee is regarded as an income
tax resident in Russia.
o Disability
If an employee is registered disabled, you make different social
insurance contributions.
Depending on an employee’s status in each of the above categories, the
system can assign a specific tax schema. The tax schema contains the
correct list of tax classes for the employee. For example, an employee
who is a social insurance resident, but not an income tax resident
requires a specific list of tax classes.
Procedure
For each decision in the above categories, enter the key that you want
to use for assigning tax schemas to employees as the return value.
The additional key that you enter corresponds to the Additional Key for
Table field in the Make Advanced Tax Schema Assignment Settings step in
Customizing for Payroll Russia under Tax and Social Insurance Payments
-> Perform Tax Schema Assignment.
Note
An employee can be relevant for more than one status, for example, the
employee can be a social insurance resident and an income tax resident.
If an employee is registered disabled, you do not differentiate between
the employee’s status for social insurance residence and income tax
residence.
С уважением.
