Текущее время: Пт, сен 11 2026, 21:33
 Заголовок сообщения: Программа BC430_CHECK
СообщениеДобавлено: Сб, окт 30 2004, 12:25
Пт, сен 17 2004, 08:10
Господа!
У кого есть исходник программы BC430_CHECK? Скиньте, плз, если не сложно!
СообщениеДобавлено: Пн, ноя 01 2004, 12:18
Пн, ноя 01 2004, 12:17
REPORT BC430_CHECK.
CALL SCREEN 1100.
* Includes f№r das Image Control
INCLUDE SIMAGECONTROLCLASSDEF.
INCLUDE SIMAGECONTROLCLASSIMPL.
* Include f№r die Icons
INCLUDE <ICON>.
* Das Programm pr№ft f№r die ?bungen 2 - 6 die von den Teilnehmern des*
* BC430 (ABAP Dictionary) angelegten Objekte auf Korrektheit. Die *
* angelegten Tabellen werden mit Beispieldaten gef№llt. *
TABLES: BC430_DS, BC430_FEEDBACK, BC430_ERROR, BC430_PROT.
TABLES: X030L.
TYPES: BEGIN OF FB_TAB,
COLOR(1),
TEXT(100),
END OF FB_TAB.
TYPES: FLAG(1) TYPE C.
DATA: FB_TAB TYPE FB_TAB OCCURS 20 WITH HEADER LINE.
DATA: TEXT_VAR(50) TYPE C,
TEXT_VAR2(50) TYPE C.
DATA: NAME_EMPLOY TYPE TABNAME, "Employee table
NAME_CREW TYPE TABNAME, "Crew table
NAME_DEPMENT TYPE TABNAME, "Department table
NAME_DEPMENTT TYPE TABNAME, "Text table for departments
NAME_CHANGE TYPE TABNAME, "Include for change info
NAME_AIRP_APP TYPE TABNAME, "Append Airport
INDX_EMPNAME TYPE INDEXID, "Name-Index for emp. table
INDX_EMPAREA TYPE INDEXID, "Area-Index for emp. table
DOMA_AREA TYPE DOMNAME. "Domain for area
DATA: ERRORS TYPE BC430_ERROR OCCURS 20 WITH HEADER LINE,
TEMP_ERRORS TYPE BC430_ERROR OCCURS 20 WITH HEADER LINE,
NAMES_WA TYPE BC430_NAMES,
SUCCESS_WA TYPE BC430_SUCCESS.
DATA: TCODE LIKE SY-TCODE,
SUBRC LIKE SY-SUBRC.
DATA: COURSE_NAME(6),
COURSE_GROUP(2).
DATA: KAP2(1),
KAP3(1),
KAP4(1),
KAP5(1),
KAP6(1).
DATA: JUST_STARTED TYPE FLAG VALUE ' '.
DATA: BEGIN OF FIELD_TEXTS OCCURS 20,
FIELD TYPE FIELDNAME,
TEXT(30) TYPE C,
END OF FIELD_TEXTS.
* Deklarationen f№r das Image Control
DATA: PICTURE1 TYPE REF TO C_IMAGE_CONTROL.
DATA: PICTURE2 TYPE REF TO C_IMAGE_CONTROL.
DATA URL(255) TYPE C. " URL-field
DATA URL2(255) TYPE C.
DATA FB_CONT_CRE(1) TYPE C VALUE 'N'. "Control for FB already created?
* Makros
DEFINE WRITE_FB.
FB_TAB-COLOR = &1.
FB_TAB-TEXT = &2.
APPEND FB_TAB.
END-OF-DEFINITION.
DEFINE WRITE_FB_VAR.
CLEAR TEXT_VAR.
FB_TAB-COLOR = &1.
TEXT_VAR = &2.
CONCATENATE TEXT_VAR &3 INTO FB_TAB-TEXT SEPARATED BY ' '.
APPEND FB_TAB.
END-OF-DEFINITION.
DEFINE WRITE_FB_TWO_VAR.
CLEAR TEXT_VAR.
CLEAR TEXT_VAR2.
FB_TAB-COLOR = &1.
TEXT_VAR = &2.
TEXT_VAR2 = &4.
CONCATENATE TEXT_VAR &3 TEXT_VAR2 &5 INTO FB_TAB-TEXT
SEPARATED BY ' '.
APPEND FB_TAB.
END-OF-DEFINITION.
DEFINE WRITE_EMPTY_LINE.
WRITE_FB 'N' ' '.
END-OF-DEFINITION.
DEFINE WRITE_FB_EXERCISE.
FB_TAB-COLOR = 'U'.
CLEAR TEXT_VAR.
TEXT_VAR = '?bung'(001).
CONCATENATE TEXT_VAR &1 INTO FB_TAB-TEXT SEPARATED BY ' '.
APPEND FB_TAB.
END-OF-DEFINITION.
* Makros f№r das Schreiben des Feedback
DEFINE PREDEFINED_OBJ_NOT_ACTIVE.
WRITE_FB 'E' '?bungsumgebung nicht korrekt eingerichtet!'(010).
WRITE_FB 'E' 'Verstфndigen Sie bitte den Referenten!'(011).
WRITE_FB 'E' 'Ursache: Vorlagen nicht aktiv!!'(013).
END-OF-DEFINITION.
DEFINE UNKNOWN_ERROR.
WRITE_FB 'E' 'Ursache: Kann nicht ermittelt werden!!'(014).
END-OF-DEFINITION.
DEFINE DDIC_INTERFACE_ERROR.
WRITE_FB 'E' 'Ursache: Problem in DD-Schnittstellen!!'(012).
END-OF-DEFINITION.
DEFINE FILL_TEXT.
FIELD_TEXTS-FIELD = &1.
FIELD_TEXTS-TEXT = &2.
APPEND FIELD_TEXTS.
END-OF-DEFINITION.
* Makros zur Modifikation der Screen Attribute
DEFINE SET_SCREEN_INP_REQUIRED.
LOOP AT SCREEN.
IF SCREEN-NAME = &1.
SCREEN-REQUIRED = '1'.
SCREEN-INPUT = '1'.
MODIFY SCREEN.
ENDIF.
ENDLOOP.
END-OF-DEFINITION.
DEFINE SET_SCREEN_INP.
LOOP AT SCREEN.
SCREEN-INPUT = '1'.
MODIFY SCREEN.
ENDIF.
ENDLOOP.
END-OF-DEFINITION.
DEFINE SET_SCREEN_NO_INP.
LOOP AT SCREEN.
SCREEN-INPUT = '0'.
MODIFY SCREEN.
ENDIF.
ENDLOOP.
END-OF-DEFINITION.
* Makros zum Handling der Bilder
DEFINE LOAD_GIF_PICTURE.
PERFORM LOAD_PIC_FROM_DB
TABLES PIC_DATA_FB
USING &1
CHANGING PIC_SIZE_FB.
END-OF-DEFINITION.
* MODULE STATUS_1100 *
MODULE STATUS_1100 OUTPUT.
SET TITLEBAR 'CHECK_TITLE'.
SET PF-STATUS 'CHECK'.
* Hole die bereits bekannten Namen f№r die Teilnehmerobjekte
PERFORM GET_NAMES.
* Lese die Infos zu den bisherigen Interaktionen mit dem Report
PERFORM GET_STATE_INFO.
IF JUST_STARTED = ' '.
PERFORM DETERMINE_ACTIVE_CHAPTER.
PERFORM FILL_FIELD_TEXTS.
JUST_STARTED = 'X'.
ENDIF.
* Pr№fe, ob die Vorlagen aktuelle Daten enthalten. Vorlagen sind die
* Tabellen SEMPLOYES, SDEPMENT, SDEPMENTT und SFLCREW.
PERFORM CHECK_PREREQUISITES.
* Modifiziere die Screen Attribute anhand des aktiven Kapitels
PERFORM MODIFY_SCREEN_1100.
* Baue das Einstiegsbild auf
CREATE OBJECT PICTURE1.
CALL METHOD PICTURE1->CREATE_CONTROL
EXPORTING DYNNR = '1100'
REPID = 'BC430_CHECK'
STYLE = WS_BORDER
CONTAINER = 'PICTURE1'.
* Setze den Display Mode
CALL METHOD PICTURE1->SET_DISPLAY_MODE
EXPORTING DISPLAY_MODE = DISPLAY_MODE_STRETCH.
* Lade das Bild aus der R/3 Databank
DATA PIC_DATA LIKE W3MIME OCCURS 0.
DATA PIC_SIZE TYPE I.
* Lade das Bild aus der WebRFC Datenbank in die interne
* Tabelle pic_data.
TABLES PIC_DATA
USING 'BC430_GRAFIK'
CHANGING PIC_SIZE.
* Hole eine URL vom Data Provider durch Export der pic_data.
CLEAR URL.
CALL FUNCTION 'DP_CREATE_URL'
TYPE = 'image'
SUBTYPE = CNDP_SAP_TAB_UNKNOWN
SIZE = PIC_SIZE
LIFETIME = CNDP_LIFETIME_TRANSACTION
TABLES
DATA = PIC_DATA
CHANGING
URL = URL
EXCEPTIONS
OTHERS = 1.
* Lade das Bild №ber die vom Data Provider generierte URL
IF SY-SUBRC = 0.
CALL METHOD PICTURE1->LOAD_IMAGE_FROM_URL
EXPORTING URL = URL.
ENDIF.
ENDMODULE.
* MODULE USER_COMMAND_1100 *
MODULE USER_COMMAND_1100.
CASE TCODE.
WHEN 'ABBR'.
LEAVE. SET SCREEN 0. LEAVE SCREEN.
CALL METHOD PICTURE1->DESTROY_CONTROL.
WHEN 'BACK'.
WHEN 'AUSF'.
PERFORM PUT_NAMES.
REFRESH FB_TAB.
ERRORS = ' '.
LEAVE TO LIST-PROCESSING.
IF KAP2 = 'X'.
PERFORM CHECK_KAP_2.
ENDIF.
IF KAP3 = 'X'.
PERFORM CHECK_KAP_3.
ENDIF.
IF KAP4 = 'X'.
PERFORM CHECK_KAP_4.
ENDIF.
IF KAP5 = 'X'.
PERFORM CHECK_KAP_5.
ENDIF.
IF KAP6 = 'X'.
PERFORM CHECK_KAP_6.
ENDIF.
WHEN 'CHAP'.
ENDCASE.
ENDMODULE.
* MODULE CANCEL: Verlassen des Bildes ohne Pr№fungen *
MODULE CANCEL INPUT.
LEAVE PROGRAM.
ENDMODULE.
* FORM GET_NAMES *
* Liest die Namen der Objekte, die die Teilnehmer in vorhergehenden *
* ?bungen schon eingegeben haben aus der BC430_NAMES. *
* In der ersten ?bung sind noch keine Namen vorhanden. F№r die *
* Standard-User BC430-xx werden die vorgegebenen Namen ermittelt. *
FORM GET_NAMES.
SELECT SINGLE * FROM BC430_NAMES INTO NAMES_WA
WHERE COURSE_USER = SY-UNAME.
IF SY-SUBRC NE 0.
MOVE SY-UNAME(6) TO COURSE_NAME.
IF COURSE_NAME = 'BC430-'.
PERFORM GET_DEFAULT_NAMES.
ENDIF.
ELSE.
NAME_EMPLOY = NAMES_WA-SEMPLOYES.
NAME_CREW = NAMES_WA-SFLCREW.
NAME_DEPMENT = NAMES_WA-SDEPMENT.
NAME_DEPMENTT = NAMES_WA-SDEPMENTT.
NAME_CHANGE = NAMES_WA-INCL_CHANGE.
NAME_AIRP_APP = NAMES_WA-APP_AIRPORT.
INDX_EMPNAME = NAMES_WA-NAME_INDX.
INDX_EMPAREA = NAMES_WA-AREA_INDX.
DOMA_AREA = NAMES_WA-DOMA_AREA.
ENDIF.
ENDFORM.
* FORM PUT_NAMES *
* Sichert die eingegebenen Namen in BC430_NAMES. *
FORM PUT_NAMES.
NAMES_WA-COURSE_USER = SY-UNAME.
NAMES_WA-SEMPLOYES = NAME_EMPLOY.
NAMES_WA-SFLCREW = NAME_CREW.
NAMES_WA-SDEPMENT = NAME_DEPMENT.
NAMES_WA-SDEPMENTT = NAME_DEPMENTT.
NAMES_WA-INCL_CHANGE = NAME_CHANGE.
NAMES_WA-APP_AIRPORT = NAME_AIRP_APP.
NAMES_WA-NAME_INDX = INDX_EMPNAME.
NAMES_WA-AREA_INDX = INDX_EMPAREA.
NAMES_WA-DOMA_AREA = DOMA_AREA.
INSERT INTO BC430_NAMES VALUES NAMES_WA.
IF SY-SUBRC NE 0.
UPDATE BC430_NAMES FROM NAMES_WA.
ENDIF.
COMMIT WORK.
ENDFORM.
* FORM GET_DEFAULT_NAMES *
* Falls der User ein Standard-User ist (User-Id BC430-xx) sind die *
* Namen der anzulegenden Objekte schon bekannt. Diese Defaultnamen *
* werden in dieser Form aus dem User ermittelt. *
MOVE SY-UNAME+6(2) TO COURSE_GROUP.
MOVE 'ZEMPLOY' TO NAME_EMPLOY.
MOVE COURSE_GROUP TO NAME_EMPLOY+7.
MOVE 'ZDEPMENT' TO NAME_DEPMENT.
MOVE COURSE_GROUP TO NAME_DEPMENT+8.
MOVE 'ZDEPMENTT' TO NAME_DEPMENTT.
MOVE COURSE_GROUP TO NAME_DEPMENTT+9.
MOVE 'ZFLCREW' TO NAME_CREW.
MOVE COURSE_GROUP TO NAME_CREW+7.
MOVE 'ZCHANGE' TO NAME_CHANGE.
MOVE COURSE_GROUP TO NAME_CHANGE+7.
ENDFORM.
* FORM GET_STATE_INFO *
* Liest Infos №ber Erfolg in bisherigen ?bungen aus BC430_SUCCESS. *
SELECT SINGLE * FROM BC430_SUCCESS INTO SUCCESS_WA
IF SY-SUBRC NE 0. "Set default if nothing is found
SUCCESS_WA-COURSE_USER = SY-UNAME.
SUCCESS_WA-CHAPTER2 = 'N'.
SUCCESS_WA-CHAPTER3 = 'N'.
SUCCESS_WA-CHAPTER4 = 'N'.
SUCCESS_WA-CHAPTER5 = 'N'.
SUCCESS_WA-CHAPTER6 = 'N'.
SUCCESS_WA-EMPLOY_FILLED = 'N'.
SUCCESS_WA-DEPMENT_FILLED = 'N'.
SUCCESS_WA-DEPMENTT_FILLED = 'N'.
SUCCESS_WA-SFLCREW_FILLED = 'N'.
ENDIF.
ENDFORM.
* FORM PUT_STATE_INFO *
* Schreibt Infos №ber Erfolg bzw. Mi?erfolg in BC430_SUCCESS *
FORM PUT_STATE_INFO.
INSERT INTO BC430_SUCCESS VALUES SUCCESS_WA.
IF SY-SUBRC NE 0.
UPDATE BC430_SUCCESS FROM SUCCESS_WA.
ENDIF.
COMMIT WORK.
ENDFORM.
* FORM DETERMINE_ACTIVE_CHAP *
* Bestimmt das gerade bearbeitete Kapitel. *
KAP2 = 'X'.
KAP3 = ' '.
KAP4 = ' '.
KAP5 = ' '.
KAP6 = ' '.
IF SUCCESS_WA-CHAPTER2 = 'Y'.
KAP2 = ' '.
KAP3 = 'X'.
IF SUCCESS_WA-CHAPTER3 = 'Y'.
KAP3 = ' '.
KAP4 = 'X'.
IF SUCCESS_WA-CHAPTER4 = 'Y'.
KAP4 = ' '.
KAP5 = 'X'.
IF SUCCESS_WA-CHAPTER5 = 'Y'.
KAP5 = ' '.
KAP6 = 'X'.
ENDIF.
ENDIF.
ENDIF.
ENDIF.
ENDFORM.
* FORM CHECK_PREREQUISITES *
* Der Report kopiert die Daten aus SEMPLOYES, SDEPMENT, SDEPMENTT, *
* und SFLCREW in die entsprechenden Tabellen der Teilnehmer. *
* Damit dies korrekt funktioniert sind zwei Pr№fungen erforderlich: *
* 1) Falls eine der Tabellen leer ist, werden die Daten aufgebaut *
* 2) Falls der Aufbau der Daten zu lange zur№ckliegt, kann es sein das*
* sie nicht zu den anderen Daten im Flugmodell (SPFLI, SFLIGHT) *
* passen. Falls die Daten nicht an diesem oder dem Vortag aufgebaut*
* wurden, werden sie erneut aufgebaut. *
DATA: START_FILL_REPORT(1) VALUE '0',
NEWEST_CR_DATE TYPE SY-DATUM,
ENTR_EMPLOYES TYPE I,
ENTR_DEPMENT TYPE I,
ENTR_DEPMENTT TYPE I,
ENTR_CREW TYPE I.
* Erste Pr№fung: Enthalten die Tabellen Daten
* BC430_FILL wird gestartet falls eine Tabelle leer ist.
SELECT COUNT(*) FROM SEMPLOYES INTO ENTR_EMPLOYES UP TO 2 ROWS.
SELECT COUNT(*) FROM SDEPMENT INTO ENTR_DEPMENT UP TO 2 ROWS.
SELECT COUNT(*) FROM SDEPMENTT INTO ENTR_DEPMENTT UP TO 2 ROWS.
SELECT COUNT(*) FROM SFLCREW INTO ENTR_CREW UP TO 2 ROWS.
IF ENTR_EMPLOYES = 0 OR ENTR_DEPMENT = 0 OR
ENTR_DEPMENTT = 0 OR ENTR_CREW = 0.
START_FILL_REPORT = '1'.
ENDIF.
* Zweite Pr№fung: Wann wurden Daten zuletzt aufgebaut
* Info №ber letzten Aufbau steht in BC430_DS
SELECT * FROM BC430_DS.
IF BC430_DS-CR_DATE GT NEWEST_CR_DATE.
NEWEST_CR_DATE = BC430_DS-CR_DATE.
ENDIF.
ENDSELECT.
* Falls BC430_DS leer ist, wird BC430_FILL gestartet
IF SY-SUBRC > 0.
ENDIF.
* Falls BC430_FILL nicht an diesem oder dem vorhergehenden
* Tag lief, wird er erneut aufgerufen
NEWEST_CR_DATE = NEWEST_CR_DATE + 1.
IF NEWEST_CR_DATE LT SY-DATUM.
ENDIF.
* Starte BC430_FILL
IF START_FILL_REPORT = '1'.
SUBMIT BC430_FILL AND RETURN.
ENDIF.
ENDFORM.
* FORM MODIFY_SCREEN_1100 *
* ?ndere die Attribute des Screens in Abhфngigkeit vom Kapitel. *
IF KAP2 = 'X'.
SET_SCREEN_INP_REQUIRED 'NAME_EMPLOY'.
SET_SCREEN_INP_REQUIRED 'NAME_DEPMENT'.
SET_SCREEN_INP_REQUIRED 'NAME_CHANGE'.
SET_SCREEN_NO_INP 'NAME_CREW'.
SET_SCREEN_NO_INP 'NAME_DEPMENTT'.
SET_SCREEN_NO_INP 'NAME_AIRP_APP'.
SET_SCREEN_NO_INP 'INDX_EMPNAME'.
SET_SCREEN_NO_INP 'INDX_EMPAREA'.
SET_SCREEN_NO_INP 'DOMA_AREA'.
ENDIF.
IF KAP3 = 'X'.
SET_SCREEN_INP_REQUIRED 'NAME_CREW'.
SET_SCREEN_INP_REQUIRED 'INDX_EMPNAME'.
SET_SCREEN_INP 'INDX_EMPAREA'.
ENDIF.
IF KAP4 = 'X'.
SET_SCREEN_NO_INP 'NAME_CHANGE'.
SET_SCREEN_INP 'NAME_DEPMENTT'.
SET_SCREEN_INP_REQUIRED 'DOMA_AREA'.
ENDIF.
IF KAP5 = 'X'.
SET_SCREEN_NO_INP 'NAME_DEPMENT'.
ENDIF.
IF KAP6 = 'X'.
SET_SCREEN_INP_REQUIRED 'NAME_AIRP_APP'.
ENDIF.
ENDFORM.
* FORM CHECK_KAP_2 *
* Pr№fe Korrektheit der LЎsung f№r Kapitel 2. *
FORM CHECK_KAP_2.
* Lokale Daten Deklarationen
DATA: SUCCESS TYPE FLAG,
EMP_FILL TYPE FLAG VALUE 'N',
DEP_FILL TYPE FLAG VALUE 'N',
GLOBAL_SUCCESS TYPE FLAG VALUE 'Y',
FILL_INFO_EMP TYPE FLAG VALUE 'Y',
FILL_INFO_DEP TYPE FLAG VALUE 'Y'.
* Finde heraus, ob ZEMPLOYxx und ZDEPMENTxx schon gef№llt waren
IF SUCCESS_WA-EMPLOY_FILLED = 'Y'.
FILL_INFO_EMP = 'A'.
ENDIF.
IF SUCCESS_WA-DEPMENT_FILLED = 'Y'.
FILL_INFO_DEP = 'A'.
ENDIF.
* Pr№fe Feldstruktur ZEMPLOYxx, ?bung 2-1-1
WRITE_FB_EXERCISE '2-1-1'.
WRITE_FB_VAR 'I' 'Pr№fen der Tabelle'(050) NAME_EMPLOY.
PERFORM CHECK_TABLE USING NAME_EMPLOY 'SEMPLOYES' FILL_INFO_EMP
CHANGING FB_TAB SUCCESS.
EMP_FILL = SUCCESS.
IF SUCCESS = 'N'. GLOBAL_SUCCESS = 'N'. ENDIF.
WRITE_EMPTY_LINE. "Leerzeile ausgeben
* Pr№fe Feldstruktur ZDEPMENTxx, ?bung 2-1-2
WRITE_FB_EXERCISE '2-1-2'.
WRITE_FB_VAR 'I' 'Pr№fen der Tabelle'(050) NAME_DEPMENT.
PERFORM CHECK_TABLE USING NAME_DEPMENT 'SDEPMENT' FILL_INFO_DEP
DEP_FILL = SUCCESS.
* Pr№fe Include ZCHANGExx, ?bung 2-3
WRITE_FB_EXERCISE '2-3'.
* Pr№fe Inclusion in ZEMPLOYxx
PERFORM CHECK_INCLUDE USING NAME_CHANGE 'SCHANGED' NAME_EMPLOY
'INCLUDE'
* Pr№fe Inclusion in ZDEPMENTxx
PERFORM CHECK_INCLUDE USING NAME_CHANGE 'SCHANGED' NAME_DEPMENT
'INCLUDE'
* Resultate in DB-Tabelle BC430_SUCCESS schreiben. Falls alle ?bungen
* erfolgreich gelЎst sind, kann diese Info nicht mehr verфndert werden
IF SUCCESS_WA-CHAPTER2 = 'N'.
SUCCESS_WA-CHAPTER2 = GLOBAL_SUCCESS.
ENDIF.
SUCCESS_WA-EMPLOY_FILLED = EMP_FILL.
SUCCESS_WA-DEPMENT_FILLED = DEP_FILL.
PERFORM PUT_STATE_INFO.
* Feedback ausgeben
PERFORM WRITE_FEEDBACK USING GLOBAL_SUCCESS.
ENDFORM.
* FORM CHECK_KAP_3 *
* Pr№fe die Korrektheit der LЎsung f№r Kapitel 3. *
FORM CHECK_KAP_3.
* Lokale Datendeklarationen
CRE_FILL TYPE FLAG VALUE 'N',
FILL_INFO_CRE TYPE FLAG VALUE 'Y'.
* Finde heraus, ob ZFLCREWxx vorher schon gef№llt war
IF SUCCESS_WA-SFLCREW_FILLED = 'Y'.
FILL_INFO_CRE = 'A'.
ENDIF.
* Pr№fe den Namensindex zu ZEMPLOYxx, ?bung 3-1
WRITE_FB_EXERCISE '3-1'.
PERFORM CHECK_INDEX USING NAME_EMPLOY INDX_EMPNAME 'SEMPLOYES' 'NAM'
* Pr№fe die Tabelle ZFLCREWxx, ?bung 3-2
WRITE_FB_EXERCISE '3-2'.
WRITE_FB_VAR 'I' 'Pr№fen der Tabelle'(050) NAME_CREW.
PERFORM CHECK_TABLE USING NAME_CREW 'SFLCREW' FILL_INFO_CRE
CRE_FILL = SUCCESS.
* Pr№fe die technischen Einst. zu ZDEPMENTxx und ZFLCREWxx, ?bung 3-3
WRITE_FB_EXERCISE '3-3'.
PERFORM CHECK_TECHN_SETTINGS USING NAME_DEPMENT 'SDEPMENT'
*{ REPLACE KP7K007605 1
*\ PERFORM CHECK_TECHN_SETTINGS USING NAME_CREW 'SFLCREW'
*\ CHANGING FB_TAB SUCCESS.
* Replaced on Nov 25, 2002 by Michael Fry
* Reason: SFLCREW is the original table, without the correct buffer
* settings, so a new table, SFLCREW_BUFF, was created which has the
* correct technical settings and is being used for the check
PERFORM CHECK_TECHN_SETTINGS USING NAME_CREW 'SFLCREW_BUFF'
*} REPLACE
* Pr№fe den Bereichsindex, falls Zusatz№bung bearbeitet, ?bung 3-4
IF NOT INDX_EMPAREA IS INITIAL.
WRITE_FB_EXERCISE '3-4'.
PERFORM CHECK_INDEX USING NAME_EMPLOY INDX_EMPAREA 'SEMPLOYES' 'ARE'
ENDIF.
IF SUCCESS_WA-CHAPTER3 = 'N'.
SUCCESS_WA-CHAPTER3 = GLOBAL_SUCCESS.
SUCCESS_WA-SFLCREW_FILLED = CRE_FILL.
ENDIF.
* Feedback ausgeben
ENDFORM.
* FORM CHECK_KAP_4 *
* Pr№fe die Korrektheit der LЎsung f№r Kapitel 4. *
FORM CHECK_KAP_4.
DPT_FILL TYPE FLAG VALUE 'N',
FILL_INFO_DPT TYPE FLAG VALUE 'Y'.
IF SUCCESS_WA-DEPMENTT_FILLED = 'Y'.
FILL_INFO_DPT = 'A'.
ENDIF.
* Pr№fe die Domфne, ?bung 4-1
WRITE_FB_EXERCISE '4-1'.
PERFORM CHECK_DOMAIN USING DOMA_AREA 'S_AREA'
* Pr№fe die Fremdschl№ssel von ZEMPLOYxx, ?bung 4-2
WRITE_FB_EXERCISE '4-2'.
* 1) zu T000
PERFORM CHECK_FOREIGN_KEY USING NAME_EMPLOY 'T000'
'SEMPLOYES' 'T000'
* 2)zu SCARR
PERFORM CHECK_FOREIGN_KEY USING NAME_EMPLOY 'SCARR'
'SEMPLOYES' 'SCARR'
* 3) zu ZDEPMENTxx
PERFORM CHECK_FOREIGN_KEY USING NAME_EMPLOY NAME_DEPMENT
'SEMPLOYES' 'SDEPMENT'
* 4) zu SCURX
PERFORM CHECK_FOREIGN_KEY USING NAME_EMPLOY 'SCURX'
'SEMPLOYES' 'SCURX'
* 5) Ende der Pr№fungen f№r ZEMPLOYxx, gebe Leerzeile aus
* Pr№fe die Fremdschl№ssel von ZDEPMENTxx, ?bung 4-2
* 1) zu T000
PERFORM CHECK_FOREIGN_KEY USING NAME_DEPMENT 'T000'
'SDEPMENT' 'T000'
* 2) zu SCARR
PERFORM CHECK_FOREIGN_KEY USING NAME_DEPMENT 'SCARR'
'SDEPMENT' 'SCARR'
* 3) Ende der Pr№fungen von ZDEPMENTxx, gebe Leerzeile aus
* Pr№fe, ob das neue Feld an ZEMPLOYxx angehфngt ist, ?bung 4-3
WRITE_FB_EXERCISE '4-3'.
PERFORM CHECK_TABLE USING NAME_EMPLOY 'SEMPLOYES_RB' 'N'
* Pr№fe FS f№r neues Feld zw. ZEMPLOYxx und STRAVELAG
PERFORM CHECK_FOREIGN_KEY USING NAME_EMPLOY 'STRAVELAG'
'SEMPLOYES_RB' 'STRAVELAG'
* Pr№fe die Feldstruktur der Texttabelle ZDEPMENTTxx, ?bung 4-4
WRITE_FB_EXERCISE '4-4'.
WRITE_FB_VAR 'I' 'Pr№fen der Tabelle'(050) NAME_DEPMENTT.
PERFORM CHECK_TABLE USING NAME_DEPMENTT 'SDEPMENTT' FILL_INFO_DPT
DPT_FILL = SUCCESS.
* Pr№fe den Fremdschl№ssel zw. ZDEPMENTxx und ZDEPMENTTxx
PERFORM CHECK_FOREIGN_KEY USING NAME_DEPMENTT NAME_DEPMENT
'SDEPMENTT' 'SDEPMENT'
IF SUCCESS_WA-CHAPTER4 = 'N'.
SUCCESS_WA-CHAPTER4 = GLOBAL_SUCCESS.
SUCCESS_WA-DEPMENT_FILLED = DPT_FILL.
ENDIF.
* Feedback ausgeben
ENDFORM.
* FORM CHECK_KAP_5 *
* Pr№fe die Korrektheit der LЎsung f№r Kapitel 5. *
FORM CHECK_KAP_5.
GLOBAL_SUCCESS TYPE FLAG VALUE 'Y'.
* Pr№fe, ob Feld f№r Chef an ZDEPMENTxx angehфngt ist, ?bung 5-1
WRITE_FB_EXERCISE '5-1'.
PERFORM CHECK_TABLE USING NAME_DEPMENT 'SDEPMENT_CH' 'N'
* Pr№fe FS f№r das neue Feld
PERFORM CHECK_FOREIGN_KEY USING NAME_DEPMENT NAME_EMPLOY
'SDEPMENT_CH' 'SEMPLOYES_RB'
* Pr№fe, ob neues Feld in ZCHANGExx eingef№gt ist, ?bung 5-2
WRITE_FB_EXERCISE '5-2'.
WRITE_FB_VAR 'I' 'Pr№fen des Include'(059) NAME_CHANGE.
PERFORM CHECK_TABLE USING NAME_CHANGE 'SCHANGED_TI' 'N'
IF SUCCESS_WA-CHAPTER5 = 'N'.
SUCCESS_WA-CHAPTER5 = GLOBAL_SUCCESS.
ENDIF.
* Feedback ausgeben
ENDFORM.
* FORM CHECK_KAP_6 *
* Pr№fe die Korrektheit der LЎsung f№r Kapitel 6. *
FORM CHECK_KAP_6.
* Pr№fe, ob die Umsetzung durchgef№hrt wurde, ?bung 6-1
PERFORM CHECK_TABLE USING NAME_CREW 'SFLCREW_CONV' 'N'
* Pr№fe, ob das Append an ZEMPLOYxx angehфngt ist, ?bung 6-2
WRITE_FB_VAR 'I' 'Pr№fen der Append-Struktur'(060) NAME_AIRP_APP.
PERFORM CHECK_INCLUDE USING NAME_AIRP_APP 'SFLUGHAFEN' NAME_EMPLOY
'APPEND'
* Pr№fe den FS im Append, ?bung 6-3
PERFORM CHECK_FOREIGN_KEY USING NAME_AIRP_APP 'SAIRPORT'
'SFLUGHAFEN' 'SAIRPORT'
IF SUCCESS_WA-CHAPTER6 = 'N'.
SUCCESS_WA-CHAPTER6 = GLOBAL_SUCCESS.
ENDIF.
* Feedback ausgeben
ENDFORM.
* FORM CHECK_TABLE *
* Pr№ft die Struktur einer Tabelle gegen eine Vorlage und kopiert *
* (falls mЎglich) die Daten aus der Vorlage in die Tabelle. *
FORM CHECK_TABLE USING PART_TABLE OUR_TABLE FILL_OPT
CHANGING FEEDBACK SUCCESS.
CLEAR ERRORS.
REFRESH ERRORS.
SUCCESS = 'N'.
DATA: FIELDTEXT(50) TYPE C.
* Aufruf des FUBA zum Strukturvergleich
CALL FUNCTION 'BC430_COMP_AND_FILL'
T_TAB = PART_TABLE
M_TAB = OUR_TABLE
FILL = FILL_OPT
TABLES
ERRORS = ERRORS
EXCEPTIONS
T_TAB_NOT_EXIST = 1
T_TAB_NOT_ACTIVE = 2
M_TAB_NOT_ACTIVE = 3
SYSTEM_INCONSISTENT = 4
OTHERS = 5.
IF SY-SUBRC <> 0.
SUBRC = SY-SUBRC.
CASE SUBRC.
WHEN '1'.
WRITE_FB 'E' 'Die Tabelle ist nicht vorhanden!'(101).
WHEN '2'.
WRITE_FB 'E' 'Sie haben vergessen die Tabelle zu aktivieren!'(100).
WHEN '3'.
WHEN '4'.
WHEN '5'.
UNKNOWN_ERROR.
ENDCASE.
ELSE.
IF ERRORS IS INITIAL.
SUCCESS = 'Y'.
WRITE_FB 'S' 'Tabelle ist korrekt definiert!'(103).
IF FILL_OPT = 'Y'.
WRITE_FB 'S' 'Die Tabelle wird mit Beispieldaten gef№llt.'(104).
ELSEIF FILL_OPT = 'A'.
WRITE_FB 'S' 'Beispieldaten waren bereits aufgebaut.'(153).
ENDIF.
ELSE.
WRITE_FB 'E' 'Die Tabelle ist falsch definiert!'(105).
LOOP AT ERRORS.
LOOP AT FIELD_TEXTS.
IF ERRORS-FIELDNAME = FIELD_TEXTS-FIELD.
FIELDTEXT = FIELD_TEXTS-TEXT.
ENDIF.
ENDLOOP.
IF ERRORS-ERROR = 'FIELD'.
WRITE_FB_VAR 'E' 'Feld'(058) FIELDTEXT.
WRITE_FB 'E' 'Kein Feld mit erwartetem Typ und Keyflag
gefunden!'(107).
WRITE_FB 'E' 'In Ihrer Tabelle hat das Feld einen falschen
Typ oder'(154).
WRITE_FB 'E' 'Sie haben vergessen das Feld in Ihre Tabelle
aufzunehmen!'(155).
ENDIF.
IF ERRORS-ERROR = 'KEY'.
WRITE_FB 'E' 'Schl№sselkennzeichen falsch!'(106).
ENDIF.
IF ERRORS-ERROR = 'KEY_TOO_SMALL'.
WRITE_FB 'E' 'Die Tabelle hat zu wenige
Schl№sselfelder!'(156).
ENDIF.
IF ERRORS-ERROR = 'KEY_TOO_BIG'.
WRITE_FB 'E' 'Die Tabelle hat zu viele Schl№sselfelder!'(157).
ENDIF.
ENDLOOP.
ENDIF.
ENDIF.
ENDFORM.
* FORM CHECK_INDEX *
* Vergleicht die Struktur eines Index gegen eine Vorlage *
FORM CHECK_INDEX USING PART_TABLE PART_INDEX OUR_TABLE OUR_INDEX
CLEAR ERRORS.
REFRESH ERRORS.
SUCCESS = 'N'.
WRITE_FB_TWO_VAR 'I' 'Pr№fe Index'(301) PART_INDEX 'zu Tabelle'(302)
PART_TABLE.
* Aufruf FUBA zum Strukturvergleich
CALL FUNCTION 'BC430_INDX_COMP'
T_TAB = PART_TABLE
M_TAB = OUR_TABLE
T_IND = PART_INDEX
M_IND = OUR_INDEX
TABLES
ERRORS = ERRORS
EXCEPTIONS
T_INDX_NOT_ACTIVE = 1
M_INDX_NOT_ACTIVE = 2
SYSTEM_INCONSISTENT = 3
T_INDX_NOT_EXIST = 4
OTHERS = 5.
IF SY-SUBRC <> 0.
SUBRC = SY-SUBRC.
CASE SUBRC.
WHEN '1'.
WRITE_FB 'E' 'Sie haben vergessen den Index zu aktivieren!'(108).
WHEN '2'.
WHEN '3'.
WHEN '4'.
WRITE_FB 'E' 'Der Index ist nicht vorhanden!'(109).
WHEN '5'.
UNKNOWN_ERROR.
ENDCASE.
ELSE.
SUCCESS = 'Y'.
WRITE_FB 'S' 'Der Index ist korrekt definiert!'(110).
ELSE.
WRITE_FB 'E' 'Der Index ist nicht korrekt definiert!'(111).
LOOP AT ERRORS.
IF ERRORS-ERROR = 'UNIQUE_FLAG'.
WRITE_FB 'E' 'UNIQUE-Flag nicht korrekt!'(118).
ENDIF.
IF ERRORS-ERROR = 'DB_STATE'.
WRITE_FB 'E' 'Option zum Anlegen auf DB nicht korrekt!'(117).
ENDIF.
IF ERRORS-ERROR = 'DB_LIST'.
WRITE_FB 'E' 'Liste der DB-Systeme nicht korrekt!'(116).
ENDIF.
IF ERRORS-ERROR = 'FIELD_NUMBER'. "Feldanzahl falsch
IF ERRORS-HINT = 'TO_MANY'.
WRITE_FB 'E' 'Der Index hat zu viele Felder!'(113).
ELSE.
WRITE_FB 'E' 'Der Index hat nicht gen№gend Felder!'(112).
ENDIF.
ENDIF.
IF ERRORS-ERROR = 'WRONG_FIELDS'. "Feldtypen falsch
WRITE_FB 'E' 'Der Index enthфlt die falschen Felder!'(114).
ENDIF.
IF ERRORS-ERROR = 'WRONG_ORDER'. "Feldreihenfolge falsch
WRITE_FB 'E' 'Die Feldreihenfolge ist fehlerhaft!'(115).
ENDIF.
ENDLOOP.
ENDIF.
ENDIF.
ENDFORM.
* FORM CHECK_TECHN_SETTINGS *
* Vergleicht die techn. Einstellungen einer Tabelle gegen ein Vorlage *
FORM CHECK_TECHN_SETTINGS USING PART_TABLE OUR_TABLE
CLEAR ERRORS.
REFRESH ERRORS.
SUCCESS = 'N'.
WRITE_FB_VAR 'I' 'Pr№fen der techn. Einstellungen zu'(052) PART_TABLE.
CALL FUNCTION 'BC430_TABT_COMP'
T_TAB = PART_TABLE
M_TAB = OUR_TABLE
TABLES
ERRORS = ERRORS
EXCEPTIONS
T_TSET_NOT_ACTIVE = 1
M_TSET_NOT_ACTIVE = 2
OTHERS = 4.
IF SY-SUBRC <> 0.
SUBRC = SY-SUBRC.
CASE SUBRC.
WHEN '1'.
WRITE_FB 'E' 'Die techn. Einstellungen sind nicht aktiv!'(119).
WHEN '2'.
WHEN '3'.
WHEN '4'.
UNKNOWN_ERROR.
ENDCASE.
ELSE.
SUCCESS = 'Y'.
WRITE_FB 'S' 'Die techn. Einstellungen sind korrekt!'(120).
ELSE.
WRITE_FB 'E' 'Die techn. Einstellungen sind nicht korrekt!'(121).
LOOP AT ERRORS.
CASE ERRORS-ERROR.
WHEN 'SIZE_CATEGORY'. "GrЎ?enkat. falsch
WRITE_FB_VAR 'E' 'GrЎ?enkategorie falsch. Erwartet:'(122)
ERRORS-HINT.
WHEN 'DATA_CLASS'. "Datenart falsch
WRITE_FB_VAR 'E' 'Datenart falsch. Erwartet:'(123)
ERRORS-HINT.
WHEN 'PROTOCOL'. "Protokollierung falsch
WRITE_FB 'E' 'Protokollierung falsch eingestellt!'(124).
WHEN 'BUFF_ALLOW'. "Pufferungserlaubnis falsch
WRITE_FB 'E' 'Pufferungserlaubnis falsch eingestellt!'(125).
WHEN 'BUFF_TYPE'. "Pufferungsart falsch
WRITE_FB 'E' 'Pufferungsart falsch eingestellt!'(126).
WHEN 'KEY_FIELDS'. "Schl.anz gen. Puffer. falsch
WRITE_FB 'E' 'Falscher generischer Schl№ssel!'(127).
ENDCASE.
ENDLOOP.
ENDIF.
ENDIF.
ENDFORM.
* FORM CHECK_DOMAIN *
* Vergleicht eine Domфne mit einer Vorlage *
FORM CHECK_DOMAIN USING PART_DOMA OUR_DOMA
CLEAR ERRORS.
REFRESH ERRORS.
SUCCESS = 'N'.
WRITE_FB_VAR 'I' 'Pr№fen der Domфne'(053) PART_DOMA.
CALL FUNCTION 'BC430_DOMA_COMP'
T_DOMA = PART_DOMA
M_DOMA = OUR_DOMA
TABLES
ERRORS = ERRORS
EXCEPTIONS
T_DOMA_NOT_EXIST = 1
T_DOMA_NOT_ACTIVE = 2
M_DOMA_NOT_ACTIVE = 3
OTHERS = 5.
IF SY-SUBRC <> 0.
SUBRC = SY-SUBRC.
CASE SUBRC.
WHEN '1'.
WRITE_FB 'E' 'Die angegebene Domфne ist nicht vorhanden!'(128).
WHEN '2'.
WRITE_FB 'E' 'Sie haben vergessen die Domфne zu
aktivieren!'(129).
WHEN '3'.
WHEN '4'.
WHEN '5'.
UNKNOWN_ERROR.
ENDCASE.
ELSE.
SUCCESS = 'Y'.
WRITE_FB 'S' 'Die Domфne ist korrekt definiert!'(130).
ELSE.
WRITE_FB 'E' 'Die Domфne ist nicht korrekt definiert!'(131).
LOOP AT ERRORS.
IF ERRORS-ERROR = 'DATATYPE'.
WRITE_FB 'E' 'Der Datentyp ist nicht korrekt!'(132).
ENDIF.
IF ERRORS-ERROR = 'LENGTH'.
WRITE_FB 'E' 'Die Lфnge ist nicht korrekt!'(133).
ENDIF.
IF ERRORS-ERROR = 'DECIMALS'.
WRITE_FB 'E' 'Anzahl Dezimalstellen ist nicht korrekt!'(134).
ENDIF.
IF ERRORS-ERROR = 'VALUE'.
WRITE_FB 'E' 'Die Festwerte sind nicht korrekt!'(135).
ENDIF.
ENDLOOP.
ENDIF.
ENDIF.
ENDFORM.
* FORM CHECK_FOREIGN_KEY *
* Vergleicht eine Fremdschl№sselbeziehung gegen eine Vorlage *
FORM CHECK_FOREIGN_KEY USING PART_FT PART_PT OUR_FT OUR_PT
CLEAR ERRORS.
REFRESH ERRORS.
SUCCESS = 'N'.
WRITE_FB_VAR 'I' 'Fremdschl№sselpr№fung gegen'(054) PART_PT.
CALL FUNCTION 'BC430_FKEY_COMP'
T_FS_TAB = PART_FT
T_PT_TAB = PART_PT
M_FS_TAB = OUR_FT
M_PT_TAB = OUR_PT
TABLES
ERRORS = ERRORS
EXCEPTIONS
T_TAB_NOT_ACTIVE = 1
M_TAB_NOT_ACTIVE = 2
OTHERS = 4.
IF SY-SUBRC <> 0.
SUBRC = SY-SUBRC.
CASE SUBRC.
WHEN '1'.
WHEN '2'.
WHEN '3'.
WHEN '4'.
UNKNOWN_ERROR.
ENDCASE.
ELSE.
SUCCESS = 'Y'.
WRITE_FB 'S' 'Fremdschl№ssel ist korrekt definiert!'(136).
ELSE.
WRITE_FB 'E' 'Fremdschl№ssel ist fehlerhaft!'(137).
LOOP AT ERRORS.
IF ERRORS-ERROR = 'FK_NOT_EX'.
WRITE_FB 'E' 'Fremdschl№ssel ist nicht vorhanden!'(138).
ENDIF.
IF ERRORS-ERROR = 'FK_STR_NOT_OK'.
WRITE_FB 'E' 'Feldzuordnung ist nicht korrekt!'(139).
ENDIF.
IF ERRORS-ERROR = 'MUST_BE_TEXT'.
WRITE_FB 'E' 'Fremdschl. mu? Textfremdschl. sein!'(140).
ENDIF.
IF ERRORS-ERROR = 'SHOULD_NOT_BE_TEXT'.
WRITE_FB 'E' 'Fremdsch. darf kein Textfremdschl. sein!'(141).
ENDIF.
ENDLOOP.
ENDIF.
ENDIF.
ENDFORM.
* FORM CHECK_INCLUDE *
* Vergleicht ein Include bzw. Append gegen eine Vorlage *
FORM CHECK_INCLUDE USING PART_INC OUR_INC PART_TAB INC_TYPE
CLEAR ERRORS.
CLEAR TEMP_ERRORS.
REFRESH ERRORS.
REFRESH TEMP_ERRORS.
SUCCESS = 'N'.
IF INC_TYPE = 'INCLUDE'.
WRITE_FB_TWO_VAR 'I' 'Pr№fe Include'(303) PART_INC 'zu Tabelle'(302)
PART_TAB.
ELSE.
WRITE_FB_TWO_VAR 'I' 'Pr№fe Append'(304) PART_INC 'zu Tabelle'(302)
PART_TAB.
ENDIF.
CALL FUNCTION 'BC430_CHECK_INCLUDE'
T_INCLUDE = PART_INC
M_INCLUDE = OUR_INC
T_TAB = PART_TAB
INC_TYPE = INC_TYPE
TABLES
ERRORS = ERRORS
TEMP_ERRORS = TEMP_ERRORS
EXCEPTIONS
T_INC_NOT_EXIST = 1
T_INC_NOT_ACTIVE = 2
M_INC_NOT_ACTIVE = 3
T_TAB_NOT_ACTIVE = 4
SYSTEM_INCONSISTENT = 5
OTHERS = 6.
IF SY-SUBRC <> 0.
SUBRC = SY-SUBRC.
CASE SUBRC.
WHEN '1'.
WRITE_FB 'E' 'Die Struktur existiert nicht!'(142).
WHEN '2'.
WRITE_FB 'E' 'Sie haben vergessen die Struktur zu
aktivieren!'(143).
WHEN '3'.
WHEN '4'.
WRITE_FB_VAR 'E' 'Folgende Tabelle ist nicht aktiv:'(144)
PART_TAB.
WHEN OTHERS.
UNKNOWN_ERROR.
ENDCASE.
ELSE.
SUCCESS = 'Y'.
WRITE_FB 'S' 'Include ist korrekt definiert!'(145).
ELSE.
WRITE_FB 'S' 'Append ist korrekt definiert!'(151).
ENDIF.
ELSE.
WRITE_FB 'E' 'Include ist fehlerhaft!'(146).
ELSE.
WRITE_FB 'E' 'Append ist fehlerhaft!'(152).
ENDIF.
LOOP AT ERRORS.
IF ERRORS-ERROR = 'FIELD_STR'.
WRITE_FB 'E' 'Feldstruktur fehlerhaft!'(147).
ENDIF.
IF ERRORS-ERROR = 'SHOULD_BE_INCLUDE'.
WRITE_FB 'E' 'Objekt ist keine Struktur!'(148).
ENDIF.
IF ERRORS-ERROR = 'SHOULD_BE_APPEND'.
WRITE_FB 'E' 'Objekt ist keine Append-Struktur!'(149).
ENDIF.
IF ERRORS-ERROR = 'NOT_INCLUDED'.
WRITE_FB_TWO_VAR 'E' 'Die Struktur'(305) PART_INC
'ist nicht inkludiert in'(306) PART_TAB.
ELSE.
'ist nicht appendiert an'(307) PART_TAB.
ENDIF.
ENDIF.
ENDLOOP.
ENDIF.
ENDIF.
ENDFORM.
* FORM WRITE_FEEDBACK *
* Diese Form erf№llt folgende Aufgaben: *
* 1) Ausgabe der Meldungen aus FB_TAB *
* 2) Sichern der Meldungen aus FB_TAB in der DB-Tabelle BC430_PROT *
* 3) LЎschen der Meldungen aus FB_TAB *
DATA: PROT_WA TYPE BC430_PROT,
PROT_TAB TYPE STANDARD TABLE OF BC430_PROT.
* Abbauen eines vorhandenen Controls f№r Feedback
IF FB_CONT_CRE = 'Y'.
CALL METHOD PICTURE2->DESTROY_CONTROL.
ENDIF.
FORMAT INTENSIFIED ON.
LOOP AT FB_TAB.
IF FB_TAB-COLOR = 'E'.
WRITE: ICON_BREAKPOINT AS ICON.
WRITE: FB_TAB-TEXT. NEW-LINE.
ELSEIF FB_TAB-COLOR = 'I'.
WRITE: FB_TAB-TEXT COLOR COL_KEY. NEW-LINE.
ELSEIF FB_TAB-COLOR = 'S'.
WRITE: ICON_OKAY AS ICON.
ELSEIF FB_TAB-COLOR = 'W'.
WRITE: ICON_ALARM AS ICON.
ELSEIF FB_TAB-COLOR = 'U'.
WRITE: FB_TAB-TEXT COLOR COL_HEADING. NEW-LINE.
ELSEIF FB_TAB-COLOR = 'N'.
SKIP.
ELSE.
WRITE: FB_TAB-TEXT COLOR COL_NORMAL. NEW-LINE.
ENDIF.
ENDLOOP.
* 2) Sichern der Meldungen aus FB_TAB in BC430_PROT
PROT_WA-COURSE_USER = SY-UNAME.
PROT_WA-PROT_DATE = SY-DATUM.
PROT_WA-PROT_TIME = SY-UZEIT.
PROT_WA-LINE = 0.
* Ermittle Kapitelnr.
IF KAP2 = 'X'. PROT_WA-CHAPTER = 2. ENDIF.
IF KAP3 = 'X'. PROT_WA-CHAPTER = 3. ENDIF.
IF KAP4 = 'X'. PROT_WA-CHAPTER = 4. ENDIF.
IF KAP5 = 'X'. PROT_WA-CHAPTER = 5. ENDIF.
IF KAP6 = 'X'. PROT_WA-CHAPTER = 6. ENDIF.
LOOP AT FB_TAB.
ADD 1 TO PROT_WA-LINE.
PROT_WA-COLOR = FB_TAB-COLOR.
PROT_WA-TEXT = FB_TAB-TEXT.
APPEND PROT_WA TO PROT_TAB.
ENDLOOP.
INSERT BC430_PROT FROM TABLE PROT_TAB.
REFRESH FB_TAB.
* 4) Ausgeben des Bildes zum Feedback
* Aufbau des Image Control
CREATE OBJECT PICTURE2.
CALL METHOD PICTURE2->CREATE_CONTROL
STYLE = WS_BORDER
CONTAINER = 'PICTURE2'.
* Setze Anzeige Modus
CALL METHOD PICTURE2->SET_DISPLAY_MODE
* Lade Bild aus R/3 Databank
DATA PIC_DATA_FB LIKE W3MIME OCCURS 0.
DATA PIC_SIZE_FB TYPE I.
* Bestimme den Namen des Bildes f№r das Feedback abhфngig von Erfolg
* und gepr№ftem Kapitel
IF GLOBAL_SUCCESS = 'Y'.
IF KAP2 = 'X'.
LOAD_GIF_PICTURE 'BC430_SUCCESS1'.
ENDIF.
IF KAP3 = 'X'.
LOAD_GIF_PICTURE 'BC430_SUCCESS2'.
ENDIF.
IF KAP4 = 'X'.
LOAD_GIF_PICTURE 'BC430_SUCCESS3'.
ENDIF.
IF KAP5 = 'X'.
LOAD_GIF_PICTURE 'BC430_SUCCESS4'.
ENDIF.
IF KAP6 = 'X'.
LOAD_GIF_PICTURE 'BC430_SUCCESS5'.
ENDIF.
ELSEIF GLOBAL_SUCCESS = 'N'.
IF KAP2 = 'X'.
LOAD_GIF_PICTURE 'BC430_FAILURE1'.
ENDIF.
IF KAP3 = 'X'.
LOAD_GIF_PICTURE 'BC430_FAILURE2'.
ENDIF.
IF KAP4 = 'X'.
LOAD_GIF_PICTURE 'BC430_FAILURE3'.
ENDIF.
IF KAP5 = 'X'.
LOAD_GIF_PICTURE 'BC430_FAILURE4'.
ENDIF.
IF KAP6 = 'X'.
LOAD_GIF_PICTURE 'BC430_FAILURE5'.
ENDIF.
ENDIF.
* Ermittle eine URL vom Data Provider durch Export der pic_data.
CLEAR URL.
TYPE = 'image'
SIZE = PIC_SIZE_FB
TABLES
DATA = PIC_DATA_FB
CHANGING
URL = URL2
EXCEPTIONS
OTHERS = 1.
* Lade das Bild №ber die URL vom Data Provider.
IF SY-SUBRC = 0.
CALL METHOD PICTURE2->LOAD_IMAGE_FROM_URL
EXPORTING URL = URL2.
ENDIF.
* Setze Flag, da? Control schon aufgebaut ist
FB_CONT_CRE = 'Y'.
ENDFORM.
* FORM FILL_FIELD_TEXTS *
* Ermittelt f№r jeden Feldnamen aus einer der Vorlagentabellen einen *
* beschreibenden Text. *
FILL_TEXT 'CLIENT' 'Mandant'(401).
FILL_TEXT 'CARRIER' 'Fluggesellschaft'(402).
FILL_TEXT 'EMP_NUM' 'Personalnummer'(403).
FILL_TEXT 'FIRST_NAME' 'Vorname'(404).
FILL_TEXT 'LAST_NAME' 'Nachname'(405).
FILL_TEXT 'DEPARTMENT' 'Abteilungsk№rzel'(406).
FILL_TEXT 'AREA' 'Bereich'(407).
FILL_TEXT 'SALARY' 'Gehalt'(408).
FILL_TEXT 'CURRENCY' 'Wфhrung'(409).
FILL_TEXT 'CHANGED_BY' 'Letzter ?nderer'(416).
FILL_TEXT 'CH_DATE' '?nderungsdatum'(417).
FILL_TEXT 'TELNR' 'Telefonnummer'(410).
FILL_TEXT 'FAXNR' 'Faxnummer'(411).
FILL_TEXT 'CH_TIME' '?nderungszeit'(418).
FILL_TEXT 'CHIEF' 'Abteilungsleiter'(415).
FILL_TEXT 'LANGU' 'Sprache'(413).
FILL_TEXT 'TEXT' 'Text'(414).
FILL_TEXT 'CONNID' 'Verbindungsnummer'(419).
FILL_TEXT 'FLDATE' 'Flugdatum'(420).
FILL_TEXT 'ROLE' 'Rolle'(421).
FILL_TEXT 'FLUGHAFEN' 'Flughafenname'(422).
FILL_TEXT 'BUERONUMMER' 'B№ronummer'(423).
FILL_TEXT 'TELEFONNUMMER' 'Telefonnummer'(410).
FILL_TEXT 'AGENCY' 'Reiseb№ro'(412).
ENDFORM.
* FORM LOAD_PIC_FROM_DB *
TABLES PIC_DATA
USING PIC_NAME
CHANGING PIC_SIZE.
DATA QUERY_TABLE LIKE W3QUERY OCCURS 1 WITH HEADER LINE.
DATA HTML_TABLE LIKE W3HTML OCCURS 1.
DATA RETURN_CODE LIKE W3PARAM-RET_CODE.
DATA CONTENT_TYPE LIKE W3PARAM-CONT_TYPE.
DATA CONTENT_LENGTH LIKE W3PARAM-CONT_LEN.
CLEAR QUERY_TABLE.
QUERY_TABLE-NAME = '_OBJECT_ID'.
QUERY_TABLE-VALUE = PIC_NAME.
APPEND QUERY_TABLE.
CALL FUNCTION 'WWW_GET_MIME_OBJECT'
TABLES
QUERY_STRING = QUERY_TABLE
HTML = HTML_TABLE
MIME = PIC_DATA
CHANGING
RETURN_CODE = RETURN_CODE
CONTENT_TYPE = CONTENT_TYPE
CONTENT_LENGTH = CONTENT_LENGTH
EXCEPTIONS
INVALID_TABLE = 1
PARAMETER_NOT_FOUND = 2
OTHERS = 3.
IF SY-SUBRC = 0.
PIC_SIZE = CONTENT_LENGTH.
ENDIF.
ENDFORM.
СообщениеДобавлено: Вт, ноя 02 2004, 13:43
Премного благодарен! Спасибо!
