Текущее время: Вс, июн 21 2026, 20:11
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Трабла при инсталляции 4.7. на соляру.
СообщениеДобавлено: Вт, ноя 29 2005, 11:52
На маздай стала с полпинка, а на соляре матюкается при копировании 000-манданта, что не хватает 418 таблиц - требует активации (DB02 -> check -> Database <-> Abap Dictionary). Что делать? (что-то не нашли как их пакетом активировать, если это вообще нужно)
(Таблицы ес-но появляются, если их активировать через se11)
СообщениеДобавлено: Вт, ноя 29 2005, 15:59
Пт, авг 27 2004, 09:10
The database utility is the interface between the ABAP Dictionary and the relational database underlying the R/3 System. The database utility allows you to edit (create, delete and adjust to changes to their definition in the ABAP Dictionary) database objects derived from objects of the ABAP Dictionary.
The database utility can be used to make modifications to database objects with various processing types.
Direct
The required database modifications are carried out immediately.
This processing type is not suitable for converting large tables. First of all, the conversion places a great load on the system. Secondly, the conversion can terminate due to a runtime restriction. You should therefore choose the processing type Background when converting large tables.
Background
A background job is scheduled for the required database modifications.
You can specify the time at which background processing is to begin. If you wish, you can choose to start background processing immediately. The advantage of selecting this processing type rather than Direct is that there is no danger of the operation terminating as the result of a runtime restriction.
Entering for mass processing
If you choose this processing type, entries are created with the corresponding function in a system table (TBATG). The requests collected in this table can then be processed in the background at fixed times (generally overnight). The background process for editing the requests must be scheduled explicitly as a job (see Scheduling Jobs for Mass Processing).
The objects already scheduled for mass processing can be displayed from the initial screen of the database utility with DB requests ® Mass processing. The interpretation of the displayed list is described in Displaying Requests for Mass Processing.
The background program writes messages in a log file. You can display these day logs starting with the initial screen of the database utility with Extras ® Logs. The interpretation of the displayed list is described in Displaying Requests for Mass Processing.
Ваш случай видимо Entering for mass processing
Либо добавить данные таблицы в список исключений при копировании.
Успехов
по прозвищу Тосманский Дьявол
СообщениеДобавлено: Вт, ноя 29 2005, 18:22
Вт, авг 17 2004, 11:44
Профиль копирования какой используется? Ставил не раз SAP R/3 4.7 на SUN, копировал 0-й клиент с профилем SAP_CUST - никаких проблем.
 Заголовок сообщения: Re: Трабла при инсталляции 4.7. на соляру.
СообщениеДобавлено: Вт, ноя 29 2005, 19:09
Skif написал:
Если DB02 -> check -> Database <-> Abap Dictionary так же показывает кучу несуществующих в базе таблиц - то инсталляция прошла не полностью. Быстрей всего не считался какой-нибудь CD или что-то подобное. Проверяй логи и т.д. Наверно сгенериловалось меньше заданий на загрузку. Сравни с логами с маздая - колличество
процессов загрузки должно быть одинаково, проверь по не созданной таблице влогах на маздае каким процессом это создавалось и тд
СообщениеДобавлено: Чт, дек 01 2005, 10:22
Anonymous написал(а):
[Сравни с логами с маздая - колличество
Повторение - мать учения. Почти как маздай - перезагрузи - и всё пойдёт :)
СообщениеДобавлено: Чт, дек 01 2005, 11:14
Чт, авг 19 2004, 09:51
Skif написал:
вы на 4.7 чтоль переходите? ;)
СообщениеДобавлено: Чт, дек 01 2005, 11:39
if написал:
Skif написал:
да так - в порядке хобби. для админов хочу сделать централизованную панель контроля-управления, а то развелось систем - как грязи.. - не в 4.0 же её делать. К тому же hr в след. году, а он на 4.7. Ну и заодно народ руку набивает на инстале.
p.s. "и крашу..крашу я заборы чтоб тунеядцем не прослыть"
