Текущее время: Ср, сен 23 2026, 21:20
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Установка SAPKB70016 и SAPKA70016 (release 700) на SAP ECC 6.0
СообщениеДобавлено: Пн, май 24 2010, 14:51
Пт, ноя 06 2009, 11:13
При установке оба SP вываливаются в дамп SYNTAX ERROR (error stop SPAM STATUS: XPRA_EXECUTION):
Runtime Errors SYNTAX_ERROR
Date and Time 23.05.2010 13:57:10
Short text
Syntax error in program "SAPLSDC_MODEL_CACHED "
What happened?
Error in the ABAP Application Program
The current ABAP program "SAPLSDC_MODEL" had to be terminated because it has
come across a statement that unfortunately cannot be executed.
The following syntax error occurred in program "SAPLSDC_MODEL_CACHED " in
include "LSDC_MODEL_CACHEDU01 " in
line 24:
"The "STATICS" statement can only be used in FORMs, FUNCTIONs, and CLAS"
"S-METHODs . ."
The include has been created and last changed by:
Created by: "SAP "
Last changed by: "SAP "
Statics задается в function - все как надо, какой-то глюк...
function sdok_mc_conns_get.
*"*"Lokale Schnittstelle:
*"  IMPORTING
*"     VALUE(CCS) LIKE  SDOKMCCS-CC_SPACE
*"  TABLES
*"      CONNECTIONS STRUCTURE  SDOKMCON OPTIONAL
*"      ENTITIES STRUCTURE  SDOKMENT OPTIONAL
*"  EXCEPTIONS
*"      BAD_CC_SPACE
  types: connections_tab_t type standard table of sdokmcon
                                            with non-unique default key,
         entities_tab_t type standard table of sdokment
         begin of conns_cache_t,
          ccs         type sdok_ent,
          connections type connections_tab_t,
          entities    type entities_tab_t,
         end of conns_cache_t.
  statics: ls_conns_cache type table of conns_cache_t,
           ls_guid type guid_32,
           ls_last_sync type timestamp,
           ls_x_dirty type xfeld.
  data: l_connections type table of sdokmcon,
        l_entities type table of sdokment,
        l_conns_cache_entry type conns_cache_t,
        l_ccs type sdokmccs.
  field-symbols: <l_fs_conns_cache_entry> type conns_cache_t.
  if ccs is initial.
    raise bad_cc_space.
  endif.
* synchronize cache
  call function 'SDOK_MC_SYNC_CACHE'
       exporting
            cache_id     = c_shbuf_conns_get
       changing
            cache_table1 = ls_conns_cache
            x_dirty      = ls_x_dirty
            guid         = ls_guid
            last_sync    = ls_last_sync.
* check if data is already in cache
  read table ls_conns_cache assigning <l_fs_conns_cache_entry>
                             with key ccs = ccs.
  if sy-subrc = 0.
    if connections is requested.
      connections[] = <l_fs_conns_cache_entry>-connections[].
    endif.
    if entities is requested.
      entities[] = <l_fs_conns_cache_entry>-entities[].
    endif.
  else.
*   read from model layer
    sdokm_make_cspc l_ccs ccs sdokm_ev_active.
    call function 'SDOK_M_CONNS_GET'
         exporting
              ccs          = l_ccs
         tables
              connections  = l_connections
              entities     = l_entities
         exceptions
              bad_cc_space = 1.
    if sy-subrc <> 0.
      raise bad_cc_space.
    endif.
*   insert into cache
    l_conns_cache_entry-ccs = ccs.
    insert lines of l_connections
                  into table l_conns_cache_entry-connections.
    insert lines of l_entities
                  into table l_conns_cache_entry-entities.
    insert l_conns_cache_entry into table ls_conns_cache.
    ls_x_dirty = 'X'.
         exporting
              x_force_sync = 'X'
         changing
              guid         = ls_guid
*   transfer requested data
      connections[] = l_connections[].
    endif.
      entities[] = l_entities[].
    endif.
  endif.
endfunction.
Подскажите, народ, в чем может быть проблема?!
 Заголовок сообщения: Re: Установка SAPKB70016 и SAPKA70016 (release 700) на SAP ECC 6.0
СообщениеДобавлено: Пн, май 24 2010, 16:30
Пт, сен 21 2007, 12:13
А левел SPAM какой?
У меня с 32 уровнем SPAM проблем с установкой до SAPKA70017 и SAPKB70017 не наблюдалось
SAP_ABA 700 0017 SAPKA70017 Cross-Application Component Appl. Interface SP
SAP_BASIS 700 0017 SAPKB70017 SAP Basis Component Basis Support Pkg.
СообщениеДобавлено: Пн, май 24 2010, 16:52
Накатываю много патчей, так что сразу поставил последнюю - 38ую версию SPAMa
СообщениеДобавлено: Пн, май 24 2010, 18:12
Пт, ноя 02 2007, 14:14
Ядро предварительно обновлялось?
Последний SPAM/SAINT - вроде уже 39 есть.
Посмотрите ноту 602820, она хоть и по SAP_BW компоненту, но вдруг...
СообщениеДобавлено: Вт, май 25 2010, 00:54
Нет, не обновлялось...
Сейчас просто SP находятся в статусе ошибки и не сбрасываются уже.
Есть ли имеет смысл накатить ядро, то как это сделать, если очередь занята?
СообщениеДобавлено: Вт, май 25 2010, 05:26
Чт, июн 15 2006, 08:41
сбросить в таблице где хрантся очередь
СообщениеДобавлено: Вт, май 25 2010, 06:46
:shumlol:
З.Ы. не сдержался
stayer
при замене ядра, самое надежное - drop database :mrgreen:
СообщениеДобавлено: Вт, май 25 2010, 07:51
шрам написал:
:shumlol:
З.Ы. не сдержался
stayer
2 шрам
Злой ты какой-то... :wink:
2 rainbow_too
Смена ядра к статусу очереди никакого отношения не имеет.
СообщениеДобавлено: Вт, май 25 2010, 09:04
Ср, июн 11 2008, 09:41
Не надо ничего дропать и сбрасывать. Просто остановите все сервисы связанные с сап, shu immediate серверу - если оракле, другие БД погасить штатным способом, скачанные файлы с новым ядром пишете в SYS и страртуете, его мальца покалбасит в первый запуск, дальше идете в SPAM и продолжаете процедуру. Будут ошибки - sdn вам в помощь. :rtfm:
SAP Basis, SAP Security Audit/Pentest, РФ, Москва
СообщениеДобавлено: Ср, май 26 2010, 10:22
Установили 39 версию SPAM, обновили ядро до 236 патча и пытались накатывать вместе с 17ым SP... - все равно та же ошибка.
СообщениеДобавлено: Ср, май 26 2010, 10:52
А почекать руками SDOK_MC_CONNS_GET получается?
На предмет синтаксиса/активации/генерации.
СообщениеДобавлено: Ср, май 26 2010, 14:36
Проверка ОК, при активации выдает то же сообщение:
"S-METHODs . ."
СообщениеДобавлено: Ср, май 26 2010, 14:42
Даже и не знаю, что сказать. Исходник совпадает с тем, что я вижу в своей системе. А оно генерится без проблем.
У Вас точно в LSDC_MODEL_CACHEDU01 больше ничего не подцеплено?
СообщениеДобавлено: Чт, май 27 2010, 05:44
Пн, авг 11 2008, 09:01
rainbow_too, а SAPKITL427 в очередь не ставили? Вдруг поможет.
