Текущее время: Вт, авг 11 2026, 12:55
 Заголовок сообщения: Блокирование склада
СообщениеДобавлено: Чт, май 10 2007, 10:59
Вт, фев 07 2006, 05:59
Требуется заблокировать склад, чтобы на нем нельзя было осуществлять движение материала (приход, расход).
Блокировка завода не подходит.
Инвентаризация тоже не подходит, т.к. блокируются материалы которые есть на этом складе.
СообщениеДобавлено: Чт, май 10 2007, 12:07
Вт, авг 24 2004, 07:19
1. Активируем проверку полномочий для складов: SPRO -> Управление ММ -> УпрЗапасами -> УпрПолномочиями -> Проверка полномочий для склада:
Проверка полномочий для складов
In this step, you activate storage location authorization for individual storage locations.
Storage location authorization means that a user has to have authorization for authorization object M_MSEG_LGO in order to enter a goods movement in the storage location, using a particular movement type. In the list of material documents, only the document items for which the user has a display authorization are displayed.
Example
Storage location authorization is useful, for example, if you want to protect the goods stored in a particular storage location.
Standard settings
In the SAP Standard configuration, storage location authorization is not active.
Recommendation
Note: Using storage location authorization means that more work is involved in configuring user authorizations. We recommend that you only use plant authorization as far as possible.
If you only want to store a material in one storage location with authorization check, it is a good idea to prevent storage location data from being created automatically, so that the material cannot be stored in another storage location without protection.
Activities
Only make these settings if you want to use storage location authorization.
1. Activate storage location authorization in the required storage locations.
2. Create an authorization for the object M_MSEG_LGO and assign the new authorization to the authorization profiles.
2. Если не использовать 1 пункт (не хочется заморачиваться с полномочиями), то вполне можно проверить/запретить движение по складу в экзитах.
 Заголовок сообщения: проводки по складам
СообщениеДобавлено: Пн, июл 02 2007, 18:42
Чт, июн 28 2007, 20:45
Скажите пожалуйста, как закрыть в профилях проводки по складам, и в модуле MM и SD очень надо, заранее спасибо!!!
СообщениеДобавлено: Пн, июл 09 2007, 16:06
Чт, май 19 2005, 10:10
Да просто экзит сделай, мы так и делали + табличку со складами, которые уже закрыты или классификацию складов - типа этот закрыт, этот открыт
СообщениеДобавлено: Ср, июл 11 2007, 13:32
Удали этот склад из настроек
При формировании отчетов выбрать его нельзя, но в отчет попадать будет,если по заводу.
Затем когда нужно будет вернуть, определишь его обратно.
