Текущее время: Вт, сен 22 2026, 15:16
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: PREP_EXTENSION/EHP_INCLUSION
СообщениеДобавлено: Пн, авг 22 2016, 09:57
Ср, янв 19 2011, 09:01
Добрый день, уважаемые коллеги!
Пытаюсь обновить SAP Solution Manager 7.1 до 7.2, на стадии PREP_EXTENSION/EHP_INCLUSION в SUM получаю ошибку ниже:
Severe error(s) occurred in phase PREP_EXTENSION/EHP_INCLUSION!
Last error code set: Unable to generate package queue, return Code = 3, Reason = "OCS package SAPKB74013 does not match the current software component vector", see phase log 'EHP_INCLUSION.LOG' and 'SPDA_EHP_INCLUSION.LOG' for details
If you put new packages in the download directory, use option 'init' to upload them
Посмотрел логи из файлов 'EHP_INCLUSION.LOG' и 'SPDA_EHP_INCLUSION.LOG':
1EETQ399 Last error code set is: Unable to generate package queue, return Code = 3, Reason = "OCS package SAPKB74013 does not match the current software component vector", see phase log 'EHP_INCLUSION.LOG' and 'SPDA_EHP_INCLUSION.LOG' for details
1EETQ204 Upgrade phase "EHP_INCLUSION" aborted with severe errors ("20160821225619")
3 ETN245 The following import prerequisites of OCS Package "SAPKB74013" have not been met:
3 ETN264 In the (alternatively) Requirement set "01":
3WETN493 Not allowed software component "ST" rel."*" is installed
3 ETN264 In the (alternatively) Requirement set "02":
3WETN492 Required Add-On component "ST" rel."720" is not installed
2WETN543 OCS package "SAPKB74013" does not match the current software component vector
2 ETN085X"Check whether the last CTS_PLUG" "Support Package has to be added" "to the calculated queue." " "
2 ETN085 "It was required to add the latest" "CTS_PLUG Support Package" "SAPK-20013INCTSPLUG" "to the calculated queue."
1 ETN214X."**************************************************"
1 ETN251 End of phase: "'Supp.Pack. Queue Calculation'"
1 ETN254 End date: "21.08.2016"
1 ETN255 End time: "22:56:08"
1 ETN214 ."**************************************************"
4 EPU202XEND OF SECTION BEING ANALYZED END OF EHP_INCLUSION ================================================
Подскажите, может кто сталкивался со схожей проблемой?
Посмотрел пререквизиты установки компонента SAPKB74013, там написано что компонент ST версии * не должен быть установлено. Я подразумевал что SUM сам все сделает.
 Заголовок сообщения: Re: PREP_EXTENSION/EHP_INCLUSION
СообщениеДобавлено: Пн, авг 22 2016, 14:51
Пн, янв 14 2013, 10:37
Бывает места не хватает для разархивирования или прав не хватает, но вам видимо перед аппгрейдом нужно в SPAM/SAINT обновить версию компанента
Последний раз редактировалось RikoNw Пн, авг 22 2016, 15:40, всего редактировалось 1 раз.
СообщениеДобавлено: Пн, авг 22 2016, 15:22
так явно же написано
плюс иногда нужны пакеты коррекции версий: ACP (Attribute Change Package)
СообщениеДобавлено: Пн, авг 22 2016, 16:02
шрам написал:
Добрый день,
У меня текущая версия уже стоит 0013.
CTS_PLUG 200 0013 X SAP CTS Plugin
Но все равно добавил его, ACP тоже есть.
СообщениеДобавлено: Вт, авг 23 2016, 08:57
Ср, фев 13 2013, 14:55
Была у меня похожая ошибка... вроде бы тоже с CTS
Один из компонентов отказывался обновляться - применял и ACP и CRT, но всё безуспешно.
Выкрутился: убрал из обновления этот компонент, а обновил уже потом руками.
СообщениеДобавлено: Вт, авг 23 2016, 09:21
Я уже и обновился до последней версии и повторно запустил SUM.
CTS_PLUG CTS_PLUGIN 200 200 0020/0 ABAP
Спрашивает уже добавить SAPK-20020INCTSPLUG, который уже установлен.
2 ETN085X"1. Calculate Support Package queue part" "for each component" " " " "
3 ETN431 Calculate the queue part for "SAP_ABA" rel."740" with target SP "SAPKA74014" (level "0014")
2 ETN085 "It was required to add the latest" "CTS_PLUG Support Package" "SAPK-20020INCTSPLUG" "to the calculated queue."
1 ETN254 End date: "22.08.2016"
1 ETN255 End time: "21:34:03"
СообщениеДобавлено: Вт, авг 23 2016, 11:44
уберите из списка этот компонент.
т.е. почистите xml и download directory
У меня однозначно была такая проблема и я её так решил
СообщениеДобавлено: Чт, авг 25 2016, 10:21
В общем, перепробовал все варианты какие мог. По всей вероятности необходимо удалить Компонент ST, это пререквизит к установке SAPKB74013.
Подскажите возможно ли удалить данный компонент?
На данный момент установлен:
ST ST 710 710 0012
СообщениеДобавлено: Чт, авг 25 2016, 13:07
Иногда в SUM бывает вот такое:
СообщениеДобавлено: Пт, авг 26 2016, 21:40
Проблема решилась следующей нотой ниже. Видимо после обращения в SAP, они исправили баг.
https://wiki.scn.sap.com/wiki/display/SL/EHP_INCLUSION+phase
2358643 - SAP IW FNDGC 100 is required to install by SAP NW GATEWAY FOUNDATION 7.40 - SAPK-740BHINSAPGWFND during the queue check
https://launchpad.support.sap.com/#/notes/2358643
Спасибо всем за помощь!
PS. SAP придумал какую то новую фишку Maintenance Planner наряду с привычным Maintenance Optimizer.
Then plan a new transaction in Maintenance Planner. You can launch the application with the below URL.
https://apps.support.sap.com/sap/support/mp
