Текущее время: Ср, июл 22 2026, 21:52
 Заголовок сообщения: BAPI_ACC_DOCUMENT_POST БСч в БЕ прямых проводок не допускает.
СообщениеДобавлено: Пт, авг 18 2017, 10:05
Пн, июн 05 2006, 13:33
Создаю бух. документ с помощью ф.м. BAPI_ACC_DOCUMENT_POST.
Дт 7605-02003 - Кт 6201-01000
Выдает ошибку F5(354): "БСч 7605-02003 в БЕ прямых проводок не допускает".
Что я делаю не так?
  PERFORM f_get_obj_key CHANGING s_docheader-obj_key.
  s_docheader-obj_type   = 'ZBKPF'.
  CALL FUNCTION 'OWN_LOGICAL_SYSTEM_GET'
    IMPORTING
      own_logical_system = s_docheader-obj_sys.
  s_docheader-bus_act    = 'RFBU'.
  s_docheader-username   = sy-uname.
  s_docheader-header_txt = 'Text'.
  s_docheader-comp_code  = c_bukrs.
  s_docheader-doc_date   = v_ddoc.
  s_docheader-pstng_date = v_ddoc.
  s_docheader-trans_date = v_ddoc.
  s_docheader-fisc_year  = v_ddoc(4).
  s_docheader-fis_period = v_ddoc+4(2).
  s_docheader-doc_type   = 'DA'.
  s_docheader-ref_doc_no = 'Text'.
  REFRESH: it_accountgl, it_currency, it_accreceiv.
  CLEAR:   it_accountgl, it_accreceiv.
  it_accreceiv-itemno_acc = 1.
  it_accreceiv-customer   = v_customer2.
  it_accreceiv-gl_account = '6201-01000'.
  it_accreceiv-comp_code  = c_bukrs.
  it_accreceiv-item_text  = 'Текст'.
  it_accreceiv-pmnttrms   = 'ZA01'.
  APPEND it_accreceiv.
  CLEAR it_currency.
  it_currency-itemno_acc = 1.
  it_currency-currency   = v_waers.
  it_currency-curr_type  = '00'.
  it_currency-amt_doccur = v_sum.
  it_currency-disc_base  = v_sum.
  APPEND it_currency.
  it_accountgl-itemno_acc = 2.
  it_accountgl-customer   = v_customer1.
  it_accountgl-gl_account = '7605-02003'.
  it_accountgl-item_text  = 'Text'.
  it_accountgl-doc_type   = 'DA'.
  it_accountgl-comp_code  = c_bukrs.
  it_accountgl-fis_period = v_ddoc+4(2).
  it_accountgl-fisc_year  = v_ddoc(4).
  it_accountgl-pstng_date = v_ddoc.
  it_accountgl-value_date = v_ddoc.
  APPEND it_accountgl.
  CLEAR it_currency.
  it_currency-itemno_acc = 2.
  it_currency-amt_doccur = - v_sum.
  APPEND it_currency.
  CALL FUNCTION 'BAPI_ACC_DOCUMENT_POST'
      documentheader    = s_docheader
    IMPORTING
      obj_type          = v_type
      obj_key           = v_key
      obj_sys           = v_sys
    TABLES
      accountgl         = it_accountgl
      accountreceivable = it_accreceiv
      currencyamount    = it_currency
      return            = it_return
 Заголовок сообщения: Re: BAPI_ACC_DOCUMENT_POST БСч в БЕ прямых проводок не допускает.
СообщениеДобавлено: Пт, авг 18 2017, 10:07
Может просто на счете в FS01 стоит галка "автопроводки"?
СообщениеДобавлено: Пт, авг 18 2017, 10:16
Нет, в поле "Проводки тлк автоматически" пусто.
Вручную документ создается.
СообщениеДобавлено: Пт, авг 18 2017, 10:34
Пн, июл 11 2011, 10:50
что то в коде не видно у вас первой позиции таблицы it_accountgl
СообщениеДобавлено: Пт, авг 18 2017, 10:45
Чт, дек 20 2007, 18:21
Контрольный счет действительно не допускает прямых проводок. Проводить надо на контрагента.
я твой сап эфай внедрял
BAdI-позитив
СообщениеДобавлено: Пт, авг 18 2017, 12:45
Первая позиция в таблице it_accreceiv.
 Заголовок сообщения: Re: BAPI_ACC_DOCUMENT_POST БСч в БЕ прямых проводок не допускает.  Тема решена
СообщениеДобавлено: Пт, авг 18 2017, 12:51
Для обоих счетов поле "CUSTOMER" заполняется.
Ваша подсказка натолкнула меня на мысль что таблица it_accountgl не предназначена для контрольных счетов.
Положил обе позиции в таблицу it_accreceiv - все получилось, ну или почти все.
Коды проводок отличаются от представленного ручного образца.
